Klipsch vs Infinity Speaker Help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-16-2007, 06:36 PM - Thread Starter
mustvid's Avatar
I'm not an audiophile so I need some help deciding between Klipsch Reference RB-51 and Infinity Beta 10. Both are bookshelf speakers about the same dimension. The RB-51 has 5.25 woofer and a 1inch titanium tweeter. The Beta 10 has 1 5 inch woofer and a 1 inch CMMD weeter. Sensitivity for the Beta 10 is 88db and the crossover 3,400Hz. The RB-51 sensitivity is 92db and the crossover is 2000Hz. This is all greek to me. I watch mostly movies and I have a 12inch JBL sub. These speakers will be fronts. I currently have Athena AS B1.2 for fronts. I have an Onkyo 705. Which speaker will sound best with the 705 and movies?
mustvid is offline
post #2 of 2 Old 11-17-2007, 02:00 AM
Soundood's Avatar
I'd opt for the Klipsch.
But then again I am a dealer for their products
For home theater, the added dynamics and output the RB-51's bring will be very noticeable. The newer compression driver/horn they use is also very smooth.
"Did you make 'em fine-ass-soundin' speakers over there what would sound gooder than hell comin' out of the back of my truck-boat-truck?"
-Early Cuyler. Poet Liquoreate
Soundood is offline
Reply Speakers
