7.1 suround : Side speaker question - AVS Forum | Home Theater Discussions And Reviews
Old 01-13-2008, 10:38 AM - Thread Starter
Cnd Joe's Avatar
I have an Onkyo 7.1 and all my stuff is mixed matched.
I have:
Main L/R : Quest Q660 - 6ohms
Center/LR/RR : NS-SP50C - 8ohms
Then I bought a 5.1 set up Studio Acoustcs S8/300 came with a sub and 5 small speakers that are 2 speakers atop each other an they can be both angled open. ie like a siscor opening. No clue as to the ohms for these guys as its not in the manual or printed on any of the bodies.
Can I use these guys for my 2 sides or if I buy 2 new bookself speakers for my sides will I hear a big difference in sound or does the sides just output ambient sound so the quality doesn't really matter?
Any input is help full thanks.
Cnd Joe is offline
Old 01-13-2008, 03:05 PM
ekb
ekb's Avatar
Note the the 6th and 7th speakers are in the rear, not at your sides. In a 5.1 setup the surrounds are at the sides.
The rear and sides put out comparable volume and detail. Ideally they should be the same quality.
Ed
ekb is offline
