Firmware/Update Requests For Onkyo/Integra-Please Read - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 5565 Old 04-02-2008, 05:46 PM - Thread Starter
joerod's Avatar
Quoted: 724 Post(s)
Liked: 655
Awesome! Good work.
My Martin Logan Illusion & Impressions Review:
http://hstrial-jrodriguez996.homeste...=1494808387395
joerod is online now
post #182 of 5565 Old 04-02-2008, 06:00 PM
GO PAT's!'s Avatar
Thanks joerod. Just updated my 875. It took 3 attempts but all is good now. 1st tried using Pioneer DV-563A...no writing at all. 2nd tried my Toshiba HD-A3...would only get to Writing 2 DSP then S/PDIF Update..had me worried a bit. 3rd time was the charm using my first ever DVD player Panasonic DVD RP62. Thanks again!
GO PAT's! is offline
post #183 of 5565 Old 04-02-2008, 06:23 PM
wwyjoe's Avatar
Originally Posted by quack724 View Post
Wanted to share my update success on my 885 SSP. I used the PS3 to perform my update.
First I used CDBurnerXP for my PC to burn the DSP update. I burned .wav file as an audio file.
On my PS3 I used the optical out and connected to optical 1 on the 885. I had the following in my PS3 settings,
1) Music settings -> Audio CD output freq: 44.1/88.2/176 & bitmapping : off
2) Sound settings -> Digital optical out: 44.1kHz & 48kHz (i know someone earlier had posted to tick 44.1 only but both my 44.1kHz and 48kHz were greyed out and could not be unticked for some reason)
My 885 has FW 1.04 / 07927A and originally had the following DSP versions,
1 - 07927A
2 - 07518A
3 - 07820B
I followed the Onkyo instructions sent from joerod. They were pretty straightforward,
On the Onkyo unit itself (not the remote)
1) Hold "Display" and then while holding display press "standby/on"
2) press tone "+" (it's the bottom button not the top)
3) press "return" (you should immediately see "S/PDIF..."
4) I immediately hit play on the PS3 controller and the PS3 played my CD
I then saw "S/PDIF Update" then "Writing 1st DSP" then "S/PDIF Update" ...then "Writing 2nd DSP" then "S/PDIF Update" again then "Writing 3rd DSP" and then "S/PDIF Update" again. I never did see "Complete" or "Clear" as the Onkyo instructions suggest. I just kept seeing "S/PDIF Update" and after about 10 min of not seeing any change, I stopped the CD and manually power cycled the 885. I immediately checked the DSP versions and was relieved to see,
FW 1.04 / 07927A (no change to FW)
1 - 08214A (this is new)
2 - 07518A
3 - 07820B
All my 885 settings were erased and I had to run set up again. Good thing I wrote all my previous settings down. Since the PS3 cannot bitstream DTS-HD MA I just did a sanity test of a Blu Ray disc outputting PCM DTS core track from LFoDH just to make sure my Onkyo would work. Not sure if the main DTS-MA HD issue is resolved however.
I hope this helps others. And many thanks again to joerod!
Thanks quack. Success with my 885 and PS3 using your steps.
wwyjoe is offline
post #184 of 5565 Old 04-02-2008, 06:53 PM
Hunter67's Avatar
Thanks Joerod, updated my 885 with 1.07 and all is well. Got to love the audio locking on almost instanly now, best part of the update IMHO.
Hunter67 is offline
post #185 of 5565 Old 04-02-2008, 06:54 PM - Thread Starter
joerod's Avatar
Quoted: 724 Post(s)
Liked: 655
I definitely agree with that...
post #186 of 5565 Old 04-02-2008, 07:22 PM
quack724's Avatar
Quoted: 94 Post(s)
Liked: 32
Awesome. Glad it helped.
quack724 is offline
post #187 of 5565 Old 04-02-2008, 07:48 PM
bbwebb's Avatar
Completed both the DSP update (using Panasonic BD30) and the 1.08 FW upgrade on my 905 with no problems.
Bill
Be good...and you will be lonesome
- Mark Twain
Finished Home Theater - For Now
Home Theater Build
bbwebb is offline
post #188 of 5565 Old 04-03-2008, 01:39 AM
Gary Murrell's Avatar
thanks Joe for the update, worked on my OP 885 last night for about 2 hours, bottom line, trying to do it the easy way with the front aux2 optical input would never take
connected to opt1 on rear via my Pioneer PDF1009 changer and it went like butter, however I must also add that after writing 3rd DSP was done my unit always went back to the blinking front panel saying SPDIF update, never saying complete or etc. I simply hit the power button after 10 mins and everything was fine
-Gary
Gary Murrell is offline
post #189 of 5565 Old 04-03-2008, 02:56 AM - Thread Starter
joerod's Avatar
Quoted: 724 Post(s)
Liked: 655
Oh yeah, you need to specifically use OPT 1...
