Firmware/Update Requests For Onkyo/Integra-Please Read - Page 186 - AVS Forum | Home Theater Discussions And Reviews
post #5551 of 5565 Old 03-25-2013, 08:14 PM
jasonvr's Avatar
Quoted: 14 Post(s)
Liked: 31
Originally Posted by charlesdill View Post
Hate to bring this back up, but I've started to get some popping on my 705. I've been researching and ended up here...
I have the following:
TX-SR705
Main 1.06 / 08223A
DSPS8051: 08214A
DSPS8052: 07518A
DSPS8053: 07820B
HDMI 1.01 / 07706A
VD: 3.62 / 07717A
Can I get some advise as to what, if anything, I can update in attempts to fix the pop? I have a 1.02 HDMI update, but nothing later than what I have as far as Main or DSP.
CD
What material are you playing/listening to when you get the pops? The DSP update only deals with pops from DTS-MA sources IIRC
LG B6 65" OLED, Phillips UHD BluRay, Denon AVR-X4000, Chromecast Ultra, Roku Ultra, eD speakers and sub
jasonvr is offline
post #5552 of 5565 Old 03-26-2013, 03:49 AM
charlesdill's Avatar
Hmmm. It's been happening with cable (Comcast) through hdmi. A few times the 705 has even shut down after some popping. Maybe it's dying? :-(
charlesdill is offline
post #5553 of 5565 Old 06-18-2013, 02:10 PM
sambou812's Avatar
Originally Posted by tridner View Post
Was able to get 1.04 and 1.05 for the 876/906/9.9 receivers so please disregard my request for the files.
Where did you get the files? I am on 1.00 so I am looking for all fw updates to date.
Onkyo sent me an dsp firmware update disk but no main firmware loader
My 906 has sat for along time and I'd like to put her back in service.
Thanks for any help you could give me.
Thanks again,
Todd
sambou812 is offline
post #5554 of 5565 Old 11-23-2013, 11:22 AM
snerp's Avatar
Hello,
I have an Integra DTR-5.6 that has Zone 1 output issues. Both amps have tested out. I was told it must be a software issue. I am trying to find a copy of the firmware and info on a flash jig.
Here is a link to my post:
http://www.avsforum.com/t/1500317/integra-dtr-5-6-w-zone-1-output-problems
Any help would be greatly appreciated.
Thank you,
Snerp
snerp is offline
post #5555 of 5565 Old 02-21-2014, 05:12 AM
irongambit's Avatar
Howdy,
I'm definitely late to the party...I just bought a new old stock DTR-9.9. Does anyone still have the firmware / dsp upgrade available for this? Please let me know.
IG
irongambit is offline
post #5556 of 5565 Old 04-09-2014, 09:19 AM
ThA tRiXtA's Avatar
Hello all, my apologies for bumping an old thread, but I am absolutely out of options.
I own 2 or 3 Onkyo receivers, one of which is the TX-SR875. I like this receiver and all but right after I bought it I found the firmware update thread and performed all of the updates up to v 1.08. Everything went smoothly, until the first power outage where I discovered the E2PROM error and the resulting setup loss. After not being able to fix it after several tries I gave up and decided to just live with it... basically I have to setup and recalibrate the receiver every time the power goes out. The "setup store" function also fails.
Fast forward and I am again trying to give it another shot and make that error go away. Through some research I have learned that some people were able to make this go away by reflashing to an older firmware version, perhaps 1.04, 1.05 or 1.06.
I have found 1.08 and 1.07 and tried flashing to each of them to no avail. I updated the DSP to 12116A / 07518A / 07820B last night which went well. (I assume this is the latest / best choice for the DSP firmware? I found it in a thread from about 2011. It didn't change anything however. My HDMI is at 1.02 so I think that is current.
Anyways, I called onkyo support this morning to see if they could help me out and of course they wouldn't barely even listen to me. They flat out said flashing to any revision wouldn't change anything as none of the firmware revisions listed this as either an issue or a fix. They also wouldn't detail what each firmware revision offered what fixes.
I have been searching for a list of what each revision, from 1.04 to current changed or did when it was applied. I can't find it anywhere. I know it is out there somewhere, it's probably just buried in a 200 page thread.
