Official Yamaha RX-V863 thread - Page 34 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #991 of 1011 Old 12-18-2012, 10:12 PM
Fxnecro's Avatar
I have the rx-v863 and recently the video from the PS3 has started flashing, on off etc. It's connected with HDMI. The dish network is also running through the receiver with HDMI and does not flash the video. Things I have tried:
Changed cables. No change, still flashed.
Changed inputs. The PS3 always flashes, and the Dish network HDMI does not, regardless of input or cable used.
Ran the PS3 directly into the TV. It does not flash.
Switched to a different TV with the PS3, worked fine.
So it seems like the PS3 and the receiver don't like each other..... Can't we all just get along!
I tried downloading the above firmware link, burned it to CD and followed the directions in the service manual. A message briefly flashes about "Header read" ( I think, it flashes fast) and then I get a "Model Type ERR" that comes up.
Next step?
Fxnecro is offline
post #992 of 1011 Old 12-19-2012, 04:28 PM
DSperber's Avatar
Quoted: 226 Post(s)
Liked: 186
Sounds like the HDMI output on your PS3 is the culprit.
Can you try connecting the PS3 directly to your HDTV via HDMI? Still flashing? You've found the culprit.
I just went through a very similar story with my own V863, which I use to relay an old 4:3 480i DVD from my Oppo BDP-93 through the V863 (using component video out of the Oppo and into the V863, and then S-video out of the V863 and into a JVC 40K DVHS/SVHS VCR, and then S-video out of the VCR and into a 4:3 SD CRT television.
Well, it recently started "flashing" (i.e. image would disappear completely and then return, repeat, repeat) the same way I'm guessing your PS3 is flashing via HDMI connection. But in my case it was via S-video (at the end), starting off component video from the source device and relaying through several pieces of equipment and analog cable types.
So I tried various alternatives, to find the actual "culprit". The key is to cut out a relay device along the signal path and see if the symptom still exists. If yes, then that device is NOT the culprit. And in the end, it was not the Oppo source device or its component video output. And it was not the V863 or any of its component video inputs, nor was it any of the S-video outputs. And it was not either of the S-video inputs on the TV And it was not the S-video input on the SVHS VCR.
It was the S-video output circuitry in the VCR (feeding both of its S-video outputs) which was at fault, unrelated to what the source was or what device was at the other end of that S-video cable. I was able to produce the "flashing" symptom both on the directly connected TV and also through a second VCR, regardless of whether the source was (a) coming relayed from my DVD player, or (b) produced internally on the VCR by playing back an SVHS tape.
In other words, it is obviously an "old age" problem in the S-video output circuitry, no matter what the source. I've now simply removed that device and have the S-video cable from the V863 running directly to the S-video input of my TV... and of course no more flashing. I may or may not spend any money trying to get that JVC 40K repaired, as I have three other JVC DT100U machines that play the same DVHS/SVHS tapes and still work perfectly. And in this case I simply wanted to get 480i S-video from an old DVD over to my TV from my Oppo (relayed through the V863), and I don't really need to use that now-defective VCR at all.
Your situation may be similar. Removing the V863 in your HDMI relay, and going direct from PS3 to your HDTV will point to the culprit.
DSperber is offline
post #993 of 1011 Old 12-19-2012, 05:16 PM
Fxnecro's Avatar
I connected the PS3 to two different HD TVS using the HDMI and neither had the 'flashing' problem. I may try it again for a more extensive test since the problem seems to come and go. Sometimes it's so severe you simply can't use the PS3, and other times it might be fine for an hour at a time. I'd really like to try and flash the receivers firmware but I can't find the file anywhere.
Fxnecro is offline
post #994 of 1011 Old 12-20-2012, 06:43 AM
kriktsemaj99's Avatar
Quoted: 636 Post(s)
Liked: 357
I don't think a firmware update will help, but it's worth a try. The error you got could be real (although I still think the 863 and 663 use the same firmware), but it could also be because the CD wasn't burned, or played back, correctly. You have to burn it with a program that doesn't modify the bits in any way.
Some software likes to adjust the volume of audio tracks, which is no good for burning a firmware disc. For example, in Windows Media player you have to turn off the option "Apply volume leveling..." or the disc won't work. Other software may have similar features that need to be disabled. On playback, you also need to make sure the player is outputting the original data at 44.1kHz. A player than resamples the data or applies some other processing will make the update fail.
