The Onkyo TX-SR606 Owners Thread - Page 317 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #9481 of 9510 Old 10-28-2014, 06:03 PM
DBacksFan5205's Avatar
Originally Posted by itsloud View Post
I assume you are talking about the 5 on the HDMI daughter card?
There are more than 5. I assume that you're referring to the YouTube video. The information presented there is just enough to be dangerous. For example (although it's been a long time since I watched it), there are NO cautions or discussions regarding ESD. So, many Onkyo owners go ahead and remove their HDMI card and thoroughly ZAP it with ESD. Game over. They will need a new card. If you're someone who was successful without taking ESD precautions, you just plain lucked out (or you live in an area of high humidity, not an arid area where you get shocked every time you exit your car).
Replacing the 5 caps is a good start, but there are others that sometimes go bad and cause problems. And we're only talking about the 100uF caps. What about the others?
I talked about an ESR meter. This is where such a simple piece of equipment comes in handy. It will tell you exactly which caps are bad and not limit your focus to just 5.
DBacksFan5205 is online now
post #9482 of 9510 Old 10-29-2014, 05:33 AM
itsloud's Avatar
So all the caps inside the receiver. I googled a bit yesterday and only saw mention of the ones on the daughter card.
itsloud is offline
post #9483 of 9510 Old 10-29-2014, 04:27 PM
No, not all the caps inside the receiver. I was referring only to those on the top and bottom of the HDMI card.
post #9484 of 9510 Old 10-29-2014, 05:02 PM
itsloud's Avatar
Thank you for clarifying. Onkyo already fixed this card for the HDMI issue, so I may just start with the one you mentioned and test. Then go from there if needed.
itsloud is offline
post #9485 of 9510 Old 11-18-2014, 08:23 PM
Liked: 0
Greetings all,
I have had the same HDMI issue I've seen many others having. I already have the capacitors and will be attempting the repair this weekend. Before I get in and do that, I have one other issue with my 606 that I haven't been able to find anyone else having. I've checked the manual and done plenty of searching but haven't found anything on it.
I get no sound out of the left front channel speaker. I've swapped other speaker wires for it and always the same result. Whatever is hooked up to front left has no sound. I've hooked the front left speaker to center channel and do get sound. So, I know the speaker and wire are good. I've tried resetting and nothing has changed. I've tried multiple inputs, and even Audyssey, and still nothing.
Does anyone have any ideas on what may cause one channel to go out? Figured I'd try to find out and order any additional components to do this all at once.
Thanks for your advice!
Doug
dugsdman is offline
post #9486 of 9510 Old 11-18-2014, 09:08 PM
WIshooter's Avatar
Quoted: 14 Post(s)
Just found this thread. Started this thread last week:
Tech Help: Receiver can't see blu-ray player
Is this a "new" 606 issue?
WIshooter is offline
post #9487 of 9510 Old 11-18-2014, 09:44 PM
Sniper_X's Avatar
It seems that you might have a bad connection in the audio board, or a BI-AMP relay that is bad.
Most likely is that there is a bad cap or power transistor.
The good news is that you can compare with the other channel on the amp board.
Each channel is well marked on the board and by comparing the components on the bad channel,. you should locate the problem fast.
dugsdman likes this.
Sniper_X is offline
post #9488 of 9510 Old 11-19-2014, 07:54 AM
Liked: 0
Thanks! I'll go ahead and try the fix this weekend and take a look while I'm in there.
dugsdman is offline
post #9489 of 9510 Old 11-24-2014, 11:28 PM
Liked: 0
Good news, I got the HDMI switching issue taken care. I took a quick look and didn't notice anything different with that one channel that isn't working though. I'll take another look after the holidays when things calm down a little bit...
dugsdman is offline
post #9490 of 9510 Old 12-01-2014, 08:21 PM
dcuomo's Avatar
TX-SR606 hookup to samsung smart tv 65"
Hi all. Been struggling to set up my new Samsung smart tv with my 606. Know I need to use the ARC output from the TV to one of the HDMI ports but cant get the audio working. Any help would be much appreciated.
