Official Wyred 4 Sound Amp Thread - Page 47 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #1381 of 1704 Old 01-27-2012, 11:06 AM
whickywhickyjim's Avatar
I am thinking of purchasing the MMC-5. I am concerned that the output is a little strong to run a set of 4ohm 100W surround speakers I have. I also want to run a pair of 6ohm front channel speakers of unknown wattage (henry kloss towerI cambridge soundworks speakers). I think the fronts will be fine with this amp, but I'm concerned about the lack of a level control to balance out the speakers and also that the surrounds may get blown out with the power output of the amp being about 4x (380W at 4ohms) the rated speaker max of the surrounds (100W at 4ohms).
Any input would be greatly appreciated.
whickywhickyjim is offline
post #1382 of 1704 Old 02-08-2012, 03:04 PM
Mr. Neverbicker's Avatar
Can anyone tell me if there is a distinguishable difference between a pair of SX-500 monos and a ST-500 stereo? I'm hoping someone with a critical ear has heard both.
Mr. Neverbicker is offline
post #1383 of 1704 Old 02-08-2012, 03:05 PM
Face2's Avatar
Quoted: 334 Post(s)
Liked: 202
I've owned both. The monos allow more placement options and shorter speaker cables.
Face2 is offline
post #1384 of 1704 Old 02-08-2012, 04:00 PM
Thanks. Do you not mention any sound differences because you heard no difference?
post #1385 of 1704 Old 02-08-2012, 04:29 PM
Face2's Avatar
Quoted: 334 Post(s)
Liked: 202
Unfortunately, I didn't compare them side by side, but I did hear both a few days apart in my rig and from what I could tell, there was no difference. IIRC, W4S will probably give you the same answer.
Face2 is offline
post #1386 of 1704 Old 02-08-2012, 05:04 PM
Some reviews I came across indicated that the SX-500 mono has the most detail and soundstage among the bunch as a result of its lowest noise floor and THD. There is a big cost difference for a full HT setup, so I wonder what the difference in detail and soundstage might be subjectively.
post #1387 of 1704 Old 02-11-2012, 12:27 AM
runnin''s Avatar
Liked: 45
I'm looking into Wyred and wondering if anyone has tried them with Paradigm speakers. I've got a 2 channel system with a pair of Paradigm S6, an Oppo 95 and an Emotiva XPA-3(1 channel idle). I think I need a pre amp and the wyred STP-SE looks like it would be a great addition. I think Emo makes decent amps for theater, but they used to have more musical models than they do now.
runnin' is offline
post #1388 of 1704 Old 02-16-2012, 07:54 AM
Glenee's Avatar
Quoted: 81 Post(s)
Liked: 76
I have used the W4S SX-1000 mono's on Aerial 9's, Revel Studio 2, and B&W 802D's with great results I have no reason to believe they would sound anything other than great with the Paradigm. I was using the Emotiva XPA-1 Mono's before the W4S and the XPA-1's are the best bang for the Buck on the market, truly a sleeper in the Audio industry. The thing that the W4S mono's do better than the Emotiva's was inky blackness on anything other than music. I mean dead silent when they were supposed to be silent.
Nothing's Perfect So Stop Expecting It ! Glenee
Glenee is offline
post #1389 of 1704 Old 02-16-2012, 09:24 AM
Adz523's Avatar
I just purchased a nice new MC3x500 -- beautiful unit. I'm looking to purchase a used Mini MC-5 if anyone is interested in getting rid of theirs - just PM me.
Adz
Adz523 is offline
post #1390 of 1704 Old 02-16-2012, 11:13 AM
runnin''s Avatar
Liked: 45
Nice to hear of a comparison with the XPA-1, Emotiva's flagship. I'm thinking I'd be looking at Wyred's stereo amp line, the ST 500 at 250wpc would give plenty of power. But with the STP pre amp I'd be looking at 3500, and I wonder if I'd be as happy with an integrated amp like their STI 500 or 1000. They wouldn't have as good a pre amp section but would come substantally cheaper.
Adz, what speakers are you running with your MC3?
runnin' is offline
post #1391 of 1704 Old 02-16-2012, 05:16 PM
Glenee's Avatar
Quoted: 81 Post(s)
Liked: 76
Runnin,
Check you messages
Glenee is offline
post #1392 of 1704 Old 02-16-2012, 05:23 PM
Face2's Avatar
Quoted: 334 Post(s)
Liked: 202
The STI comes close to a ST/STP-SE combo. If I didn't score an excellent deal on a STP-SE, I would still be more than content with a STI-500.
Face2 is offline
post #1393 of 1704 Old 02-17-2012, 04:43 AM
Adz523's Avatar
Inwall solution - Most likely at the end of the day Triad Gold/Silver
Adz
Adz523 is offline
post #1394 of 1704 Old 02-17-2012, 10:11 AM
runnin''s Avatar
Liked: 45
Thanks, Glenee.
Face, so have you been pretty happy with your STP-SE? I've heard it described by some as slightly warm. Added to a Wyred amp is the result pretty neutral? As far as the STI option goes, that's what I was thinking, except the STP has better specs and apparently better volume circuitry. Whether that adds up to an audible difference depends on the speakers perhaps.
runnin' is offline
post #1395 of 1704 Old 02-17-2012, 01:05 PM
Face2's Avatar
Quoted: 334 Post(s)
Liked: 202
Thanks, Glenee.