Glad you got it done...
post #190 of 5565 Old 04-03-2008, 04:55 AM
PerryRhodan's Avatar
Hi Gurkey & joerod,
finally DSP and FW-Update works for my 875er.
Done with Toshiba HD-EP 30 (set to PCM-Ouptput).
With DSP3 i had some trouble, but after burning a second CD with 2 tracks
and no crossover/fading applied it works!
So one remark for gurkey's inital posting: DSP-Update also updates DSP3 if it's downlevel, e.g. it's not only for DSP1!
Best regards, Perry
PerryRhodan is offline
post #191 of 5565 Old 04-03-2008, 05:13 AM
gurkey's Avatar
Quoted: 276 Post(s)
Liked: 172
Originally Posted by PerryRhodan View Post
Hi Gurkey & joerod,
Best regards, Perry
You are right, but compared to the level one usually starts from (1.04/1.05) , only DSP1 is been changed.
gurkey is offline
post #192 of 5565 Old 04-03-2008, 05:40 AM
jmschnur's Avatar
"On my PS3 I used the optical out and connected to optical 1 on the 885. I had the following in my PS3 settings,
"My 885 has FW 1.04 / 07927A and originally had the following DSP versions,
1 – 07927A
2 – 07518A
3 – 07820B
1 – 08214A (this is new)
2 – 07518A
3 – 07820B
I hope this helps others. And many thanks again to joerod"
Any reason why this could not be done with a Toslink Ooptical cable from a computer to the 885 with the computer playing the wav file? I have all my CD's ripped to a hard disk annd play my music with foobar. So playng the wav file using kernal streaming at 44 khz 24 bit depth seems straight forward.
Is it?
what happens when the dSP upgrade fails?
Joel
jmschnur is offline
post #193 of 5565 Old 04-03-2008, 05:45 AM
Bill Mac's Avatar
Quoted: 1591 Post(s)
Liked: 1859
I am in the process of ordering a RS232 cable from Monoprice and wanted to make sure I am ordering the correct cable.
The cable is DB9 M/M cable molded 25'
Product ID 441: $2.89
Is this the correct cable? I have a RS232 port on my PC so I do not need a Keyspan adapter.
Thanks, Bill
My SACD collection and HRAudio.net Library, getting larger as my wallet gets smaller ;-).
Emotiva XMC-1, Wyred 4 Sound SX-500s, ST-500, ST-250, Oppo BDP-103/105D, Panasonic TC-P60GT50 plasma, Panamax 5100EX, Salk HT2-TLs, Salk 1801b center, Salk 1801TL (surrounds) and two Rythmik F12SEs.
Bill Mac is online now
post #194 of 5565 Old 04-03-2008, 05:52 AM
Hot Grits's Avatar
Thanks, Bill
check the back of your pc. I think you need a female end on the cable for the pc side. So it would be a M/F cable. Dont take my word on this. double check.
Hot Grits is offline
post #195 of 5565 Old 04-03-2008, 06:19 AM
Bill Mac's Avatar
Liked: 1859
HG,
You are 100% correct! I was looking at the wrong port. I do need a M/F cable but unfortunately Monoprice is out of 25' cable. Oh well.
Thanks for your help, Bill
post #196 of 5565 Old 04-03-2008, 06:30 AM
Hot Grits's Avatar
HG,
I woonder if you could buy two 15' and connect them.
m->f->m->f
post #197 of 5565 Old 04-03-2008, 06:39 AM
Bill Mac's Avatar
Liked: 1859
m->f->m->f
HG,
Good question and great idea. I do not see why it would not. Could anyone comment if connecting two DB9 cables together will work.
Thanks again, Bill
post #198 of 5565 Old 04-03-2008, 06:44 AM
spectra57's Avatar
Originally Posted by gurkey View Post
The 1.07/1.08 "Main" firmware update (model dependent) is accompanied by the corresponding "DSP" Update.
Beware ! The "DSP" Update will clear all Your settings though.
