Triad Owner's Thread - Page 286 - AVS Forum | Home Theater Discussions And Reviews
 493Likes
post #8551 of 8567 Old 05-09-2017, 05:24 AM
Dawn Gordon's Avatar
Quoted: 166 Post(s)
Liked: 120
Originally Posted by Jengo View Post
Hello,
I need advice deciding inceiling and side/rear surround speakers for atmos 5.2.4. Room is 40'x19'x13'h with screen on 19' wall. This is a multi purpose room with theater on one end. Screen is 14'w. LCR will be 3 matching Tekton DI placed behind screen 13' apart. I want to mount an angled baffle like the IC Silver/6 monitors on the side walls 22' from screen and connect them as rear surrounds. The rear surrounds will be 6-7' behind main seat. I have 6" of depth in side walls and over 12" in ceiling. I guess my options are
6x IC Silver/6 monitors
4x IC Gold/8 mini monitors(I prefer but can't fit in side wall) & 2x IW Gold/4 surround(footprint too big)(not baffled)
Will triad custom make a IC Gold mini monitor in a IC Silver/6 monitor box?
Tekton DI
2 Pendragon 10" transducers
Unique 4-way loudspeaker design
Proprietary polygon-oriented, triple-ring radiator high frequency array
Dual 6" mid-bass transducers
98.82dB 2.83V@1m sensitivity
4 Ohm design for optimum performance
20Hz-30kHz frequency response
400 Watt power handling
Thank you
If you need help with custom Triad, contact me and I'll see what I can do to help.
Dawn Gordon is offline
post #8552 of 8567 Old 05-09-2017, 05:27 AM
Quoted: 166 Post(s)
Liked: 120
Originally Posted by bambam View Post
Has Triad released that in-ceiling speaker for Atmos that has the tweeter that you can aim via a laser? I remember seeing it on a trade show update, but haven't seen it since.
Triad hasn't started shipping the RotaSat as yet.
I'll contact them today to find out what's going on.
post #8553 of 8567 Old 05-10-2017, 06:00 AM
Quoted: 166 Post(s)
Liked: 120
Spoke to Triad yesterday.
They are still working on the speakers they showed at this past CEDIA -- no official release date however.
post #8554 of 8567 Old 05-10-2017, 06:54 AM
bambam's Avatar
Quoted: 100 Post(s)
Liked: 80
Thanks for the update!
bambam is offline
post #8555 of 8567 Old 05-11-2017, 10:43 AM
Srubin's Avatar
Quoted: 18 Post(s)
Two generations of silvers
Hello,
If I have a set of current generation silver LCRs and wanted to mate them with older generation (pre 2010) silver surrounds would they work ok together? I understand this is not the ideal set up but I can save a bunch if I use older surrounds.
I understand they have some different components but I would think triad would try to match pretty closely? I think it would be more of a problem if I was trying to mix and match LCRs.
Srubin is offline
post #8556 of 8567 Old 05-11-2017, 05:13 PM
batpig's Avatar
Quoted: 3658 Post(s)
Liked: 3499
Originally Posted by Srubin View Post
Hello,
I'm sure it will be fine, especially since older Silver surrounds will be dipole which means you are going to be getting a very diffuse surround field. Like you say, it would be more of a concern if you were mixing LCR's, but for surrounds, I wouldn't sweat it.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #8557 of 8567 Old 05-12-2017, 04:55 AM
Srubin's Avatar
Quoted: 18 Post(s)
Thanks for the help!
Srubin is offline
post #8558 of 8567 Old 05-13-2017, 08:43 PM
sumik's Avatar
Any dealer recommendations for US/Canada ?
sumik is offline
post #8559 of 8567 Old 05-14-2017, 05:32 AM
Quoted: 166 Post(s)
Liked: 120
I'm a Triad dealer and I can help you find a local dealer if you like.
post #8560 of 8567 Old 05-18-2017, 02:57 PM
jimim's Avatar
Quoted: 489 Post(s)
Liked: 143
Dawn,
I have a question regarding the new satellite outdoor setup with sub that Triad has. Is the sub buried or above ground? seems from the site that it is a cabinet above ground but then some drawings show below ground? Also the main set, how many satellites? Finally, what amp runs the full set? a rack amp 350, saw mention of it on the site? how does everything hook up? oh ya does the amp have a line in for 1/8" stereo. i want to hook it up to one of the non amped zones on my nuvo grand concerto. right now those zones hook up to nuvo amps with a 1/8 mini stereo jack.
thanks!
jim
jimim is offline
post #8561 of 8567 Old 05-19-2017, 04:46 AM
Quoted: 166 Post(s)
Liked: 120
I recently added the Garden Array DataSheet to my website. It *should* answer all your questions. Let me know if you need any pricing or additional info.
http://www.triadspeakersforum.com/sh...tdoor-Speakers
post #8562 of 8567 Old 05-19-2017, 07:39 AM
jimim's Avatar
Quoted: 489 Post(s)
Liked: 143
hey dawn,
how do you power multiple satellite. i see the sub runs off a rackamp, but how do you tie a sub and 4-8 sats into 1 zone on a whole house system?
sonance has an amp that it all ties into it looks?
http://www.sonance.com/outdoor/sonarray
jimim is offline
post #8563 of 8567 Old 05-19-2017, 07:49 AM
Quoted: 166 Post(s)
Liked: 120
The Satellites can run off a standard 8 ohm multichannel amplifier or can be powered and daisy-chained via a Crown 70 or 100 volt amplifier.
post #8564 of 8567 Old 05-19-2017, 10:46 AM
jimim's Avatar
Quoted: 489 Post(s)
Liked: 143
so pretty much if i want a sub i got to use a regular receiver. use 2 of the channels for the sats and the sub out for the sub.
integrating it in a full home audio unit like a nuvo or russound can't happen.
jimim is offline
post #8565 of 8567 Old 05-19-2017, 11:56 AM
Quoted: 166 Post(s)
Liked: 120
I don't see why you couldn't use a Multiroom audio system with the Garden Array speakers and sub. Since the satellites can work as plain 8 ohm speakers, just use them the way you would with any other speaker. The trick is to have a line level out for use with a Triad RackAmp for the sub. If your music system has line level out, you're all set. If not, you may have to look for a line-level to speaker-level converter, and decent ones are not easy to find.
post #8566 of 8567 Old 05-23-2017, 04:35 AM
Quoted: 166 Post(s)
Liked: 120
Hi Folks,
Just released an article on Hidden Home Theater.
grtuck likes this.
post #8567 of 8567 Old Today, 02:44 PM
dschulz's Avatar
Quoted: 597 Post(s)
Liked: 404
Does anyone know why the Platinum in-wall speakers are larger than the in-rooms, and in particular whence the asymmetry? Sketching an idealized home theater space, with an eye to keeping the acoustic center of the speakers on the center line (or at the Dolby-recommended 5/8 up) of the screen, and the asymmetry is throwing me.
dschulz is online now
Reply Speakers
Triad
