Firmware/Update Requests For Onkyo/Integra-Please Read - Page 58 - AVS Forum | Home Theater Discussions And Reviews
post #1711 of 5565 Old 05-27-2008, 12:10 PM
WilliamZX11's Avatar
Quoted: 25 Post(s)
Originally Posted by r1dude57 View Post
Is the updater version (1.00 or 1.01) what you find under the HDMI when scrolling through the different versions? If so, I am at 1.01 which is good right? All of this stuff is way over my head, so am feeling pretty apprehensive about doing this myself. I will be doing the update for the DTS-MA bomb because I can handle that one. I strictly watch movies with my 805(haven't noticed any lip sync issues, but do get audio delay once in a while ff/rewinding through a movie), and am wondering if I should keep obsessing about the upgrade. My present firmware says 1.04, but the HDMI says 1.01.
You will only see the updater version when you put the unit in update mode.
WilliamZX11 is offline
post #1712 of 5565 Old 05-27-2008, 12:12 PM
billbillw's Avatar
No, the HDMI version is not the same as the MainUpdate Mode version. The MainUpdate Mode version is only displayed when you enter the serial update mode. To get there, you have to do the following:
Unplug the unit,
Press/hold enter (on the front panel),
and then plug in the unit.
You should see MainUpdate Mode on the front panel along with a series of numbers. That number needs to start with 1.01/ for you to to the update posted in this thread.
Chances are, you do not have 1.01. Most everybody that has the 1.04 firmware is stuck with the 1.00 updater version. Sorry.
If it ain't in HD, it ain't worth watching!
billbillw is offline
post #1713 of 5565 Old 05-27-2008, 12:46 PM
eap_44's Avatar
Unplug the unit,
I will try this when I get home tonight. Last night I updated the DSP FW and I saw that my main FW is 1.04. I may have the 1.00 MainUpdater which will leave me stuck.
Oh well, if that's the case then I just will leave it the way it is. I haven't noticed any lipsynch issues anyway to bother changing the FW.
Or maybe I will sell my Unit and get the Yammy 663.
eap_44 is offline
post #1714 of 5565 Old 05-27-2008, 01:16 PM
r1dude57's Avatar
Unplug the unit,
Thanks for the reply. I won't even bother checking to see if I have 1.01 updater, as it appears I probably won't. I haven't been plagued by many of the issues that you guys describe so I may just leave it alone. Well, I need to do the DSP upgrade because I have a Samsung Bluray/HDDVD player coming this week that will supposedly allow bitsreaming. Maybe I should just buy a PS3 for this thing to be on the safe side (using PCM), and plug my new Sammy into my XBR4 in the bedroom. Fortunately, if I decide to send my 805 to Onkyo, I believe that the regional service center is only about 25 miles away.
r1dude57 is offline
post #1715 of 5565 Old 05-27-2008, 01:52 PM
eap_44's Avatar
I just confirmed that my MainUpdater is only 1.00 although my main FW is 1.04. Oh well... I'll just leave it the way it is.
eap_44 is offline
post #1716 of 5565 Old 05-27-2008, 03:52 PM
allano's Avatar
Originally Posted by ohjay View Post
unplug your 805 or 705.
hold down enter on the 805* under the flap*
plug in 805 while holding enter down
Mode should appear. To get out of this mode I had to unplug my 805 again.
I tried to verify my version on my 705, I it does not seem to work. Tried this with the sytem on, unpluged it, held enter, plugged it back in. Nothing. Tried the same thing with the system in standby same results. As I missing something?
allano is offline
post #1717 of 5565 Old 05-27-2008, 03:54 PM
mrgribbles's Avatar
The hold enter and plug routine does not work on the 705.
Some days it's hardly worth chewing through the restraints.
mrgribbles is offline
post #1718 of 5565 Old 05-27-2008, 04:00 PM
allano's Avatar
Is there a way to check the 705? The main version is main 1.01/07618A, would this be the mainupdater version?
allano is offline
post #1719 of 5565 Old 05-27-2008, 04:55 PM
Skid71's Avatar
Sorry to say, but nope. It's your Main FW version number, not the MainUpdater version number.