As a side note, I see many have had issues with this unit (as have I). Is onkyo still warranting these issues on this receiver?
Thanks in advance
dcuomo is offline
post #9491 of 9510 Old 12-03-2014, 12:59 PM
dcuomo's Avatar
Following up on my own post. I finally spoke with a knowledgeable Onkyo tech...turns out...according to Onkyo....there is no alternative but to connect the 606 via optical. The HDMI ARC is not for sending TV audio back to the AV receiver...at least not this receiver.
Also, on the warranty issue, apparently my unit (purchased in 2009) does not have the faulty board. Have to say that I am still stumped as to why my unit has consistently had issues in finding the HDMI input signal. I have to turn it on and off repeatedly to get it to recognize the signal. With the new TV it has not had this issue so I am hoping that it is now moot.
Don
dcuomo is offline
post #9492 of 9510 Old 12-03-2014, 05:55 PM
JackB's Avatar
Quoted: 478 Post(s)
Liked: 76
Is there a test tone generator on this receiver? I could not find one.
Jack
JackB is offline
post #9493 of 9510 Old 12-06-2014, 10:08 AM
MikeMartell's Avatar
You have the 606 and they told you your unit isn't affected ? Lol.
Go to onkyousa dot com there is a link for Special Warranty service which I know for a fact is covering the x09 series at the moment. Fill out the online form. You may get lucky.
MikeMartell is offline
post #9494 of 9510 Old 12-07-2014, 10:16 AM
shinksma's Avatar
Location: Wandering the intertubes, on the way to damnation
Quoted: 80 Post(s)
Liked: 54
Don
Long time no post in this thread for me.
Onkyo is not covering the x06 units, made in 2008, or anything older, for the official warranty extension. Just 2009 models and newer.
My last working 606 just died HDMI-wise (takes component in just fine, and outputs it fine over HDMI, just won't process HDMI inputs), so I'm in the market for a non-Onkyo AVR that has the same overall feature set at the 606. I don't need Dolby Atmos or 9.1 or networking, just a solid 5.1 or 7.1 with second powered zone, 4 or more HMDI inputs, and HDMI upconversion from Component. At this stage, assuming HDMI inputs work, I don't even need analog multi-channel inputs. Anything obvious that I should be checking out? Yamaha's latest?
My opinions are my own, and do not necessarily reflect those of my captors.
shinksma is offline
post #9495 of 9510 Old 12-07-2014, 12:45 PM
Carsfanatic's Avatar
I forget and can't seem to find the old information on when my 606 was made/purchased does anyone have a link to the special warranty service form to fill out just started to have the HDMI issues Edit just found it, it doesn't cover the 606 at all.
Other than not knowing when mine was made the same for me almost...I need the analog multi-channel inputs because the main thing the receiver/TV is used for is PC to computer and HDMI for PC only does 2.0 for the most part. The HDMI in still works sort of it will work if I change the resolution to something lower than 1080p on the PC at least but other components like PS3 will not work at all so have to be directly fed to the TV and then TV to receiver via optical which is only passing 2.0 audio so really no need to have the 5.1 receiver at that point.
Carsfanatic is offline
post #9496 of 9510 Old 12-07-2014, 01:35 PM
JChin's Avatar
Quoted: 348 Post(s)
Liked: 204
Hi Carsfanatic, 8th and 9th digits on back of receiver serial number should indicate when it was made.
For audio on the PS3, connect optical cable directly from PS3 to receiver and go into PS3 Sound Settings to output via optical.
