The Onkyo TX-SR606 Owners Thread - Page 81 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #2401 of 9512 Old 07-31-2008, 12:03 PM
VictorWI's Avatar
Originally Posted by drfruit View Post
Would it not be better for those affected to start a separate thread about the hum/buzz problem in 606's?
I have just tested it by pausing several dvd's (Dolby 1, 2.0, 5.1 and DTS) on my PS3 and turning the volume to Max. Even with my ear to the speaker, I hear nothing. Then I remembered, someone wrote that it only occurs on 1080p systems (mine is 1080i). Do I need to use bitstream or PCM, DD sources and non-DD sources? A 7.1 or 5.1 setup? A disconnected sub? A 5.1 system tricked into thinking it is 7.1?
I have followed this thread from the start, but I lost track of what is or is not required to hear the unwanted noise. A separate thread with a startup FAQ might save a lot of confusion and repeat posts.
I can cause the humm/buzz by doing the following. Start the PS3 and make sure the audio is PCM (not sure if you have a choice here). Sit on an item in the XMB (main menu) with no sound and crank the volume up. The buzz is there.
Using a DVD, make sure the PS3 is outputting PCM and pause the DVD of BD and crank the volume.
I have a 1080p set and 5.1 setup with sub and this happens every time.
VictorWI is offline
post #2402 of 9512 Old 07-31-2008, 12:07 PM
huxrules's Avatar
I ran a spectrum analyzer on the my 606 - to hunt out the buzz. you can see the results on my blog at http://www.huxrules.com.
Short version- turn off the Audyssey in the EQ. (but what fun is that)
huxrules is offline
post #2403 of 9512 Old 07-31-2008, 12:19 PM
tlabatte's Avatar
Hux, Can you call your service center and ask if they did more than upgrade the FW? Specifically, did they make a resistor change to the HDMI Board. This will help a lot.
tlabatte is offline
post #2404 of 9512 Old 07-31-2008, 01:36 PM
mystik610's Avatar
Is there any additional audio processing done by audyssey 2eq calibration feature? I know the audyssey dynamic EQ actively processes the audio signal based on the output volume (which is a great feature over the 605 btw), but does the audyssey 2eq calibration system involve any active audio processing? If the Audyssey 2eq system is really the culprit, and there isn't any active audio processing done by the system, couldn't someone run the audyssey set-up, turn audyssey off, and manually calibrate the audio and speaker settings using the values the audyssey system generated? And by doing so, could one still benefit from the auto-calibrated settings (minus the dynamic EQ) without leaving the audyssey setting on?
I'm fortunate enough to own a 606 unit that doesn't have any buzzing issues, so I'm enjoying both the audyssey 2eq and the audyssey dynamic EQbut for those who are suffering the buzzing issues, maybe this would be worth a shot
Cool feature on your iphone btw. If they ever get around releasing a simplified unlock for version 1.1.2 (I'm using a jailbroken 1.1.4), I might look into downloading it myself.
mystik610 is offline
post #2405 of 9512 Old 07-31-2008, 01:45 PM
aydu's Avatar
Quoted: 147 Post(s)
Liked: 122
Originally Posted by nc_av_newbee View Post
After reading some of the professional reviews of this receiver, I recently upgraded from a Pioneer VSX-1015TX to this Onkyo receiver. Mainly I did it to get the HDMI connections and so I could pass 'bitstream' to this receiver so it could decode 'DTS-HD Master Audio' and 'Dolby TrueHD' for lossless sound.
I have the following equipment hooked up to it.
JVC HD61FH96 LCOS - HDTV
Panasonic DMP-BD30 - BluRay player
Toshiba HD-A35 - HD-DVD player
Explorer 8300HD - cable box
Speakers:
Infinity Beta 50 - fronts (bi-wired)
Infinity Beta C360 - center
Infinity Beta ES250 - surrounds
Infinity SW-12 - powered subwoofer
I have to say that the setup of this receiver was VERY easy and while my Pioneer VSX-1015TX had very good sound, this Onkyo is noticably better. Incredible surround sound clarity with my setup.
