Official Denon AVP-A1HD/AVP-A1HDCI and POA-A1HD/POA-A1HDCI owners thread.
2M views 28K replies 555 participants last post by  Yroger
#1 ·
Well now that there are some of us that actually own this amazing pre/pro, it's now time to officially get this thread started.
___________________________________________________________
Firmware Revision
Thanks to MarkB for sharing this most useful info.
From Japan website concerning the recent update (for the AVP-A1HD)
AV サラウンドプリアンプ AVP-A1HD
2008/04/16 (1) scaling operation of the dual monitor connected time was improved.
(2) operation at the time of function change was improved.
(3) operation of optical digital output was improved.
As for the product where this update is necessary,end of serial number is only the product 250thor less.
* Product number the guarantee, is the number of 10 columns of statement in the carton case, and the product rear.
To check the firmware revision on the AVP (thanks to Steve91 of avforums for this):
1) Power off using the front panel main power switch (not the stand by button)
2) Inside the front panel door, press 'dimmer' and 'status' buttons simultaneously.
3) Power on using front panel main power switch whilst still holding the 'dimmer' and 'status' buttons.
4) Release the 'dimmer' and 'status' buttons after a couple of seconds.
5) Use the 'status' button to scroll through the firmware list (starts with unit's serial number).
6) Cycle the power using the front panel main power switch to restore normal operation.
Version Info:
Originally Posted by MarkB
Before update:
Main Ver 00.98
Sub Ver 00.50
Main ROM 00.98
Main PLD 00.25
DSP1 Ver 36.56
DSP2 Ver 37.14
DSP3 Ver 38.10
...a few Ethernet ones that I have not bothered to include...
GUI PRG 00007621
GUI DAT 10003007
REALTA 070C14
HDMIA PLD 00.20
DGTL FPGA 00.10
POA1 Ver 00.37
After update:
Sub Ver 00.58
!!!New Firmware update info from Denon!!!
** If your current set up has no problem , then we don't recommend to have any firmware update .**
**The update is set for some hardware HDMI handshaking problems, BD disc audio format display problems**
**GUI rolling word speed up ...**
**The best environment for update is using wired LAN cable hooked with AVP.**
**Make sure the ISP you are using can pass all the data from Denon server .**
**It will freeze the AVP if the update cannot complete.**
I was given permission by The President/Owner of Audioholics (Gene DellaSala) to post a re-print of a comprehensive information page about the firmware updates he has on the Audioholics website. Thank you to Gene for allowing me to share this most helpful information here on our thread.
Also Gene has started a Denon AVP-A1HDCI / POA-A1HDCI Review Support Thread . Gene will be supporting this product there and has direct contact with Denon to answer any questions. This is an excellent companion site for our AVP/POA owners thread.
Denon AVP-A1HDCI & AVR-5308CI Firmware Update
*Anyone considering this update should proceed with caution as some AVP owners have experienced some serious unit freeze ups and operational issues. More info on this will be provided as it becomes available.*
[update] 08/10/08
After hearing about the success that AVP owners are having with the update here recently, I decided to give it a go myself. I'm happy to report that my AVP update was successful and went through without a hitch. The update took exactly 61 minutes. So it "seems" as though whatever problems were there before, may have now been corrected. After the update I tested the music streaming to make sure that was ok, it was fine.
by Gene DellaSala — last modified June 23, 2008 12:59
Firmware
Denon has just announced firmware updates for their flagship AVP-A1HDCI 12CH A/V Processor. There are two updates which are tabulated below. The updates will only benefit users experiencing these operational issues. All updates are cumulative; meaning the latest one will include the previous ones if the unit had not been updated prior. These update corrections are for North America units only – other updates are available for other markets as well.
Models Affected: AVP-A1HDCI, AVR-5803CI
SUBJECT: Correction of the Firmware via DPMS (Denon Product Management Server)
Update #1 April 16th, 2008
SYMPTOM:
If "Hi-Def-signal" of 720p inputs to the unit, it can scale to "1080i" but can not
scale to "1080p".
"Pop" noise occurs when the muting function turns on.
The noise occurs when the input selector is changed.
A different digital signal might be output to "OPT-4" output.
The connectivity of HDMI is improved.
CAUSE: The malfunctions occurred due to bugs in the firmware.
COUNTERMEASURE: corrected the firmware so that no malfunction occurs.
Update #2: June 16, 2008
SYMPTOM:
Addition of the Rhapsody Merge function.
