Triad Owner's Thread - Page 281 - AVS Forum | Home Theater Discussions And Reviews
 466Likes
post #8401 of 8411 Old 02-09-2017, 01:10 PM
ronroland's Avatar
Liked: 1
Originally Posted by jimmyk36 View Post
Good to know. I have the older versions and Triad doesn't support converting the older models.
I did find a schematic for the crossovers on the older models and according to the schematic it looks like the tweeters are just directly wired out of phase. Thinking about just wiring them in phase and see how they sound.
I have Silver In Walls for the L/R Surrounds and Bronze In Walls for the Back Surrounds.
Curious if you ever tried to change the crossovers in your surrounds and if so were you successful?
ronroland is online now
post #8402 of 8411 Old 02-16-2017, 11:21 AM
cdepaola's Avatar
Quoted: 20 Post(s)
Installing two slimsubs and a RackAmp 700 in a family room, one on right front wall and the other opposite rear wall.
Any best practices or recommendations for set-up?
cdepaola is online now
post #8403 of 8411 Old 02-16-2017, 02:21 PM
Dawn Gordon's Avatar
Quoted: 159 Post(s)
Liked: 113
If it's not too late, I would put them in diagonally opposing corners.
nathan_h likes this.
Dawn Gordon is offline
post #8404 of 8411 Old 02-16-2017, 03:35 PM
nathan_h's Avatar
Quoted: 1017 Post(s)
Liked: 611
Dawn has given you the best succinct approach. You want them to be a mirror image of each other in the room -- remembering that the room is not just the same where you watch TV but the whole physical space (which might include a kitchen and dining area, in a great room, for example).
More details in this podcast:
http://www.avrant.com/501-dual-sub-calibrations/
http://www.audioholics.com/subwoofer...nnection-guide
____________________
Current theater & gear: "Nathan's Theater in Search of....".
nathan_h is offline
post #8405 of 8411 Old 02-16-2017, 04:38 PM
cdepaola's Avatar
Quoted: 20 Post(s)
Yes they are diagonal, I guess that's what I meant by opposite.
I'm more concerned with amp aetup, never been a whiz with subs typically just let the AVR set them up. Seems like setting the subs up this way requires more work.
Thanks for the links!
post #8406 of 8411 Old 02-17-2017, 07:34 AM
Quoted: 159 Post(s)
Liked: 113
You should be able to find helpful files here: Triad Guides and Installation Files
post #8407 of 8411 Old Yesterday, 08:11 AM
Draden1's Avatar
Quoted: 125 Post(s)
Liked: 52
I've been doing more and more 2 channel listening recently and was curious of the differences between the silver lcr's and silver monitors? If anyone has heard both and would like to share their impressions I would appreciate it.
Can the monitors really be used effectively without a sub for music (moderate to loud levels) because the lcr's 100% need one?
Would having the l/r speakers as monitors and the center as an lcr be very noticeable during movies? My front stage is behind an AT screen if that is of concern.
I don't have the room for a dedicated 2 channel setup so I need to make the space I have as effective as possible, thanks!
Audio: Emotiva XMC-1 Processor / Emotiva XPA-7 Gen 3 amp
Speakers: Triad Silver LCR (5), Triad Bronze LCR (2 rear), SVS PB13 Ultra sub
Video: Epson 5025 projector / Darbee Darblet / 98" 16:9 Seymour AV XD screen
Sources: Oppo 103 / Dish / Apple TV / Audio Technica LP-120 TT
Draden1 is online now
post #8408 of 8411 Old Yesterday, 09:16 AM
Quoted: 159 Post(s)
Liked: 113
Both Gold and Silver Monitors can be used full range without a sub, but they do sound best with a sub. However, before committing to purchasing a sub you should try them without one to see how you like them.
One thing I would definitely not do is mix a Silver LCR with the Silver Monitors. They sound too different. Keep all front speakers the same. For surround and Atmos channels you can use Silver MiniMonitors. See my speaker matching chart here.
post #8409 of 8411 Old Yesterday, 01:59 PM
Liked: 3
I have the gold in room sub but it's showing in the new 700 rack amp triad in room silver sub ??
Can anyone help me in that
A7mad78 is online now
post #8410 of 8411 Old Today, 06:50 AM
Quoted: 159 Post(s)
Liked: 113
You should have your dealer change the setting. Or go to these RackAmpinstructions.
post #8411 of 8411 Old Today, 12:39 PM
Liked: 3
Done ...thx a lot Dawn
Reply Speakers
Triad
