Official Denon AVP-A1HD/AVP-A1HDCI and POA-A1HD/POA-A1HDCI owners thread. - Page 570 - AVS Forum | Home Theater Discussions And Reviews
 89Likes
Old 07-02-2010, 01:11 PM
rnrgagne's Avatar
Quoted: 49 Post(s)
Liked: 56
Originally Posted by gimp View Post
double, triple checked. The AVP has no problem recognizing bitstreamed TrueHD and STS-HD MA from my OPPO BDP-83.
Well then it's sounding like an HDCP issue. Have you checked your PH unit with anything else that can do those codecs, to be sure it is bitstreaming or that you did burn the codecs to those discs? The only other thing I can think of is if you have to do like a standard blu ray movie and select the codec output option in the disc's set up menu, but you more than likely already tried that...
rnrgagne is offline
Old 07-02-2010, 01:12 PM
rnrgagne's Avatar
Quoted: 49 Post(s)
Liked: 56
Originally Posted by progprog View Post
Comments? Hmm. It's a clumsy, expensive POS. Nothing works right on it. I think I'll sell it and get something that works exactly the way I want, right out of the box, without having to read the manual.
Amen.
rnrgagne is offline
Old 07-02-2010, 06:52 PM
CIH USER
Franin's Avatar
Quoted: 2178 Post(s)
Liked: 1300
I've never used the front panel scaler button. In fact, I very seldom open the front panel. If you need different configurations on one input, I'd suggest you set up a couple macros for it, or maybe use two of the Quick Select buttons.
Do we have a front panel??
_________________________
Franin is offline
Old 07-02-2010, 06:58 PM
CIH USER
Franin's Avatar
Liked: 1300
Has Robert been directed to the wiki site? Lots of hints and tips for the avp.
Franin is offline
Old 07-02-2010, 09:44 PM
progprog's Avatar
Apparently....
progprog is offline
Old 07-02-2010, 09:54 PM
Waboman's Avatar
Quoted: 4543 Post(s)
Liked: 10471
And here I thought it was just the fancy champagne-colored ones that had a front panel.
Waboman is online now
Old 07-03-2010, 03:07 PM
gimp's Avatar
HDCP seems to handshake ok. I can bitstream DD and DTS ok as well. Unfortunately I don't have any other processors to try. Thanks for the suggestions.
gimp is offline
Old 07-04-2010, 07:35 AM
danielo's Avatar
Quoted: 24 Post(s)
Liked: 53
Hmm i never noticed this, was it installed as part of the last software firmware update ? .
Daniel.
for men to evolve we have to upgrade
danielo is offline
Old 07-04-2010, 07:37 AM
danielo's Avatar
Quoted: 24 Post(s)
Liked: 53
It almost sounds like its limited as with spdif to the old formats (bandwidth) or pcm. Maybe the source is downmixing or something ?
Daniel.
danielo is offline
Old 07-04-2010, 07:45 AM
danielo's Avatar
Quoted: 24 Post(s)
Liked: 53
Originally Posted by PLA View Post
For those of you wondering if we will be able to upgrade to 1.4a, this may be a bigger concern:
http://www.audioholics.com/news/indu...i-dead-hdbaset
I don't think this will happen, it seems to me that they indeed reuse the cables but that is not enough. The more inportant parts will the switches and protocols. In time they will all be ip based there is no room for a second network in our homes.
Remember : The internet will take over everything, all networks will become the internet. There is simple no reason to have multiple networks the cost/value simple will make multiple systems a hard sell.
Daniel.
danielo is offline
Old 07-04-2010, 10:14 AM
robert5545's Avatar
I tried to use video select to listen to some music CD's, while watching the Wimbledon tennis so I selected my HDMI connected Direct TV receiver while using the CD input and got no video.
What I am doing wrong?
It seems it should work.
robert5545 is offline
Old 07-04-2010, 10:47 AM
robert5545's Avatar
I am not getting any audio playing SACD's outputting from a digital connection to the receiver.
The player shows the SACD playing but no audio coming from the speakers.
Is it possible to get SACD audio to play using a digital connection, or must I input to the Ext In Inputs on the AVP.
Old 07-04-2010, 10:54 AM
progprog's Avatar
See p.45 in the manual: It is not possible to select HDMI input signals.
progprog is offline
Old 07-04-2010, 02:32 PM
Joe C5's Avatar
Check all your settings on both the player and the Denon. It does work (at least in some cases). I have used a PS3, Denon 3910, and 3930. The PS3 defaults to converting the SACD to LPCM though. I believe (but am not sure - been a while) that the 3910 used HDMI, though I am using Denon Link for the 3930. I also used to use an Oppo, but gave up on that because the SACD was horrible compared to the PS3 (this may have been before I got the AVP - not all implementations of SACD to PCM are good).
Joe C5 is offline
Old 07-04-2010, 03:39 PM
robert5545's Avatar
I saw that so how would you use these feature, and for what. Just about everything is video connected HDMI.
What was the idea behind this feature?
Old 07-04-2010, 04:53 PM
Joe C5's Avatar
http://www.avsforum.com/avs-vb/showt...1#post11537571
Joe C5 is offline
Old 07-04-2010, 06:28 PM
PLA
PLA's Avatar
Are you using denon link? If so, check whether HDMI settings in your player is set to SACD out, that may be the issue.
