speaker wire polarity - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 02-21-2008, 07:26 PM - Thread Starter
jbhxray's Avatar
I bought 14 gague generic speaker cable from Lowe's. I am in the process of wiring my speakers and I find I can't tell + from - polarity on the wires. I do not see any indication marked and both wires are copper. Is there a simple way to make sure I am correctly wiring + and - ? Any help appreciated.
jbhxray is offline
post #2 of 15 Old 02-21-2008, 08:06 PM
Beta_max's Avatar
You mean the cable is the same color?
Beta_max is offline
post #3 of 15 Old 02-21-2008, 08:28 PM
oztech's Avatar
Liked: 101
One side will usually have ribs or a stripe if no markings at all you will have to use
a toner to make sure ,lowe's has them.
oztech is offline
post #4 of 15 Old 02-21-2008, 08:54 PM
Patdeisa's Avatar
I have two speaker wires that have the same problem. One has printing on it, which makes it able to identify the same strand, so I just use that as negative (it doesn't matter, as long as you're consistant). The other has a green thread mixed in with the copper on one side- very hard to see, but can be used to identify it.
If nothing else, use a black marker and follow the wire yourself and label the ends.
Patdeisa is offline
post #5 of 15 Old 02-22-2008, 06:44 AM - Thread Starter
jbhxray's Avatar
Thanks for replys. What is this toner you speak of? I do not see any markings on the wire and some of it is already in the walls.
jbhxray is offline
post #6 of 15 Old 02-22-2008, 07:13 AM
Noubourne's Avatar
A toner is a two-piece device; a transmitter and a receiver.
You connect the transmitter to one of the wires, and then use the receiver to check the other end of the wires. When you connect the receiver to the same wire that the transmitter is on, you will hear the signal (usually a steady tone or beeping) coming from the transmitter. This helps you to know which wire you have on both sides, even if you've already installed them in some walls.
It was one of my best tools when I was a cable installer - especially considering the price of my other meters.
Noubourne is offline
post #7 of 15 Old 02-22-2008, 07:34 AM - Thread Starter
jbhxray's Avatar
Thanks for the info. Where is the best place to get this and what is price estimate?
jbhxray is offline
post #8 of 15 Old 02-22-2008, 07:58 AM
ajstan99's Avatar
I haven't tried it, but this looks to be an inexpensive way to determine polarity:
http://www.sweetwater.com/expert-cen.../d--04/20/2007
"Disconnect the speaker wire from your amp, then connect the cable to a 9-volt battery. The battery's DC voltage will cause the woofers to move forward if the polarity is correct (that is, positive to positive). If the woofer moves backward, your polarity is reversed. If that's the case, simply reverse the connection on your amp."
Then, put on some color-coded banana plugs so you won't have to test the wire again.
ajstan99 is offline
post #9 of 15 Old 02-22-2008, 01:39 PM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
All you need is something that will measure continuity. There are some relatively inexpensive devices made for doing this. There are some simple continuity testers in which will illuminate an LED indicator light when a circuit is completed. Check your local hardware store, mega home imnprovement store, or Radio Shack. A voltmeter, ohmeter, or multimeter will work, too; also available form the same places.
But there should be SOMETHING that distinguishes one strand from another. Lettering? A "rib". Something. If not, I would not use it. It's just going to be a pain in the ass.
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is offline
post #10 of 15 Old 07-13-2008, 03:15 PM
WAR_GA's Avatar
Blame it on the wife . . . I too bought the same wire at Lowes. At the store I told her I could not see a difference in the two sides of the wire. She looked at the picture on the spool and said, one side should be black and the other side copper after you cut them.
After stripping the wire and seeing that both sides looked the same, I searched the forum for this issue. The response I was using was as a fix was - mark one side and run down the length of the wire and mark the other end.
As I was stripping, complaining, and marking the wire and my wife was hooking up our new Axiom Epic 80 system, she commented "did you know one edge of the cable is flat and the other edge is round?" There's the answer to determining polarity on Lowe's speaker wire. I hate that she is both more mechanical and smarter than me on issues such as this!
WAR_GA is offline
post #11 of 15 Old 07-13-2008, 04:06 PM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
They ARE useful for some things.
post #12 of 15 Old 07-13-2008, 06:14 PM
pmf
pmf's Avatar
Are you sure your wife wasn't alluding to the fact that the outside edges of a double stranded wire being round and the inside edges (where the 2 strands came fused together till you pull them apart) being more square (flat), or the other way around?
The way I check continuity is to use a speaker (old car speaker should work fine) & connect it's terminals to the + & - or a AA battery to make clicking noises. Get the speaker & the AA battery with one terminal already hooked up & use the open terimal(s) on the 2 ends of your cable in doubt to look for continuity.
PF
pmf is offline
post #13 of 15 Old 07-13-2008, 10:35 PM
quadriverfalls's Avatar
Sounds like you used generic speaker wire which is NOT rated CL-2 or CL-3 for in wall use. If you should happen to have a fire, and it is discovered that you used improper wiring inside your walls (whether that caused the fire or not is irrelevent), your insurance company can deny your claim and cancel you without cause.
You should ALWAYS use jacketed CL-2 or CL-3 rated speaker wire when running it inside a wall or ceiling cavity.
John W.
Indy
quadriverfalls is offline
post #14 of 15 Old 07-14-2008, 09:13 AM
Easyaspie's Avatar
Excellent point.
Easyaspie is offline
post #15 of 15 Old 07-14-2008, 09:28 AM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
Unrelated but still relevant. And it may be too late.
Add to this the fact that if there IS a fire and you survive the flames, toxic fumes from the burning of the non-CL2/3 wire may kill you.
Reply Speakers
