BIC Acoustech Owners Thread - Page 155 - AVS Forum | Home Theater Discussions And Reviews
 50Likes
post #4621 of 5261 Old 06-16-2014, 02:33 PM
Bond 007's Avatar
Quoted: 2440 Post(s)
Liked: 1952
Originally Posted by isaac415 View Post
Originally Posted by Bond 007 View Post
Theyre both good speakers but very different.
The tweeters are different. The Bics have a horn and will be brighter. The Infinity are a soft dome and will be warmer.
The Infinity is a 3 way so thats a plus if done properly. And in the Beta series I believe it has been.
The Bics are more sensitive so will be louder at a lower volume.
Sounds like youre buying used so it also depends on what else is in the package.
I assume you mean H100. Youre getting both subs?
Yes, I meant h100. I am buying it seperately because i found a great deal on it. I am also looking into a couple pl200s i have found for sale and plan on purchasing one as well.....
Both systems come with all wires needed but the infinitys have the receiver as a i stated.
Why do you feel they are so different? Simply because the acoutech are more efficient and bright because of the horns?
Thanks for the help!
If youre buying them locally why not go listen to them both? Atleast the towers.
Bond 007 is online now
post #4622 of 5261 Old 06-18-2014, 08:22 PM
zeinoonm's Avatar
Quoted: 16 Post(s)
Hi guys,
I am looking to buy 4 pairs of in walls speakers and a center speaker (all in wall). I have to make my decision very soon and i'm torn between the BIC FH8-W and the Acoustech HT-8W. The first one seems to be a Horn speaker, and the 2nd isn't. Any recommendations?
Also, does BIC sell an center in-wall speakers?
__________________________________________________________
I suppose Mr. Bond has been explaining to you his "Big Bang" theory.
Yeah, I think I got the...thrust of it.
zeinoonm is offline
post #4623 of 5261 Old 06-19-2014, 09:09 PM
zeinoonm's Avatar
Quoted: 16 Post(s)
bump :P
zeinoonm is offline
post #4624 of 5261 Old 06-20-2014, 11:25 AM
Augerhandle's Avatar
Quoted: 772 Post(s)
Liked: 667
Originally Posted by zeinoonm View Post
...Also, does BIC sell an center in-wall speakers?
http://bicamerica.com/index.php
Augerhandle is offline
post #4625 of 5261 Old 06-21-2014, 04:14 PM
zeinoonm's Avatar
Quoted: 16 Post(s)
thank you for your help. I did look and BIC don't' sell any IN-WALL center channel speakers. So my question is, can i install either the Formula FH8-W or the Acoustech HT-8W horizontally? How about Vertically with the tweeters down and teh woofers up?
If you had to pick one, which speaker would you pick for watching Movies?
Thank you so much for helping me make my decision.
zeinoonm is offline
post #4626 of 5261 Old 06-21-2014, 04:53 PM
Bond 007's Avatar
Liked: 1952
The Acoustech series is supposed to be an improved version of the Formula series.
post #4627 of 5261 Old 06-21-2014, 06:01 PM
zeinoonm's Avatar
Quoted: 16 Post(s)
Hey, thanks for replying.
The Inwall acoustech are NOT horn loaded, right?
I was wondering if they have that characteristic Klipsch sound to them
zeinoonm is offline
post #4628 of 5261 Old 06-21-2014, 06:13 PM
Bond 007's Avatar
Liked: 1952
Dont know if theyre horn loaded or not. Never researched Bic in-walls. Whats the Bic website say?
post #4629 of 5261 Old 06-21-2014, 06:21 PM
zeinoonm's Avatar
Quoted: 16 Post(s)
It doens't mention anything about horn loaded tweeters. Actually the tweeters are in teh center of the woofers, and above them there's a 2 1/2 inch midrange woofers.
Seems like a weird configuration to me. I wish the Formula series had tiltable tweeters.
I'm hoping if someone has heard either the Formula or the Acoustech series to chime in
zeinoonm is offline
post #4630 of 5261 Old 06-21-2014, 06:27 PM
Bond 007's Avatar
Liked: 1952
Just looked it up. The tweeter is in the middle of the midrange so the tweeter cant be horn loaded.
The regular Acoustech horn loaded tweeter sounds similar to a Klipsch tweeter but thats not what youre getting with the in walls.
post #4631 of 5261 Old 06-21-2014, 06:49 PM
zeinoonm's Avatar
Quoted: 16 Post(s)
yeah
That's why i'm gravitating towards the Formula Series. Not sure if i can install those horizontally though, cos BIC dont' make an in-wall center speaker.
zeinoonm is offline
post #4632 of 5261 Old 06-21-2014, 06:53 PM
Bond 007's Avatar
Liked: 1952
yeah
You cant mount one in wall vertically for a center?
post #4633 of 5261 Old 06-21-2014, 06:56 PM
zeinoonm's Avatar
Quoted: 16 Post(s)
that's the question i'm asking
zeinoonm is offline
post #4634 of 5261 Old 06-21-2014, 07:01 PM
zeinoonm's Avatar
Quoted: 16 Post(s)
I'm sorry i misread your comment.