The STP-SE is pretty neutral, maybe slightly warm. As I mentioned before, the differences are subtle, but if you're like me and want to know you have the best possible setup, you know what you need to do.
Face2 is offline
post #1396 of 1704 Old 02-17-2012, 04:36 PM
Adz523's Avatar
So does anyone have the MC Mini-5 and do they like it?
Adz
Adz523 is offline
post #1397 of 1704 Old 02-17-2012, 06:24 PM
runnin''s Avatar
Liked: 45
Yep, I'm workin' on it!
runnin' is offline
post #1398 of 1704 Old 02-17-2012, 08:52 PM
Face2's Avatar
Quoted: 334 Post(s)
Liked: 202
I went from a ST-500 and 3 channel chip amp to a Mini MC-5. I originally kept my ST-500 and planned on using it with my mains, with the Mini powering the center and rear surrounds. After going back and forth a few times, I decided the Mini was enough for my HT. If you have a large room, difficult to drive speakers(2ohm impedance dips), or very inefficient speakers, then you may want to consider the larger MC amps. Otherwise, the Mini does a very good job on it's own.
Face2 is offline
post #1399 of 1704 Old 02-17-2012, 09:53 PM
jtuttle's Avatar
Looking at MC7x500, paired with Integra DHC 80.3 and PSB Imagine Ts. Anyone tried this combo?
jtuttle is offline
post #1400 of 1704 Old 02-17-2012, 11:23 PM
cmryan821's Avatar
Quoted: 194 Post(s)
Liked: 59
I'd direct much more of your budget into speakers.
cmryan821 is online now
post #1401 of 1704 Old 02-18-2012, 11:21 AM
jtuttle's Avatar
My goal is home theater usage 95% of the time. Are you suggesting I need speakers that can handle more WPC?
jtuttle is offline
post #1402 of 1704 Old 02-20-2012, 10:27 AM
Adz523's Avatar
Thanks Mike. Let me know if you're ever interested in selling the unit. Looks like we live near each other too.
Adz
Adz523 is offline
post #1403 of 1704 Old 03-08-2012, 11:05 PM
N8DOGG's Avatar
Quoted: 967 Post(s)
Liked: 1041
I'm interested in a MC7 with 3 x 500 and 4 x 250's. If anyone is looking to sell, drop me a pm with a price.
thanks
N8DOGG is offline
post #1404 of 1704 Old 04-01-2012, 09:47 PM
h.rav's Avatar
has anyone bought the mini mINT?
h.rav is offline
post #1405 of 1704 Old 04-02-2012, 06:56 AM
Face2's Avatar
Quoted: 334 Post(s)
Liked: 202
Not yet, hopefully in the next month or two.
Face2 is offline
post #1406 of 1704 Old 04-08-2012, 06:57 AM
screener's Avatar
I'm looking to purchase a MC3 Mini.
Please PM if anyone is interested.
Kim
screener is offline
post #1407 of 1704 Old 04-09-2012, 03:38 PM
MSchu18's Avatar
Quoted: 166 Post(s)
Liked: 359
in for later
My Name is Nobody...
Klipsch x11i - Klipsch x20i - Oppo HA2
Pioneer SC85 - Bel Canto REF 500M
Klipsch La Scala II - Klipsch Cornwall/Crites/Aletheia Audio - Klipsch RC64II - SW-115
Wyred 4 Sound DAC2 DSDse - OPPO BDP-93
Samsung PN64D8000
MSchu18 is offline
post #1408 of 1704 Old 04-09-2012, 04:11 PM
Face2's Avatar
Quoted: 334 Post(s)
Liked: 202
Couldn't wait, just placed an order with my local dealer and should have one in the next week or two.
Face2 is offline
post #1409 of 1704 Old 04-10-2012, 07:43 AM
fishinbob's Avatar
Well I sucked it up and ordered a pair of SX-500s last night and now the monetary post-partums have begun as I await their arrival. You see, my thoughts are running toward the notion that my new amps may be a somewhat lateral move.
My current setup (6.1) is being driven by an Elite SC-07 receiver which will be my pre for sometime but the plan is to go to a HT bypass setup down the road, which is another justification for this move. I am not at all disappointed with the current sound, I'm just hoping that there is much more in store than just the additional wattage of the Wyreds. I'm curious to know if anyone has compared the sound or is using a similar setup?
The Wyreds will be driving my Salk Songtower RTs.
Who knows, if this works out maybe my Songcenter will get one too.
fishinbob is offline
post #1410 of 1704 Old 04-10-2012, 12:18 PM
MSchu18's Avatar
Quoted: 166 Post(s)
Liked: 359
My current setup (6.1) is being driven by an Elite SC-07 receiver which will be my pre for sometime but the plan is to go to a HT bypass setup down the road, which is another justification for this move. I am not at all dissapointed with the current sound, I'm just hoping that there is much more in store than just the additional wattage of the Wyreds. I'm curious to know if anyone has compared the sound or is using a similar setup?
I am in a similar situation... I am currently running an sc35 and I think I am not getting great sound out of it at or near max levels. I love ice and the blackness of it's floor so a pair of sx500's was my next choice. I will be curious if you could post a review when you get them in.
Samsung PN64D8000
MSchu18 is offline
Cambridge Soundworks Newton Series Mc500 Main Center Speaker Each
