Triad Owner's Thread - Page 273 - AVS Forum | Home Theater Discussions And Reviews
 400Likes
post #8161 of 8189 Old 08-14-2016, 08:49 AM
Tristan944's Avatar
Quoted: 13 Post(s)
Originally Posted by nathan_h View Post
You could put it there. It might not give you the intended outcome.
I would use them as in-ceiling surrounds.
Tristan944 is offline
post #8162 of 8189 Old 08-14-2016, 11:47 AM
Tristan944's Avatar
Quoted: 13 Post(s)
Would they be okay as in-ceiling surrounds? Would I have to buy any extra installation materials since they would go in-ceiling instead of in-wall?
post #8163 of 8189 Old 08-15-2016, 08:09 AM
nathan_h's Avatar
Quoted: 719 Post(s)
Liked: 360
No extra installation materials, from what I can see, are needed -- assuming you have good solid sheet rock and can cut the whole at the right size, etc. But you are right: That is NOT how these are designed to be installed, and I would be a little nervous. I guess the better answer is: Triad doesn't make or offer anything extra or special to ceiling mount these in WALL speakers so you have to rely on the tabs designed for wall mounting.
But regarding sound quality:
They are sub optimal for in ceiling placement. The angled speakers from Triad are the ones you want most (which have been recommended above), for high end sound -- then, far down the list, those are followed by the circular co-axial ones (which is what I am using for Atmos). Either of these are designed for dispersion that makes sense in a ceiling location.
____________________
Current theater & gear: "Nathan's Theater in Search of....".
nathan_h is online now
post #8164 of 8189 Old 08-15-2016, 08:17 AM
Mike Garrett's Avatar
Quoted: 4642 Post(s)
Liked: 2808
Yep. While Triad does not make a Gold, the Silver that I linked to would make excellent surround speakers. If we can help you, give us a call.
mike@avscience.com
Sony, JVC, Epson, Denon, Marantz, Yamaha, Onkyo, Parasound, Triad, Atlantic Tech, M&K, RBH, SVS, Polk, Stewart, Seymour, Falcon, DNP, SI, Screen Excellence, Carada, MicroLite & more.
Mike Garrett is offline
post #8165 of 8189 Old 08-15-2016, 08:17 AM
Liked: 2808
mike@avscience.com
post #8166 of 8189 Old 08-17-2016, 09:22 AM
haroldminer's Avatar
Quoted: 14 Post(s)
Hi All. Is there a place in which I can find a general price list?
Specifically, I am looking for in-ceiling LCR speakers and wondering the basic price. I am comparing against the B&W CCM 7.4. Would anyone have any general comparisons between the two?
I have been looking for the frame options but can't find any good pics. Finally, any good images of the frames available? The ones immediately shown online aren't very attractive. Thanks.
haroldminer is offline
post #8167 of 8189 Old 08-17-2016, 10:27 AM
Dawn Gordon's Avatar
Quoted: 149 Post(s)
Liked: 91
They look much better in person. See below:
Name:	Triad Grill Choices.jpg
Dawn Gordon is online now
post #8168 of 8189 Old 08-17-2016, 10:59 AM
Quoted: 14 Post(s)
Thank you!
Frameless is the immediate winner for me.
I'd like for the speakers to be invisible. There is no reason why anyone need to look at the ceiling!
post #8169 of 8189 Old 08-17-2016, 11:44 AM
Liked: 2808
Originally Posted by haroldminer View Post
Thank you!
Then get them custom painted to match your ceiling.
mike@avscience.com
post #8170 of 8189 Old 08-17-2016, 09:16 PM
jjcook's Avatar
Quoted: 273 Post(s)
Liked: 98
Triad's InCeiling products do not mount differently than the InWall products so no worries there -- and they're both sealed so insulated similarly -- the question is just whether the dispersion and if angled baffle is correct for the application.
nathan_h likes this.
jjcook is online now
post #8171 of 8189 Old 08-20-2016, 10:41 AM
Tristan944's Avatar
Quoted: 13 Post(s)
Thank you and everyone for their insight and help!
post #8172 of 8189 Old 08-21-2016, 02:00 PM
Tristan944's Avatar
Quoted: 13 Post(s)
Can the Triad Bronze Powersub amplifier be used to power subwoofers from different companies?
