Monoprice in-wall, in-ceiling speakers - Page 70 - AVS Forum | Home Theater Discussions And Reviews
 13Likes
post #2071 of 2079 Old 01-12-2016, 07:25 PM
SDNick484's Avatar
I'm moving to a new house and need to replace my two pairs of Polk T15 bookshelf speakers that I've been using as my surrounds and rear surrounds for in-walls. Most likely I'll have to go ceiling, and I was considering the 15° angled Monoprice speakers although I'm open to other suggestions (and to potentially not do angled). The receiver currently driving it is an Onkyo TX-NR 708, and the LCR speakers are the Newegg Polk Monitor 70s and a CS2. Would I be better off considering the RC/MC85 Polks mentioned above? Home theater & gaming will be the primary use for the surrounds.
SDNick484 is offline
post #2072 of 2079 Old 01-18-2016, 08:44 PM
ripflash's Avatar
Originally Posted by clubwerks View Post
Thanks. That is very helpful because I'm planning on adding four ATMOS speakers and I have a vaulted ceiling.
Angled speakers might also be useful if you're pointing them down to hardwood or tile, since that would create bad reflections.
ripflash is offline
post #2073 of 2079 Old 01-21-2016, 09:22 AM
uscpsycho's Avatar
Quoted: 56 Post(s)
Nearly impossible to get a question answered in this thread these days, but I'll try another question.
Does anyone have any experience with the Monoprice metal back cans? Do they make a noticeable difference?
Sounds like using them is a good idea but they have limited compatibility which means I'd have to use a more expensive speaker than I had planned on using, and that speaker has no reviews.
On that note, has anyone tried the 13684 speakers? Those are the speakers I would have to get if I go with the metal cans.
uscpsycho is online now
post #2074 of 2079 Old 01-25-2016, 08:35 PM
coolguy2010's Avatar
I recently installed 4 monoprice inwall 7604 speakers for my living room, i got the 11948 center channel from monoprice but the speaker was small and need something more powerful. Looking for suggestions for center channel in 200-300$ range which would go well with the inwalls. Receiver is Sony STRDN1060. Also, looking for a decent subwoofer. This is for a living room with kitchen/nook (so big open area with high ceilings). I have the Hsu STF-MK2 for my media room which I love but wife does not want a 18X18X18 box in living!
Appreciate your feedback!
coolguy2010 is offline
post #2075 of 2079 Old 01-25-2016, 08:38 PM
fitbrit's Avatar
Quoted: 40 Post(s)
Liked: 46
Just use another 7604 for center. Buy two, sell one, or keep as a spare.
The BIC DV62CLR is highly reviewed and cheaper than your budget if you want a non-in-wall center.
fitbrit is offline
post #2076 of 2079 Old 01-26-2016, 06:58 AM
Thanks...although i would have loved another in wall, there are pipes in the area which prevents me from inwall. Will look at BIC DV62CLR...Appreciate it!
post #2077 of 2079 Old 01-26-2016, 04:47 PM
cozilla's Avatar
If you do go the 7604 route let me know. I need a single.
cozilla is offline
post #2078 of 2079 Old 01-27-2016, 11:07 AM
johnstonk's Avatar
Quoted: 23 Post(s)
Has anyone used these with the Monoprice speakers?
http://www.monoprice.com/product?c_i...seq=1&format=2
I looking at using these speakers with the No Label Whole House Audio unit from Monoprice, our home is a ranch wanted to keep the insulation out of the speaking in the ceiling.
Ken
johnstonk is online now
post #2079 of 2079 Old Today, 03:39 PM
Liked: 0
So has anyone ordered the carbon fiber Monoprice speakers (13684) and the corresponding metal back can enclosures (14364)? I am curious whether or not to leave the front air port closed or open it up. If you notice in the pictures from Monoprice, they originally have the air port sealed off; but with the new back cans I do not know if it would sound better sealed or opened. I tried asking Monoprice themselves but just got a generic response that "either way" will work. :-\
ArcticWolf005 is online now
Reply Speakers
In Wall Speakers , In Ceiling Speakers