When space is used for the character of SSID, Wi-Fi cannot be set.
Problem for Tuner preset memory when RDS is received.
Scroll speed of "Artist" becomes slow when playback music files with DLNA by network-audio.
Spelling error on web browser display. "Controler" > "Controller"
MVUP/down (master volume up/down) command can affect zone 2 volume if any zone 2 command has been recently sent.
No title via internet radio with the new firmware version 1.60.
When AVP-A1HDCI connects Marantz DV9500 with EXT.IN connection and chose "Monitor2", Sound output stops.
The disc where "Dolby Digital" and "TrueHD" are alternately recorded is reproduced. And, when "Dolby Digital" and "TrueHD" are promptly switched, the sound is not outputted.
When the stream signal of "DTS-HD MA 7.1ch" is reproduced by setting "5.1ch", the sound is distorted.
Noise occur from surround channel when playback a blue-ray disc "The Golden Compass" when connected AVP-A1HDCI and DVD3800BD.
The connectivity of "HDMI" and "CEC" is improved.
____________________________________________________________ _____
Thanks to captavs at AVS for translating the following from the Denon Japan website and for sharing this info:
Info added 08/10/08
Update #3 June 26, 2008
GUI shown some improvement.
Wireless LAN Settings some improvement.
Internet radio to play some improvement in information display.
specific voice to improve the operation of the disk format.
HDMI, CEC to improve connectivity
Info added 09/07/08
Update #4 August 29, 2008
Last 2-pixel cropping at 1080p.
Several pixels on the right hand side of the image are apparently gone or have been replaced with different information at 1080p.
Here is the translate firmware change log info for the AVP posted on Denon Japan website as of September 1, 2008 thought you guys might find useful:
AVP-A1HD
*latest update on the earlier apply*
2008/08/29
Scaling work better
Info added 09/22/08
Update #5 September 19, 2008
Internet radio is playing the power OFF / ON operation at the time was improved
USB memory to play music when the random behavior was improved.
WMA (Lossless) to improve the operation of playback time.
JPEG files with metadata work at the time of play has improved.
NET / USB function better in the aspect ratio has been set.
GUI has been showing some improvement.
Thanks to Gene DellaSalla from Audioholics for the following info:
This update has fixed the Net Radio issues many were having.
Denon also informed Gene of the following:
This update sets the AVP up for the October 1 upgrade of Dynamic Volume and Sirius Radio Ready features. If you go to ‘Add New Feature’ and press Enter, you should see a new page. Also depending on when you did your last update, it may have included the fix for 2 pixel cutoff on right side of image.
Gene also confirmed that Dynamic Volume & EQ will function for those using the Audyssey Pro Calibration kit with the computer software.
Thanks to captavs at AVS for sharing the following info. (Update) Additional update info from Gene DellaSala from Audioholics.
Info added 10/01/08
Update #6 October 1, 2008 (approx. 110 minute update)
Here is the change log for North America AVP firmware update reported available October 1:
3-1. Additional of new features
1) SIRIUS Ready
Need to get optional Sirius Home Connect Tuner (plus subscription) with RS-232C connector
2) Audyssey Dynamic Volume
Note: No Audyssey recalibration is needed after the update
ii. In Surround Parameters section you will see new menu item for Audyssey with selections for MultEQ, Dynamic EQ and Volume
iii. Dynamic Volume has 4 settings
1. Day/Evening/Midnight/Off
2. Each settings has different desired listening level, so Day mode will have a higher range, while midnight will have the least
3) Improving of connectivity with ASD-11R
Operation with new iPod/iTouch/iPhone models when used with optional ASD-11R dock – Full audio and video output is now permitted with meta-data on GUI of AVP/AVR
4) Change the name of 2-way Remote in OPTION SETUP menu. (232C PORT(1))
5) Correspondent to Resolution of 1080p/24Hz
Adds scaling to 1080/24 from any analog/digital signals
3-2. Improvement of malfunction
1) The unit does not come back to the last state of playback when we turn off the power during playback Internet radio then turn on.
2) The customer has connected a "USB-Stick memory" with more than 4GB. Random-function of USB devices is not active.
3) Drop-outs via Ethernet playback from PC with "Windows Vista".
4) No playback of JPEG with Meta data.
5) Missing Aspect ratio setup for NET/USB source.
