Monoprice in-wall, in-ceiling speakers - Page 28 - AVS Forum | Home Theater Discussions And Reviews
 17Likes
post #811 of 2115 Old 11-20-2010, 11:03 AM
FlashJim's Avatar
I need surrounds and rears for a 7.1 setup. Surrounds will be in the vaulted part of the ceiling and the rears in the back wall.
My question is ... Monoprice 6816 or Parasound C280?
FlashJim is offline
post #812 of 2115 Old 11-20-2010, 09:17 PM
jjensen2's Avatar
Hey guys--
I am doing research for a potential new Home Theater!!
I am almost ready to pull the trigger on a 5 speaker set-up using monoprice's in ceiling (6.5 inch 2-way) speakers for the front and rears. I am wondering about the center channel though. I am looking at getting the 60" LG 60PK550 and wall mounting it with monoprice's corner wall mount (id # 4926). I have a full-height fireplace (stone from floor to ceiling) and then to the right is a cutout where the Tv will be mounted. Problem is, the cutout is only 41" wide (across) and 20" in depth. This means I will mount the tv so it is outside of the cutout. This means the monoprice in-wall center speaker will be 20" min behind the tv. Do you guys think it will impact the performance of the speaker in any way? Will it echo "inside" the cutout and drive me nuts, or sound perfectly normal? Any input you guys could give me would be awesome!
Also, if you think I shouldn't go with monoprice's center speaker, do you guys have an alternative that pairs well with the other monoprice speakers? I am on a huge budget, but I want something that sounds good but not uber-spendy (ideal would be under 50 bucks but not sure that is possible).
Let me know if you need clarification on my wall and cutout--it is hard to convert into words
Thanks! I know you guys will have some expert opinions and knowledge to share
Long Live AVS
jjensen2 is offline
post #813 of 2115 Old 11-21-2010, 10:32 AM
Plasman's Avatar
Originally Posted by chrispy View Post
Plasman, that is an absolutely top-notch setup! I am currently pursuing new construction. Framing should being in 2-3 weeks. Our viewing area is very similar to yours, with a propane fireplace and two windows on either side. I was contemplating doing some in-wall speakers instead of floor-standers, and seeing your pictures basically made up my mind for me.
If you don't mind, I have some questions:
Hi Chrispy, sorry to answer late - I didn't see your questions from last week. Thanks for the nice comments. Answers in blue.
  1. What is the height from the floor to the top of your mantel?
    46" to top of mantel and 47.5" to bottom of recessed pocket
  2. Is the TV is sitting on its pedestal on the mantel, rather than being wall-mounted? It looks like it's tilting slightly downward, which is something I think is needed for best viewing ergonomics.
    I used a wall mount (Monoprice of course) model 5916 slim tilting mount. I did tilt it slightly and my couches are about 10-13 feet away because of the U shape. But no neck strain.
  3. Was the 2x4 framing depth enough for the 2-ways? By the specs, it looks to barely be enough with the sheetrock depth included
    Yes, those speakers are made for 2x4 framing. Remember, the drywall gives you an extra 1/2 inch or so.
  4. Is the orange flex conduit for video cabling? If so, what diameter is it?
    I think it was 2 inches and it carries some pull strings, 22 gauge HDMI cables and several CAT6 for future proofing. I can't do 3D at this point since there are no high speed HDMI cables that are long enough and no reliable HDMI 1.4 Cat 6 converters.
  5. How did you bring this conduit through the wall - did you mate it to a work box, or just punch it through the wall?
    It just lines up with a dual gang low voltage plastic box in the drywall - nothing fancy. A plastic recessed workbox with a nice conduit fitting might have been neater. I had the electrician use a dual recessed clock outlet for the power.
  6. Do you find any issues with speakers not being angled downward? In other words, does the sound improve noticeably when you stand up? (I'm wondering if fabricating some angled spacer collars from wood is worthwhile.)
    It sounds quite good and I don't notice center channel spatial issues even though it is obviously not an ideal setup. Angling the center would probably work better but I wanted a clean modern look. Even the Samsung built in speakers sound good when not using the home theater setup.
  7. Where is your equipment located?
    60 feet away in an equipment closet. I use URC RF20 RF remotes in the house which work just great. For a wireless PC keyboard, I had to go to this rather expensive 900 Mhz one for the long range to my HTPC in the closet: http://www.fentek-ind.com/lkbmrf100tbu.jpg
Good luck with your installation. I've got another TV with the same recessed pocket and home theater setup in the Master Bedroom too (although the center channel is under the TV in that room). As I said, my builder thought it was foolish to lose floorspace by building the pocket walls - but I think my 2 TV's looks 100X better than a hanging picture look with an exposed (albeit thin) wall mount behind.