I have a SpeakerCraft outdoor underground subwoofer that I need an amp for. Will Triads work? Any other suggestions?
post #8173 of 8189 Old 08-22-2016, 04:14 AM
nathan_h's Avatar
Quoted: 719 Post(s)
Liked: 360
Probably work okay but you should match the specs of the sub and amp. There are several geneartions of Speakercraft subs and several different iterations of Triad sub amps. Personally unless budget dictates itherwise, I'd probably get a professional Crown amp for such a sub. Much more bang for buck.
post #8174 of 8189 Old 08-22-2016, 06:31 AM
Liked: 2808
Yes it would power the sub, but it has been set up to match the specs of the Bronze sub driver.
mike@avscience.com
post #8175 of 8189 Old 08-22-2016, 08:21 AM
ab325is's Avatar
Liked: 1
I'm still trying to figure out which in-walls I want for my living room which will be for music and movies. How do the Silver/4 Monitors compare to the Gold/4 Omni SE for 2 channel music and home theater uses? Will one work better than the other horizontally mounted as a center channel?
ab325is is offline
post #8176 of 8189 Old 08-22-2016, 08:34 AM
Liked: 2808
Best if you can keep either of them vertical. Does the shorter height of the Silver (11-15/16") allow you to do so? If it does, then that is the route i would go.
mike@avscience.com
post #8177 of 8189 Old 08-22-2016, 11:34 AM
ab325is's Avatar
Liked: 1
I don't think vertical is an option for either one. The bottom edge is about 7' above the floor.
How does the sound compare?
ab325is is offline
post #8178 of 8189 Old 08-22-2016, 11:40 AM
Liked: 2808
Horizontal dispersion will not be as good with speaker mounted horizontally, but sound quality would go to the Gold.
mike@avscience.com
post #8179 of 8189 Old 08-22-2016, 01:25 PM
ab325is's Avatar
Liked: 1
If the sound quality of the Gold/4 Omni SE is better, why do the Silver/4 Monitors cost over twice as much?
Is it better to mount vertically despite how high they are off the floor? Should the Gold Omni SE be installed inverted so the tweeter is lower?
ab325is is offline
post #8180 of 8189 Old 08-22-2016, 02:07 PM
Liked: 2808
Sorry, I got in a hurry and looked at the wrong speaker. I was comparing the Silver/4 Omni SE to the Gold/4 Omni SE. If you look at my post above I listed the height of the Silver as 11-15/16". That is Silver Omni SE height. The height of the Silver/4 Monitor is 19". The Silver Monitor is a much better speaker. It uses the Scan Speak driver and a better tweeter. Better power handling, higher SPL, higher sensitivity and better sound quality, while doing so. Sorry for the confusion.
mike@avscience.com
post #8181 of 8189 Old 08-22-2016, 05:12 PM
jjcook's Avatar
Quoted: 273 Post(s)
Liked: 98
AFAIK the Gold Omni SE uses the same tweeter as the Gold Monitor (and maybe the Silver Monitor) but it is the Scan Speak driver in the Monitor series that is upgraded over the Omni SE
post #8182 of 8189 Old 08-25-2016, 07:32 PM
ShoutingMan's Avatar
Quoted: 203 Post(s)
Liked: 40
I've got a new suite of Triad speakers. Silver LCR and Bronze satellites. The cones all look like they are spattered with brown paint or dirt; see the photo of a new-in-box Bronze satellite cone. Is this normal?
ShoutingMan is offline
post #8183 of 8189 Old 08-25-2016, 08:27 PM
Dan Hitchman's Avatar
Quoted: 3216 Post(s)
Liked: 1640
Brand new? Send 'em back and say that's unacceptable. They'll make it right.
