Official Denon AVP-A1HD/AVP-A1HDCI and POA-A1HD/POA-A1HDCI owners thread. - Page 50 - AVS Forum | Home Theater Discussions And Reviews
 89Likes
Old 05-05-2008, 04:03 PM
pentium7's Avatar
Quoted: 20 Post(s)
Originally Posted by syswei View Post
Please excuse my ignorance as well (I don't have a PJ yet), but if I don't get an anamorphic lens, then do I get the same dimension images, but at lower resolution, with any image other than ______ aspect ratio (fill in the blank) not using all the pixels of the PJ?
Thanks in advance.
You will need the three items I outlined in the previous post
1. PJ that stretches or a processor
2. Anamorphic lens
3. Scope size screen
You could use ZOOM but that isn't too desireable, however much cheaper.
AVS has dedicated 2.35:1 section and CIH
pentium7 is offline
Old 05-05-2008, 04:09 PM
pentium7's Avatar
Quoted: 20 Post(s)
Originally Posted by progprog View Post
Thanks, Pentium. Your explanation is not only clear and concise, but apparently effective, as this now sounds pretty cool and well...I want it! Just what I need, another pricey item on my wish list.
I won't ask you to indulge me here with all the technical details- I'll read up on it elsewhere. But why is it a problem that you need the three things to get CIH? The screen sounds easy enough, though a nice masking system no doubt adds lots of $$. For the anamorphic lens and projector that can do it, is it a cost or availability issue? (As I recall, you got a JVC projector, right? Assuming you resolved the heat issue, are you pretty happy with it?) If you've taken any pics of your screen set-up, I'd love to see them. Thanks again for the post- it was really helpful.
A true electric with controllable RS232 or IR masking is quite expensive that is why there is a dedicated DIY thread on screen masking.
Screen size ordering is simple, JVC RS2 is by far the best PJ right now for the cost it does do the verticle stretch needed for 2.35:1 image. Anamorphic lens is easy to come by but range in pricing for quality but I'd recommend the new UH440/480 Panamorph best lens for the money to go higher end is 2x-3x the cost, then you can get a motorized sled or manual sled to move the lens in and out of place.
Heat issue is due to my office having too much computer equipment and laser printer generating heat and it rising, I have solved it with using the dedicated room A/C set to fan high without the compressor turned on. I also added some cooling fans above the RS2 that helped but isn't always enough to ensure it is cool enough, the fan blowing across the room is and it is ultra quiet my computers are actually louder. All of which can't be heard in the main viewing room.
I need to take new pics that show my screen masking done soon
pentium7 is offline
Old 05-05-2008, 06:06 PM
CIH USER
Franin's Avatar
Quoted: 2230 Post(s)
Liked: 1344
Very true. My apologies. Somebody mentioned it and I was probably the one that started asking all the questions.
yeah who mentioned that oops!
_________________________
Franin is online now
Old 05-06-2008, 06:35 AM
cinemike's Avatar
Could you please explain to me why the same company new line released Rush Hour 3 7.1 dts hd master and it works with 5.1.I Cant see how Denon can process that but the Golden Compass it cannot.
Just got an email from Denon regarding this issue:
"The issue is the way the disc was authored. We are currently working to get a fix for this on our products."
"It has been confirmed that it is an issue with the disc in 5.1. It will play fine in 7.1. We are going to report the issue to Japan. Keep checking the web site for any updates."
It actually won't matter for me anymore since I'm going to 7.1 from 5.1 today with my new rear speakers finally mounted!
cinemike is offline
Old 05-06-2008, 07:33 AM
CIH USER
Franin's Avatar
Liked: 1344
So is it just Denon? Filmixer said it not unique to Denon.
Old 05-06-2008, 10:06 AM
CIH USER
Franin's Avatar
Liked: 1344
Just finished watching the posideon and amazing.The AVP really handles it well.
Old 05-06-2008, 02:47 PM
thebland's Avatar
Quoted: 1519 Post(s)
Liked: 869
You just had to drop in and make us drool, didn't ya Jeff?? I'm glad you did, as that's a pretty sweet set-up you've got there. I actually browsed through the other thread last night, trying to learn more about this, and saw your theater and Art's. Do you both use Stewart screens and masking systems? I'm obviously just getting my feet wet with this and I'm trying to discern who makes what and which companies make the good stuff.
Yes, the screen is the Stewart Vistascope. It is RS-232 controlled. The screen material is a Stewart Microperf X2 1.3 Ultramatte. 14' wide.
Thanks for the all the complements guys... I do appreciate them.
Goodbye to a great audio and video genius and writer... JOHN GANNON. I enjoyed your friendship, wit and a nice long run we took around Indianapolis at CEDIA years back... and for buying my Runco 980 Ultra years back... you saved my ass! Rest in peace.
thebland is offline
Old 05-06-2008, 06:05 PM
bschaen's Avatar
is there a recall button or display button on either remote?
bschaen is offline
Old 05-06-2008, 06:07 PM
CIH USER
Franin's Avatar
Liked: 1344
And well deserved mate.I went to your site to see the construction and absloulety amazing.It's good idea for anyone looking at building a great HT as it gives you an idea on how it all comes together.
