eD Owner's Thread - Page 71 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #2101 of 2119 Old 11-17-2013, 03:52 AM
ChopShop1's Avatar
Quoted: 325 Post(s)
Liked: 325
I'll tell you what, I consider myself extremely fortunate. I know a lot of folks ended up losing money to these guys as they went out. Before getting much more diy capable, I had a very large deposit with them on a fully custom 7 channel setup...thousands....and it was tough, but I got every cent back. I think there are a bunch of folks running there stuff now who got a decent value and enjoy what they have, so enjoy away. I would not buy something that couldn't be repaired/sourced/replaced etc. I know that sounds funny based on the amount of diy stuff I have, but I buy enough backups of drivers, etc, JIC. The thought of having something become useless based on inability to source a single part scares the crap out of me.
ChopShop1 is offline
post #2102 of 2119 Old 06-05-2014, 06:02 AM
jag2006's Avatar
Quoted: 24 Post(s)
Still running my eD set up with no issues.
sent from my phone
jag2006 is online now
post #2103 of 2119 Old 11-18-2014, 07:04 AM
utee05's Avatar
Quoted: 44 Post(s)
Are there any recs on what type of tweeter to get to replace a dying one in the a6-6t6 tower? Would the same tweeter work as a replacement for the a6mtm center?
utee05 is offline
post #2104 of 2119 Old 01-05-2015, 01:45 PM
asoofi1's Avatar
Quoted: 937 Post(s)
Liked: 443
For eD6c, what adjustable mounts do you recommend and what locations on the back are safe to drill? I'm going to try a few on the ceiling for Atmos.
asoofi1 is offline
post #2105 of 2119 Old 01-05-2015, 03:27 PM
carp's Avatar
Quoted: 2818 Post(s)
Liked: 2125
Do you already have them? I don't think they would be ideal for ceiling speakers since there dispersion pattern is narrow. I'm using them for my 4 surrounds and I want to eventually upgrade to something with wider coverage.
carp is offline
post #2106 of 2119 Old 01-05-2015, 03:29 PM
carp's Avatar
Liked: 2125
If you have them already though I can show you where I drilled mine.
carp is offline
post #2107 of 2119 Old 01-05-2015, 06:00 PM
asoofi1's Avatar
Quoted: 937 Post(s)
Liked: 443
Yup...I've got 11 of them so have to put them to good use. I had 5 from before, but then my BIL and sis wanted to move to in-walls, so I picked up their 6 I had originally put in as surrounds and installed in-walls for them recently... The eD6c dispersion is supposed to be 90°x90° per the specs I had saved from the good'ol days...hope it was accurate. I'm going to play around with angling them to get in the general Atmos recommended setup, but I'm not 100% on committing to the format either, so the final placement will change...being that DTS will also be releasing their own version of '3D' surround this year and they do have more leverage with majority of BD releases are usually carrying DTS audio tracks over Dolby.
My plan is to put 2 as Back Surrounds and 6 on the ceiling. Already using 2 for Heights. The S8's are going to continue Wide and Side Surround duties for now...That Wide channel is doing a great job in filling in between the LR and Sides in my room...really recommend this now for any room 15' or wider.
Btw, I'm running 3 of the eD6c as LCR right now...and man these sound very good...not as 'big' as the 212s, but paired with some great subs, these will rock most HTs...really lucky to still have these speakers...I'm going to ask Jonathan to ship me his switcheroo-panel nonetheless for the sake of R&D.
Can you post a pic showing the back of yours?
asoofi1 is offline
post #2108 of 2119 Old 01-05-2015, 06:16 PM
carp's Avatar
Liked: 2125
Here's some pretty old pictures, let me know if you want more up close. I flipped them upside down as you can see.
Hmm, that surprises me that they are 90x90. I took a pair over to Jonathan's to compare with his Mackie's and I thought they sounded very narrow in comparison. Also, I put them up front once and didn't like what I heard but it could have all been placebo!!
You are giving me hope that I should cross off surrounds from my upgrade list!!!
carp is offline
post #2109 of 2119 Old 01-05-2015, 08:16 PM
asoofi1's Avatar
Quoted: 937 Post(s)
Liked: 443
That mount looks really nice and compact...does it adjust and lock with a hex key? What's the make/model of the mounts?