Plasman is offline
post #814 of 2115 Old 11-22-2010, 04:42 AM
chrispy's Avatar
Originally Posted by Plasman View Post
Q: Is the TV is sitting on its pedestal on the mantel, rather than being wall-mounted? It looks like it's tilting slightly downward, which is something I think is needed for best viewing ergonomics.
A: I used a wall mount (Monoprice of course) model 5916 slim tilting mount. I did tilt it slightly and my couches are about 10-13 feet away because of the U shape. But no neck strain.
Thanks Plasman, this was all great information. I have one follow-up question regarding the quoted answer above. For the mount above, how do you get to the back of the TV to adjust and tighten the TV mounting bracket? And once the TV is on the bracket, how do you take it back off? I'm wondering because there is so little clearance around the TV to get back in there.
- Chris
chrispy is offline
post #815 of 2115 Old 11-22-2010, 06:38 AM
caper_1's Avatar
Liked: 26
It doesn't look THAT bad, does it?
HT: Yamaha RX-V565 | 3 X Energy Take FPS, 2 X VS Surround, 2 X Take LCR | DIY Subs: SDX12 APR15 & TRIO12 Dual APR 12's | 47" LCD
Music: Yamaha RX-V863 | 2 X Energy RC-70 | MA RXw12 Sub
Bathroom: 2 X Energy Take LCR
Car: Sony Xplod HU, Xplod 6X9s, Kenwood 4"s, Alpine 12" Type-S, Rockford Amp,...
caper_1 is offline
post #816 of 2115 Old 11-22-2010, 07:58 AM
Plasman's Avatar
OK, only 50X better Your install indeed looks great, so no offense. In my bedroom you can enter the room looking perpedicular to the TV - so the pocket really frames the TV and helps hide the brackets and wires. In my old house, the TV looked "tacked" on with one of the original wall mounts that stuck out 3 inches.
Plasman is offline
post #817 of 2115 Old 11-22-2010, 08:14 AM
Plasman's Avatar
- Chris
Oh you mean I have to be able to take it off? I'm old, so I simply got a TV with a MTBF that was longer than my actuarial table predicts. It will be my wife's problem
There just has to be enough clearance for fingers to get in there and hang it. I set the tilting mechanism screws so that motion was possible but very firm. I was not able to tilt out the bottom enough to tighten the 2 retaining screws but I left them in a position which does some good in terms of preventing the TV from getting unhooked from the top hangers during vertical movement in an earthquake.
Plasman is offline
post #818 of 2115 Old 11-22-2010, 09:33 AM
jjensen2's Avatar
Originally Posted by jjensen2 View Post
Hey guys--
Long Live AVS
Anybody have any suggestions?? Any help would be appreciated!!
jjensen2
jjensen2 is offline
post #819 of 2115 Old 11-22-2010, 09:45 AM
Wirelessness's Avatar
I am still looking for suggestions for a good Center Channel to match up with either the 6.5 or 8.0 surrounds? I need in ceiling for everything but the Center. Thanks!!!
Wirelessness is offline
post #820 of 2115 Old 11-23-2010, 03:22 AM
chrispy's Avatar
Cool, I was thinking of doing the same thing. One more question... It looks like the recess is framed with 2x4s. Is this correct? Was the back wall of the recess covered with sheetrock, or did you attach the bracket directly to framing?
I'm asking all these questions because I have to draw out the fireplace framing and give it to the builder. Since it's new construction, it all has to be framed and finished, inspected by the township, etc. I can't just get in there and tweak it until it's right. Well I could, but it's easier to have the builder do it right the first time.
Right now I'm aiming to frame out a 78" wide fireplace. This puts me right on the hairy edge of being barely big enough for a 52" TV with a speaker on each side, or having to step down to a 47" TV. I'm going to wait until they have the rough framing done and see how much distance there is between the window frames, then make a decision based on that.
This is gonna be so great!
- Chris
chrispy is offline
post #821 of 2115 Old 11-23-2010, 07:11 AM
Plasman's Avatar
I went through my construction photos and these may help. The pocket is fully drywalled. The pocket is 54" x 33" to accomodate the Samsung 55" TV. I even put 4 special lag screws into the studs before drywall for the Monoprice mount to connect to. The lags have screw threads like a lag bolt but a machine threaded hex face. The drywallers simply made holes for these to pop through. The framing diagram is amateurish but was my attempt to explain this to the builder.
Plasman is offline
post #822 of 2115 Old 11-23-2010, 03:25 PM
mxpx5678's Avatar
Liked: 24
Honestly I would just look for a good Black Friday deal and get the best center channel you can buy, I wouldnt worry about matching it too much. I dont have matching rears and you would never know.
mxpx5678 is offline
post #823 of 2115 Old 11-23-2010, 03:38 PM
Quaid's Avatar
Matching C to FR and FL is far more important than matching to the rear surrounds.