JChin is offline
post #9497 of 9510 Old 12-07-2014, 01:51 PM
Not really a solution go from 7.1 to 5.1 and have to manually switch HDMI on the TV because it only has one working HDMI input. I been using a HDMI switch that has dual outputs to at least give me 7.1 sound still and get video to the TV still have to manually switch the HDMI to the TV to take out the HDMI from the 606 to the TV to the PS3. Actually been thinking about it today I should get component cables for the PS3 and do that out to TV for video and then should still be able to do sound through HDMI to the 606 would make it so it is a simple video switch on the TV to have 7.1 audio and working video.
post #9498 of 9510 Old 01-06-2015, 02:16 PM
BasementHT5's Avatar
Quoted: 73 Post(s)
Liked: 42
3D Pass through
Has anyone hooked up the 606 via optical through their Display for 3D content? I have to do that as the 606 does not support 3D pass through, which sucks after I just paid $120 to have the HDMI board caps all replaced. It works like a charm but is outdated now and I'll lose the 7.1 from the optical.
I wanted to gauge if anyone is using this and if the setup works well. otherwise, I'll likely replace this with a new 4K/3D capable receiver.
BasementHT5 is offline
post #9499 of 9510 Old 06-19-2015, 06:42 PM
blobula's Avatar
Quoted: 12 Post(s)
Can this receiver not passthrough sound from a tv? I currently have an HDMI cable running from an HDMI input to the HDMI out on the receiver with HDMIAudioOut set to 'On'. I'm still not able to get the sound from the tv to be output through the receiver.
Any ideas?
Thank you.
blobula is offline
post #9500 of 9510 Old 06-19-2015, 06:42 PM
blobula's Avatar
Quoted: 12 Post(s)
Any ideas?
Thank you.
blobula is offline
post #9501 of 9510 Old 06-19-2015, 07:09 PM
Menu 7-5 AudioTvOut: ON
post #9502 of 9510 Old 12-18-2015, 03:32 PM
Liked: 0
Unhappy Remote "idle" for 5-7 seconds after each button pressed ?
Hi,
On my TX-SR606, I have a very strange behavior for some month. It was not so before. I found some forums mentioning similar issue, but nothing to solve. so I come to this forum hopping that somebody already experienced this and have a solution...
The wrong behavior is very simple to describe: each time I use the remote control (for example to change volume or change input), it works one time... and then I can't do anything more on the remote before 5-7 seconds. Then it works again... for one button press only... and I need to wait again. Therefore, moving the volume from 30 to 40 takes me several minutes... which means that the remote control is totally unusable for features like the volume. The behavior is relatively new, but I couldn't find what conducted to this behavioral change.
What I tried (and didn't work)
  • Change the batteries
  • Tried to use extensively the "receiver" key of the remote
  • Reset the remote (Button Receiver + Audio during 3 seconds and then button "Receiver again"
I don't need any "advanced" feature of the remote, like managing a third party device. I just need that the Onkyo TX-SR606 remote allows me to use several buttons without freezing the communication for seconds, and especially allows me to manage the volume by simply let the button press for exemple.
Any idea ??
Best regards.
apaschou is offline
post #9503 of 9510 Old 08-18-2016, 04:48 PM
DigitalfreakNYC's Avatar
Quoted: 52 Post(s)
I know I'm unearthing an old thread but I assume that this is a similar problem to what everyone else had.
Lately, my 606 has been cutting out. It will flash out and I'll see "no supported signal" on my tv for a second and then it will go back to what I was watching. Both the sound and the picture will be gone for that second. I assume this is the HDMI board failing?
From what I read here, it seems to be more permanent than my issue but I wanted to make sure before I started looking for a new receiver. Any ideas?
"I have never seen it, but by all accounts it is terrible. However, I have seen the house that it built, and it is terrific." - Michael Caine, on Jaws the Revenge
DigitalfreakNYC is offline
post #9504 of 9510 Old 08-18-2016, 05:28 PM
Sniper_X's Avatar
You likely just need to replace the capacitors like most of us have done.