I can, but that would push my tv up too high. I'm trying to keep the tv in a comfortable height so i'm not looking up all the time when watching
zeinoonm is offline
post #4635 of 5261 Old 06-22-2014, 09:28 AM
rmaddog's Avatar
yeah
I have 2 pairs of the BIC Formula FH6-W. I use them in my theater room as my Front Height and Front Width speakers. These are used with my BIC Acoustech setup. There work really well to compliment my system and I have no complaints. While I have these mounted vertically, I do have 3 pairs of BIC Muro Concept-6 (now discontinued...) in my family room 6.1 setup. The center is mounted horizontally under the TV. Both the FH6-W and Concept-6 have the same mounting setup so you can mount them veritically or horizontally - heck even diagonally if you wanted. I have the other 5 in walls mounted in my ceiling because I felt they would fit better aesthetically than having round ones. The in-walls and in-ceilings can be use interchangably. While some in-ceilings have tweaters that can be angled/pivoted, just isn't something I am so concerned with. While the tweeter is on one side and the woofer on the other, the space/distance is so minimal I don't feel that mounting the Concept-6 horiztonally has made the sound imbalanced or anything.
I would defintiely recommend the FH6-W. It's a great speaker particularly compared to the Concept-6s that I just needed something basic for my family room setup. I'll see if I can get some pics of my family room setup and post em...
rmaddog is offline
post #4636 of 5261 Old 06-22-2014, 11:31 AM
zeinoonm's Avatar
Quoted: 16 Post(s)
thank you. that's very helpful. I think i'll go with the FH8-W for the whole system. It's gonna be a 9.2 system in the game room and a 5.1 in the family room. It's good to know that i can mount them horizontally. And yeah, i didn't think it'd be a big deal with the tweeter being a bit to the side relative to the prime listening spot. the distance is just very small to matter. I'm also thinking of installing the surrounds upside down to keep the tweeters as close to ear level as possible. Not sure what your thoughts about that are.
I was told that the Acoustech HT-8W are the newer/improved version compared to the FH8-W, but the acoustechs in wall seem to be out of stock everywhere. I'm guessing BIC is getting ready to release a new version, but i don't have time to wait as my installer needs those speakers in a few days.
BTW: nice theater
zeinoonm is offline
post #4637 of 5261 Old 06-23-2014, 10:04 AM
zeinoonm's Avatar
Quoted: 16 Post(s)
Hi, anyone here installed the FH8-W or the FH-6W horizontally? I called BIC America and the lady told me i cannot install it horizontally cos it'd be longer than the space in between studs. But, when i think of other brands In-wall center channel speakers they are even longer and are meant to be installed horizontally. So what gives?
zeinoonm is offline
post #4638 of 5261 Old 06-23-2014, 10:14 AM
Bond 007's Avatar
Liked: 1952
Dont know but the skeptic in me says the lady doesnt know what shes talking about. Call back later and see if you can get a second opinion.
post #4639 of 5261 Old 06-23-2014, 10:21 AM
zeinoonm's Avatar
Quoted: 16 Post(s)
they are a small company, i'm sure i'm gonna get the same person
It'd be weird if i call again and ask the same question..
Ugh this is a bummer. I really had my mind set on the FH8-W for a complete system. Now i might have to look for a different brand for the whole system, or at least for the center speaker
zeinoonm is offline
post #4640 of 5261 Old 06-23-2014, 10:25 AM
Bond 007's Avatar
Liked: 1952
I used to work for a call center. She may not even be a Bic employee. Did she seem knowledgeable? Call back with a different question prepared and see who answers.
post #4641 of 5261 Old 06-23-2014, 10:57 AM
zeinoonm's Avatar
Quoted: 16 Post(s)
I dont' think there's any way around it. If installed horizontally, the width of the speaker would be wider than the 16" stud spacing
I just called Klipsch and got the same answer about their center channel speaker. Not sure how much my installer will charge for cutting studs and reframing. My other option would be to get a standalone floor standing center channel, or to get another brand center speaker that would have a cut out dimension no more than 13.875" wide.
zeinoonm is offline
post #4642 of 5261 Old 06-23-2014, 11:11 AM
Quoted: 772 Post(s)
Liked: 667
According to the BIC website the 6 inch should fit.
Cutout: 14 1/4"H x 7 3/4" W
There is normally 14 1/2 inches between studs.
post #4643 of 5261 Old 06-23-2014, 11:18 AM
zeinoonm's Avatar
Quoted: 16 Post(s)
You may have saved the day
Gonna head to the home now and ask the electrician if he can work with this..
