Rocket RS850 Signature and New Onkyo reciever - AVS Forum | Home Theater Discussions And Reviews
Old 10-16-2007, 02:23 AM - Thread Starter
siopao777's Avatar
Will the Rocket RS850 Signature speakers go good with the Onkyo 805? Are they a good match?..Thanks
siopao777 is offline
Old 10-16-2007, 07:13 AM
craigsub's Avatar
I have run a pair with a 674, with very good results. I would think the 805 should also be fine.
craigsub is offline
Old 02-21-2008, 08:18 AM
davdev's Avatar
I know this is an older thread, but I am bumping it, as I am considering the same system.
It is finally time to replace my Pio 1014 and my JBL E-80 fronts. I have loved the Pio since day 1, but I want to get a PS3 for Blu-Ray and I need the ability to accept HDMI audio. My JBL's have been decent, but are in no way a great speaker, and I feel it is time to move up in the world.
I plan on getting a pair of RS850's for my front speakers. I am not currently running a center as my setup doesn't allow it, and in all honesty, I am not really missing it that much. My surrounds are 2 pairs of Dayton in-ceilings, which work perfectly fine for surrounds, of which I am much more forgiving than Fronts. I also have an SVS 20-39PCi sub. The room is roughly 24x16.
I am looking for a receiver to power all this, and I believe the 805 should fit, but I was wondering how well they would power the Rockets. One of the reasons I am planning on the 850's over the 750's is they are more efficient so should run better off of a receiver. I also have a crown xls 402 amp that I could add in, but I would actually prefer to run everything off of the receiver if possible.
So if anyone could comment on their experience with the 805 and Rockets, I would be very appreciative.
Also, my budget at this point is very tight, so while I am very open to other suggestions, I really can't see myself going from the $600-$700 or so 805 to a $1300 Elite or Denon. So please try to keep recomendations in the same price range.
davdev is offline