3-3. Improvement of GUI indication
1) Improvement of remote control receipt operation
a) To turn on the power supply of the unit in the standby by "INPUT SOURCE selection" button of remote control or "QuickSelect" code.
b) After the power supply of the unit had been turned on, the operation time by the remote control such as "INPUT SOURCE selection" button, "Surround mode", and "Master volume control" were shortened.
2) The display condition of "Subwoofer channel" of "DIRECT" and "STEREO mode" when 2ch is input is changed.
3) To turn off the channel indicator on the FL display when the subwoofer was not output.
(Subwoofer Mode : "LFE", Front Speaker: "Large")
4) The setting of "SB CH OUT" can be changed by operating "Standard" button at 5.1ch input.
5) When "PCM Multi Ch+Matrix" has been turned on, the surround mode display name is changed.
6) When the mastering volume is operated, the setting that displays "Volume display" of "GUI/OSD" in the screen upper row is added.
(A set value of Option/GUI/Master volume is changed to Bottom/Top/OFF.)
7) "Aspect setting item" is added to the "NET/USB" function. (SOURCE SELECT/NetUSB/video/Aspect)
Info added 10/29/08
Update #7 October 16, 2008 (approx. 65 minute update)
1) Translation mistake in German and other languages.
2) The GUI and OSD of the A/V amplifier doesn't operate correctly when the A/V amplifier is connected with "iPhone 3G".
3) Improvement of the Audyssey Dynamic Volume function. (For only PAY-Upgraded models.)
Info added 10/29/08
Update #8 October 27, 2008 (approx. 11 minute update)
Change log for update available October 27th for upgraded units.
1) If Volume of the unit is operated when the voice changes from "DIRECT mode" to "Another mode" when "DynamicEQ mode" is selected, the level might become large.
2) When the input signal is changed while displaying the Audyssey Setting screen of MENU, the key might not be able to be operated.
Info added 10/29/08
Update #9 November 28, 2008 (approx. 10 minute update)
fixed/improved:
When the Dolby TrueHD audio of "Batman Begins" reproduces, the noise is generated from "0h49m05s (Track 14)" in the output of "Surround channel and surround back channel"
Info added 1/10/09
Update #10 January 6, 2009 (approx. 8 minute update)
fixed/improved:
After upgrade to A/V amplifier is the 7 Channel Stereo not selectable via Remote controller RC-1067 DSP-simulation
Info added 5/20/09
Update #11 May 13, 2009 (approx. 40 minute update)
Denon firmware change log for this update reported available about May 13, 2009 (June 22, 2009 for North America):
1. Addition of function
1-1. DENON Link 4th function (When the power supply is turned on, "DENON LINK 4th" is displayed in FL).
1-2. The HDMI Assign function for CD input is added.
Other updates including the October 2008 release which added Audyssey Dynamic Volume and Sirius Radio Ready capabilities along with other improvements including updated iPod compatibility, 1080p/24f scaling and more is also included.
2. Improvement of problem
2-1. AVP-A1HD cannot be correctly controlled from RC-7000CI/7001RCI.
2-2. Neither Dynamic EQ nor the parameter button work after executing an auto setup with external MIC terminal V.AUX L.
____________________________________________________________ _________________________
Info added 07/30/09
Update #12 July 24, 2009 (approx. 11 minute update)
1- Sound is not outputted when play a specific disc with "DVD-A1UD" which is connected to A/V amplifier with "DENON LINK 4th".
2- "EVANGELION: 1.0 YOU ARE (NOT) ALONE" (KIAX-9). There is the case that a sound does not out right after started playback.
3- After main power off/on, Parameter check "DISTANCE" shows "SURR.BACK" speaker instead of "SUBWOOFER".
How to initiate firmware update:
Turn off power of AVP-A1HDCI
Connect straight thru Ethernet cable from your router to the AVP-A1HDCI
Enter “Manual Setup” > “Option Setup” area of OSD
Select “Firmware update”
Do NOT use a wireless connection when updating firmware and make sure there are no power interruptions during this process. The update can take up to one hour which during the process will render your AVP-A1HDCI/ AVR-5308CI inoperable.
While not as up to date as the info we have listed above and on our Wiki, here is the Denon Japan Firmware update listing page translated to English.
http://translate.google.co.uk/transl...hl=en&ie=UTF-8
All new firmware update info available here is also available on our Wiki site.
Here's a list of current and soon to be AVP and AVP/POA owners here on this thread.
