Any good center speakers from Best Buy? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 11-27-2007, 10:53 AM - Thread Starter
dkyork's Avatar
Quoted: 185 Post(s)
Liked: 103
I have a $300 gift certificate to Best Buy and I'm looking to buy a center this week. I'm willing to spend a total of 500-600 dollars, but I'm wondering if there are any good center speakers there. It'd be nice to be able to use my gift card if I can. I've compiled a list of what they have and I hope some of you have some experience and/or knowledge of anything worth getting. I currently have the BOSE setup, and really need to replace that little satellite center speaker I have. One thing I have replaced so far is the sub with a HSU subwoofer. HUGE improvement there. Center next, and then the front and left.
1. Klipsch - Synergy III 5-1/4" 2-Way Center-Channel Speaker - Black/Titanium Color
Model: C-2 SKU: 6780735
2. JBL - Dual 6" 4-Way Center-Channel Speaker (Each)
Model: STUDIOLC2 SKU: 8461372
3. JBL - Cinema Sound Dual 5" 2-Way Center-Channel Speaker
Model: CSC55 SKU: 8394187
4. Mirage - OMNISAT 3-Way Center-Channel Speaker (Each) - Black
Model: OMNISAT V2 SKU: 7478446
5. JBL - Dual 5-1/4" 3-Way Center-Channel Speaker
Model: LC1 SKU: 8356361
6. Definitive Technology - Dual 5-1/4" 2-Way Center-Channel Speaker
Model: CLR2002BLA SKU: 6638855
7. Definitive Technology - Mythos 3 Dual 4-1/2" 2-Way Center-Channel Speaker
Model: MYTHOSTHRE SKU: 6639364
8. Definitive Technology - Mythos Seven 2-Way Center-Channel Speaker
Model: MYTHOSSEVE SKU: 6639328
9. Klipsch - 5-1/4" Center-Channel Speaker
Model: RC-52BLA SKU: 7973525
10. Klipsch - Synergy III 6-1/2" 2-Way Center-Channel Speaker - Black/Titanium Color
Model: C-3 SKU: 6780833
11. Bose - Center-Channel Speaker
Model: VCS-10 SKU: 3253106
So should I spend my gift certificate on any of these or will it be DVDs?
My price limit is around $500 for a center.
thanks,
Dale
dkyork is offline
post #2 of 15 Old 11-27-2007, 10:58 AM
daron73m's Avatar
First thing I wouldnt mix speaker brands, stick with one so they somewhat match....I am a klipsch man myself, If movie theaters use klipsch that gives them some credibility, but It looks like most of your system is Bose...
Good luck on sticking to budget, I never am able to do that.
d.
daron73m is offline
post #3 of 15 Old 11-27-2007, 11:01 AM - Thread Starter
dkyork's Avatar
Quoted: 185 Post(s)
Liked: 103
d.
My Bose will slowly be replaced. I started witht he sub and finally able to move on to the center. Sounds like from you though I need to think ahead and plan on buying the rest of my speakers to match my center.
thanks,
Dale
dkyork is offline
post #4 of 15 Old 11-27-2007, 11:05 AM
ssteel01's Avatar
Yup. Couldn't have said it better myself. You really do want to match your front three speakers as closely as possible. It's not as big of a deal with the surrounds, but it's definitely something to be aware of for the L/C/R.
Scott
ssteel01 is offline
post #5 of 15 Old 11-27-2007, 01:40 PM
1stHD's Avatar
Just came back from BB looking for center. I had been prepared to get the Klipsch RC-52 since I have the F-3 and my stand can only hold RC-52.
What make this Vienna center so expensive? I did not see it but saw a $799 one in the store. I did not listen to any because I had to leave.
http://www.bestbuy.com/site/olspage....=1151657715793
1stHD is offline
post #6 of 15 Old 11-27-2007, 05:24 PM
piodef's Avatar
i would definately listen to most of them i have the def tech clr 2002 and love it. that would be my recomentation
piodef is offline
post #7 of 15 Old 11-27-2007, 06:26 PM
Steve_D's Avatar
Originally Posted by 1stHD View Post
J
Listen to their main L/R speakers on music and you'll know what makes VA so special.
You really want to make your front 3 to match...I'd start with replacing your main L/R speakers and run phantom mode until you can get a center, not buy a center and then add L/R.
Steve_D is offline
post #8 of 15 Old 11-27-2007, 06:40 PM
zero the hero's Avatar
how big is your room? Of course I agree that the l/c/r should all match, but I don't see a problem in starting with your center and working your way out. I think for the money the Def techs are hard to beat out of what's offered at BB. I bought a set of ProCinemas for my temporary theater, and I was shocked at how good they sounded in a properly set up room (not like the awful rooms at Magnolia). I'd also go for the 2002 if I were you. If I wasn't building my own speakers now, I'd stick with Def Techs when my theater is finally built.
zero the hero is offline
post #9 of 15 Old 11-27-2007, 07:49 PM
CrossRoad's Avatar
I second what Steve D said about the Viennas. Listen to them and then you'll know why the high price. They simply sound amazing. (with music) I also second what was mentioned earlier about keeping the center and mains as matching. Go with different surrounds if you wish but I think you will regret it if you get a center that isn't a match for you mains.
CrossRoad is offline
post #10 of 15 Old 11-27-2007, 08:43 PM
piodef's Avatar
personally i wasn't a fan of the va's. they lacked the low end... i guess with a good sub they would be perfect, just not a full range speaker.
piodef is offline
post #11 of 15 Old 11-28-2007, 06:55 AM
Steve_D's Avatar
Really? To each there own, but I noticed a solid low end (sans sub) with a recessed midrange...which is exactly what the professional reviews say. Of course, compared to most HT oriented systems, any musical speaker will need a sub to produce the rumble.
Steve_D is offline
post #12 of 15 Old 11-28-2007, 08:22 AM
The Vienna's sound pretty good in the store with music, but they're not exactly a transparent speaker which I think would get tiring at best and annoying for movie use. The frequency responses are definately not the worst I've seen, but decidedly not flat.
post #13 of 15 Old 11-28-2007, 08:43 AM
Steve_D's Avatar
Very true, VA's are a love'em or think they aren't worth it type of speaker, imho.
Steve_D is offline
post #14 of 15 Old 11-28-2007, 08:48 AM
inca's Avatar
Does best buy still carry athenas, if so I would be all over those, forget the other brands.
inca is offline
post #15 of 15 Old 11-28-2007, 10:32 AM - Thread Starter
dkyork's Avatar
Quoted: 185 Post(s)
Liked: 103
Well I bought the Mythos 3 for the center and working on getting the Mythos ones for my L/R. They sounded great in the store, but the Viennas sounds amazing. The $1200 Vienna center sounded so crisp clear, rich, and noticeably had great low end. Too bad I can't afford it! Now I think I need a reciever, so I'm looking at the Denon 2808, but it's so much. I was hoping to stick around the 500-600$ range for a reciever as well. BTW, I found a deal on the mythos ones for $930 a pair. 2 Years old but supposedly in great condition with new grills. Should I buy those or pay 1800 for some new ones. OBviously I'm leaning to the used ones, but 2 years is a while and I don't know the lifetime on drivers, etc.
thanks,
dale
dkyork is offline
Reply Speakers