That said, I'll take another look at the 663 firmware file tonight and see what models it seems to be for. I can also verify the burn you made if you re-rip the CD to get back a .wav file (make sure to rip losslessly). I can tell if it's still a valid Yamaha firmware file, or whether it got modified during the burn process.
kriktsemaj99 is offline
post #995 of 1011 Old 12-20-2012, 08:28 PM
Quoted: 636 Post(s)
Liked: 357
FXnecro, I don't know what might be causing your HDMI problem, but I do think that firmware file linked a few posts ago is for the 663, 763 or 863 (the file name even starts with Vx63_, rather than V663_).
So the error message you got is probably because of the way the CD was burned or is being played back. You could try again with different burning software, and a different player if you have one. Which software and player did you use when you got the error message?
post #996 of 1011 Old 12-21-2012, 09:36 AM
caper_1's Avatar
Liked: 26
Is there a way to change speaker selection (A, B, A+B) on the remote?
HT: Yamaha RX-V565 | 3 X Energy Take FPS, 2 X VS Surround, 2 X Take LCR | DIY Subs: SDX12 APR15 & TRIO12 Dual APR 12's | 47" LCD
Music: Yamaha RX-V863 | 2 X Energy RC-70 | MA RXw12 Sub
Bathroom: 2 X Energy Take LCR
Car: Sony Xplod HU, Xplod 6X9s, Kenwood 4"s, Alpine 12" Type-S, Rockford Amp,...
caper_1 is offline
post #997 of 1011 Old 12-23-2012, 05:45 PM
Fxnecro's Avatar
I tried using both iTunes and Windows media player to burn the cd. I might have some version of Nero somewhere which I could try but at this point I believe the receiver is going. I had the "apply volume level.." turned off for both tries. Still get the "Model Type err" message. The cd/dvd player I have is an old Sony cd/dvd player model DVP-NS725P. It does have optical so I was able to attempt the firmware update / cd.
After further testing, it appears that the HDMI handshake between the PS3 and my V863 seems to be faltering. I ran the HDMI direct to the TV and ran the PS3 for many hours with no issues.
This is actually the second time the HDMI has caused me problems. The first time I took it and had it sent out for repair. I'm not going to do that again, I'll just get a new one. Looking at the Marantz SR7007 maybe.
I just thought attempting a firmware 'update' might help, and if I totally bricked it I would have a better reason to convince WifeUnit01 that we need a fancy new av receiver.
Still open to suggestions on fixes.
Fxnecro is offline
post #998 of 1011 Old 03-03-2014, 10:04 AM
vcrpro3's Avatar
Quoted: 107 Post(s)
Liked: 25
Ok RX-V863 owners; 5-6 years on since this model was current, how is yours holding up? minor/major problems?? I'm asking because i have the possibility of getting one used at a decent price......
vcrpro3 is offline
post #999 of 1011 Old 03-03-2014, 10:45 AM
DSperber's Avatar
Quoted: 226 Post(s)
Liked: 186
I've had mine about 5 years now, and it's still performing perfectly.
I originally bought it primarily as a replacement for a Zektor 4-in-1-out component video/audio switch I'd been using for handling multiple video/audio sources, because I really wanted to use HDMI. Also, the V863 is very much "analog-centric" and included a complete set of S-video connections which was important to me at the time, something that appears to pretty much no longer be present on any current AVRs.
However about a year ago I made a significant equipment upgrade (entirely HDMI-based), and upgraded to a Yamaha RX-V867. Although S-video was now gone with the V867, the unit now had four HDMI inputs instead of three, and had two HDMI outputs instead of one. This was very important to me. Still had multi-channel analog audio inputs/outputs which was important to me. I simply stopped using the old analog VCR's and other video sources which were S-video based, which is just a step forward anyway as I've solved the problem by making much more practical and durable DVDs and BluRays of those old tapes.
Furthermore, the V867 had "party mode" which was a way to deliver downmix-to-stereo of multi-channel primary 5.1 input to a second 2-channel stereo set of external speakers, which was important to me in support of a particular TV location.
