Klipsch THX Ultra2 System - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #91 of 102 Old 07-18-2013, 02:21 PM
nflguy's Avatar
I'm considering the following speakers for my 7.1 system. They are listed as THX but not sure if they are "ultra".
Klipsch KL-7800-THX for my front three speakers mounted inwall
Klipsch KS-7800-THX for side surrounds
Klipsch RS-52 II for back surrounds
will pair with a SVS PB12-NSD Subwoofer
Any feedback is appreciated.
nflguy is offline
post #92 of 102 Old 07-18-2013, 02:43 PM
ifor's Avatar
Quoted: 59 Post(s)
Liked: 72
You could use the KL or the KS for rear surrounds as well. Depending on your seating and room. That way, all your speakers are matched.
ifor is offline
post #93 of 102 Old 08-16-2013, 11:22 PM
yin
yin's Avatar
Quoted: 23 Post(s)
In my HT I use Klipsch Ultra THX 2
3x Klipsch KL 650 for the front + 4 Klipsch Sub KW 120 behind Stewart Studiotek 130 MICROPERF X2 THX-ULTRA
2x Klipsch KL 650 for Sorround
2x Klipsch Ks 525 Dipol
Room correction with Audyssey MultiEQ XT Pro and you can watch Avatar at 115 DB entire movie without having any distortion, no ear pain after the movie
If you want to beat this system you will have too invest big Money to get a couple of % better
Landmonster likes this.
yin is offline
post #94 of 102 Old 03-15-2014, 07:33 PM
metalguy's Avatar
Quoted: 127 Post(s)
Liked: 41
Do you use the ks 525 for the side surrounds or the rears? and how far apart do you have the left and right speakers? And what are you powering the speakers with?
metalguy is offline
post #95 of 102 Old 03-15-2014, 08:30 PM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 176
For the price of the Ultra-2 setup you could do JTR 228's or even 212's across the front, that would easily best the Ultra-2. Actually it would be pretty easy to best them for much much less if you can DIY
Martycool007 is offline
post #96 of 102 Old 03-16-2014, 02:44 AM
yin
yin's Avatar
Quoted: 23 Post(s)
Well if you you can do a better job by DIY
Then do it!
yin is offline
post #97 of 102 Old 03-16-2014, 02:45 AM
yin
yin's Avatar
Quoted: 23 Post(s)
Well if you can do a better job by DIY
then do it!
yin is offline
post #98 of 102 Old 03-16-2014, 04:02 AM
Hugo S's Avatar
Quoted: 252 Post(s)
Liked: 148
Hi,
In our 11.2 installation (DSX type of configuration), we have 7 Klipsch KL650 THX U2 in the front, and 4 Klipsch KS525 as SL/SR and BL/BR + 2 SVS PB13 Ultra Sledge as subwoofers, this produces an EXCEPTIONALLY involving sound, totally credible with real life dynamic (DTS Neo X 11 Cinema processing, Marantz 8801).
Hugo
Hugo S is offline
post #99 of 102 Old 03-16-2014, 10:15 AM
metalguy's Avatar
Quoted: 127 Post(s)
Liked: 41
Originally Posted by Hugo S View Post
Hi,
Hugo
WOW, my mouth just started watering on this set up. Can you post some pictures of it? I would love to see it.
metalguy is offline
post #100 of 102 Old 03-16-2014, 10:44 AM
Hugo S's Avatar
Quoted: 252 Post(s)
Liked: 148
Now you can see a picture in the signature, otherwise you can go here, posts 1 to 3 where you can see the various evolutions of the installation.
Hugo
Hugo S is offline
post #101 of 102 Old 01-23-2015, 12:30 PM
AidenL's Avatar
Quoted: 471 Post(s)
Liked: 218
So I'm thinking about buying this system, and just researching - its been out a long time - will there be updates to the design, is it end of life does anyone know?
I guess a good speaker is a good speaker......
Display : JVC X7000 Projector | SE 103" Enlightor 4k | LG 65B6 OLED |
Sources : Oppo UDP 203 Multizone UHD Player | Apple TV3 | HTPC | Sky Q UHD Satellite | Sonos Connect | Synology 24Tb |
Audio : Marantz 8802A | Genelec 8050 LCR | Monitor Audio IDC Sides & Rears | Seaton Submersive Master/Slave |
Control : Control 4 |
AidenL is online now
post #102 of 102 Old 11-23-2015, 08:49 PM
maxht's Avatar
Was thinking of getting the KL-650-THX LCR but I saw it listed in Amazon as 'discontinued'. However, it is still being listed in Klipsch website. I'd sent an e-mail to them to inquire about it last week. No reply as to date. Makes me wonder.
Bass, please. Shaken, not stirred.
maxht is offline
Reply Speakers
