Official Denon AVP-A1HD/AVP-A1HDCI and POA-A1HD/POA-A1HDCI owners thread. - Page 877 - AVS Forum | Home Theater Discussions And Reviews
 76Likes
Old 07-12-2014, 12:17 AM
Johnla's Avatar
Quoted: 39 Post(s)
Liked: 30
Originally Posted by gsr View Post
Yes, but I don't remember the specifics. IIRC, you order the pro kit from a vendor and then get the license direct from Audyssey. Here's a link to 1 vendor, but they currently list the kit as being on back order. You may also find this thread handy for some Pro Kit info.
That vendor, Perfect Home Theater, pretty much always shows the Pro Kit as back ordered. But it really don't mean a whole lot either, because if you do order it from them they will then have it drop shipped to you direct from Audyssey. That's how they it did it for me and it only took about 5 or 6 days before it was delivered to me, and I'm pretty sure that's how it was for others that also bought the Pro Kit from them as well.
Sam S likes this.
Johnla is offline
Old 07-12-2014, 06:37 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 780 Post(s)
Liked: 594
That makes sense. I'm pretty sure I ordered my pro kit from them too, but it was probably 3+ years ago now so I don't remember if they had it listed as back ordered back then.
gsr is offline
Old 07-12-2014, 01:07 PM
DoctorO's Avatar
Quoted: 20 Post(s)
Same here. "Back ordered" but got it drop shipped in no time, about 2 years ago.
DoctorO is offline
Old 07-13-2014, 06:30 PM
grassy's Avatar
Quoted: 45 Post(s)
Well i have had the latest firmware update looking at me now for some time for the AVP and have been skeptical on downloading it, as i was weary on what it was for and now i just found out that it has something to do with the bass management(improving the bass) when listening to SACD via denon link. I think i will now go ahead and download it as it is only a 3min download. Has anyone noticed a difference in their bass after this update when listening to SACD via denon link.
Fame is a mask that eats into the face.
grassy is offline
Old 07-14-2014, 05:57 PM
Digione's Avatar
Quoted: 22 Post(s)
Liked: 31
This update fixes the -10dB LF loss in the 0.1 channel when listening to SACD over DL3. It really makes a big difference. If you don't use Denon Link then maybe you don't need it.
Digione is offline
Old 07-14-2014, 08:59 PM
grassy's Avatar
Quoted: 45 Post(s)
Thanks Paul,have not played an sacd disc since but plan on checking the results today sometime,
grassy is offline
Old 07-15-2014, 09:08 PM
Sam S's Avatar
Quoted: 177 Post(s)
Liked: 60
Did we ever figure out if a 3D/XT32 upgraded AVP supports Audyssey SubEQ HT, i.e. independent eq'ing of 2 (or 3?) subs?
Sam S is offline
Old 07-16-2014, 05:07 AM
alebonau's Avatar
Quoted: 708 Post(s)
Liked: 374
I ran my 2 subs discretely when first got the xt32 update and it did ping, setup them all independently
"Technology is a drug. We can't get enough of it."
Welcome to my lounge room :)
alebonau is offline
Old 07-16-2014, 04:48 PM
Digione's Avatar
Quoted: 22 Post(s)
Liked: 31
The implementation of Sub EQ is left to the AV manufacturer.
The AVP only pings the subs separately and not together as the Audyssey Sub EQ does. This is not the best way to EQ subs. You need to set the levels and distances separately and then ping them all as one and EQ all the subs combined. This will generally result in the smoothest LF response curve. I have validated this approach as I also have the stand alone Audyssey Sub EQ HT, that does exactly what I have just described; I use 4 subs, two matched pairs equally set up about the MLP.
