Official Denon AVP-A1HD/AVP-A1HDCI and POA-A1HD/POA-A1HDCI owners thread. - Page 235 - AVS Forum | Home Theater Discussions And Reviews
 97Likes
post #7021 of 26950 Old 10-18-2008, 12:53 PM
QueueCumber's Avatar
Quoted: 70 Post(s)
Liked: 38
I'm having an issue with component out through the Denon AVP-A1HDCI. If I have the signal going out through component outputs and the HDMI outputs at the same time to the same projector, the component outputs won't work correctly. The signal goes in and out.
If I connect a second HDMI cable to my backup TV in the equipment closet and turn it on, I can get the component signal to stop switching on and off. If I switch off the TV, the component signal starts switching on and off again.
If I disconnect the HDMI to the projector and just connect through the component cables, it works fine.
Something is going wrong when trying to run a signal to the same device through two cables. This happened with HDMI as well when running both monitor outputs to the same projector as well.
Does anyone know a solution for this problem? I would like to be able to turn off the other TV so I'm not wasting energy when I watch cable on the projector...
I know it is not any of my other equipment because I tried the projector and cable box out together separately using the same cables and it worked perfectly fine. It is only when I pass it through the Denon with both the HDMI and the Components hooked up that I have the issue. This leads me to believe there is some kind of grounding issue involved...
QueueCumber is offline
post #7022 of 26950 Old 10-18-2008, 01:04 PM
GlenC's Avatar
Why not just use HDMI on the projector since that works? You could be having HDCP issues when trying to use the component signal.
Glen Carter<br />
Home Theater Calibration<br />
GlenC is offline
post #7023 of 26950 Old 10-18-2008, 01:27 PM
Quoted: 70 Post(s)
Liked: 38
Now what would make you think this is related to HDCP at all? I'm passing it purely analog through component cables... HDCP isn't an issue over component cables, and it works fine if I remove the HDMI cable and/or plug in a second monitor to a second device that is powered on. All things considered, a HDCP issue doesn't make sense in this situation at all as far as I can tell... The cable box only has the component out hooked up. If there is a HDCP issue with the Denon, then why does it work once a second monitor is connected via HDMI, but not when only one is hooked up? If it is the projector, then how come it works under these circumstances as well?
There are a few reasons I can't convert to HDMI only. One is that not all my devices have HDMI out, and they suffer from the same exact issue when I try to use them. The second is, this particular device doesn't handle the distance from the preprocessor to the projector well, so HDMI sparkles appear on the screen every now and then. I don't have this problem with HDMI sparkles any other device, just the cable box. I can't use my Xbox360 without component cables ATM, so I still need component hookups at this time.
In any case, even if I got rid of the Xbox 360 with one of those HDMI add-on cables, I still have the problems with my cable box sending a clean signal to the projector, which currently requires me to unplug the connection and manually mess with it to get it working correctly again...
post #7024 of 26950 Old 10-18-2008, 01:29 PM
drmanny's Avatar
Originally Posted by progprog View Post
Can the HDMI Audio Out option be set for each HDMi output? If not, I can see where this would be a big problem. As you mentioned, if Manny sets HDMI=TV and it applies to both outputs, he'll get audio over on his second setup, and it won't hurt his projector. But wouldn't he lose audio in his main system? I.e., it would no longer be sent to his amp in that room?
The more I think about it, I don't see how this dual-HDMI feature could work very well if you can't set this option individually.
EXACTLY, if i set Hdmi=TV i lose audio from amp and vice versa.
why have 2 hdmi outs if they cannot be fully utilised.
AVP doesnt have main RCA audio outs, which if present i could send to 2nd XBR setup. even then hdmi sources will not output from analog RCA
if i have to set hdmi=tv then why spend $7500 on AVP pre amp
any ideas ???
Manny
drmanny is offline
post #7025 of 26950 Old 10-18-2008, 01:30 PM
Quoted: 70 Post(s)
Liked: 38
The other odd thing is, it will send the signal to the second Denon HDMI monitor and the TV displays the signal no problems at the same time that the projector displays the signal no problem with the component output from the same Denon.
post #7026 of 26950 Old 10-18-2008, 01:44 PM
Quoted: 70 Post(s)
Liked: 38
Also, the component setup works fine with the HDMI output to the same projector unplugged even while the HDMI to the other TV is still plugged in...
post #7027 of 26950 Old 10-18-2008, 02:12 PM
GlenC's Avatar
Now what would make you think this is related to HDCP at all? I'm passing it purely analog through component cables... HDCP isn't an issue over component cables, and it works fine if I remove the HDMI cable and/or plug in a second monitor to a second device that is powered on. ........
I don't know your complete connection setup, HDMI in >> Component out = potential HDCP issues.......