AVP owners
Number of AVP owners: previous 72 (current 69)
  1. Waboman
  2. GoodSonics
  3. alebonau
  4. elockett
  5. progprog
  6. gimp
  7. Spearmint
  8. markrubin (ex-owner)
  9. dpowg
  10. Joe C5
  11. EricBergan
  12. tassop
  13. rnrgagne
  14. ohyeah32
  15. phastlane
  16. zeejayzee
  17. stenvik
  18. guapote
  19. orologio
  20. KX250F
  21. giomania (ex-owner)
  22. norpus
  23. ddimberio
  24. Curious George
  25. StephenBishop
  26. joeh71
  27. ChrisWiggles
  28. Wilfred
  29. hmuller
  30. markhal
  31. MC Maniac
  32. David Shapiro
  33. Adam_G
  34. cinemike
  35. Ian_Currie
  36. Jeff Owen
  37. fperra
  38. pers1 (ex-owner)
  39. JonFo
  40. bschaen
  41. ahr34
  42. tassop
  43. Krellav
  44. AVMN
  45. QueueCumber
  46. Aesculus
  47. lavan
  48. kcrowtroy
  49. misterdoggy
  50. Shutterman
  51. Gungadin
  52. djdmt
  53. Al Jones
  54. dbaydoun
  55. DigitalNut
  56. AudioBear
  57. BRADH
  58. beever (ex-owner)
  59. larryy
  60. wilsonj
  61. Aetherhole
  62. perrin21
  63. gchuva
  64. gaza916
  65. ctouhey
  66. grassy
  67. Krobar
  68. Nick Satullo
  69. AcuDefTechGuy
  70. ToolmanJohn
  71. jason shep
  72. WillyJ
  73. GlenC
AVP/POA owners
Number of AVP/POA owners: previous 30 (current 28)
  1. Franin
  2. MarkB (ex-owner)
  3. nethomas (ex-owner)
  4. pentium7
  5. danielo
  6. thebishman
  7. lectricman
  8. kyle333
  9. Jan T
  10. richard_onyschak
  11. ShaharT (2 POA-A1HD amps)
  12. bigimp65
  13. MrSTI
  14. djdna
  15. SmithMK (2 POA-A1HD amps)
  16. noobman
  17. Tom Blake
  18. gsr
  19. SJHT
  20. bankrupt
  21. jomark911
  22. RIK2
  23. onn
  24. robercy
  25. deckarep
  26. BrutaleZEN
  27. thrang
  28. frahengeo
  29. Svend P
  30. v8sam
Many more to be added soon.
Denon AVP upgrade program
Below is where to see which owners are going to be getting their units upgraded.
Owners getting their units upgraded (22)
  1. gimp
  2. gsr
  3. deckarep
  4. aesculus
  5. PLA
  6. Daniel
  7. magking
  8. RNRGAGNE
  9. AudioBear
  10. bankrupt
  11. keithrj
  12. jason shep
  13. alebonau
  14. rrussell
  15. Digione
  16. JonFo
  17. boe
  18. grassy
  19. tassop
  20. jackox
  21. shyrix
  22. AVMN
Owners not getting their units upgraded
This site is dedicated to all things AVP/POA, please check it out.
Also checkout our new AVP and AVP/POA owners systems photo gallery thread here
Professional Reviews:
Audioholics review of the Denon AVP-A1HDCI
Audioholics review of the Denon POA-A1HDCI
Home Cinema Choice Magazine review of the Denon AVP-A1HD/Denon POA-A1HD
Podcast interview with Jeff Talmadge (Denon's Director, Product Development & Systems Integration) discussing the AVP/POA and other great info:
Podcast interview with Denon's Jeff Talmadge
See less See more
6
#13,342 ·
Originally Posted by orologio /forum/post/16099609
Frankly, I don't know how to help you with this.
I am answering because I have a similar set up: two f113 and 500w icepower modules. At first when I got the -12 for the subs that was easy to adjust the level just as you did. Regarding the speakers, I have no idea what the solution is.
Perhaps your speakers are not as power hungry like mine and 500w at 8ohms is overwhelming. The level at -12 is not acceptable because you don't know whether you reached the bottom or not and they will be louder then the rest in the system.
I have the exact same problem. two F113's. 500 W4S amps. My sub level check says -12. However all my speakers show a negative level check. How can that be? Wouldn't one of the speakers need to be positive or at least flat?
#13,343 ·
Originally Posted by Franin /forum/post/16867925
Thanks rnrgangne. Just did not want to waste the guys time in borrowing it.