Old 05-06-2008, 11:18 PM
progprog's Avatar
On the primary remote, there's a button immediately above "volume up" that's labeled RTN, with DISP as the secondary label. A real frustration with this remote is that so many of the buttons are function-dependent, but the labels are not always intuitive for each situation. Many here have mentioned that they use thrid-party remotes, and for good reason.
progprog is offline
Old 05-07-2008, 01:05 AM
CIH USER
Franin's Avatar
Liked: 1344
I use the Philips pronto Tsu 9600 with the extender but I have to say the remote on the right is so much better than the remote on the left.
Old 05-07-2008, 04:38 AM
MC Maniac's Avatar
I have 4 different players and presently am doing lots of evaluating between them..
Is there a simple way to toggle between stereo and say Mch input with DPLiix applied..??
John
MC Maniac is offline
Old 05-07-2008, 08:23 AM
thebishman's Avatar
Quoted: 198 Post(s)
Liked: 132
If anyone in the USA is looking for a AVP-A1HD but are having trouble finding one locally, and with a decent discount, my local Denon dealer might be able to help. I've bought from him for years and have never had a bad experience. Highly recommended. PM me for contact info if interested.
Bish
thebishman is offline
Old 05-07-2008, 08:34 AM
cinemike's Avatar
2. Anamorphic lens
Do any Denon products support Vertical Stretch? I guess the AVP does not? How about the Denon 2500 blu-ray transport?
I have a JVC RS2 and Panamorph lens and am trying to find a way to make the RS2 go Vertical Stretch with one push of a remote button without having to go through its menu. Any ideas?
cinemike is offline
Old 05-07-2008, 09:41 AM
nethomas's Avatar
I have set my POA to bridge for my RT, Center and LT. channels. I am an Audyssey Pro installer. I discovered something yesterday which will be of interest to those of you with similar setup. The Bridge mode has you connect to the "posititve" post of the two amp modules. When you set up and run the Audyssey, it will tell you that your Rt, center and lt. speakers are out of phase. They aren't, just go on and set up as you normally would.
gthomas
nethomas is offline
Old 05-07-2008, 10:01 AM
progprog's Avatar
I don't use those Quick Select buttons on the front- can you apply parameters along with inputs on those? If that's not an option, I use a programmable remote and I'd make a temporary page with my own four "quick selects" that would have the inputs and options I want.
progprog is offline
Old 05-07-2008, 10:13 AM
progprog's Avatar
In Pentium's list, there is no requirement that the processor be able to stretch the image, as long as the PJ does it. If you have the screen already, it sounds like you have everything you need. Pentium uses the RS2 as well and he says it works great. I'm sure he'll weigh in and let you know how his set-up makes it happen.
progprog is offline
Old 05-07-2008, 10:40 AM
MC Maniac's Avatar
these appear to just be a way to select your input on the front instead of using the remote..so doubt they could store different parameters..
ok..yeah guess I could set up other inputs with the alternative DSP mode - on my former Lexicon remote there were seperate buttons marked '2CH" or "DPLii", so was simple to toggle..
Like most things, it will take some time to get used to the way to navigate thru this preamp, but I'm sure it will eventually be quick to make some setting change..and without having to turn on your projector..
John
Old 05-07-2008, 10:44 AM
MarkB's Avatar
It did not do this on mine. Although both sets are marked +, they are not actually +, they are HOT and COLD. Are you sure you have HOT going to + and COLD going to - speaker terminals?
MarkB is offline
Old 05-07-2008, 10:50 AM
progprog's Avatar
Have you tried the web controller?
progprog is offline
Old 05-07-2008, 11:37 AM
nethomas's Avatar
Actually I set them according to the diagram in the manual, but I'll double check tonight.
gthomas
nethomas is offline
Old 05-07-2008, 11:48 AM
stenvik's Avatar
What is soundstyle in POA compared to hegel H4SE? Did just read a magazine that has tested avp and poa they said POA sounded like japanese style... In the midrange... when listening to stereo mode
stenvik is offline
Old 05-07-2008, 12:11 PM
bschaen's Avatar
i saw that button but pushing it does nothing at all
bschaen is offline
Old 05-07-2008, 12:13 PM
nethomas's Avatar
What is Japanese style midrange? Any thoughts.
gthomas
nethomas is offline
Old 05-07-2008, 12:16 PM
progprog's Avatar
What source are you trying to control, and what are you trying to do? As I mentioned, most of the buttons have functions that change according to the source/operation you are controlling.
progprog is offline
Old 05-07-2008, 12:25 PM
progprog's Avatar
John, I just looked at the manual and it appears those Quick Select buttons can do what you need. Apparently, you can select input source, input mode, surround mode, room EQ settings, and volume for each of the three buttons. That's seems pretty comprehensive. In fact, I'm glad I discovered that as I can see other handy applications aside from the testing you're currently doing.
progprog is offline
Old 05-07-2008, 12:31 PM
zeejayzee's Avatar
What article? Have not seen any magazine article yet on either bit of kit...
zeejayzee is offline
Old 05-07-2008, 01:40 PM
QuadMersed in bass!
giomania's Avatar
Quoted: 14 Post(s)
Liked: 35
giomania is offline
Old 05-07-2008, 01:49 PM
bschaen's Avatar
i'm just looking for recall or display
like what shows when you switch sources on screen
bschaen is offline
Old 05-07-2008, 02:29 PM
progprog's Avatar
Originally Posted by giomania View Post
How do you like my new avatar?
Mark
I recently made a stylized version of that image for use on my remote. I'd thought of using it as an avatar, but looks like I missed the boat!
progprog is offline
Denon Avp A1hdci Ultra Reference A V Network Streaming Preamplifier , Denon , Component Preamplifiers