Listen up, studios! Just say "NO" to DNR and EE!!
Dan Hitchman is offline
post #8184 of 8189 Old 08-25-2016, 08:27 PM
Liked: 2808
Yes. That is the fibers strengthening the cone.
ShoutingMan likes this.
mike@avscience.com
post #8185 of 8189 Old 08-25-2016, 08:29 PM
Liked: 2808
The next pair will be exactly the same. They are not defective.
mike@avscience.com
post #8186 of 8189 Old 08-25-2016, 08:31 PM
Liked: 1640
Good to know. The cone material looks a little raw n' funky.
post #8187 of 8189 Old Today, 06:51 AM
ababaie's Avatar
Liked: 0
I recently acquired a pair of triad inceiling silver/6 mini monitors and inwall silver/4 surrounds for a new family room 5.1 HT setup. I definitely need some help. The new family room will be around 12 x 16 with a 9 foot ceiling. The couch will be set along the 16 foot wall.
  1. Will the mini monitors be okay as fronts in this setup?
  2. I need a center channel. Is there any benefit to getting a silver monitor for the center channel for clearer voices vs a third mini monitor ? I have some mild hearing loss and speech discrimination can sometimes be an issue.
  3. I can only place the surround speakers in wall just below the ceiling or in the ceiling. Which position would be better?
  4. Is there any benefit to installing a 7.1 system vs 5.1 in this smaller space?
  5. I have heard of using the mini monitors as surrounds. If so how would you orient the angled baffle?
Thanks for any insight you can provide!
ababaie is offline
post #8188 of 8189 Old Today, 10:08 AM
Quoted: 149 Post(s)
Liked: 91
For those of you going to CEDIA don't forget to visit the Triad booth. The company will be showing a number of *very* exciting and unique new products.
post #8189 of 8189 Old Today, 05:27 PM
nathan_h's Avatar
Quoted: 719 Post(s)
Liked: 360
Welcome to AVS! Please don't take this the wrong way, but here are some opinions about your plans. This is much less about Triad and more about the general approach but luckily Triad is great stuff and when matched properly with a situation and used with a good plan, they are EXCELLENT.
I realize that sometimes the couch must be along the wall, but this will compromise dialog intelligibility, accurate bass response and make the surround effect much less impactful and clear.
[*]Will the mini monitors be okay as fronts in this setup?
Yes they will be. You are approaching the limit of their capabilities for reference listening at that distance. You can compensate for this a bit by crossing over to the sub at 100 or even 120hz instead of the usual 80hz.
[*]I need a center channel. Is there any benefit to getting a silver monitor for the center channel for clearer voices vs a third mini monitor ? I have some mild hearing loss and speech discrimination can sometimes be an issue.
I would choose an identical center to what you have for the left and right. Dialog intelligibility will be increased by brining the couch off the back wall, and by adding some acoustic treatments at the first reflection points (if you haven't already). If these words don't mean anything to you, I will recommend this link:
http://www.gikacoustics.com/early-reflection-points/
There are many different opinions about what is best for setting up a room. I can tell you from first hand experience, the older I get, the more important it is for me to control the room well in order to hear into the recording well.
[*]I can only place the surround speakers in wall just below the ceiling or in the ceiling. Which position would be better?
I would vote for the wall.
[*]Is there any benefit to installing a 7.1 system vs 5.1 in this smaller space?
No, since you are sitting on the back wall, those surround back speakers would be about 1" from your head. Don't do it.
[*]I have heard of using the mini monitors as surrounds. If so how would you orient the angled baffle?
The regular mini monitors don't have angled baffles. If you mean the 'in ceiling' versions then you would place them in the ceiling, facing where you sit. This is not a bad idea at all.
I feel bad going to town on your first post. I hope you came here for opinions! Please take this as me caring about your audio experience and hoping you can get the most from it.
Reply Speakers
Triad