I used 3x monoprice center channels for my C, FR, and FL. This worked extremely well for me, but if you have monoprice FR and FL then I would whole heartedly recommend a monoprice C. The higher end speakers from monoprice are no longer 4ohm like they were when I made my purchases, so I would go with the higher end C unit now that it's 8ohm. The binding posts and cross over are higher quality.
Quaid is offline
post #824 of 2115 Old 11-23-2010, 05:22 PM
I can't use the MP Center in-wall speakers because I have AV cabinetry installed in the center and there really is not room. So I need to use a cabinet style center channel speaker that can sit on the shelving just below the TV. That is why I am looking for suggestions for pairing a different center with the FL and FR from Monoprice. Thanks!!!
post #825 of 2115 Old 11-24-2010, 05:10 AM
Quaid's Avatar
Sorry about the confusion. I don't think you'll ever be able to timber match without bringing center channels to your home theater and auditioning them. Only higher end stores selling expensive products are likely to allow this. Since that doesn't fit the monoprice theme of low-budget, I don't think it will be an attractive option.
As the previous response said, just buying the best you can afford might be your best option. You could look for products with similar speaker construction and similar crossover components, but this won't guarantee anything in terms of timber matching...it might be wasted effort.
Quaid is offline
post #826 of 2115 Old 11-24-2010, 05:43 AM
caper_1's Avatar
Liked: 26
A friend of mine has MP in-ceiling for L/R and a paradigm studio center channel, lol. Probably not the best timbre match, but YPAO will try and EQ the difference I believe. IMHO, if you are using low budget speakers like MP, then SQ isn't a priority so any center should suffice your particular needs.
caper_1 is offline
post #827 of 2115 Old 11-25-2010, 02:25 AM
chrispy's Avatar
This information is perfect. Thanks Plasman! I'll need to adapt this to a 47" TV since we have less room between the windows, but that should be straightforward. Thanks very much for all your help. Once we get to framing, I will also share pictures with my fellow AVSers to document the in-wall speaker installation aspects.
chrispy is offline
post #828 of 2115 Old 11-25-2010, 09:30 AM
mxpx5678's Avatar
Liked: 24
Honestly the MP speakers are really good for the price, they arent as good as maybe 1000 dollar in ceilings but they are still really good speakers.
That being said I used Niles Audio for my fronts and Center, they are really good quality and I got a great deal on them, my setup sounds great and I cant imagine how it could sound any better.
(aside from an upgraded subwoofer)
mxpx5678 is offline
post #829 of 2115 Old 11-26-2010, 10:01 AM
davidtt485's Avatar
Liked: 34
I have just installed the 8" 3 Way monoprice in walls and they are being used for surround sound duty. I have to say im very impressed with the build quality, and the sound quality. I had to install them and remove them quite a few times, the screw calmps held very well. And for sound quality, they sound very "balanced" and im using them with pioneer elite, so they can handle a fair share of power... I wouldn't use them for fronts, i have definitive technology up front bookshelfs and CLR center.
davidtt485 is offline
post #830 of 2115 Old 11-26-2010, 10:32 AM
**OptimusPrime**'s Avatar
Liked: 29
Originally Posted by **OptimusPrime** View Post
The speaker set-up I have includes:
1 4881 (5-1/4 Inches Center Channel In-Wall Speaker),
4 4101 for my L/R mains as well as my L/R surrounds (8 Inches Kevlar 2-Way In-Wall Speakers (Pair) - 80W Nominal, 120W Max),
and 2 4104 for my rear surrounds (8 Inches Kevlar 2-Way In-Ceiling Speakers (Pair) - 80W Nominal, 160W Max).
I have since retired my Denon AVR 3300 and am now using a friend's Harman Kardon AVR 335 with the included SUBTS-14 200 watt powered subwoofer.
Using this receiver, I am able to set crossover frequencies. I have experimented with the auto-calibration setup from the AVR (called "EZset"), but the results came back weird:
Front L/R = 150Hz
C = 60 Hz
Surround R/L = 150Hz
Rear Surround R/L = 200 Hz
I would think setting your center channel to 60 Hz is a bad idea!
What crossover settings are being used by the people in this thread?
Thanks again for your help fellow AVSers!
**OptimusPrime** is offline
post #831 of 2115 Old 11-26-2010, 11:56 AM
davidtt485's Avatar
Liked: 34
i should also mention the bass resposne from these was pretty decent, the x over is 80hz for me for all my speakers...
post #832 of 2115 Old 11-28-2010, 05:49 AM
krnbk2's Avatar
Hey guys, im about to order my 3 front speakers and was wondering what route I should take.