Pure speculation, and I'm not giving up.... I'm thinking that since we 705 owners cannot find a way to find out our Main Update version, it may not exist, and only have the option of using the jig.
Again, nothing but speculation. I'm certainly hoping someone proves this theory pure rubbish.
Skid
BOTJ Member... Onk 705 FW 1.06
Skid71 is offline
post #1720 of 5565 Old 05-27-2008, 05:34 PM
allano's Avatar
Skid
Thanks for the info. I will continue to watch this and the main 705 thread.
allano is offline
post #1721 of 5565 Old 05-27-2008, 09:11 PM
TiVoHD's Avatar
Quoted: 57 Post(s)
I hate to burst your bubble, but the Samsung combo player doesn't currently bitstream any advanced codecs. It doesn't internally decode them either for that matter.
TiVoHD is offline
post #1722 of 5565 Old 05-27-2008, 09:13 PM
Smarty-pants's Avatar
Quoted: 747 Post(s)
Liked: 621
Ya but TiVo, isn't there supposed to be a new firmware coming to maybe address those issues?
Smarty-pants is offline
post #1723 of 5565 Old 05-28-2008, 12:51 AM
tpaxadpom's Avatar
Quoted: 37 Post(s)
Liked: 25
I successfully upgraded the main fw from 1.06 to 1.08. I saved the setting before I upgraded it. I think Lip Sync delay is gone now. I have to play more with the AV delay settings to fine tune it though. Not sure if 5 ms increment is good enough.
It feels like the unit sounds somewhat different. I wonder if anyone noticed that.
tpaxadpom is offline
post #1724 of 5565 Old 05-28-2008, 07:16 AM
jimjr's Avatar
Samsung is not a reliable enough company to bet the farm on that. I've had one since January, Samsung suggested that the mythical firmware you speak of would be released sometime in May, but now nobody at Samsung seems to have a straight answer as to its status. I'm hopeful, but not optimistic.
jimjr is offline
post #1725 of 5565 Old 05-28-2008, 07:20 AM
jimjr's Avatar
I'm not sure if it's my imagination, but it sounds to me like there's more detail in the side channels.
jimjr is offline
post #1726 of 5565 Old 05-28-2008, 08:00 AM
Kevin R. Anderson's Avatar
I had a similiar experience, but I also re-ran Audyssey immediately after the DSP and Main update. I took 7 readings (as suggested in the FAQ) and then did a check with Room EQ Wizard and found a very nice frequency response across the board (generally +-3db). The Audyssey even did a reasonably good job flattening out 40Hz peak from the subwoofer.
I don't know if there is a cause-and-effect resulting from the new firmware, but it seems a good idea to re-run Audyssey after doing the upgrade.
ISF Certified
Kevin R. Anderson is offline
post #1727 of 5565 Old 05-28-2008, 08:22 AM
manofsteele's Avatar
How can this FW fix the Lip Synch. Didn't Onkyo admitt that with the three DSP chips that there is an inherent delay that cannot be solved?
manofsteele is offline
post #1728 of 5565 Old 05-28-2008, 08:58 AM
TiVoHD's Avatar
Quoted: 57 Post(s)
We won't take this thread on that tangent. It would be a long one!
TiVoHD is offline
post #1729 of 5565 Old 05-28-2008, 08:59 AM
jimjr's Avatar
Originally Posted by Kevin R. Anderson View Post
I had a similiar experience, but I also re-ran Audyssey immediately after the DSB and Main update. I took 7 readings (as suggested in the FAQ) and then did a check with Room EQ Wizard and found a very nice frequency response across the board (generally +-3db). The Audyssey even did a reasonably good job flattening out 40Hz peak from the subwoofer.
I reran it too, using three more positions than the pre-update set up. No way to tell if it was the firmware or the more extensive calibration. Probably more the latter, but who knows.
jimjr is offline
post #1730 of 5565 Old 05-28-2008, 09:02 AM
billbillw's Avatar
Its possible that they introduced a video delay, or they just shaved the audio delay down to the very lowest possible level, which would minimize the problem. Most of the newer TVs have some delay in processing the image anyway.
