Linn 5103 / 5125 Problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-11-2008, 10:33 PM - Thread Starter
sgshanaf's Avatar
Hi all,
I just purchased a Linn AV5103 pre amp and Linn AV 5125 Amp for a grand total of $10. The owner's son, and I quote, "Over-drove it" and damaged "something". I haven't plugged in the unit's to investigate yet. I don't expect the pre-amp is damaged, but perhaps the amplifier is.
Does anyone have any knowledge of what the problem could be, if I can/should repair it myself, or should/could I send it to Linn? I'm not terribly interested in spending a lot of cash on it. But it would be a fun project to repair.
sgshanaf is offline
post #2 of 4 Old 04-12-2008, 05:50 AM
FMW
FMW's Avatar
Quoted: 1652 Post(s)
Liked: 1681
You haven't turned it on. You are wondering if you can fix it without knowing what is wrong with it. You wonder if someone can provide knowlege for a problem you haven't encountered and can't describe. I don't know what to say. Plug it in. If it doesn't work throw it away. You only spent $10.
FMW is offline
post #3 of 4 Old 04-12-2008, 06:23 AM
Filthy McNasty's Avatar
Are you sure he said "Over-drove it" as opposed to "Drove-over it" ?
Filthy McNasty is offline
post #4 of 4 Old 04-12-2008, 10:39 AM - Thread Starter
sgshanaf's Avatar
Thanks for the super-helpful response... I was asking if anyone knew about a common problem, which clearly you don't.
It was a bad fuse.
sgshanaf is offline
