The Onkyo/Integra direct firmware updates - Page 142 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #4231 of 4259 Old 06-13-2015, 08:21 AM
Liked: 0
Hi to All AVR Guru there!!!
Onkyo service in my country are so lazy and slow....need 15 days to update my machine so I like to do my self!
I find this topic very helpfull for update my Onkyo Amp ,,,,but unfortunally ALL links are old and broken!
So please if any can help my out to find the Firmware AND the flashing pogram for my Onkyo TX-SR876 i will be much aperciated!
Also if I have installed the firmware 1.02 can I go to 1.05 for example? there will be problem this?
send me an pm on contact me in the following mail: cosmicrain51(AT)yahoo(dot)com
Thanks in Advance for your help!
cosmicrain is offline
post #4232 of 4259 Old 07-08-2015, 07:55 AM
FuzzyQ's Avatar
Originally Posted by slaw82 View Post
Hello there,
i have a problem i need help, i had flashed my 906 with 876 v1.05 firmware and now my network and usb functions are working no more. Can anyone please send me proper firmware for 906? Can be v1.04 or v1.05, no difference to me.
The 906's firmware can still be found here
Alternatively, you can find them here as well.
(I'm finally able to post links, yay!)
Originally Posted by wiliris View Post
Hi FuzzyQ,
can you provide me with the firmware v1.04 for TX-SR875?
Thank you inadvance.
Wilson
I'm sorry, but I've never had the 875's firmware upgrades, only those for the 906 model. Good luck though!
Best regards.
Last edited by FuzzyQ; 07-08-2015 at 08:02 AM. Reason: Added download mirror; optimized formatting for better readability
FuzzyQ is offline
post #4233 of 4259 Old 07-08-2015, 12:43 PM
slaw82's Avatar
Best regards.
Thanks man, you saved my life
slaw82 is offline
post #4234 of 4259 Old 07-14-2015, 12:22 PM
FuzzyQ's Avatar
Glad to be of service
Gesendet von meinem Nexus 5 mit Tapatalk
Pioneer CLD-D925, Philips BDP7700, Faroudja NRS, Onkyo TX-NR906, BenQ W1070
FuzzyQ is offline
post #4235 of 4259 Old 07-15-2015, 03:48 PM
sambou812's Avatar
were you able to flash without a dongle?
thanks
sambou812 is offline
post #4236 of 4259 Old 07-16-2015, 12:02 AM
FuzzyQ's Avatar
thanks
No need for a dongle of you can resurrect an old PC with a COM-port. That's all I needed back then.
Just be sure to follow the instructions to the letter.
FuzzyQ is offline
post #4237 of 4259 Old 07-16-2015, 12:38 AM
slaw82's Avatar
I'm using USB to RS232 interface, work like a charm
slaw82 is offline
post #4238 of 4259 Old 07-17-2015, 02:18 PM
sambou812's Avatar
my original firmware version on this 906 is 1.00 my other one had 1.2 it flashed with no problems using win 8.1 and my usb-rs232 cable.
but the 906 with 1.00 will not flash no matter what i try.
i don't have an xp pc laying around.
thanks
post #4239 of 4259 Old 08-04-2015, 12:05 PM
sambou812's Avatar
thanks
my 906 is done, the hdmi board has died and i found a cracked thermal sensor and a slightly cut main ribbon cable.
so its now up on a shelf wrapped in plastic un-till i can find a donor unit
post #4240 of 4259 Old 08-17-2015, 10:05 PM
Liked: 0
Why ONKYO 886 of the firmware can not be downloaded?
prost2809 is offline
post #4241 of 4259 Old 08-17-2015, 11:00 PM
Liked: 0
Can you send a copy to my email address? Contains 886 DSP and main firmware。
Thank you!
post #4242 of 4259 Old 09-16-2015, 03:46 PM
dimitrov's Avatar
TX-NR1000 v2 firmware
Can somebody please send me or post a link for the TX-NR1000 (US model) v2 firmware. I just got a C-HDSAT card but it's not recognized by the receiver with my v1.06 firmware. I asked the same in the NR1000 thread a few weeks ago but no luck - that thread seems pretty much dormant. Onkyo CS hasn't been helpful either.
Thanks in advance
Aleks
dimitrov is offline
post #4243 of 4259 Old 10-07-2015, 06:00 AM
Liked: 0
Hi all
I have a problem with handshake between my TX-SR875 with Blu-Ray player pioneer BDP- LX55.
The two units works fine if i use hdmi output one ( sound and vision ) however if i connect to hdmi 2 to output sound only ( 3D content)there is no sound coming out from the unit, this is not the case with other Denon amplifier and even if connect it to the TV the sound comes out without any problem.
firmware on my unit is 1.05
HDMI 1.01
help is much appreciated, does any of you have a full suite of the firmware
David
askim98 is offline
post #4244 of 4259 Old 10-07-2015, 06:01 AM
Liked: 0
Hi all
HDMI 1.01
David
askim98 is offline
post #4245 of 4259 Old 10-10-2015, 01:32 AM
Liked: 0
Hi all,
I have a Onkyo TX-SR875 and i lost all audio output. I did a reset but
nothing
Inside the receiver nothing is smelling, looks burned or give me the idea
that there is something damaged.
Could this be caused by a firmware issue?
currently i have:
Main: 87 1.01/07613A
MainUpdataMode Ver1.00/07502L
As i read in the forum i need to build a JIG to do an upgrade but i cannot
find the software for the flashing (only dead rapidshare links).
