ps3 -> yamaha v663 no surround sound - AVS Forum
post #1 of 4 Old 05-04-2008, 11:24 AM - Thread Starter
mjr62's Avatar
What I have done
5 speakers connected and working (2 f, 1 c, 2 r,1s)
1.Plugged hdmi cable from ps3 to receiver, and another hdmi cable to the display
2. ran the Yamaha auto audio setup program
3. turned on receiver, turned on ps3, turned on tv
4. setup all set to auto on ps3, with hdmi set as audio and video source
5. set yamaha input source to dvd, source type straight effect
6. HDMI box is lit up
7. video is working
8. audio is only outputting two channels, one to each front speaker!!
(no lights or indications saying it is receiving a dobly signal, although when I pull up the information on the tv,the ps3 data display says Dobly Digital, 5.1CH 48 KHZ 448 KBS)
any help?
mjr62 is offline
post #2 of 4 Old 05-04-2008, 11:29 AM - Thread Starter
mjr62's Avatar
also add i am playing a blue ray disc if that helps
mjr62 is offline
post #3 of 4 Old 05-04-2008, 11:39 AM
kplex's Avatar
Did you do the audio setup on your ps3 when it was connected straight to your TV or after you connected it to your receiver. If it was the former, do the audio setup on your ps3 again.
kplex is offline
post #4 of 4 Old 05-04-2008, 11:46 AM - Thread Starter
mjr62's Avatar
worked thanks!
mjr62 is offline