Check here
http://www.avsforum.com/avs-vb/showt...3#post13494013
Have you experienced loss of your settings for the Main Firmware?
spectra57 is offline
post #199 of 5565 Old 04-03-2008, 06:46 AM
gurkey's Avatar
Quoted: 276 Post(s)
Liked: 172
No.
gurkey is offline
post #200 of 5565 Old 04-03-2008, 06:50 AM
gurkey's Avatar
Quoted: 276 Post(s)
Liked: 172
So I just finished hooking everything back up after upgrading to fw 1.07. I definitely notice an improvement with the audio lock. When changing channels with different listening modes the audio seems pretty instantaneous. I've only played with it for a couple minutes since upgrading but there is a definite improvement. Also skipping from scene to scene on a dvd, the audio also locks on almost instantaneous. I dont remember if this was a problem before. My settings did not reset even though the unit displayed clear after updating. I found this a little weird.
One quick question. Was anything involving audessey adressed in this update? Just wondering if I should run it again.
Look here
Although Audyssey reported no changes for this firmware update, users observed a somewhat changed behavior at the outcome of measurments.
So it's up to You to rerun Audyssey.
The "DSP" update routine definitely erradicates all settings.
gurkey is offline
post #201 of 5565 Old 04-03-2008, 06:58 AM
ddgtr's Avatar
Is it?
Joel
Joel, I was thinking about doing this exact thing with my foobar via toslink optical to the 805. I use this setup to play all my music archived as FLAC files. "The Fly" should be here tonite according to Blockbuster, and once I confirm the disc has the pop I'll do the update. I've played the WAV file in foobar and "on paper" it looks like there is no reason why it should not work.
If it fails, I have the CD and will also play it via foobar/optical. I'll post the results as soon as I'm done.
ddgtr is offline
post #202 of 5565 Old 04-03-2008, 07:04 AM
Ciccio's Avatar
Hi all,
Over on the SR875 owner's thread, there is talk again about the removal of a capacitor that started back when the v1.04 was out. Here's also a link to a post that was from an Onkyo service bulletin and it mentions the removal of a capacitor ... http://www.avsforum.com/avs-vb/showt...2#post12759742
SERVICE INFORMATION No. 5/2007
Model Date
TX SR 605 / 705 / 805 / 875 TX NR 905 - 25. October 2007
Overview about the actual FW Version's of the xx05 AV-Receiver's
The files are ready for download at ONKYO ExtraNet/Service Information/Software
At the same folder's you will find the explanation for the update.
For the new main FW you have to remove a capacitor.
Please see the next pages for more information.
With the new FW version of TX SR 875 and TX NR 905 new functions are added.
Have any North American owners here know if their Onkyo had this capacitor removed while at a service center? One poster said that it supposedly speeds up the Reon syncing. Thanks.
Ciccio is offline
post #203 of 5565 Old 04-03-2008, 07:04 AM
spectra57's Avatar
Have you experienced loss of your settings for the Main Firmware Update?
No.
Is it recommended or necessary to do a manual reset?
post #204 of 5565 Old 04-03-2008, 07:08 AM
gurkey's Avatar
Quoted: 276 Post(s)
Liked: 172
The DSP update does a reset anyway (everything gone).
It's recommended and the service points always do it, because default data might have to be re-initialized.
I would suggest running AUDYSSEY again, too.
But its not proven, that this will change things to the better or worse...
gurkey is offline
post #205 of 5565 Old 04-03-2008, 07:17 AM
spectra57's Avatar
Thanks, I am just curious because I did the DSP Updates first and than went back and adjusted all the lost settings, including AUDYSSEY. Now after the Main Update are you suggesting to do another reset and run AUDYSSEY again? Thanks.
post #206 of 5565 Old 04-03-2008, 07:24 AM
gurkey's Avatar
Quoted: 276 Post(s)
Liked: 172
It's up to You, because nobody except Onkyo / Integra will know, if it's "really" necessary or redundant.
I always do... anyway, although it's a hassle.
gurkey is offline
post #207 of 5565 Old 04-03-2008, 07:29 AM
Hot Grits's Avatar
so once the xx06 models are released. there wont be anymore fw updates?
post #208 of 5565 Old 04-03-2008, 07:30 AM
cuibap's Avatar
Quoted: 27 Post(s)
I just updated my 905 from 1.05 to 1.08 main and DSP as well. Everything went smoothly except that at the end of the DSP upgrade, I had to wait about 10 minutes and manually power down. I used Pioneer DVD DV-444 to upgrade DSP. Thanks very much to joerod for his help
cuibap is offline
post #209 of 5565 Old 04-03-2008, 08:17 AM
canyon500's Avatar
Did the 1.07 update on my 875 THE AUDIO DELAY IS GONE on my HR20 DTV box.
Thanks, Joerod and all others for the help.
canyon500 is offline
post #210 of 5565 Old 04-03-2008, 09:43 AM
Rygar's Avatar
Anyone tried the update using an xbox 360?
thx
Rygar is offline