I also love how the HDMI makes the hookups so much more uncluttered, along with the fact that I can now pass 'bitstream' lossless sound to this receiver for it to decode. 'DTS-HD Master Audio' and 'Dolby TrueHD' sent bitstream from the Panasonic BluRay and Toshiba HD-DVD players sound incredible.
I love my new setup and have not had any issues with buzzing.
I upgaded from a 1015 to the 606 too. I thought the 1015 sounded good, but after listening to the 606 I have to admit that the Pioneer sounded like a blanket was placed over my speakers.
The Onkyo removed that blanket and added a significant amount of power, even though the receivers don't differ much in their output ratings (Onkyo is actually lower).
aydu is offline
post #2406 of 9512 Old 07-31-2008, 02:34 PM
nc_av_newbee's Avatar
Also, it seems that I hear more (or clearer) sounds from my 'surround' speakers. Not sure if that is a bi-product of the Onkyo vs the Pioneer or it could possibly have something to to with the 'automatic' setup of the speakers via the 'microphone' setup. All, I can say is that the surround sound from the High Def dvds I have played so far has been great.
nc_av_newbee is offline
post #2407 of 9512 Old 07-31-2008, 03:08 PM
NKrader's Avatar
the microphone setup sucks ass.. i run it and it ****s my audio.. levels and such are all wrong.. better to manually setup.. anyone else have this problem? 606 is fukin amazing
NKrader is offline
post #2408 of 9512 Old 07-31-2008, 05:03 PM
I'm sure the results you get depend somewhat on your speakers, room size, room shape, and furnishings. Plus, everyone has their own perception of what sounds good to them. I was happy with how mine sounded. After living with it a while, I may make some minor adjustments.
post #2409 of 9512 Old 07-31-2008, 05:32 PM
SeriousHorse's Avatar
You might be right, drfruit.
There's a lot of confusion around this problem, largely because that's the nature of internet chat boards:-) But also because there actually seem to be two separate problems. They may well be related, but as far as I can tell they're not the same thing. The other factor that complicates things is that not every 606 is affected. Some people get no buzz, others get more than they can handle, and certainly more than they'd like.
Buzz problem 1: The Dynamic EQ/Dolby digital problem, ie, if you turn on Dynamic EQ while running a Dolby digital source your speakers will start to buzz. This is the problem I've been tracking with help from Chris from Audyssey. It can only happen if you've done an Audyssey 2EQ set up because only then will Dynamic EQ come into play (I'm not sure if it's enabled by default once you've done the Audyssey set up - I think not). It happens either with HDMI or optical audio connections - it's not just a HDMI problem - but it only happens with Dolby digital sources. PCM sources produce no buzz. The solution is simple: turn off Dynamic EQ. The only problem is, Dynamic EQ is a great feature, especially at lower listening volumes.
According to Chris, this is definitely not an Audyssey problem - it's a problem with Onkyo's hardware. He contacted Onkyo Japan about it and they were able to reproduce it. They also promised a fix, most likely a hardware fix. But it doesn't seem like details of this fix have been communicated to Onkyo US yet, or other worldwide dealers, because, so far, nobody has reported their unit being fixed. I thought huxrules was going to be the first, but his 606 came back "fixed" and it still buzzes.
Chris has been incredibly helpful trying to get this issue fixed. Onkyo, on the other hand, haven't been helpful at all. Both Cal1981 and I have tried to contact Onkyo USA's Product Manager for the 606 but he simply hasn't answered any emails. If you want his details and want to try for yourself, just PM me.
I'm still hopeful that a fix is in the works. We just have to wait for it to filter through to Onkyo's service departments.
Buzz problem 2: the HDMI buzz issue. This appears to affect PS3 owners mostly, but there have also been reports that it affects DVD players and cable boxes with HDMI audio connections. The problem here is buzz, buzz, buzz, all the time. As far as I can tell it has nothing to do with the source (Dolby or PCM) or whether or not Dynamic EQ is enabled.