Digione is offline
Old 07-17-2014, 03:56 AM
alebonau's Avatar
Quoted: 708 Post(s)
Liked: 374
yes left up to manufacturer, worked well for my two 2 identical mirror placed subs. currently I utilise my subs separately i.e. one just extends my mains so they act as full range. and the other for LFE duties. the avp eqs both discretely and for excellent end result.
have just picked up the pro kit. will see how that adds to the mix
one thing to keep in mind is the many wide and varied options the avp gives for sub setup and config. am sure a choice there for all that will work well.
the thing I didn't like about the sub eq was that it hooked upto the subs and eqd so the av processor saw them as one. which is not much use for instance if you run them off the avp as L&R subs and then add another for LFE. you want them all eqd discretely. which is just what the avp will do
alebonau is offline
Old 07-17-2014, 11:14 AM
Ganymed4's Avatar
Quoted: 78 Post(s)
Liked: 71
Some time ago, I asked Audyssey about this and they told me that Denon deliberately decided not to deploy SubEQ HT. They didn't tell me the reason. May be this only works with two Subs and not three Subs? I don't know.
I am happy with this, because I didn't like SubEQ-HT with my former Onyko PR-SC5509. From the theoretical point of view, it seems correct to me, to measure the Subs together. However, from my listening impression, I like the independent measurement better.
I am happy of what the AVP does and I made already many measurements with my Pro kit.
alebonau likes this.
Ganymed4 is offline
Old 07-17-2014, 04:39 PM
grassy's Avatar
Quoted: 45 Post(s)
Congrats on the pro kit Al, hopefully i will not be far behind in getting mine although i might have to wait till after our Tax is done with. My amp is still going like the clappers and i am really enjoying the home theater experience now. Never been better
grassy is offline
Old 07-18-2014, 02:49 AM
alebonau's Avatar
Quoted: 708 Post(s)
Liked: 374
good to hear gany, am looking forward to using the pro kit, just on a massive learning curve with it...
hi grassy, audyssey service is amazing. order was processed literally overnight, payment made and shipped very promptly to arrive in the next week ! can highly recommend. comes very well packed to double boxed and very well packaged. looks a really good quality piece of kit.
now just to register it and start down the path...one will have to wait on a while though...july is a very busy month for us ! yep tax time that is always a bonus
grassy likes this.
alebonau is offline
Old 07-18-2014, 06:52 AM
CIH USER
Franin's Avatar
Quoted: 1915 Post(s)
Liked: 1121
Pro kit is awesome AL. You'll love it. I use mine and never looked back
_________________________
Franin is offline
Old 07-18-2014, 01:12 PM
Ganymed4's Avatar
Quoted: 78 Post(s)
Liked: 71
Yes, I was also going through this 'learning curve', especially regarding microphone placement. Also the program settings at the end, even there are only a few, can give you some headache. But this is individual and depends on your own set-up you have in your HT. If you need some help, there is a very good Pro thread in the forum with some very knowledgeable experts - not me only. You find it here The Audyssey Pro Installer Kit Thread (FAQ in post #1)
They have a lot of detailed information, collected from Audyssey directly or their own experience.
The best thing for me with the Pro kit is, that you can load your measurements and then play with the parameters - target curves, x-over values. This is really great and I used it quite often.
Looking forward to read about your experiences.
Ganymed4 is offline
Old 07-18-2014, 04:57 PM
Digione's Avatar
Quoted: 22 Post(s)
Liked: 31
Whilst I agree that the AVP gives the flexibility to EQ each sub separately, that is not how you listen to them. The interactions between combined subs is very complex and not terribly predictable so I do not see how EQ'ing each sub separately can provide the best overall response. Having said that we each have are own experiences based upon our very different rooms. Even Chris at Audyssey never recommends EQ'ing subs separately.
I have spent many hundreds of hours comparing the two approaches in my purpose built music/HT room using Pro. My room is heavily acoustically treated with significant bass trapping and absorption, and without exception EQ'ing all subs as one alway produces the best frequency response AND decay response at the MLP.
I will not elaborate any further as this is not the correct thread to do so.
Just fixed my link, apparently the recent site upgrade broke it.