I, for one, did not have a lip-sync issue with v1.06, so the upgrade to 1.08 was for the audio lock on speed, which I am happy to say, is very noticeable and a nice improvement.
post #1731 of 5565 Old 05-28-2008, 09:13 AM
TiVoHD's Avatar
Quoted: 57 Post(s)
Is the audio lock now instantaneous? Do we know if that improvement was a result of the main fw or the DSP fw?
TiVoHD is offline
post #1732 of 5565 Old 05-28-2008, 09:35 AM
Quoted: 747 Post(s)
Liked: 621
TiVo, some people have said that the audio actually comes on BEFORE the video sometimes. So, I guess that would count as instantaneous.
It is the result of the MAIN fw upgrade.
post #1733 of 5565 Old 05-28-2008, 09:41 AM
billbillw's Avatar
Not instant, but probably less than 1 second. Previously, it was about 2-3 seconds. This improvement is purely from the 1.06>1.08 upgrade. I did the DSP update more than a month ago and it had no noticeable change.
post #1734 of 5565 Old 05-28-2008, 10:33 AM
jimjr's Avatar
Yep, that's been my experience. Audio before video and it was the main firmware, not the DSP. I know this because I did not apply both updates at the same time. Did the main first and that fixed the audio lock by itself. Actually, I have not noticed the DSP update doing anything at all. I don't have a Blu-Ray player than can bitstream DTS-MA to confirm the bomb fix. I presume it was successful, but I don't hear anything from my receiver leading me to believe that the DSP update did anything other than fixing the bomb.
jimjr is offline
post #1735 of 5565 Old 05-28-2008, 10:52 AM
People were raving at how the DSP update fixed this, now people are saying the FW fixed this. Is there an official memo as to what this FW was supposed to fix?
post #1736 of 5565 Old 05-28-2008, 11:01 AM
slimm's Avatar
No.
slimm is offline
post #1737 of 5565 Old 05-28-2008, 11:03 AM
r1dude57's Avatar
Yup, I was aware of that(knew that before purchasing for 299). I'm just hoping for the promised firmware update , then will decide which of three systems to throw it into.
r1dude57 is offline
post #1738 of 5565 Old 05-28-2008, 12:07 PM
jimjr's Avatar
rlb I think made the observation that the Reon processor adds some additional video delay already. That may be how Onkyo is trying to compensate for at least some of the audio lag, if in fact it is true that the DSPs can't be further tweaked and that the delay on the audio side is unavoidable. It will be interesting to see if the rumored f/w version 1.10 will do anything more on the video end.
jimjr is offline
post #1739 of 5565 Old 05-28-2008, 12:14 PM
nfrankli's Avatar
I'm a fellow 805 owner who has Main FW 1.03 and thus probably has the MainUpdater 1.00. It looks like the only way to upgrade the FW on these systems is with the "jig", but thus far no one has been able to get their hands on one of these. I had guessed that the IC on this jig was actually a very common IC and started hunting for it. If you look in detail at the photo in the 805FW pdf it looks like it has "NEC D4721" printed on it. A quick google search turned up the following part
NEC
MOS INTEGRATED CIRCUIT
m P D 4 7 2 1
RS-232 LINE DRIVER/RECEIVER AT 3.3 V/5 V
http://pdf1.alldatasheet.com/datashe...721GS-GJG.html
The intended use description confirms this is the part we are looking for. The actual part is called a "micro" or uPD4721, but if you just paste that into another window the "u/micro" gets converted to the letter "M", thus the MPD4721GS seen in the 805FW part sheet.
Who wants to take ball and run with this?
nfrankli is offline
post #1740 of 5565 Old 05-28-2008, 12:24 PM - Thread Starter
joerod's Avatar
Quoted: 607 Post(s)
Liked: 486
Already running with the ball.
Good work, we are on the same page!
My Sony 5000ES Review PART 2 FINISHED:
http://hstrial-jrodriguez996.homeste...=1462841668379
joerod is online now
