Official Wyred 4 Sound Amp Thread - Page 54 - AVS Forum
post #1591 of 1606 Old 05-30-2014, 11:53 AM
gce
gce's Avatar
HELP...I really only want to enhance my 2 channel but they have so many options. I have a Marantz 7008 that does just fine with my 5.1 HT but I need more power for my fronts for 2 channel. So what would be the best solution for me, there mAMP's, SX Series, STmkII Series or should I move to the MC Series? I'm driving Polk RTi A7's. I want the best sounding amp's they have and something that will take some of the harshness out of the highs and tighten up the bass. Any recommendations?
gce is offline
post #1592 of 1606 Old 05-30-2014, 12:27 PM
MSchu18's Avatar
Quoted: 14 Post(s)
Liked: 129
http://www.icepower.dk/en/solutions/speaker/
Klipsch Image Ones
Klipsch x11i
Rega P5/Groovetracer/Denon DL-103R
Parks Audio Budgie Phono Pre/SUT
Pioneer SC35
Bel Canto REF 500M
Klipsch Cornwall/Crites/Aletheia Audio
Klisch RC64II
Klipsch SW-115
OPPO BDP-93
Samsung PN64D8000
MSchu18 is offline
post #1593 of 1606 Old 05-30-2014, 08:49 PM
Woof Woof's Avatar
Liked: 38
The third gen modules used in the mAmps and ST MkII power amps should sound warmer than the 2nd gen modules but I wouldn't class either as warm.
If you are finding your speakers a bit harsh, you might want to consider the following.
a. run them in for the recommended amount of time - my Thiel CS2.4 was nigh unlistenable for the first 100-200 hours.
b. place them far away from side walls and corners and back walls
c. use some carpet and or room treatment materials for first reflection points
d. change the amount of toe in - sometimes firing it straight (i.e. away from the years may result in a less harsh sound).
Woof Woof is offline
post #1594 of 1606 Old 05-31-2014, 06:37 AM
MSchu18's Avatar
Quoted: 14 Post(s)
Liked: 129
I agree about the third gen mAMPS... they are a significant step forward. also, keeping them on 24/7 gives them a thermal efficiency that helps keep the sound warm and consistent.
Klipsch Image Ones
Klipsch x11i
Pioneer SC35
Bel Canto REF 500M
Klisch RC64II
Klipsch SW-115
OPPO BDP-93
Samsung PN64D8000
MSchu18 is offline
post #1595 of 1606 Old 05-31-2014, 07:09 AM
Quoted: 107 Post(s)
Liked: 66
Hey guys,
My Wyred Mini MC has arrived....Sounds great so far. I'm curious, will the amp sound even better after the 300 hour break in?...or is that exaggerated...
Cheers!
Deckard97 is offline
post #1596 of 1606 Old 05-31-2014, 07:30 AM
MSchu18's Avatar
Quoted: 14 Post(s)
Liked: 129
I bought all my ICE units used, so really I can not say for sure if it's new. I tend to think there is exaggeration there, but I don't really know first hand.
I DO KNOW that you should keep them on though(speaking mainly about the power amps), they open up a little more if thermal balance is achieved/maintained.
Deckard97 likes this.
Klipsch Image Ones
Klipsch x11i
Pioneer SC35
Bel Canto REF 500M
Klisch RC64II
Klipsch SW-115
OPPO BDP-93
Samsung PN64D8000
MSchu18 is offline
post #1597 of 1606 Old 05-31-2014, 07:36 AM
Woof Woof's Avatar
Liked: 38
I don't have the mini MC but from what I recall there was no major changes in the sound on my ICEpower amps after the unit had been warmed up for a few days and kept on after wards.
post #1598 of 1606 Old 06-03-2014, 08:59 AM
extract1's Avatar
I recently bought a pair of Wyred 4 Sound SX-1000 mono blocks and a NAD M51 to use as a DAC and Pre Amp. How do i connect both monoblocks to the one trigger output on the NAD?. Can i safely use a 3.5mm splitter cable like this one
http://www.ebay.com.au/itm/3-5mm-Male-to-2-Dual-3-5mm-Female-Mono-Splitter-Adapter-/170614720552?pt=AU_Television_Accessories&hash=item27b96e0828
or
http://www.ebay.com.au/itm/3-5mm-Mono-Male-to-Dual-Mono-Female-IR-Audio-Cable-splitter-Y-adaptor-/330921516967?pt=AU_Television_Accessories&hash=item4d0c759fa7
extract1 is offline
post #1599 of 1606 Old 06-03-2014, 09:20 AM
a1usedcomp's Avatar
Liked: 25
or
. On my mamps i run a trigger from one amp to the other
Preamp: NOS Valves NBS Preamplifier
Selah Tempestas
BMC Pure Dac - Mac Mini
VPI Classic 2
a1usedcomp is offline
post #1600 of 1606 Old 06-03-2014, 09:30 AM
extract1's Avatar
On the mAMP's, it has both input and output trigger slots allowing you to daisy chain them where as on the SX1000 it only has 12v input.
extract1 is offline
post #1601 of 1606 Old 06-03-2014, 11:17 AM
a1usedcomp's Avatar
Liked: 25
I did not know that , I have just been leaving mine on 24/7
Selah Tempestas
VPI Classic 2
post #1602 of 1606 Old 06-03-2014, 05:23 PM
gce
gce's Avatar
So how much will the "WBT binding posts and TCX Kimber wire" add to the mAMP's sound quality?
gce is offline
post #1603 of 1606 Old 06-03-2014, 07:27 PM
Woof Woof's Avatar
Liked: 38
or
I've heard cases where some owners of the Marantz AV8801 had their trigger outputs fried because there was too much current drawn.
I think Emotiva sells a trigger switch which can boost the power if you are worried about damming your NAD.
Personally if this is for stereo use, I'd just leave the amps on 24/7. The ICE modules sound better after a few days of use, if they are powered on from cold.
post #1604 of 1606 Old 06-14-2014, 08:07 AM
Quoted: 107 Post(s)
Liked: 66
Smile
Just an update....I have been using the mini MC for a couple of weeks now, and am yet to turn it off. The break in time took less than 1 week....more than satisfied so far with Wyred gear.
I was using a 200x5 Rotel 1095....which sounded great, I must admit. But the wyred amp is better in almost every aspect of sound reproduction....
No more upgrades for another couple years....
post #1605 of 1606 Old 06-14-2014, 08:14 AM
MSchu18's Avatar
Quoted: 14 Post(s)
Liked: 129
good for you...
should have gone with Bel Canto
Klipsch Image Ones
Klipsch x11i
Pioneer SC35
Bel Canto REF 500M
Klisch RC64II
Klipsch SW-115
OPPO BDP-93
Samsung PN64D8000
MSchu18 is offline
post #1606 of 1606 Old 06-18-2014, 07:19 AM
Quoted: 107 Post(s)
Liked: 66
good for you...
Naa,,..I think we should have went with D-sonic
Cambridge Soundworks Newton Series Mc500 Main Center Speaker Each
