The Onkyo TX-SR606 Owners Thread - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #121 of 9512 Old 05-10-2008, 09:18 AM
wolver98's Avatar
Originally Posted by metal83 View Post
We need info on this receiver guys. Not when and where you bought it lol.
Good point!
wolver98 is offline
post #122 of 9512 Old 05-10-2008, 09:32 AM
shinksma's Avatar
Location: Wandering the intertubes, on the way to damnation
Quoted: 80 Post(s)
Liked: 54
Originally Posted by POR08 View Post
Hi Shinksma,
Thanks. I will be buying DVD player since my old DVD player did not work for audio.
I think i did a mistake connecting my Boston Acoustic speakers to my Onkyo606 receivers. It could ne able to detect my speakers. I have 4 speakers connected in my home (wall mount) and i have connected through Surround left, right, back left and back right speakers. I was unable to any sound through receivers. Could you please help me? Family wanted to see how the new receiver is woking, but i was failed to that.
POR08
OK, you need to connect Front Left and Right speakers to get anywhere, as pointed out by wolver98.
Also, this receiver doesn't like 4 ohm speakers as much as 6 or 8 ohm, so make sure you go into the menu and tell it you have 4 ohm speakers (technically the North American version is not rated for 4 ohm, but you should be fine at low-mid volume).
Hope that helps,
shinksma
My opinions are my own, and do not necessarily reflect those of my captors.
shinksma is offline
post #123 of 9512 Old 05-10-2008, 09:39 AM
omirp's Avatar
To be an owner you have to buy. Sharing where and how much did one pay for his would help others decide where to buy and how much to spend.
If you are already an owner and have already explored the 606 please post your experiences and please refrain from discouraging others to post something that would help others.
omirp is offline
post #124 of 9512 Old 05-10-2008, 09:41 AM
metal83's Avatar
True
metal83 is offline
post #125 of 9512 Old 05-10-2008, 09:45 AM
1080pixel's Avatar
Anyone checked out if the 606 does not have the issue that 605 owners complained about?
1080pixel is offline
post #126 of 9512 Old 05-10-2008, 09:54 AM
metal83's Avatar
[quote=omirp;13837541]To be an owner you have to buy. Sharing where and how much did one pay for his would help others decide where to buy and how much to spend.
If you are already an owner and have already explored the 606 please post your experiences and please refrain from discouraging others to post something that would help others.[/QUOTE]
I agreed with you already, you didnt need to add in that extra comment.
But i appologize if my post came off as discouraging. Its just not to hard to go to different websites and see how much its going for thats all.
metal83 is offline
post #127 of 9512 Old 05-10-2008, 09:56 AM
DillnutMcGee's Avatar
Originally Posted by cheroo View Post
what does the osd look like on the 606?is it fancy?
thanks in advance.
I think the OSD on the 606 is basic looking, but very functional. I haven't had any issues navigating through any of the menus so far and I think it serves its purpose.
DillnutMcGee is offline
post #128 of 9512 Old 05-10-2008, 11:12 AM
Davidt1's Avatar
Quoted: 111 Post(s)
Liked: 35
Gave this receiver some thought but it looks like there is no outlet in the back. Looking at something else now.
Davidt1 is offline
post #129 of 9512 Old 05-10-2008, 11:19 AM
metal83's Avatar
No outlet?
metal83 is offline
post #130 of 9512 Old 05-10-2008, 11:32 AM
maley's Avatar
No outlet?
I think he means electrical.
Originally Posted by TNVOL View Post
Not seeing anyone comment on the differences in the two AVR's. I think the 606 has more HDMI inputs than the 605 but are there other big differences?
Also, is there an Onkyo AVR that has TWO HDMI outputs that are both active at the same time? I could use this function to send A/V to a 2nd TV in a game room right below the Family Room where the AVR would sit. If I could send SAT or DVD signals to another TV then that would be usefull.
I'd also like some info between the two. I'm planning on buying a 605 in about a week and wondering if the extra $120 is worth it for the 606.
maley is offline
post #131 of 9512 Old 05-10-2008, 11:46 AM
metal83's Avatar
Ok i'm confused (not to hard to do when talking about audio) lol.
metal83 is offline
post #132 of 9512 Old 05-10-2008, 12:06 PM
maley's Avatar
Some receivers, like the one my dad has an extra outlet on the back of it so you can plug something into it. So instead of plugging his dvd changer into the wall or power strip he plugs it into the receiver.
maley is offline
post #133 of 9512 Old 05-10-2008, 12:08 PM
metal83's Avatar
Oh ok, i see. Thanks for clearing that up for me.
