Monoprice in-wall, in-ceiling speakers - Page 64 - AVS Forum
 3Likes
post #1891 of 1905 Old 10-05-2014, 09:40 PM
Teecee's Avatar
Tons of good info in there. Thanks for the contributions. very helpful.
Teecee is offline
post #1892 of 1905 Old 10-09-2014, 08:53 AM
ckronengold's Avatar
Quoted: 12 Post(s)
Went with a 3.1 setup from monoprice as a test. Just wanted to see if you could get decent enough sound for a den system that wasn't my primary movie or music set up. Its the room for casual TV watching and listening to music when we've got company.
Gotta say that I'm tremendously impressed with the sound for only spending $200.
I went with Product ID: 4101, the 8-inch Kevlar 2-Way In-Wall Speakers for the L&R. Since I was just experimenting, I didn't go for the 3-ways (Product ID: 6816) for $30 more. Now I'm wondering if that wasn't a mistake and if they'd sound even more than acceptable had I done that. Guess I can always move these somewhere else later if I want.
Also installed Product ID: 6317, the 5-1/4 Inches Center Channel Micro-Flanged In-Wall Speaker right below the TV, and Product ID: 4928, the 10 Inches In-Wall Subwoofer (Passive).
The instructions on how to wire the sub were less than clear. Because my receiver doesnt have speaker-level outs for the sub, I had to connect it in series to the Left Front. Didn't quite get it right on the first hook-up, but had run a pair of in-wall speaker wire, so it was easy enough to make the additional connections.
Overall, I'm pretty happy with how it sounds, and the wife is VERY happy with how they look. So I guess thats a win right there. Plus, now I've got an extra $1000 that I was going to put towards speakers in that room to spend elsewhere.
Name:	inwallprogress (Small).jpg
ID:	302290   Click image for larger version
Name:	inwallinstall (Small).jpg
Media Room: Onkyo NR-709 / OPPO-103
Paradigm Mini Monitors v2 / Atoms (rears) / CC-370
Den: Samsung 59D6500 Plasma & Monoprice in-walls
Server: WHS2011, i5 2500k CPU
HTPC1(LR):Win8 Pro 64-bit, i5 750 Radeon HD 5850
HTPC2(BR):Win8 Pro 64-bit, i3 2105, Radeon 6770
ckronengold is offline
post #1893 of 1905 Old 10-09-2014, 03:10 PM
Liked: 0
I plan to use the monoprice speakers for surround sound in my basement. I'm going to use the 8 inch in wall speakers for the front LCR, but my problem is what to do with the rears. I had planned to use in walls for the rears positioned on the left and right wall, but those are both exterior walls that I think I don't want to lose insulation R value. So my options are to place the speakers on the rear wall which I don't think is the best option, or to go in ceiling which I don't have an issue with as long as the sound is adequate.
My question is which way would you go, rear wall or in ceiling? Which in ceiling speakers would best perform in this application? What is the best location to put these speakers, behind and left/right of seating position, or just directly left/right of the seating position?
IrishStout is offline
post #1894 of 1905 Old 10-10-2014, 08:09 PM
prince.nothing's Avatar
Quoted: 33 Post(s)
Liked: 2
This is a very helpful thread. I'm looking for four economical in ceiling speakers to atmos enable my Klipsch 5.2 HT setup. I was thinking of either at PID 4104 or 4619. Has anyone used these, or any other monoprice in ceiling speakers in an atmos setup. Thanks.
My Home Theater Build: Geeky Talkies
prince.nothing is offline
post #1895 of 1905 Old 10-21-2014, 08:13 AM
cozilla's Avatar
If anyone is interested I have a brand new 7604 in box that I do not needs as I used 3 of the 4 for my LCR. Let me know if you are interested.
Colin
cozilla is offline
post #1896 of 1905 Old 10-22-2014, 07:44 PM
Bill97Z's Avatar
I want to start off by saying this is an awesome thread!
I am building a small theater room in my basement, ~11' wide b y 23' long. It's hard to believe the great reviews of these speakers for the price. I want a clean setup with speakers behind the screen and don't want to deal with building a false wall so am considering these in wall models, probably 3 of the 8" (for the front mains and center and 2 of the 6" for the surrounds). I will run it with 2 powered subs for a 5.2 system.
As an aside, in my living room I am running an onkyo receiver with klipsch towers, surrounds and subs. When I crank it up, movies sound awesome. Will these speakers give me the same power, volume, and room shaking sound quality? I just don't want to go through the install and be disappointed.
Bill97Z is offline
post #1897 of 1905 Old 10-23-2014, 11:31 AM
PlayU18's Avatar
Colin
Since I only have 13 posts, I can't send you a pm. How much do you want for the MP 7604 speaker?
PlayU18 is offline
post #1898 of 1905 Old 10-23-2014, 11:33 AM
PlayU18's Avatar
Colin
Forgot to mention, I would need it shipped to Ohio.
PlayU18 is offline
post #1899 of 1905 Old 10-26-2014, 09:03 AM
hoyalawya's Avatar
Quoted: 18 Post(s)
About ready to pull the trigger for 5 pairs of Monoprice in-wall/in-ceiling. All to be used as in multizone audio system and all will be configured as stereo. One quick question. Is there any advantage in using round shape speakers over rectangular shape speakers for in-ceiling? It seems that everyone is choosing round shape speakers for ceiling.
Edit: I am thinking about using 7604 for all of in-ceiling speaker pairs.
hoyalawya is offline
post #1900 of 1905 Old 10-27-2014, 08:20 AM
roblanderson's Avatar
I'm building a theater / multi-purpose room in my basement and planning to use in wall Monoprice speakers. For the L/R I'm thinking 6816 (8" 3-way) and for the rear surrounds I'm thinking 7606 (5.25" 3-way). I'm not sure on the center channel - 4881 seems to be a popular choice, but it looks like some recommend using the same speaker as the L & R. Any advice offered would be great!
I don't have a receiver yet, but I'm planning to buy the Denon AVR-X1000. I'm also not sure which powered sub I'll buy.
roblanderson is offline
post #1901 of 1905 Old 10-27-2014, 08:30 AM
hoyalawya's Avatar
Quoted: 18 Post(s)
Look into Dolby Atmos before you decide on the speaker configuration. I will be doing a 5.1.2 system in my family room and 7.2.4 in my dedicated HT.
post #1902 of 1905 Old 10-27-2014, 10:50 AM
Thanks - I'll look into Dolby Atmos.
post #1903 of 1905 Old 10-28-2014, 10:11 AM
Liked: 0
I'm putting together a system and I'm thinking of 7604's for LCR. I had planned to mount the center 7604 horizontally but I've read some posts in this thread about the lack of symmetry as compared to a dedicated center channel speaker.
For those who are using the 7604 horizontally, do you notice anything weird with it? I'm wondering if I'm really going to notice. Seating area will be about 10' back.
buzz fretwear is offline
post #1904 of 1905 Old 10-28-2014, 10:43 AM
Bill97Z's Avatar
Anyone have any comments?
Bill97Z is offline
post #1905 of 1905 Old 10-28-2014, 10:50 AM
hoyalawya's Avatar
Quoted: 18 Post(s)
Try to listen to some in-wall/in-ceiling speakers at Best Buy Magnolia. Ask the sale rep to do A/B comparison between bookshelves and in-wall/in-ceiling speakers. It will give you some idea of what to expect from in-wall/in-ceiling speakers.
Reply Speakers
In Wall Speakers , In Ceiling Speakers
User Tag List