On another note, i have no experience with horn loaded tweeters. Would they sound good if they were installed horizontally?
zeinoonm is offline
post #4644 of 5261 Old 06-23-2014, 11:21 AM
Bond 007's Avatar
Liked: 1952
Some horns have a 90x90 disperion angle. In that case it wont matter. If its 90x60 it may make a small difference.
post #4645 of 5261 Old 06-23-2014, 11:27 AM
zeinoonm's Avatar
Quoted: 16 Post(s)
Good point. I'll have to call BIC again and ask. I'll update this thread.
zeinoonm is offline
post #4646 of 5261 Old 06-23-2014, 06:11 PM
zeinoonm's Avatar
Quoted: 16 Post(s)
So i called the BIC tech support to ask about the dispersion angle. Same lady answered. LOL. She gave me the number for the "more advanced" tech support. Called them 3 times, left 1 message. Have NOT heard from them yet.
zeinoonm is offline
post #4647 of 5261 Old 06-25-2014, 08:52 PM
zeinoonm's Avatar
Quoted: 16 Post(s)
Ok. So i promised to update this trhead.
The dispersion angle for the FH8-W is: 90 degrees vertical, and 60 horizontal. Per tech support it is ok to mount it horizontally.
zeinoonm is offline
post #4648 of 5261 Old 07-24-2014, 11:42 AM
Liked: 0
Okay, so I am new to the forum. But I wanted to thank everyone that participated in this thread. It really sold me on the following items:
BIC PL-200 Acoustech Platinum Series Subwoofer
BIC PL-200 Acoustech PL-28ll Center Speaker
BIC PL-200 Acoustech PL-89
I did not want to spend or have a lot of money to spend and the reviews here were really helpful. Using Amex points, did I mention I got the package down to under $400 out of pocket. Free Amazon Prime shipping. I hope these are as good as everyone said!
I am keeping my rears for now, older set of Boston Acoustic's, if these new ones work out, they will be replaced with PL-66's or HT8W's. I am thinking the HT because I can hide them in the wall. Recommendations here would be appreciated.
I am using an older Yamaha RX-V667 receiver which I will eventually upgrade. But for now this is it. I am no true audiophile and I feel a little trepidation when it comes to tuning the speakers. I figure I'll use the tuning mike and then I have to break them in and retune them again and then make manual adjustments from there. It's making the manual adjustments that is worrying me because I have never done this before. I'll have to figure it out.
I'll post back once the break in period is done. Oh yeah, I am also taking back the Definitive center I recently bought because I wont need 2 centers. Saving some money there too!
Now to start looking at receivers. We watch a lot of movies and listen to music when we have a party, so that will be the primary use here.
canons900 is offline
post #4649 of 5261 Old 07-25-2014, 07:23 AM
rmaddog's Avatar
Hi, anyone here installed the FH8-W or the FH6-W horizontally? I called BIC America and the lady told me i cannot install it horizontally cos it'd be longer than the space in between studs. But, when i think of other brands In-wall center channel speakers they are even longer and are meant to be installed horizontally. So what gives?
Ok sorry guys... After I posted last month, the next day I went on a vacation and got back, super busy at work so haven't been on AVS since then! Well, the FH6-W can fit horizontally. As Augerhandle states, 'normal' framing puts the distance between studs at 14.5 inches. A stud is 1.5" wide & if framed 16" on center, which is typical, it puts the center of each stud 16" away from each other. So from each center, you got .75" of stud on one side and 0.75" on the other, leaving an open space of 14.5". With the cutout of the FH6-W being 14.25" H x 7.75" W, when you flip on the side, it technically fits. If your walls are open, then you can easily measure to see what spacing you have & need. The FH8-W's cutout is 16.125" H x 8.75" W so it would be wider than can fit in a typical framed wall.
zeinoonm, if your walls happen to be open still (no drywall), then you could easily modify the framing there to basically insert a framed box that spans 3 studs (re-enforcing that area) to make a space that is plenty wide enough. If the wall is drywalled, mudded, etc. then you still can do it but it will just be a little messier to cutout, modify the framing, redrywall, mud, etc. If the wall is load bearing, well, I am no contractor but just make sure you aren't messing with the integrity of the strength of the wall. You could make the wall stronger if you did the framed box right. I did this to fit my BIC Acoustech PL-28's in my wall. I just framed an open-boxed shelf that I can sit my PL-28 on. I don't have great pics of it but there are some in my Maddog Theater thread.
I have some open framed walls with some extra drywall laying around still in my basement so I will take one of my FH6-W's and make a little video showing how it fits as a little side project if that would help give anyone any helpful info.
rmaddog is offline
post #4650 of 5261 Old 07-29-2014, 08:13 PM
Liked: 0
Well so far the center channel and the sub are excellent. I cannot wait until they are broken in. The speakers were delivered finally today and I will set them up when I get back from the beach. Man can that sub pound the crap out of the walls.
I am thoroughly impressed and will finish up configuration this weekend. More to come regarding these speakers. I cannot believe how clean they are. And man o' man do they get loud..............
Reply Speakers
Acoustech By Bic , Bic Acoustech , Bic Acoustech Pl 26 Center Speaker , Bic Acoustech Pl 28 Center Speaker , Bic Acoustech Pl 76 Tower Speaker , Bic Acoustech Pl 89 Speakers , bic acoustech pl 980 speakers
