Firmware/Update Requests For Onkyo/Integra-Please Read - Page 13 - AVS Forum | Home Theater Discussions And Reviews
Old 04-06-2008, 11:33 AM
kinchung's Avatar
Thanks Joerod
I have already updated my 905 from 1.03 to 1.08 and the latest DSP as well.
KC
PC: Sony Notebook with USB-Serial Adapter (Keyspan USA-19)
Burning Software: Nero Burning Rom 8
Update Path: 1.03 -> 10.5 -> 1.08 -> DSP
kinchung is offline
Old 04-06-2008, 11:42 AM - Thread Starter
joerod's Avatar
Quoted: 607 Post(s)
Liked: 491
I appreciate the few people who have responded about the donation.
I should have a paypal account up and running here soon. For those that don't mind taking the time the usps will work to...
UPDATE: 876 firmware/DSP Updates sent out (the new ones) with more to come...
My Sony 5000ES Review PART 2 FINISHED:
http://hstrial-jrodriguez996.homeste...=1462841668379
joerod is offline
Old 04-06-2008, 12:32 PM
bingo600's Avatar
Btw. with the new SR875 - fw. 1.07
I can confirm that Setup+Enter invokes the : Save Settings ? - Menu
And pressing Enter one more time does nothing , it never writes(says) settings saved.
Setup+Return says : Save failed
/Bingo
bingo600 is offline
Old 04-07-2008, 08:29 AM
nutthouse's Avatar
/Bingo
I saw the same thing initially but I was hitting return. As soon as I tried the correct "enter" it worked for me. Too much interchangability of return and enter from pc's was my problem. The save failed message was the restore function saying the save failed because it had not been done since the reset after firmware update.
nutthouse is offline
Old 04-07-2008, 08:36 AM
boe
boe's Avatar
Quoted: 902 Post(s)
Liked: 416
There are three pages to the PDF on the firmware update - I'm not sure if page 3 is necessary if you've completed the second page - please let me know.
I ran the update under the app updater - it seemed to update the firmware OK.
I see Firmware update -3 (installable setup executable)- is that only to be be run if Firmware update -2 doesn't work or do you have to run both? (I'm not sure if there is more than one section to the firmware like there is for the DSP).
boe is offline
Old 04-07-2008, 08:42 AM
fyzziks's Avatar
Originally Posted by sjv View Post
I updated my 8.8 a few days ago and re-set all perameters. Just an added test I performed last night as some had posted that this "feature" of the updates didn't work for them. I played a concert DVD with my Oppo 970 CD/DVD player as usual with my monitor on. The Oppo is connected to the 8.8 only by an HDMI cable and the monitor (70" Sony XBR2) is connected to the 8.8 also by a HDMI. While playing the DVD, I turned off the monitor and the audio continued playing from the Oppo. At about 2 minutes into this, the sound stopped breifly for a few seconds but returned thereafter. So apparently in my case, that fix worked as stated.
Did it not work before? AFAIK the Oppos have always worked fine whether the display was on or off, no matter what display it was. One of their many virtues.
fyzziks is offline
Old 04-07-2008, 10:01 AM
manofsteele's Avatar
Can't wait for the 805 fw update. I have two older dvd players a Toshiba and a Sony. Which one should I use? I do need optical cables correct?
manofsteele is offline
Old 04-07-2008, 11:14 AM
Category 5's Avatar
Quoted: 140 Post(s)
Liked: 103
You have to keep holding setup the second time you hot enter as well.
Samsung 55" JS8500, 48" JS9000, 65" HU8550, 46" ES7100, 55" D8000 (RIP)
I Like Digital!
Category 5 is offline
Old 04-07-2008, 12:02 PM
trikosuave's Avatar
So I couldnt find the right cable to borrow from work so I went to a computer store in town and asked for a 9 pin straight-thru serial cable. The guy didn't understand the terminology "straight-through" in regards to a serial cable so he asked a co-worker who told him I needed a null-modem cable. Now that i'm back from lunch I looked a a null modem cable diagram and noticed that the transmit -received cables are crossed. It doesn't look straight through to me.
Is a null modem cable what I need?
trikosuave is offline
Old 04-07-2008, 12:10 PM
billbillw's Avatar
Nope. You need a "straight thru" or 'extension' cable. DB9 M/F (male one end, female the other end).
Something like this:
They have other lengths available, just make sure if is DB9 M/F, and not a Null Modem.
Just pick your length. With shipping, it will probably still be cheaper than buying on in-store. Monprice ships quickly too (same day or next day)
If it ain't in HD, it ain't worth watching!
billbillw is offline
Old 04-07-2008, 12:52 PM
bingo600's Avatar
A Straight through , is the same cable used for connecting a PC to a Modem.
So get a "PC 9Pin Modem Cable" it has "a male & a female" 9 Pin plug
/Bingo
bingo600 is offline
Old 04-07-2008, 02:13 PM
trikosuave's Avatar
so whats the difference between a "null modem cable" that one person says not to get and a "modem cable" that one person says I should get?
Old 04-07-2008, 02:23 PM
Clark Burk's Avatar
Quoted: 138 Post(s)
Liked: 188
I'll take a stab at that one. A null modem cable will have two female ends, and is used usually to transfer files between two computers. It has the receive and transmit wires cross-linked.