Onkyo supposedly have a hardware fix available for this issue. Old Deuteronomy posted a link to the Onkyo service document here. Direct link (to ImageShack) is here.
Again, we have to wait and see what this actually fixes.
SeriousHorse is offline
post #2410 of 9512 Old 08-01-2008, 02:34 AM
drfruit's Avatar
For those asking about satisfied users of a TX-SR606, I am one of them.
The Onkyo replaced my Marantz SR5300, which sounded good but lacked HDMI capacity.
I kept my Mordaunt Short 302/304/308 surround speaker set and bought a couple of Dali Suite 1.7 front speakers to create a 5.1 system. The great thing is that they seem to be perfectly matched after using the Audyssey setup. I cannot tell which speaker produces which part of the sound.
This reciever puts me right in the middle of the sound stage. I used to wonder what a movie with a great sound track would sound like in a state-of-the-art cinema, but now I feel like I know. The Marantz did not make my Mordaunt Shorts sound anywhere near this good.
My Toshiba HD DVD player, PS3 (even at maximum volume) and TViX 6500a HD media player all work flawlessly over HDMI. The only problem I had was with my Philips HDTV PVR for UPC cable TV, which produces audio dropouts over HDMI (a couple of times an hour at random intervals). I fixed the problem by using an optical cable for the audio.
I have not experienced any of the buzz/hum problems with my PS3 or any other source. I hope those affected will find a fix so they can enjoy their 606 as much as I do.
drfruit is offline
post #2411 of 9512 Old 08-01-2008, 06:07 AM
adam320's Avatar
Quoted: 74 Post(s)
Does anyone have the Onkyo Ipod dock? Do you know if you can use it without the tv on? I dont want to leave static images on the plasma while playing music. Thanks.. Or if there is a similiar non-onkyo product that works better any suggestions would be great. Thanks.
Samsung UN75H7150 - 75"
Denon AVR-X4100W
DefTech 8080 Center Chanel; 8060 Towers; 8080 Surrounds
HSU VTF-15H MK2
Xbox One
Directv Genie
adam320 is offline
post #2412 of 9512 Old 08-01-2008, 08:22 AM
tmc1971's Avatar
Quoted: 41 Post(s)
Liked: 29
I must say, I almost didn't buy this receiver because of this famous buzzing sound. I got one at the suggestion of a couple people just the same. I have my TX-SR606B hooked up to JBL CS6100, PS3 and HD-Cable box hooked up using HDMI850HD Monster cables and so far the sound is unreal. The PS3 is running DTSHD and it sounds great at both low and high volume levels.
Good luck to those with issues and I hope I never run into any of them.
So far the 606 has been a great upgrade to my old system.
Cheers,
tmc1971 is offline
post #2413 of 9512 Old 08-01-2008, 08:38 AM
Itsdon's Avatar
The people or the issues?
"Life is a toy, play with it"
Itsdon is offline
post #2414 of 9512 Old 08-01-2008, 09:27 AM
GoodToGo1's Avatar
Are recent buyers of the 606 getting buzz? Or it only confined to older ones?
GoodToGo1 is offline
post #2415 of 9512 Old 08-01-2008, 10:09 AM
BRAISKI's Avatar
Quoted: 20 Post(s)
Guys is the remote control RF or IR?
Denon 2809CI
C: Def Tech - CLR2002
F: Def Tech - BP2002TL
S: Def Tech - BP1.2X
SB: Def Tech - PM400
Sub: Plan to get the SVS-SB1000
BRAISKI is offline
post #2416 of 9512 Old 08-01-2008, 10:20 AM
tallguylikacurry's Avatar
Brand new here...I recently purchased (recieved it on 7/18) the 606 from crutchfield and it had the dreaded buzz when played through the PS3. Unaware others were experiencing the same problem, I spoke to crutchfield and onkyo and was directed to try another unit without any acknowledgement from either party a problem exists. While I waited for my new unit I found this forumn and discovered many others are experiencing the same problem. My new unit arrived yesterday from Crutchfield and had the exact problem. Spoke with onkyo, armed with data that this is a real problem, and they informed me that all of their distributers have been notified to no longer send out faulty units. They told me crutchfield does know as well but was probably trying to get rid of their inventory. I was pretty annoyed in hearing this and called crutchfield back today and explained to them what onkyo had said. They claim they may have recieved notice but it hasn't filtered throughout their company but now that i have called them, they will surely make sure this doesn't happen.