Works fine after
Add a large slow moving fan in the unit to cool it constantly
Sniper_X is offline
post #9505 of 9510 Old 12-13-2016, 01:49 PM
Liked: 0
Looking to correct the "No signal" without changing the capicitors. Does it help to run the video switching through the TV and then just run a single Optical audio into the 606? Perhaps I need to do that anyways, since the TV is newer? I'm fairly new at all this - the receiver has been running fine with cable, Blu-ray, Xbox 360 running into it via HDMI and a single output to projector, also via HDMI. I recently got the Vizio M70-D3, and I fear the 4K signal may be messing with the 606.?
I'm happy to scrap the receiver and get a modern one, unless moving all the HDMI signals to the TV might help?
kkelly1958 is offline
post #9506 of 9510 Old 12-13-2016, 02:19 PM
rexb610's Avatar
I was in the same dilemma before, getting the no signal from one of the HDMI inputs. I just went ahead and bought an Onkyo NR525 for $150 2 yrs ago from one of the BF Deals. It's a budget receiver but I haven't found anything the 606 can do that the 525 can't and only have 5.1 anyways. I thought for the price and effort fixing it, I'd rather just get a new receiver. I was going to scrap the 606, but the new house we bought last year had whole house speakers pre-wired, I then re-purposed the 606 as B receiver to drive the whole house speakers and used 525 for my home theater 5.1 set-up in the family room. The 525 can send audio signals to 606 So really depends on your situation and budget.
If you do HDMI to TV and do optical to the receiver, that may work out, but unsure how 5.1 also HD audio would translate. Others may correct me on this, but I'm guessing you won't get the best audio from your content (ie. Blu-ray with HD audio DolbyHD, DTS Master or even regular 5.1 Dolby/DTS).
rexb610 is offline
post #9507 of 9510 Old 12-13-2016, 03:55 PM
Liked: 0
Thanks - yeah - that was my concern. If I can't get the various audio signals coming out of the optical from the TV to the 606, in a re-routed situation, then it's not worth trying to re-wire the switchover through the TV - I'd just get a new AV Receiver that can handle the newer signals. I can handle $500-700 to spend on the upgrade -I presume I can get a reliable receiver for that amount?
post #9508 of 9510 Old 01-11-2017, 12:06 PM
mienime2488's Avatar
Bringing back an old thread... hopefully dudsdman is around!
My right-channel front speaker just stopped working too. Any speaker I plug into the R-ch front doesn't work either, so I think it may be a setting issue (my daughter pressed something), or failed hardware.
Anyone experience something like this?
PS. I bought my TX-SR606 used from Goodwill ~3 years ago and replaced the caps!
mienime2488 is offline
post #9509 of 9510 Old 01-11-2017, 01:05 PM
nlpearman's Avatar
Mine is still running strong! (9 years this year). I replaced the caps a few years ago and I'm still working around some HDMI things but, for the most part, no issues... and I won't replace it until the whole 4K/HDR/HDMI/3D sound format situation settles down.
(sorry I can't help with your channel issue)
Upgraditis Anonymous
nlpearman is offline
post #9510 of 9510 Old 01-21-2017, 05:32 AM
mrsubtraction's Avatar
Exclamation Sudden, loud CRACKING sound when powering on
Hi, hopefully there are some TX-SR606 still active here!
I've had mine for more than seven years now. I had the capacitors replaced and it's worked like a charm ever since.
Until recently, that is. Not long ago I started occasionally getting a very loud, alarming CRACKING sound when I power on the receiver. It sounds like the speakers are blowing out or something really ugly. What usually happens is that the receiver powers on, starts playing music (via HDMI) for a second or two and then a very loud CRACK/POP sound, and then the receiver powers itself off.
This happens randomly; sometimes it works just fine when I power on, and other times this happens.
Does this sound like the board is dying? Is anyone else familiar with this phenomenon? I'm otherwise really happy with this receiver and don't want to have to replace it if I don't have to.
mrsubtraction is offline