Sparkles is a classic HDMI cable problem. Replace the cable with a better one.
Glen Carter<br />
GlenC is offline
post #7028 of 26950 Old 10-18-2008, 02:20 PM
Quoted: 70 Post(s)
Liked: 38
It is component connection from the cable box to the Denon receiver, and then a component connection from the Denon receiver to the projector. Thus, HDCP is not the issue...
The HDMI line is not being used for the cable box output, but it is plugged into the projector because it is used for other devices. Having it plugged in at all into the same projector, even though it is not being used, is causing the issues I described, unless I plug in a second HDMI cable to a second TV. In that case, everything works.
Not possible ATM, it is run through the ceiling and I'm not planning on ripping holes in the ceiling right now. All of my other devices run completely problem free over that same HDMI connection, only the cable box has issues. Those issues go away if I unplug the HDMI cable from the projector and ground it on my finger and then plug it back in...
post #7029 of 26950 Old 10-18-2008, 02:43 PM
JonFo's Avatar
Quoted: 88 Post(s)
Liked: 78
Ah, cable box = possible ground loop on the video circuits (since you ahve two cables to the same device)
Unplug the cable from the cable box and see if you have the problem.
Just something to try.
Jonathan
My System
JonFo is offline
post #7030 of 26950 Old 10-18-2008, 02:45 PM
Quoted: 70 Post(s)
Liked: 38
I only have the component cable coming out of the cable box. The projector has two cables going to it from the Denon AVP though: the component and HDMI cables.
post #7031 of 26950 Old 10-18-2008, 02:53 PM
Quoted: 70 Post(s)
Liked: 38
I think it is some kind of grounding issue, but I'm not sure what options I have to deal with it. Any suggestions?
When I went back to try your suggestion and plugged everything in, it works now without the monitor HDMI TV having to be on. I think it is grounded now, but I'm sure it will unground or a charge will build up again when I turn things on and off at some point...
post #7032 of 26950 Old 10-18-2008, 03:21 PM
GlenC's Avatar
Yes, I agree, Cable company ground loop. Read more hereInstall a ground loop isolation device on the input cable to the cable box.
Glen Carter<br />
GlenC is offline
post #7033 of 26950 Old 10-18-2008, 03:30 PM
Quoted: 70 Post(s)
Liked: 38
Great thanks.
Do either of you know if there is a solution for ground loop problems over HDMI?
post #7034 of 26950 Old 10-18-2008, 04:22 PM
rnrgagne's Avatar
Quoted: 65 Post(s)
Liked: 65
Originally Posted by danielo View Post
Did i make a mistake again ? The poa is stable for 4ohm speakers when bridged (so stable in 2ohms). If his speakers go below that on large parts of the freq. range than it can ask too much no?
Or do i mis something again, please correct me.
Daniel.
I don't know for sure, but I thought that bridging should be able to handle lower impedance loads better than passive bi-amping, which is why I said I don't understand.
Current Gear: Anthem AVM60, D-Sonic 3500/7, Oppo UDP-203, PS Audio Nuwave Phono Pre, Technics SL1210 w/ Denon DL103, Dune Duo 4K, LG Oled55e6, Paradigm Sig. S6 & C3 v.3's, Monitor ADP's, Velodyne SPLR1200.
rnrgagne is offline
post #7035 of 26950 Old 10-18-2008, 04:30 PM
JonFo's Avatar
Quoted: 88 Post(s)
Liked: 78
Great thanks.
First, try an isolation transformer on the Cable TV feed into your cable box.
The Ferrari solution is this: http://www.jensentransformers.com/datashts/vrd1ff.pdf
But RadioShack also has cheaper versions.
If you want to solve both your long run for HDMI as well as eliminate any grounding questions on that line, then Geffen has this product: http://www.gefen.com/kvm/dproduct.jsp?prod_id=7986 that uses fiber for up to 1,000' extension
or this one: http://www.gefen.com/kvm/dproduct.jsp?prod_id=3872
Which goes up to 200' over twin Cat5e cables. The Cat5's are opto-isolated which breaks any grounds.
Also look into any amplified HDMI long-run cable that features opto-isolation.
Jonathan
My System
JonFo is offline
post #7036 of 26950 Old 10-18-2008, 04:59 PM
Aesculus's Avatar
Quoted: 18 Post(s)
I am confused too. Why do you have both HDMI and Component from the AVP to the projector? Since all of your sources are fed into the AVP anyway, why not just have the HDMI only go to the projector? It can handle all of the resolutions you need.
