Speaker wire covers? - AVS Forum | Home Theater Discussions And Reviews
Old 01-16-2008, 11:47 AM - Thread Starter
SHOWTIME07's Avatar
Question from a newb. I just got done hanging my surrounds on my walls. The wires are now left dangling down the wall. Those things that some people have used to cover the wires....things you can paint over...what are those called and where can I get some?
SHOWTIME07 is offline
Old 01-16-2008, 12:45 PM
jaseman's Avatar
Quoted: 34 Post(s)
Can't recall exactly what they're called but you can probably go to Home Depot and someone there will point you in the right direction.
Vizio M80-C3 - Denon AVR-X4200w - Samsung UBD-K8500 - Roku 4 - Charter Spectrum - Logitech Harmony 700 Remote
Axiom VP150-v2 Center - M60-v2 Front Left & Right - 4>QS8-v2 Quad Polar Surrounds - EP500 Front Sub - DIY 12" Rear Sub
jaseman is offline
Old 01-16-2008, 01:09 PM
oztech's Avatar
Liked: 101
raceway is a way to hide ,cableorganizer.com
oztech is offline
Old 01-16-2008, 02:16 PM
quadriverfalls's Avatar
Can't you just drill a hole behind the speaker, remove the base molding under the speaker and drill a hole there.... run the speaker wire down through the wall cavity and then replace the base molding? That way, it's TOTALLY unseen....
John W.
Indy
quadriverfalls is offline
Old 01-16-2008, 02:22 PM
naughty's Avatar
you should be able to find some trunking or conduit - whichever name its called by - im using some plastic stuff that looks like this all round my walls - it will be visible - but you can paint it the same color as the wall if you like - or if you like you can dig that bit of the wall and duck it into the wall and then fill it up and repaint
naughty is offline
Old 01-16-2008, 02:25 PM
gspin2k1's Avatar
I found some in fred meyer yesterday. Just some cheap plastic cable covers. I think it costs about $10 for every 9 ft kit. But they are paintable and come in a variety of sizes (depending how thick and how many wires you need to run in them).
~G
gspin2k1 is offline
Old 01-16-2008, 03:09 PM - Thread Starter
SHOWTIME07's Avatar
That would be ideal. However, the base molding would a major PITA to remove.
Old 01-16-2008, 06:05 PM
perryw's Avatar
http://www.wiremold.com - Their stuff is available at most home improvement stores. I know Home Depot and Menard's have a decent selection of their stuff.
perryw is offline
Old 01-16-2008, 06:51 PM - Thread Starter
SHOWTIME07's Avatar
Great. Thanks for all the info, everybody. I think I'll head to HD or Menards tomorrow.
Old 10-07-2008, 04:11 PM
bolistik's Avatar
This is the type of cord cover im looking for to use for my rear speakers. Is there a specific name for this? im guessing they would have it @ homedepot or lowes.
I like how their thin. Wiremold cover is nice too but i need something thin as this one for the rears.
Playstation Network ID# bolistik
bolistik is offline
Old 10-07-2008, 05:01 PM
rr330i's Avatar
How about flat wire that can be painted?
rr330i is offline
Old 10-07-2008, 05:17 PM
Chris Ruhl's Avatar
bolistik -
That looks like the thin wiremold that you can pick up at Menards. Pretty common stuff... you shouldn't have too much trouble finding it.
Chris Ruhl is offline
Old 10-07-2008, 07:15 PM
rr330i's Avatar
rr330i is offline
Old 10-07-2008, 07:41 PM
fireman325's Avatar
Originally Posted by Chris Ruhl View Post
bolistik -
+1. You should be able to find it at any Lowe's or Home Depot.
Steve
fireman325 is offline