Would you go with 3 of these: 5-1/4 Inches Center Channel Micro-Flanged In-Wall Speaker - 8 Ohm
or
2 of these: 8 Inches Kevlar 3-Way High Power In-Wall Speaker (Pair) - 100W Nominal, 200W Max
and 1 center from above
My thought process for using the 3 centers as my FR, FL, and C was purely aesthetic. The room is large and opens into another room (its 26x20 with 10' tray ceiling) so maybe I would be better suited to use the 8" 3 ways for the FR and FL?
Any help would be appreciated.
krnbk2 is offline
post #833 of 2115 Old 11-28-2010, 07:52 AM
Liked: 29
Front L/R = 150Hz
C = 60 Hz
Another quick update...I downloaded the DVDaudio test, v.2 available through another thread on the AVS forum. I decided to use it to test the various Hz frequencies on each individual speaker, both with the sub on and off to help determine where the "breaks" were.
I also used the sweeps to help determine where the crossover sounds best.
I'm definitely no expert, and I was NOT using any equipment other than my ears, but I was astounded with the results. For my room size/type, EZset was actually spot on - for the most part.
For the curious minded, at -30db, below are the lowest HZ results (clearly audible from the main listening/viewing area) for each of the speakers I am using:
8" 2 way in wall = 60 Hz
5 1/4 " in wall center = 50 Hz
8" 2 way in ceiling = 80 Hz
Using the 300-30Hz sweep, I set my crossovers to the following:
Front L/R = 120Hz
C = 60 Hz
Surround L/R = 150 Hz
Rear L/R = 200 Hz
I guess EZset tries to achieve complete room balance, figuring the center channel being used for primarily dialogue in HT situations. Setting the crossover lower on the center channel achieved a more realistic sound for speaking voices (I literally cannot hear the sub for speaking voices at all), which is what I was hoping to achieve.
Does anyone else care to share their crossover settings for these speakers? I am hoping we can learn more about their "real-world" specs since MonoPrice does not list their recommended crossover levels.
post #834 of 2115 Old 11-28-2010, 02:09 PM
Quaid's Avatar
Either choice will suffice. I went with 3x center channels for FR, FL, and C.
It seems that most choose the alternative. You will get slightly better bass response from the 8" in walls vs the center channels, but this is less relevant when you incorporate a subwoofer, and less so again when you optimize with Audessey, YPAO, etc.
If you go back a few pages in this thread you'll come across the posts from my install.
Like I said, either choice is adequate.
or
Quaid is offline
post #835 of 2115 Old 11-29-2010, 07:25 PM
jjensen2's Avatar
Hey guys--
Thanks! I know you guys will have some expert opinions and knowledge to share.
jjensen2 is offline
post #836 of 2115 Old 11-29-2010, 07:42 PM
Smoothjake's Avatar
Hey guys--
Putting the speaker behind the tv inside the cut out is a very BAD idea. The sound will be muffled you may not even hear the speaker playing
I would try mounting the tv to the fireplace stone. Hide the cable as best you can. If you are using a hdim receiver you will only be hiding 2cables the power cable for tv and the hdmi cable from the receiver. Then I would close off the cut out with drywall and mount the speaker there
I would also try and mount a center speaker above or below the tv. But you wil not be able to use a in wall speaker for that
Use your imagination stare at the fireplace and figure out a way to do it. I am sure it can be done some how
May cut out the mortar around the stone put the wire in the cut out and then cover the wire with new mortar
Smoothjake is offline
post #837 of 2115 Old 11-30-2010, 02:46 PM
jjensen2's Avatar
Any other suggestions? I don't think I want to mess with the wall or mounting the TV to the fireplace--too much hassle and potential for bad things as the fireplace gets really hot.
Has anyone been able to find a good, cheap center channel speaker that matches the Mono in-ceiling speakers??
I would appreciate any input anyone has on this subject, or pertaining to my previous post.
jjensen2 is offline
post #838 of 2115 Old 12-02-2010, 10:49 AM
erekan's Avatar
For those of you running these in a 5.1 setup, which is what I will be doing, what are you setting the Xover point to in your reciever's??
erekan is offline
post #839 of 2115 Old 12-02-2010, 03:35 PM
caper_1's Avatar
Liked: 26
above that of your low end freq response of the speaker. My freq response of my Take FPS is around 65 Hz bottom end...I set my xo 80 or higher (around 100 I think).
caper_1 is offline
post #840 of 2115 Old 12-03-2010, 10:03 AM
erekan's Avatar
That is what I was thinking as well but just wanted to get a little feedback on the matter. Thanks for the response.
erekan is offline
Reply Speakers
In Wall Speakers , In Ceiling Speakers