Chris
Aesculus is offline
post #7037 of 26950 Old 10-18-2008, 05:55 PM
progprog's Avatar
Quoted: 94 Post(s)
Liked: 72
I'm not entirely sure what his requirements are, but I know that THX recommends keeping the format the same from source to monitor, i.e., {source}>component >{AVP}>component>{monitor}. My own experience bears this out. Component from a source and upconverted in the AVP, then out HDMI to my TV does not look as good as HDMI all the way or component all the way.
progprog is offline
post #7038 of 26950 Old 10-18-2008, 06:39 PM
Aesculus's Avatar
Quoted: 18 Post(s)
I have been running component to HDMI via the AVP and it looks good to me.
Chris
Aesculus is offline
post #7039 of 26950 Old 10-18-2008, 06:50 PM
progprog's Avatar
Quoted: 94 Post(s)
Liked: 72
I'm not saying it looks bad; I just found that it seem to look a little better without that upconversion. To my eyes, there seemed to be a slight loss of contrast and color saturation with component-to-HDMI upconversion. Could well have been a function of my equipment, so I don't want to over-generalize, but THX does always include that recommendation.
progprog is offline
post #7040 of 26950 Old 10-18-2008, 06:57 PM
Quoted: 70 Post(s)
Liked: 38
Like I said in a previous post, I get noticable line noise on the HDMI line when outputting the cable signal over it. Sadly I'm getting it on the component cables also... So, my only solutions at this point seem to be some kind of grounding, or a different cable/satellite provider.
post #7041 of 26950 Old 10-18-2008, 08:51 PM
progprog's Avatar
Quoted: 94 Post(s)
Liked: 72
Is there a grounding block on the incoming line?
progprog is offline
post #7042 of 26950 Old 10-18-2008, 09:58 PM
Waboman's Avatar
Quoted: 5103 Post(s)
Liked: 11769
I just watched the Speed Racer blu-ray. I feel like I just spent 2 hours in a pinball machine. I don't know if you guys have seen it, but it's like a Pixar movie, only not nearly as good. I need to take some Dramamine now.
Waboman is online now
post #7043 of 26950 Old 10-19-2008, 12:12 AM - Thread Starter
ohyeah32's Avatar
Quoted: 68 Post(s)
Liked: 43
Interesting that you mention Speed Racer, as I just received it from Netflix. Since your thoughts on movies many times mirror mine, let's see how I fare.
Seth
ohyeah32 is offline
post #7044 of 26950 Old 10-19-2008, 12:17 AM
Waboman's Avatar
Liked: 11769
Seth, my amigo, all I'm going to say is, that's 2 hours and 15 minutes of my life I will never get back. I don't want to influence your Speed Racer enjoyment (oxymoron) but it could quite possibly be the worst movie I have seen this year.
post #7045 of 26950 Old 10-19-2008, 04:45 AM
Quoted: 70 Post(s)
Liked: 38
No. Any recommendations on a cheap, but robust solution for the incoming line? I assume you mean the RG cable that is going into the cablebox?
post #7046 of 26950 Old 10-19-2008, 04:59 AM
Franin's Avatar
Quoted: 2401 Post(s)
Liked: 1508
Guys I have 2 fathoms which are connected to a power conditioner in which also has a built in surge protector. Now today we had a brownout, nothing was powered on beautiful day and guess what they don't even work, everything else plugged in that is the DVD players work fine. I tried different power points everything else fine. $11000 wasted man im very upset how subs of this quality can be affected like this. Is there a reset switch? Any ideas?
_________________________
Franin is offline
post #7047 of 26950 Old 10-19-2008, 05:26 AM
danielo's Avatar
Quoted: 24 Post(s)
Liked: 53
Sorry to hear that, checked if they have fuses ?
Lots of bad luck going around the last few days...
Daniel.
for men to evolve we have to upgrade
danielo is offline
post #7048 of 26950 Old 10-19-2008, 05:30 AM
Franin's Avatar
Liked: 1508
Daniel.
Daniel, they are sealed. I just can't understand how that can happen. I've tried to google and it seems to me im like the only one to have this problem. Im very annoyed, im still puzzled how this can happen.Everything else works. My focals never had this problem.
Franin is offline
post #7049 of 26950 Old 10-19-2008, 05:58 AM
QuadMersed in bass!
giomania's Avatar
Quoted: 16 Post(s)
Liked: 36
Frank, did the power conditioner "trip" and requires a reset?
Mark
giomania is offline
post #7050 of 26950 Old 10-19-2008, 06:03 AM
Franin's Avatar
Liked: 1508
Mark
I've done a power reset all the other players are working everything else work.I've even tried different power outlets. 2 subs don't work. I tried to google there is literally no info on reset switches, nothing.I tell you im not impressed, I cannot believe how 2 subs died.
there must be someone who knows.
Franin is offline
Denon Avp A1hdci Ultra Reference A V Network Streaming Preamplifier , Denon , Component Preamplifiers
