Boomy speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 11-06-2007, 06:07 PM - Thread Starter
Raymond Leggs's Avatar
Is it okay to have a preference to Boomy/forward in the Bass region speakers to The more neutral sounding Audiophile speakers?
I dont mean boomy as hollow one note BOOOMMOOOMOOOM. I'm talking about speakers that just have a more pronounced bass sound that isn't fatigueing.
Raymond Leggs is offline
post #2 of 12 Old 11-06-2007, 06:18 PM
Pibbo's Avatar
What do you consider "good" boomy speakers?
Pibbo is offline
post #3 of 12 Old 11-06-2007, 06:20 PM
Jonomega's Avatar
It is a subjective thing, so of course it is "okay" to like something that someone else might not. Thats the name of the game!
A subwoofer could easily accomplish what you want (since it is very adjustable in terms of relative volume to the speakers, crossover point) and has its own amplification (if active) that can give you that mid-bass extra slam that may be expensive to reproduce in speakers with smaller drivers.
A trend in many "audiophile" speakers is actually to have that mid-bass hump. If you check out some of stereophile's FR curves, you will notice that speakers like the B&W 802D have a mid-bass hump. So..., if a mainstream company is producing speakers with these "colorations" perhaps you are not the only one who desires that "extra kick".
Jonomega is offline
post #4 of 12 Old 11-06-2007, 06:37 PM
Logic_BomB's Avatar
This would be like saying if it's okay to like sauce that is a bit spicier than normal to a chef. The chef might think the sauce is supposed to taste a bit different but he'll make it with a smile knowing that's how you like it.
Logic_BomB is offline
post #5 of 12 Old 11-06-2007, 11:19 PM
BobL's Avatar
Liked: 56
I'd look for accurate speakers with a good EQ to tailor the sound to your liking. The EQ (which can be built into a receiver/processor) should have multiple presets. In my system I boost the very lower end <30 hz to get a little 'feel' if I'm listening at a lower volumes. At higher volumes I use my preset for flat. Since our ears aren't linear we don't hear frequencies the same at various volume levels. Having different presets makes a nice solution and will work with whatever speakers you have.
Bob
BobL is offline
post #6 of 12 Old 11-07-2007, 03:58 AM
William's Avatar
Quoted: 29 Post(s)
Liked: 50
Room acoustics and dimensions could have as much effect or more of the "Boomy/forward in the Bass" sound as the choice of speaker.
William is offline
post #7 of 12 Old 11-07-2007, 07:06 PM
b4z
b4z's Avatar
Quoted: 18 Post(s)
Most receivers used to have(they may still) a loudness control which would boost bass, and to a lesser extent treble
at lower volumes. This slope was designed by Fletcher-Munson, I had an old NAD integrated amp that would boosted bass 6db and treble 3db.
Perhaps the OP might tilt toward a more neutral speaker and use the loudness button for lower/mid level listening and then as he gets more experience with audio and his tastes start to change he can stop using it altogether.
http://en.wikipedia.org/wiki/Equal-loudness_contours
b4z is offline
post #8 of 12 Old 11-08-2007, 07:09 AM
PULLIAMM's Avatar
It is always okay to have a preference, regardless of what it is a preference for. There is no accounting for taste.
PULLIAMM is offline
post #9 of 12 Old 11-08-2007, 08:18 AM
Paul Scarpelli's Avatar
Liked: 54
That explains Clamato juice.
Paul Scarpelli
aka TRIAD DUDE
I can tell people who are judgmental just by looking at them...
Paul Scarpelli is offline
post #10 of 12 Old 11-08-2007, 09:27 PM
LTD02's Avatar
Quoted: 2342 Post(s)
Liked: 2580
__________________
Paul Scarpelli
aka TRIAD DUDE
Director of Sales & Marketing, Triad Speakers, Inc.
must you keep spamming these boards with your brand? please stop.
Listen. It's All Good.
LTD02 is offline
post #11 of 12 Old 11-08-2007, 09:31 PM
Splicer010's Avatar
Liked: 39
If that is what you prefer then by all means there is nothing wrong with it... I myself like the audiophile speakers but with a good sub I get that punch I like so much without detracting from te flatness and transparency of the speakers...
Splicer010 is offline
post #12 of 12 Old 11-08-2007, 10:21 PM
Jonomega's Avatar
Jonomega is offline
Reply Speakers