So for instance you could plug your sub cord in the back.
metal83 is offline
post #134 of 9512 Old 05-10-2008, 12:13 PM
makry's Avatar
It does have pre-outs!
makry is offline
post #135 of 9512 Old 05-10-2008, 12:34 PM
makry's Avatar
Correction: It doesnt have pre-outs. That really bites, but ill deal with it!
makry is offline
post #136 of 9512 Old 05-10-2008, 01:11 PM
Davidt1's Avatar
Quoted: 111 Post(s)
Liked: 35
That's exactly why I need an electrical outlet. I want to plug the dvd player to the receiver and use the receiver's sleep timer to shut them off at the same time. The 663 has an electrical outlet but it has only 2 HDMI inputs. The up-coming Pioneer doesn't have an electrical outlet either.
Davidt1 is offline
post #137 of 9512 Old 05-10-2008, 01:20 PM
ercdvs's Avatar
Update:
It seems the TivoHD and the 606 play nicer now, as the LONG lag for HDMI sync is gone... its very quick now..
Heat is MUCH less then the 605 .. it still gets hot, but not 'i can feel the heat a few feet away hot'.
I need to play with the various options, but it seems there are seperate mods for music / tv/ gaming? Ie. I can have a gaming Theater direct, a tv theater direct, and a music 'all channel' ?
ercdvs is offline
post #138 of 9512 Old 05-10-2008, 01:29 PM
metal83's Avatar
Is it really that big of a deal? Cant you just plug your DVD player into a line conditioner/surge protecter or something of that nature. No offense or anything i'm just curious as to why that is such a big deal for you.
metal83 is offline
post #139 of 9512 Old 05-10-2008, 01:29 PM
metal83's Avatar
Pre-outs would be for hooking up an external AMP correct?
metal83 is offline
post #140 of 9512 Old 05-10-2008, 01:54 PM
britdiver's Avatar
Originally Posted by ercdvs View Post
Update:
I have a TivoHD and my 606 will arrive on Tuesday. What did you do to get rid of the lag? My TivoHD is currently directly hooked to my TV via HDMI and is fixed at 1080i.
britdiver is offline
post #141 of 9512 Old 05-10-2008, 03:02 PM
arsenic0's Avatar
Or just use a universal remote like a Logitech Harmony 550 or one of the other many remotes to turn on/off everything at once.
arsenic0 is offline
post #142 of 9512 Old 05-10-2008, 03:13 PM
metal83's Avatar
Speaking of those universal remotes, like the harmony's. Would i be able to control everything on my tv, my Directv HD/DVR, and whatever receiver i end up getting?
metal83 is offline
post #143 of 9512 Old 05-10-2008, 03:18 PM
wolver98's Avatar
I have my sub plugged into my HK 330 so I don't have to turn it off and on. The no outlet may cause me to take the 606 back if I keep forgetting and leaving my sub on. How stupid not to have an outlet, I mean the Denon 588 as 2 outlets.
wolver98 is offline
post #144 of 9512 Old 05-10-2008, 03:47 PM
dssturbo1's Avatar
yes you should be able to set it up to control all of your a/v equipment.
HD HD HD I Need more HD, Yes I am a HD Addict :)
dssturbo1 is offline
post #145 of 9512 Old 05-10-2008, 03:57 PM
metal83's Avatar
Hmm i guess i can see the problem with not having an outlet on it now. Because if it had an outlet, i would plug in my sub. It would nice to not have to remember to turn on and off the sub all the time.
metal83 is offline
post #146 of 9512 Old 05-10-2008, 04:43 PM
word302's Avatar
I don't think these outlets were designed to run something as high current as a subwoofer anyway. I guess if your sub has a very small amplifier it would be OK. Subs should be plugged directly into wall. As far as I know, the outlets on the rear of AVR's are for low current devices like a CD player or something.
Kent
word302 is offline
post #147 of 9512 Old 05-10-2008, 04:45 PM
jmaccool's Avatar
Does the sub have auto signal detect, I have a polk sub that detects if there is a signal, no signal and it goes into low power setting. Maybe yours is just crappy, LOL just kidding!!
jmaccool is offline
post #148 of 9512 Old 05-10-2008, 04:50 PM
wolver98's Avatar
I have always plugged my sub into my receiver without any problems. I have a DT Powerfield 15 and I have had it plugged into 1 Yamaha and 2 HKs without problems. Maybe it will be better having it plugged into the wall but I think it would be better to not leave the sub on for days.
wolver98 is offline
post #149 of 9512 Old 05-10-2008, 04:56 PM
word302's Avatar
I'm not saying it won't work. I can plug 4 saws and an air compressor into one 15 amp circuit and everything will work. I don't think my tools would last as many years if I did this. I think your sub amp will be much happier plugged into a wall outlet or surge protector/power conditioner.
Kent
word302 is offline
post #150 of 9512 Old 05-10-2008, 05:04 PM
wolver98's Avatar
Kent, you maybe right and i guess I will find out since I will have to plug my sub into the wall now.
wolver98 is offline