If anyone has this information if they could copy and paste it I would greatly appreciate it. I am trying to see how far back I can roll my firmware without running into other problems or issues. If I did roll back to 1.06 or any of the earlier versions, what functionality would I lose?
Also if anyone has any of the older F/W versions for the 875 aside from 1.08 and 1.07 if you could post them I would be in your debt.
For those that need I have the latest DSP, HDMI and 1.07 / 1.08 firmwares if you want.
Thanks for reading.
ThA tRiXtA is offline
post #5557 of 5565 Old 04-09-2014, 02:59 PM
Toknowshita's Avatar
Quoted: 37 Post(s)
Liked: 61
Ah the days of the Onkyo jig FW update. I never had an issue with my 805 not holding setup information after doing the jig update.
Sorry I don't think I have access to any of the older FW files. At this point if it's an issue it might be time to retire the unit.
Audyssey XT32 is a worthy upgrade.
Toknowshita is offline
post #5558 of 5565 Old 04-09-2014, 06:19 PM
ThA tRiXtA's Avatar
Hey, thanks for your feedback.
I never had to use the dongle or jig at least, so I have that going for me. I just bought a new usb to serial cable, worked great.
I am considering retiring the unit in a sense, in this case retiring it is moving it to my rec room where it will still be used fairly regularly but not is my HT room as my main receiver. I will shortly be building a new dedicated theater room in the basement of the house we just moved into so it will include a new battery of equipment with that.
So I am going to continue on my search for the older revisions of the firmware. I appreciate you stopping by even if you didn't have them on you. You by chance don't know what each revision fixed or changed do you? That's what I really need, to know what I am trading out in order to not have this e2prom error if I roll back to an old F/W.
What's Audissey XT32? a new AVR?
post #5559 of 5565 Old 04-18-2014, 07:47 AM
Snype32's Avatar
Just wondering if this is the right place to be looking for the firmware update for an Integra DTR 8.8 that has never been updated? Is there also a guide showing how to do it? Thanks for any info.
Snype32 is offline
post #5560 of 5565 Old 06-02-2014, 06:49 PM
juancaca's Avatar
How can I update the firmware of my TX-SR806?
Please somebody help me.
juancaca is offline
post #5561 of 5565 Old 09-01-2015, 03:55 AM
Liked: 0
Hello,
Time to bring some life to this old thread again.
I just updated my 805 main firmware from 1.06 to 1.08.
I downloaded the iso xx5. Everything went well but now i get the E2PROM error.
Tried to search for solutions but nothing works.
Maybe someone still have the old firmwares so i can try downgrading? =)
Please send me a PM if you have or if you think you know a solution.
Thanks in advance =)
Daniel Kristensson is offline
post #5562 of 5565 Old 10-10-2015, 12:25 PM
Liked: 0
Hi Daniel,
Can you tell me where to download that xx5 ISO? I can only find dead rapidshare links.
I have a TX-SR875 and i need to upgrade with a JIG but i can't find the flash software or the
1.04 firmware what i supposed to flash.
Johan
aardbei is offline
post #5563 of 5565 Old 11-09-2015, 01:38 AM
Liked: 0
Onkyo MMPU Setting
Hello
After a failed firmware update, my TX-NR807 display show
MMPU Setting
and is totally unresponsive to any actions and buttons.
It is in fact "Bricked".
I have found that there is a jtag interface available and hope there are someone out there able to help me with necessary info and bin-files for me to be able to fix the problem.
The very best regards
Ketil Tuft
Norway
ktuft@online.no is offline
post #5564 of 5565 Old 10-26-2016, 07:05 PM
Liked: 0
Got any more of them dongles?
Do you still have any of those dongles. I got a used gem integra 7.8 with updater 1.0. have my usb to serial, but no dongle. I'm not sure I can trust myself with the circuitry.
sdriggs is offline
post #5565 of 5565 Old 10-30-2016, 07:09 PM
jasonvr's Avatar
Quoted: 14 Post(s)
Liked: 31
If you're talking about the same dongles that were used for updating 805's, I think I have the last one remaining in existence
The details on the Deposit system are here:
If you're interested, PM me, but know it is going to be about a week before I could send it out
jasonvr is offline
