Best wireless headphones for HD DVD and Blu-ray movies? - AVS Forum
post #1 of 17 Old 11-14-2007, 08:28 AM - Thread Starter
FrancescoP's Avatar
I need a good wireless 5.1 headphone set, but with HDMI support (for 5.1 lossless TrueHD or PCM audio).
But all the 5.1 headphones I've found have an optical connection, not HDMI, like those:
http://www.audiocubes.com/category/H...+Surround.html
Any help?
FrancescoP is offline
post #2 of 17 Old 11-14-2007, 04:36 PM
High Gear's Avatar
I'm looking at the Q-home FX by LTB. They have freeshipping and a 30 day money back guaranty. I talked to them the other day about the 5.1's and am convinced they are above many of the others like Sony and pioneer in technology. I like the idea that I can use them for my xbox 360 on or off line. They even have a mic that clips on. Take a look t the link below.
http://www.shopltb.com/catalog/
High Gear is offline
post #3 of 17 Old 11-14-2007, 05:29 PM
grubyhalo's Avatar
Hi,
Sorry for the thread-jack. Does anyone know of a good quality surround sound adapter that could be used with a good quality headphones, like the HD650 for instance. I did find this in audio cubes, but am not sure if there are others similar/better to this one. Any hints suggestions, deepy appreciated
Thanks in advance
grubyhalo is offline
post #4 of 17 Old 11-15-2007, 12:51 AM - Thread Starter
FrancescoP's Avatar
Thank you, but those lack HDMI input, so they don't provide lossless sound.
5.1 Headphones for HD DVD and Blu-ray must feature HDMI input, otherwise you cannot eperience next gen audio codecs provided with HD DVD or Blu-ray.
post #5 of 17 Old 11-15-2007, 02:50 AM
High Gear's Avatar
I'm pretty sure digital is digital. As long as you have a tos-link or digital coax running to the headset base. Am I wrong?
post #6 of 17 Old 11-15-2007, 05:28 AM - Thread Starter
FrancescoP's Avatar
Yes is digital, but is lossy. Optical supports only old gen DVD audio codecs like AC3, Dolby Digital, DTS... maximum bit rate of 1.5 Mbps. So they can only compress in a lossy way the audio.
HDMI supports 10.2 Gbps, up to 8 channels lossless. TrueHD and DTS-HD MA, the high def audio track used by HD DVD and Blu-ray, are lossless, and up to 24,5 Mbps. Even the lossy tracks of HD DVDs and Blu-ray, uses more bandwidth (3 Mbps for DD+, and more for DTS-HD) than allowed on optical.
So HDMI is necessary to transport them (bitstream compressed or in PCM uncompressed).
Any headphone designed for HD DVD and Blu-ray next gen audio will need HDMI input.
post #7 of 17 Old 11-15-2007, 04:40 PM
High Gear's Avatar
Wow, good to know. Thanks!
post #8 of 17 Old 11-17-2007, 08:27 PM
Digitally challe's Avatar
Liked: 26
Can you suggest any wireless HDMI headphones? Thanks in advance -Bill
Digitally challe is offline
post #9 of 17 Old 11-19-2007, 07:03 AM
wtr_wkr's Avatar
I'll guess LPCM from a HD player is better but not lossless. What I'm having trouble with is the idea that someone will provide the bandwidth you want with wireless.
HD-DVD is dead, so now I'm a Gary McCoy fanboy.
wtr_wkr is offline
post #10 of 17 Old 11-19-2007, 07:06 AM
Pugnax555's Avatar
The bandwidth is there with 802.11g and 802.11n. However, I know that I personally wouldn't want a tx/rx for one of those strapped directly to my head.
Pugnax555 is offline
post #11 of 17 Old 08-01-2008, 04:32 PM
pappy97's Avatar
Any update on this? I've been looking for headphones, wireless or not, 5.1 or 7.1 whatever, that take in HDMI and allow the headphone listener to enjoy lossless audio such as uncompressed PCM, Dolby True HD, and DTS-MA. Any products like that out there yet? Thanks!!!
pappy97 is offline
post #12 of 17 Old 09-05-2008, 09:34 AM
rhk0327's Avatar
I'm not a headphones guru, you might want to check with head phone specific forums. There's a healthy sized community out there.
Wire vs wireless. It's common consensus that if you go wireless route, you will take degradation in sound quality, especially for money. The wireless itself is limiting factor so even $400 wireless headphones won't ever sound as good as equal level wired ones. One reason wireless home theater speakers don't have stellar reviews.
Stereo vs Surround. I'm not really sure if surround headphones are even worth it. Check the forums. As far as wireless next gen audio surround, I think is a pipe dream at this point. we're talking about a new cable format (hdmi) with the bandwidth necessary for uncompressed, but then squeezing that bandwidth in a wireless signal X 5 channels. Unlikely. I kind of doubt that headphones marketed as surround really are more surround sounding than regular headphones. There's not that much space in there even for direction placement of the speakers.
rhk0327 is offline
post #13 of 17 Old 09-05-2008, 09:56 AM
Bazzy's Avatar
Liked: 30
Hi,
I have the Pioneer SE-DIR2000C Dolby Surround Sound Headphone System - it is wireless and sounds really great with both movies and music - crystal clear with the option to connect your own headset. Comes with separate decoder unit & wireless headset (extra headsets can be added). Stay away from the cheaper ones, I have tried many and they are awful!
Bazzy
Bazzy is offline
post #14 of 17 Old 09-05-2008, 01:19 PM
gunbunnysoulja's Avatar
From my experience, high quality headphones with Dolby Headphone > wireless 5.1 headphones.
Also, for those that wan't lossless quality, optical DOES transmit lossless advanced audio codecs, such as TrueHD and DTS HD MA, but only in 2 channels.
gunbunnysoulja is offline
post #15 of 17 Old 11-01-2008, 03:09 PM
jstachowiak's Avatar
Motorola S805 Blue Tooth headphones $59, and Sony Bluetooth adapter TMRBT10A for about $40 really works well. Sound is great.
jstachowiak is offline
post #16 of 17 Old 02-13-2009, 11:51 PM
Snyder81's Avatar
Sorry to drag up an old thread, but these are great headphones and they are available for under $40 from at least a couple major online retailers. I am using a bluetooth transmitter from a Logitech "Wireless Music System for iPod" that plugs in my Onkyo's headphone jack and the audio sounds great and allows my to contain noise when watching movies or playing games late at night.
Snyder81 is offline
post #17 of 17 Old 01-07-2012, 11:24 PM
curiousgeorgieo's Avatar
Hey guys its finally starting. Losses headphones. Now we just need audiophile companies to make better versions. Google Sony mdrds7500
Any thoughts
curiousgeorgieo is offline
Reply Speakers
User Tag List