PLA is offline
Old 07-05-2010, 09:15 AM
rnrgagne's Avatar
Quoted: 49 Post(s)
Liked: 56
Just about everything HDMI is ruled by HDCP to some degree, most of the issues and limitations arising from HDMI have something to do with that. It's all about protecting against content pirating. The older formats like component don't have any such limitations which is why those signals can be sent anywhere. So the trick to doing what you want is to do an analog connection of your video source to an unused AVP input to watch the video feed while listening to music.
rnrgagne is offline
Old 07-05-2010, 09:22 AM
rnrgagne's Avatar
Quoted: 49 Post(s)
Liked: 56
Again, as suggested many times here read your manuals!
The AVP will play any format you can send it over the connection you're using, if the AVP isn't playing it, it's not getting it from the source (or connection, i.e., you can't send DTS HD MA over toslink.)
The only exception right now might be a 3D signal.
rnrgagne is offline
Old 07-07-2010, 10:15 AM
QuadMersed in bass!
giomania's Avatar
Quoted: 14 Post(s)
Liked: 35
I have been following the discussion of a new Audyssey technology coming out in some new products: MultEQ XT32
The new Onkyo 5008/3008 receivers series range has been officially announced here (in Europe), and they feature MultEQ XT32.
What is MultEQ XT32 exactly? There has been speculation over on the Audyssey thread that it doubles the filter resolution of the satellite channels, going from 16x to 32x, which matches the capability of the stand-alone Audyssey Sound Equalizer (SEQ).
There has been no speculation on a possible increase to the subwoofer channel filter resolution, which is currently 128x for MultEQ XT and the SEQ. The Audyssey Sub EQ and the SVS AS-EQ1 stand-alone devices feature 512x subwoofer filter resolution.
We have not yet received confirmation from Audyssey, but 32x satellite filter resolution is a good bet, in my opinion.
So, my question is if anyone thinks the AVP has the available DSP resources to implement this new Audyssey technology. I realize this would be highly speculative at this stage of the game, but that is half the fun!
Mark
giomania is offline
Old 07-07-2010, 11:42 AM
progprog's Avatar
Okay, Mark, I apologize off the top for being so dense about this, but I've just never really been into Audyssey so I haven't educated myself yet. Could you briefly explain what channel "filter resolution" means? I can tell from your post that more (32x vs 16x) is better, and I'm presuming that somehow makes Audyssey more accurate?
progprog is offline
Old 07-07-2010, 11:56 AM
QuadMersed in bass!
giomania's Avatar
Quoted: 14 Post(s)
Liked: 35
Yes, it allows the filters more "resolution" to be applied to the acoustics problems measured in the room. Resolution is the term used on the Audyssey web site. I think it means there are more FIR filters used for each channel, but I could be wrong on that.
Mark
giomania is offline
Old 07-07-2010, 12:15 PM
progprog's Avatar
Thanks. One day, I'll learn all this stuff!
progprog is offline
Old 07-07-2010, 12:17 PM
CIH USER
Franin's Avatar
Liked: 1300
There has been no speculation on a possible increase to the subwoofer channel filter resolution, which is currently 128x for MultEQ XT and the SEQ. The Audyssey Sub EQ and the SVS AS-EQ1 stand-alone devices feature 256x subwoofer filter resolution.
Mark
I was under the impression with the last update the SVS AS-EQ 1 was now at 512x resolution, correct me if I'm wrong.
As much it would be nice I cannot see it happening. I don't think the AVP will endure many more upgrades. There has been talk about the height channel upgrade but yet to be confirmed.
Franin is offline
Old 07-07-2010, 01:45 PM
QuadMersed in bass!
giomania's Avatar
Quoted: 14 Post(s)
Liked: 35
You are correct, sir! I will edit my post to correct that error.
Mark
giomania is offline
Old 07-07-2010, 02:16 PM
CIH USER
Franin's Avatar
Liked: 1300
Actually mark that new audyssey might be the answer for us European owners as we don't get the pro capabilities as you guys do with your AVP. Who knows we might see something
Franin is offline
Old 07-07-2010, 04:06 PM
danielo's Avatar
Quoted: 24 Post(s)
Liked: 53
Mark
I think it will be possible, the question is will it be for all modes and if not will they bother doing it in a 'mixed' solution.
There are 2 things that can be 'slow', first is the calculation that needs to be done. Only question there is are we will too wait longer on each step (if run on the avp and not externally like with pro). Does it have enough room to store the bigger settings.
The second is runtime, well we know the avp unlike other models can do all the modes mixed (hd decoding, thx modes and audyssey) on all 12 channels. They could drop some of these demands if decoding is too much. For example only apply the extra filters when in 2.x (so max 5 channels) mode saving cpu power on the 7 left. Or they might (probably not) reuse the other dsp to do some of the work and just disallow these new level for THX modes. This last is probably tricky since the 3 dsp's seem to have been assigned for different tasks.
It does make the possible October upgrade very interesting.
Daniel.
danielo is offline
Old 07-08-2010, 12:57 AM
Johnla's Avatar
Quoted: 39 Post(s)
Liked: 30
I think Chris from Audyssey, tonight just ended any speculation that it could happen in the Audyssey thread. It's not going to be something that is upgradeable by something like a simple firmware update.
http://www.avsforum.com/avs-vb/showp...ostcount=28493
"Sadly, it is not something that can be applied as a firmware upgrade to past products from Audyssey or from our licensees. It's a completely new way of measuring and processing and so it will only be available in new products going forward."
Johnla is offline
Old 07-08-2010, 08:39 AM
QuadMersed in bass!
giomania's Avatar
Quoted: 14 Post(s)
Liked: 35
Great news, and also a bummer.
Mark
giomania is offline
Old 07-08-2010, 09:06 AM
CIH USER
Franin's Avatar
Liked: 1300
Mark
Agree!!
Franin is offline
Denon Avp A1hdci Ultra Reference A V Network Streaming Preamplifier , Denon , Component Preamplifiers
