White/red cable converter to headphone jack?? - AVS Forum
post #1 of 6 Old 11-10-2007, 10:19 AM - Thread Starter
Sythe X10's Avatar
Ok, im buying the xbox 360 VGA cable - http://hardware.teamxbox.com/reviews...D-AV-Cable/p1/
And i want to hook up headphones to this but i need some kind of coverter so i can plug the red and white cables into something and plug the headphone jack into that and get sound. now what would this converter be called?
Sythe X10 is offline
post #2 of 6 Old 11-10-2007, 10:36 AM - Thread Starter
Sythe X10's Avatar
Found it.... sorry guys. del. plz.
post #3 of 6 Old 11-10-2007, 10:44 AM - Thread Starter
Sythe X10's Avatar
nevermind.. still looking for a female Y RCA left/right to a female 3.5mm cable
post #4 of 6 Old 11-10-2007, 11:08 AM
buzzy_'s Avatar
Liked: 48
have a look around
monoprice.com
partsexpress.com
radioshack
headphone is called 3.5mm or mini stereo
not sure you'll find female if that's really what you're looking for. you might need to buy adapters
buzzy_ is offline
post #5 of 6 Old 11-10-2007, 11:20 AM
whoaru99's Avatar
Liked: 67
Might need a small amp of some kind and something to control the volume...
Just because there is a knob doesn't mean you should turn it.
whoaru99 is offline
post #6 of 6 Old 11-10-2007, 12:46 PM
Pibbo's Avatar
The 360 is outputting a line-level signal anyway. Not appropriate to drive headphones and you won't be able to adjust the volume. You'll need a headphone amp.
Pibbo is offline
Reply Speakers
User Tag List