The V863 has been re-purposed (along with some other supporting original equipment) to provide multi-channel audio from my HTPC computer at a second location (fed via optical coax from the PC), while the V867 and related new equipment is the mainstay at the primary HDTV location. I suspect the V863 will be with me and still working perfectly for many years to come, in its current audio-only implementation. But it was just fine for me even when I using its S-video/component/HDMI video features as well.
DSperber is offline
post #1000 of 1011 Old 03-03-2014, 11:50 AM
vcrpro3's Avatar
Quoted: 107 Post(s)
Liked: 25
Thanks for the info. The receiver is available from a local Craigslist ad, the seller responded that it works properly but he is out of town until next week. I have been sitting on a couple of Marantz power amps and some Mirage speakers for a while, and the receiver has pre outs so power is no problem, and it is a price i can currently affored....so,we'll see if if he contacts me then or not:)
vcrpro3 is offline
post #1001 of 1011 Old 03-11-2014, 01:52 AM
vcrpro3's Avatar
Quoted: 107 Post(s)
Liked: 25
Picked up my bargain RX-V863 today.. Too tired to hook it up today and run it through its paces. Tomorrow afternoons project.....smile.gif
vcrpro3 is offline
post #1002 of 1011 Old 03-13-2014, 06:13 PM
vcrpro3's Avatar
Quoted: 107 Post(s)
Liked: 25
WooHoo!! Got a surround system again!! Lacking network capability is no biggie, i have been sitting on some Netgear EVA9150's and a EVA9000 for a while. Picked up a couple of Marantz power amps a while back, so the $C note Yammie is going to serve pre/pro duties (have it connected to speakers on its own amps currently).....biggrin.gif
vcrpro3 is offline
post #1003 of 1011 Old 04-04-2014, 10:19 AM
scooterp7's Avatar
Okay, as an owner of the 863, I'm a little confused by the bench test at sound and vision, that rated the 663 with more wpc (5 and 7 ch driven) than the 863.
Casts doubt on all of their work.
http://www.soundandvision.com/content/yamaha-rx-v863-av-receiver-ht-labs-measures
http://www.soundandvision.com/content/yamaha-rx-v663-av-receiver-measurements
scooterp7 is offline
post #1004 of 1011 Old 09-01-2014, 02:08 PM
Liked: 0
I just changed from directtv to a cable provider. When I turn on my system I can hear the audio but cannot see the picture on the TV. However, when I turn another input and then switch it right back to DTV/cable, the hdmi signal final appears and the picture appears on the TV. Why is the video (HDMI Signal) not coming on? Called Yamaha and the tech there could not understand why either. I appreciate any help. The cable box is a Motorola VIP1232. When I turn on the DVD player everything works as it should. Thanks in advance.
bigtex03 is offline
post #1005 of 1011 Old 09-01-2014, 03:15 PM
DSperber's Avatar
Quoted: 226 Post(s)
Liked: 186
Sounds like an HDMI handshake problem during the instability occurring across all devices when first powering things on.
Assuming you have the DVR connected to the AVR, and the AVR connected to the TV, I'd suggest you try simply powering things on in a different sequence, rather than trying to power everything on all at once. I'd turn the TV on first and let it "stabilize". Then turn the DVR on second, and let it stabilize. Actually, you can probably power on both DVR and TV without worrying... as long as the AVR is not yet powered on until both DVR and TV "stabilize".
Then finally turn the AVR on last. With both TV and DVR's (i.e. the devices on either side of the AVR, which shouldn't be able to "see each other via HDMI until the AVR itself is finally powered on last) already powered on and stabilized, the HDMI handshake process that will go on (to the two active HDMI-enabled devices as seen by the AVR) when you power on the AVR should probably work without any issue. Certainly you already see evidence of this for yourself, as you describe changing inputs on the AVR and then returning to the DVR input and now everything magically works just fine.
This is unfortunately to be expected when you have more than two devices connected directly to each other via HDMI (and where the HDMI handshake is less complicated and typically what is tested by the manufacturers), i.e. when you insert an AVR as an "HDMI switcher" in between two HDMI-enabled devices.