Digione is offline
Old 07-20-2014, 12:05 AM
alebonau's Avatar
Quoted: 708 Post(s)
Liked: 374
thanks Frank, can't wait to get going….now just need an evacuated quiet house ….. might takes months for that to happen !
thankyou Gany, for the links etc, partly your experience sealed it for me to to get there pro kit.
thanks, however would beg to differ, the avp does a fine job in Equing my full range mains (mains - sub pair) … each one individually just as it measures and eqs my sub. had no issue with dual subs either. but I respect your view and understand what your wishing to achieve. however no plans here in getting a subeq myself but certainly looking forward to utilising the pro kit just received
alebonau is offline
Old 07-20-2014, 01:23 AM
CIH USER
Franin's Avatar
Liked: 1121
I do mine around 1am-2am in the morning once the neighbourhood is asleep.
Franin is offline
Old 07-20-2014, 04:22 AM
alebonau's Avatar
Quoted: 708 Post(s)
Liked: 374
now theres an idea frank ! not sure what the wife would think. or the cat that tends to prowl the house at those hours
alebonau is offline
Old 07-20-2014, 08:27 AM
jomark911's Avatar
Yeah mine does that too. Once I did it at 03"00 am got scared of the sound chirps , and destroyed the first set of measurments.
Meaoowing .
Limits established to be exceeded.
jomark911 is offline
Old 07-20-2014, 09:11 AM
Digione's Avatar
Quoted: 22 Post(s)
Liked: 31
I have never run my 1038's as a full range main/sub pair like yourself so your approach maybe more suitable and obviously works well for you.
The Pro kit is a great tool (especially when used in conjunction with something like REW) in that you can easily re-load, add to and extensively edit previous measurements; it also "tailors' the speakers LF roll off in order to match the selected crossover frequencies, something that XT32 in the AVP cannot do. You can have hours/days/weeks of "fun" tweaking, refining and optimizing.
Have fun
Digione is offline
Old 07-20-2014, 08:42 PM
jlp1021's Avatar
Unhappy Finally getting up to speed... Doh! Maybe not...
Back in Sept. 2009 I purchased the AVP (due to my sincere desire to hear and see what composers, directors and other artists had intended). Planning to build my first home theater, but then shifting priorities to focus on my two children and work, those plans were placed on hold. Having utilized the hardware in a very limited way the past few years, I started looking online and realized there were available firmware updates to install. Hmmm…. interesting... updates. Cool!
So, I connected to the network and started to install the available update (from 2009 presumably). Big mistake!! I now see, I’m not the only one who has ever run into the “DSP1 Firm updating - 24 min.” issue the unit can’t seem to get past. I managed to perform the task three years after the unit was out of warranty... -NICE!
I doubt I’ll be able to use the option others have (3 years ago!) by requesting the upgrade (XT-32), and having the service center address the firmware issue during the process.
I’ve contacted two service centers (via email since they are closed now), but don’t expect they’ll be willing to do much, without me forking over another $1k (likely without the upgrade). We’ll see.
Any suggestions from any of you? Anyone willing to share how to address the firmware issue (further than resetting the micro-processor, disconnecting all other cables and having a direct network connection)? There has to be a way to install a prior firmware version and try again. (?)
Best regards,
Josh
jlp1021 is offline
Old 07-22-2014, 11:38 AM
Ganymed4's Avatar
Quoted: 78 Post(s)
Liked: 71
Best regards,
Josh
I wish you good luck with this issue. There are - IMO - more than one problem related to your firmware problem. As far as I am aware, you cannot get the firmware except via the Internet. Only service centers may have it - read very mixed experiences here with service centers from others.
The upgrade is definitely not available any more. I guess only a service center can help you in your case.
Sorry not having better news for you. This is what I know, but may be somebody else has an idea or more knowledge?
Ganymed4 is offline
Old 07-22-2014, 04:19 PM
Digione's Avatar
Quoted: 22 Post(s)
Liked: 31
Only a service center can reload your firmware, it is not available anywhere else, and you need a suitable driver in order to connect to the AVP in order to reload the entire firmware suite.
I do not know where you are located but if you are in North America I would strongly advise you to send it to one of the major service centers preferably Panurgy in NJ with who I have had extensive dealings, all of which have been very positive. If it is just a firmware re-load due to a glitch the biggest cost will most likely be the freight charge not the re-load labor.