I noticed a difference when I plugged them in, but I played with the crossover and have them at 150Hz right now...talk about mid bass ..If someone was to walk in, they wouldn't know the 212's weren't on right away...until you switch them back and then you can def tell the diff...The 'wall' of sound is not there...just like a 'band' of sound...and that heightened clarity of the 212's is lacking, but still clear as better horns should be...The volume also has to pushed to get them to as loud as the 212's would be 10db sooner. I have them toe'd in as much as the 212s and I have a nice sweet spot in stereo as my son is watching Sesame Street songs!
Definitely keep yours and save the cash...these are great for surrounds and spending any more is really not necessary. They match up with the JTRs really well.
carp likes this.
asoofi1 is offline
post #2110 of 2119 Old 01-05-2015, 08:31 PM
carp's Avatar
Liked: 2125
http://www.axiomaudio.com/full-metal-bracket
Here you go. Wow, they were pricey when I bought them at 39, now they are 44. Still I really like them and like you see in the pics you can angle them or turn them how you like before tightening.
asoofi1 likes this.
carp is offline
post #2111 of 2119 Old 01-05-2015, 08:34 PM
carp's Avatar
Liked: 2125
Oh, and yes a hex key tightens them. They are rated for 40 pounds but seem like they could hold more.
asoofi1 likes this.
carp is offline
post #2112 of 2119 Old 01-05-2015, 09:01 PM
asoofi1's Avatar
Quoted: 937 Post(s)
Liked: 443
GAHH...that price...for each?!...Yuck man...Wish that price was for a pair...but the weight support seems to justify compared to others out there...but I need to hang 8...350...hmmm...
asoofi1 is offline
post #2113 of 2119 Old 01-06-2015, 05:45 AM
carp's Avatar
Liked: 2125
That is a lot, there has to be a better/cheaper option out there.
carp is offline
post #2114 of 2119 Old 03-07-2015, 09:59 PM
thrillcat's Avatar
Quoted: 211 Post(s)
Liked: 257
Well, add me to the list.
Last summer I picked up a few of the new eD Cinema Series 6 MTM cabinets and finally got around to building the crossovers and finishing them out this week (no small thanks to Chris Seymour for assistance building the crossovers).
I also just picked up four slant surround 6 cabinets to match that I will eventually finish up. I'm really in no rush on those, though. My room isn't big enough to use them for surrounds.
I love my iPhone, but it will never replace my turntable.
The Cinema 1858 Remodel Thread
thrillcat is offline
post #2115 of 2119 Old 04-10-2015, 04:26 AM
combos99's Avatar
Does anyone know if it's possible to get replacement drivers? I assume not, it just stinks because I would have thought eD would have a warehouse full of them after they closed.
Need drivers for my A6-6T6
I like turtles.
combos99 is offline
post #2116 of 2119 Old 04-10-2015, 02:06 PM
thrillcat's Avatar
Quoted: 211 Post(s)
Liked: 257
I'm not going to claim to be an expert as I was pretty late to the game, but the way I interpreted all their communication at the end was that they had lots of boxes and no electronics or drivers to put in them.
The craigslist market around Iowa (where they were based) still shows a lot of cabinets available (that's what I bought).
I loaded mine with Faital Pro drivers from parts-express.com. The 6FE200 drivers sound great.
post #2117 of 2119 Old 01-11-2016, 09:27 PM
paradoxical3's Avatar
Sorry to bump this thread but I have a question. I just picked up some ED6C speakers and a center with the DE250 compression drivers. The DE250 is a revelation for classical music, and I am in love with how they image and sound.
However, these speakers have the weakest midbass I have ever heard - to the point where I am suspecting something is wrong with them. It's very thin sounding, and Audyssey wants to set the crossover at 225hz....something has go to be wrong. What is the midbass like on the ed6c speakers for other owners - am I missing something here or is it just that weak?
Could they be wired out of phase or something internally?
Thanks in advance.
paradoxical3 is offline
post #2118 of 2119 Old 01-11-2016, 09:27 PM
Thanks in advance.
post #2119 of 2119 Old 01-12-2016, 06:51 AM
SteveSatch's Avatar
Quoted: 33 Post(s)
I only own the Elemental Designs w6-6tc so I don't know about the ED6C.
SteveSatch is offline
Reply Speakers