Note that I have a similar issue with my own setup which uses a newer RX-V867, and also my Linksys DMA2100 Windows Media Extender (i.e. DVR-like box from my HTPC), and my Oppo BDP-103 (with the DMA2100 going INTO the external HDMI-1 input of the 103), and my Panny 65VT50 HDTV. The Oppo has an optional setup where one of its two external HDMI inputs or its own internal disc player can be selected as the default when you power on the 103. Well, even though I want to select the DMA2100's external HDMI-1 input as the default, I too was getting a black screen on my TV because the DMA2100 takes about 30-seconds to stabilize and become operational after its power-on. So in my own FOUR-DEVICE HDMI-chain, everything else was looking for an HDMI handshake while the DMA2100 was still stabilizing!!
My solution: DMA2100 powered on first, and just wait until it stabilizes. Then the other devices can be powered on. Alternatively, since this was really a pain in the neck, I just changed the 103 to use its own internal player as the power-on startup default (even though I really wanted to be watching HDTV via the DMA2100). And I could now power on all devices (including the DMA2100 which takes 30-seconds to stabilize) at about the same time. Then, once the DMA2100 was ready to go, I change the input on the 103 to be external input HDMI-1 for the DMA2100, thus triggering an "end-to-end 4-device HDMI handshake" which works perfectly, and I'm off and running.
Again, anytime you have three or more devices inter-connected via HDMI, your HDMI handshake stability is up for grabs. You'll just have to live with it I'm afraid, including any workaround tricks or gimmicks you've discovered to overcome the anomalous behavior.
DSperber is offline
post #1006 of 1011 Old 01-21-2015, 08:54 AM
Surferman's Avatar
RX-V863 w Dual 691 Turntable & Shure V15 Type IV
After a number of years without playing my vinyl I finally decided to hook up my Dual 691 turntable with Shure V15 Type IV cartridge. As this is a moving magnet cartridge I hooked it up directly to the phono jacks, and to the ground connection. The sound output is way down in the mud and when I do turn up volume I get hum and some distortion.
Has anyone else experienced this and are there any suggestions on a fix? This turntable configuration worked fine with my Onkyo A10. Thanks in advance. I hope this is in the appropriate forum.
Surferman is offline
post #1007 of 1011 Old 01-29-2015, 12:37 PM
enjoyingmylife's Avatar
I've read from many people that most of these modern Yamaha AVRs don't have quality phono preamps. Your best bet IMO might be to buy an affordable but working vintage (from before CDs became popular) integrated amplifier and use that as a separate preamp between your turntable and the Yamaha. It's what I plan to do as well.
Prob can get something good from CL for $100-200 or less depending on where you live
Here's a good place to start on makes and models: http://www.audiokarma.org/forums/sho...d.php?t=307887
Surferman likes this.
enjoyingmylife is offline
post #1008 of 1011 Old 07-16-2016, 03:14 PM
mario64's Avatar
Could someone please post a link to the most recent RX-V863 firmware? The 663 firmware file doesn't work. You get a "Model Type Err"
mario64 is offline
post #1009 of 1011 Old 09-19-2016, 07:21 PM
lkaskel's Avatar
Liked: 0
Sub while listening to music on my V863
So...while listening to music I prefer to use the 2 channel settings without any effects. My issue is that it does not output to my sub. I cannot seem to figure this out so hopefully someone here can. My previous system (Onkyo) would output to L&R + sub in 2 channel mode so I thought this system would as well. Maybe my fault The sub is a powered Infinity and it is connected to the RCA sub out.
Thanks in advance!!!!
lkaskel is offline
post #1010 of 1011 Old 12-28-2016, 08:51 PM
WormInfested's Avatar
Quoted: 63 Post(s)
Liked: 48
finally found this thread. i just picked up a used 863 and have yet to get a spool of 12 gauge wire to hook everything up but with one speaker connected by short wire, i like what i hear. just a secondary 7.1 setup. can presence speakers work with 7.1 or just 5.1? looking forward to getting this thing up and running fully and get an svs pb-1000 or something near to that.
Pioneer Elite SC-05
JBL Studio S312II fronts, JBL Studio S10IIs mid and S8IIs rear.
Single JBL S38 center channel
Power Sound Audio V1800 & DIY 18" Ported Sub
Oppo BDP-103
BenQ W7500 & Silverticket 110" matte white 16:9
WormInfested is offline
post #1011 of 1011 Old 01-20-2017, 07:36 PM
Quoted: 39 Post(s)
So it is time to update the receiver to one with HDCP 2.2. Can someone suggest a newer replacement? I'd like similar specs etc. Thanks!
akmandal is offline