Is there somebody who can share this software with me?
Johan
aardbei is offline
post #4246 of 4259 Old 11-15-2015, 10:11 AM
dimitrov's Avatar
Getting FW from a donor unit?
Hi all
Is it possible to copy/download the firmware from a unit?
Has anybody tried that?
dimitrov is offline
post #4247 of 4259 Old 11-15-2015, 10:19 AM
vitod's Avatar
Quoted: 237 Post(s)
Liked: 121
Any updates for the 80.2?
Panasonic AE-2000, Carada BW 120", Paradigm Studio 40v3 x 2, Paradigm 690v4, Paradigm ADP 470v3 (rears), Micca M-8C x 4, Volt 6 x 2 (SR), SI DS4-18 in 12cuft X 2, Marantz 7702MKII, OPPO 103D, Emotiva XPA-3,
Integra 9.8 for sale
: http://www.avsforum.com/forum/209-au...l#post37109226
vitod is offline
post #4248 of 4259 Old 12-20-2015, 07:08 AM
Liked: 0
Hi all
I'm also looking for firmware 1.04 and 1.05 to my Onkyo tx sr875. Thanks
aron.p is offline
post #4249 of 4259 Old 01-24-2016, 05:41 PM
Lotharr's Avatar
DSP update file for TX-NR906
Does anyone have a link for the latest DSP update file for the TX-NR906. I have been searching but all links appear to be dead. I have the firmware just need the dsp update.
Lotharr is offline
post #4250 of 4259 Old 03-21-2016, 05:02 AM
dunkle's Avatar
Originally Posted by Hannes Goldmann View Post
Well I know that it's a long time since somebody dealt with this thread but I've got a question to the thread starter gurkey.Could maybe send me the file's for the TX-NR905
because I just noticed I am running version 1.06 and really like to update to 1.09. So since rapidshare unfortunately is down could you may send it to my E-Mail adress
hannes.goldmann and than @google mail
Kind regards Hannes Goldmann
looking for 1.09 also if anyone has it
dunkle is offline
post #4251 of 4259 Old 03-30-2016, 12:57 PM
Liked: 0
I just acquired an nr905 and its firmware is ver 1.07 would love to update it I dont have 5 posts yet so cant post email....buy try
528hemi at gmail
Rick
HemiRick is offline
post #4252 of 4259 Old 03-31-2016, 05:21 PM
Liked: 0
Hi!
I'm searching for a TX-SR607 firmware, does anyone have it?
William
w1ll14m is offline
post #4253 of 4259 Old 04-21-2016, 07:33 PM
jprfolts's Avatar
Liked: 0
I'm being kind of lazy on this request. Does anyone have the firmware for the TX-SR805. My menus are all messed up from an attempt to update a firmware that was supposed to be correct.
Looks like Gurkey no longer has access to the files and they were deleted for non-use. Would really like to get this receiver back to 100%.
jprfolts is offline
post #4254 of 4259 Old 05-26-2016, 03:45 PM
Liked: 0
Hello there,
I know it's been sometime since this post, but I'm looking to update my Onkyo TX-SR876' firmware from version 1.01 to 1.05.
Can anyone help ??
Mikohay is offline
post #4255 of 4259 Old 06-06-2016, 01:56 AM
Liked: 0
Hello,
I have a TX-NR509 amp with a wrong firmware. Onkyo updated the fw via internet automatically. After the update I have no HDMI sound and the network/USB menus are greyed out. I had connected an UART interface to the P3102A port, but I couldn't see any communication on that port. The P751A port is working (9600bps), I can see the commands. Is there any fix available?
Thank You,
GreaTx is offline
post #4256 of 4259 Old 06-07-2016, 09:33 PM
AVS Club Gold
Baenwort's Avatar
I have the xx5 firmwares and DSPs in archive but I can't certify that there hasn't been any bitrot from sitting on a HD for the last decade. I used them to update to HDMI 1.01, Main 1.08 and Video 3.62 for the 805 via the jig back in the day and haven't touched them since.
I've also got the flasta jig assembly instructions in-case anyone needs them still.
Any reliable upload locations around? It's been years since I was involved in anything that required uploading 40mbit zip +files.
My stuff is old, but it still works well. Apparently AVS finds it to old to keep in their database but I'm still happy with it.
Baenwort is offline
post #4257 of 4259 Old 06-08-2016, 01:57 PM
Liked: 0
Hi everyone,
I read that there exist firmware update(s) for the TX-SR508. However, I could not find further information like a changelog. Also: where can I download them? All links I found were dead...maybe someone still has it on its hard drive and would upload one?
Thanks in advance,
inspire
inspire1989 is offline
post #4258 of 4259 Old 06-08-2016, 10:30 PM
jasonvr's Avatar
Sorry I missed this until now. The "all in one" update CD ISO for the xx5 devices can still be downloaded from my Google Drive
https://drive.google.com/file/d/0BwN...ew?usp=sharing
This is the same CD that I was sending out when I was running the dongle rental service for updating 805 receivers.
Baenwort and jprfolts like this.
jasonvr is offline
post #4259 of 4259 Old 06-09-2016, 06:58 PM
jprfolts's Avatar
Liked: 0
Awesome! Thank you!
jprfolts is offline
Onkyo Tx Sr605 Receiver , Onkyo Tx Sr805 7 1 Channel Home Theater Receiver Silver , Onkyo Tx Nr905s