From answers.com:
An RS-232 cable used to connect two computers in close proximity for file transfer. It attaches to the serial ports of both machines and simulates what would occur naturally if modems and the phone system were used. It crosses the sending wire with the receiving wire
Clark
Clark Burk is offline
Old 04-07-2008, 03:04 PM - Thread Starter
joerod's Avatar
Quoted: 607 Post(s)
Liked: 491
Another UPDATE... I received a few PMs about the "donation" for my contact. I am taking her out to dinner (actually next Friday) and plan to maybe get her something. SO far I have received about 12 PMs. I now have the paypal account ready so feel free to send me a PM. I was only asking for members who felt like it to send $1.00. I figured if we had around 75 to 100 I could get her something from us members here at AVS. Who know, maybe she will slip me 1.10... If you can't I totally understand and I am not keeping track of who does and who doesn't. I just thought this would be a good gesture for all the risks she takes for us...
Firmware/DSP Updates= 1198... Once I get the 805 I expect it to be around 5,000 in a hurry...
joerod is offline
Old 04-07-2008, 03:22 PM - Thread Starter
joerod's Avatar
Quoted: 607 Post(s)
Liked: 491
I guess it really does not matter... Paypal joe.rod@msn.com
joerod is offline
Old 04-07-2008, 03:43 PM
Dazog's Avatar
Quoted: 35 Post(s)
Liked: 50
Hopefully it works on the 705 also then you are talking around 10,000 :P
Dazog is offline
Old 04-07-2008, 03:45 PM
Bizill's Avatar
set up perfectly. $ sent.
Bizill is offline
Old 04-07-2008, 04:05 PM - Thread Starter
joerod's Avatar
Quoted: 607 Post(s)
Liked: 491
THX So far we have enough for the tip...
joerod is offline
Old 04-07-2008, 04:06 PM - Thread Starter
joerod's Avatar
Quoted: 607 Post(s)
Liked: 491
And yes, 10,000 requests sounds about right once we add the 705.
I don't even want to think about the 605...
joerod is offline
Old 04-07-2008, 04:28 PM
rayjs's Avatar
905 Version IDs after 1.08:
Main 9....1.08 / 08223A
SR8051...08214A
SR8052...07518A
SR8053...07820B
My 905 Version IDs after 1.08:
Main Version 9 1.08/08223A
DSP1 07601A
DSP2 07518A
DSP3 07518A
So any ideas what is going on here with my DSP's?
I have not yet applied the DSP update via CD
Thanks in advance
rayjs is offline
Old 04-07-2008, 04:59 PM
Smarty-pants's Avatar
Quoted: 747 Post(s)
Liked: 623
Joe, I haven't actually obtained anything from you yet, but I sure plan too. Hopefully maybe you can get that main firmware update for us soon. We'd all be "up a creek" without you, so you certainly deserve it. Sweet talk her into giving you waht you need (<-talkin firmware here ).
I actually sent you $2 since I will probably need more help than others... .
Smarty-pants is offline
Old 04-07-2008, 05:09 PM
sjv
sjv's Avatar
Location: New Orleans' North Shore-beautiful St. Tammany Parish LA
SR8051...08214A
SR8052...07518A
SR8053...07820B
DSP1 07601A
DSP2 07518A
DSP3 07518A
So any ideas what is going on here with my DSP’s?
Thanks in advance
Uhhhh, yeah! You answered you're own question. If you don't apply the DSP update via CD.......the DSP #'s will not change or be updated.....on your 905.
It's a two (2) part updade.... 1. main firmware 1.08 and then 2. DSP update via CD....or 1. DSP update via CD and then 2. main firmware 1.08. It doesn't matter which is done 1st as they're not related. Remember that the DSP update WILL wipe out all your settings...write them down first so you can restore them. DSP 1 & 3 numbers will change with the DSP update.
sjv is offline
Old 04-07-2008, 05:18 PM - Thread Starter
joerod's Avatar
Quoted: 607 Post(s)
Liked: 491
Thanks! I noticed paypal takes about 36 cents per donation!
joerod is offline
Old 04-07-2008, 05:22 PM
sjv
sjv's Avatar
Sorry, joe. Had I known that, I would have added it to the total.....what the hell....I'll send more. For what you've done for hundreds in time invested alone, you and you're O/I friend are more than worth it.
sjv is offline
Old 04-07-2008, 06:04 PM
quozl's Avatar
G'day joerod,
10 bucks sent to you towards the dinner fund. Thanks for sending the update as the Australian service centre's had no bloody idea what they were doing where as we did the update at home in about 15 minutes thanks to your and gurkey's help.
Cheers Al
quozl is offline
Old 04-07-2008, 06:08 PM
billbillw's Avatar
Perhaps, you should just upload them to a free file hosting site and post the link. That would be so much easier.
Old 04-07-2008, 06:09 PM - Thread Starter
joerod's Avatar
Quoted: 607 Post(s)
Liked: 491
THX! 10.00 is the record! I appreciate everyone's effort... This is AVS at its best!
joerod is offline
joerod's Avatar
Quoted: 607 Post(s)
Liked: 491
I would like to billbillw but Onkyo would definitely have an issue with that.
joerod is offline
Old 04-07-2008, 06:15 PM - Thread Starter
joerod's Avatar
Quoted: 607 Post(s)
Liked: 491
Thanks Bill M.! You did to much!
If we get up there I will let the AVS members help pick out something nice for her...
joerod is offline
Old 04-07-2008, 06:18 PM
Dmitry's Avatar
Joe, I put a couple of bucks into snail mail before you got your Paypal up and running, so let me know if it's not there by week's end.
Dmitry is offline