Audyssey pro authentification is a two step process :
1 the AVP must be recognize by the Audyssey software on teh PC
2 you must activate a key from the MAC adresse of the AVP unit that will cost 150$ US. That means you need an audyssey pro account.
You take the risk of loosing 150$
PM me maybe I can check it out over my own Audyssey pro acount (before doing any payment of course).
#13,344 ·
Originally Posted by Franin /forum/post/16867550
Just curious just making certain we can't dial into the Audyssey with an Audyssey kit with AVP from Europe/Australia. I have been offered one to borrow so I can dial in but wanted to make certain.
which are the differences btw this kit and the audissey within AVP?
how we can access to it in EU?
thx a lot.
#13,345 ·
I experienced the same issue with my front amps (and the sub) that have a sensitivity higher then the other channels managed by the POA.
I understood (but I could explain this in the wrong way) that Audissey sets a certein level for the test signal (0db ?) and then work to set all the speakers level to 75db. Now if some of your channels are higher then the Audissey Denon range (+/- 12db) they cannot be set properly.
Now all your speakers are higher then 75db (some of them higher 87db), so all of them are lowered.
I tried to make after the Audissey setting a manual setting of the speakers level using an audiometer and loweirng the test tone to 10db (at the end I was able to stay properly withing the range of +/-12db - some of the speakers where boosted, some other cut and some at 0db), but I was told that this will reduce the level of accuracy of the Audissey settings.
So at the end I was suggested to get some XLR attenuators ( http://www.rothwellaudioproducts.co....tenuators.html ) to reduce my amps input sensitivity. I just got them yesterday and I'll test them in the next couple of days.
#13,346 ·
Just give him the info he needs and see if he can generate a key for it, if he can, then you're off to the races.
#13,347 ·
Yeah I know that, I suppose I could also check it out for Frank, I never thought of that though.
I couldn't remember if it was mac address or serial no since it's been over a year that I bought the license.
#13,348 ·
thx a lot.
The "Pro" software runs on a laptop and has a higher quality mic & preamp. The Pro can take up to thirty two measurements and do the required calculations from there. You can also program target curves or select from three default curves along with an option to use mid-range compensation.
You can store measurements for re-loading to the avp.
I don't know the answer to the last question.
#13,349 ·
Will Do thank you Jackox.
#13,352 ·
Originally Posted by stenvik /forum/post/16872594
people say it might be supported on rest of world AVP's ? the pro setup thing
I wanted to make sure I can borrow one but did not want to waste my friends time in sending one out to me if it did not work.
This is the one I could have problems with.
the AVP must be recognize by the Audyssey software on the PC
#13,353 ·
In-line attenuators sound like a good idea. Let me know if you find that they work.
#13,355 ·
This is what the upgrade consits of(Have not the Model Upgrade):
(1) GUI in the "Parameter Check" to improve the view.
Products that require this update is only following the end of the product serial number.
AVP-A1HD (SP: Premium silver): 450 at the following
AVP-A1HD (K: black): 26 Number Below
※ The number of warranty cases, cartons, the products listed on the back and 10-digit number.
Time to update the broadband Internet connection about 11 minutes.
※ Depending on the environment around you to your house and situation of the Internet server.
Funny thing is when checking what it does it shows the Denon AVP A1HD (The model upgrade) and the other
Denon AVP A1HD(Have not the model upgrade)
The Model Upgrade:
(1) DVD-A1UD and DENON LINK 4th disk activity was improved in particular when connecting.
(2) certain Blu-ray disc to improve the operation.
(3) GUI in the "Parameter Check" to improve the view.
Products that require this update, DENON LINK 4th will be eligible to upgrade all of the products.
Here is the Link
#13,357 ·
PM sent thankyou
#13,358 ·
Quick question.... If any of you put your A1 in "Pure Direct" mode, do you loose video and revert to 2-channel ? I just went through the Denon dealer CI training and this is how it is designed, but my A1 doesn't do it.
#13,359 ·
Will test at home for you but i think hdmi will go into passthrough mode and if if external ins are used than ofcourse it doesn't go back to 2 channel.
update : just tested it and it indeed works like this.
Daniel.
#13,360 ·
Hello,
I've done about 3 firmware updates so far on my Denon - this time it got to VPLD Firm 01min updating failed.
I can't press menu or anything else - my only option is to power off and back on - it tries to continue the update but then gets the same error.
Any suggestions?