I have fairly close connections with Denon Corporate in Mahwah NJ and Panurgy. Please PM me if you need more help.
Digione is offline
Old 07-26-2014, 07:17 PM
grassy's Avatar
Quoted: 45 Post(s)
Just thought i would give everyone an update on how my new POA is getting on. I have read in lots of articles how it has been stated that the AVP and POA have been described as the best home theater combination in the world. Most of us would agree that that statement is a big one, but after watching "Van Helsing" last night with the family i can see where they are coming from. As far as 2 channel music goes i have a lot to learn even though i am a muso, i still have a lot to learn about setting this combo up for 2 channel stereo listening to get to its full capabilities. I can really only speak for home theater here and after last nights performance i came away speechless and really didnt know what to say other than the fact it was the best home theater sound i have ever heard in all my time that i have been involved in home theater.It really made me appreciate all the work that goes into these units and we really don't get the full meaning of the reviews or claims until we hear them for ourselves. Buying this POA was probably the best move i have ever made since buying the AVP and i can now truly understand what i actually have here. After last night i came away thinking how on earth can this combination get old or aged in comparison to whats coming out on the market today after the AVP upgrade. This leaves me with the opinion of How much better can Home theater sound get.And it leaves me with the question of will Dolby Atmos really make a noticeable difference to me. As far as last nights movie I was hearing every detail in the sound and i cannot begin to describe how the POA helped my Yamaha HX8 speakers sound.I had to turn the sound down from -20 to -25 first time ever on the AVP.I think i have the AVP and POA combo tuned in to where it needs to be.The great thing about having the POA is the fact that now that i am using it every movie is now unique in sound. Boy has it taken some years to get to this stage.
grassy is offline
Old 07-27-2014, 10:15 AM
robgarcia's Avatar
Quoted: 56 Post(s)
Congrats!
There's a company in Germany (IIRC) that does do extensive (and expensive) mods to the AVP that seem to have received favorable reviews, but that's most likely not practical unless you live relatively close to them. It's pretty darned good in stock form though
That would be extremely unlikely as the AVP is a discontinued product and Atmos would most likely require some fairly extensive hardware changes. For that matter, I suspect that any further upgrades of any sort are very unlikely at this point.
After reading what you said i have had no luck finding that company in Germany that upgrades it. or any other company other than the one out of Michigan called the upgrade company lol.
ok so here is where i stand after thirty days . love this Denon the sound quality is better than the Yamaha rx-z11 that i had.
i can not stop myself from watching movies thru this. just bought thru another site the Denon DVD-A1UCDI to match up the other piece. and i would like any tips on it. anyone know if there is a company that would unlock all regions or a firmware that i could get to do it. or if there are any companies out there like for OPPO that can make it even better than it is.
Im hoping i made a good decision on the Denon blu ray player
robgarcia is offline
Old 07-27-2014, 12:36 PM
Digione's Avatar
Quoted: 22 Post(s)
Liked: 31
You could try contacting JVB Digital, see link below. They used to do region free and SDI mods for all Denon players, I have used them several times for Denon SDI upgrades.
http://www.jvb.nl/jvb.asp?cur=2&level=home&page=front
Here is the player codefree link:
http://www.jvb.nl/jvb.asp?cur=2&leve...tle&title=1089
Digione is offline
Old 07-28-2014, 12:55 AM
magicvinny's Avatar
The german upgrade company you're looking for is cinemike.de I guess.
He still does AVP upgrades. The only upgrade that's not available anymore is the 3D-upgrade.
magicvinny is offline
Old 07-28-2014, 04:40 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 780 Post(s)
Liked: 594
^ Yes, that's the place I was thinking of.
gsr is offline
Old 07-29-2014, 12:12 AM
Johnla's Avatar
Quoted: 39 Post(s)
Liked: 30
Even though you are not in the US. For others that are that may be looking to have mods done, if you do a forum search on that place in Michigan called "The Upgrade Company", you will find loads of reasons why they should be avoided.
Johnla is offline
Denon Avp A1hdci Ultra Reference A V Network Streaming Preamplifier , Denon , Component Preamplifiers
taboola here