I doubt they will stop shipping faulty units, but who knows? I am now going to take it to the service center and wait three weeks in the hopes the problem is resolved. If it wasn't for the fact that my wife through out the box, I would of sent this back and gone on my way. Its hard not to like all of the options this reciever offers at this price range, but the buzzing noise is f'ng rediculous. If you don't have a unit thats impacted, you are lucky.
tallguylikacurry is offline
post #2417 of 9512 Old 08-01-2008, 10:34 AM
mystik610's Avatar
I got my 606 just last saturday from CC (on sale for 399 + another 10% off)....haven't had any problems with buzzing so far.
Here's my set-up:
40gb PS3 -->HDMI --->onkyo 606
xbox 360-->HDMI --->onkyo 606
comcast HD cable box ---->HDMI --->onkyo 606
onkyo 606 ---->hdmi ---> samsung lnt5271f
post #2418 of 9512 Old 08-01-2008, 10:35 AM
mystik610's Avatar
Here's my set-up:
onkyo 606 ---->HDMI ---> samsung lnt5271f
post #2419 of 9512 Old 08-01-2008, 12:52 PM
gabrielh1979's Avatar
FYI...
Onkyo SR606B for $350 shipped.
http://www.6ave.com/shop/product.aspx?sku=ONKTXSR606B
Use coupon code SUMMER72908 for the extra 6% off.
gabrielh1979 is offline
post #2420 of 9512 Old 08-01-2008, 01:03 PM
glemigh's Avatar
Quoted: 14 Post(s)
Liked: 24
My 606 arrived July 31st, no buzzing with Toshiba HD-A3, FiOS HD box connected via HDMI.
All seems well.
George
Home Theater:
Samsung UN55JS8500, Onkyo TX-NR838, Oppo UDP-203, Motorola QIP7232, Harmony 650 Remote
Computer Screen:
Samsung UN49MU6500
Mediabridge HDMI cables everywhere.
glemigh is offline
post #2421 of 9512 Old 08-01-2008, 01:38 PM
mazer75's Avatar
Hey how do you guys get this for $399 at CC? Right now it's listed as $429 there...
mazer75 is offline
post #2422 of 9512 Old 08-01-2008, 02:00 PM
sparky3003's Avatar
Hi I am new to this so please forgive me for sounding stupid.I have just purchased a 606 and using it with jamo A102hcs5 ,panosnic th42px70,ps3,sky+,wii.How do I best connect this all up.SO far I have a couple of qed HDMI cables a optical cable.I have also got speaker cable.How do I connect the spaeakers to the amp.Do I connect them first to the sub or straight to the amp.Also what do I use to connect the sub to the amp and how many cables do I need for this.Thanks for your help.
sparky3003 is offline
post #2423 of 9512 Old 08-01-2008, 02:02 PM
zetachi's Avatar
Quoted: 85 Post(s)
Liked: 70
well just bought this a 6th ave could not pass up on that price. Here's hoping for no buzz.
zetachi is offline
post #2424 of 9512 Old 08-01-2008, 02:35 PM
Whitay's Avatar
I so want to pull the trigger and buy this from 6th Ave as well, but I just don't want to deal with all of the hassle if it turns out badly.
Whitay is offline
post #2425 of 9512 Old 08-01-2008, 02:51 PM
mike6789's Avatar
how do you get the subwoofer to work on "DIRECT" audio mode??
mike6789 is offline
post #2426 of 9512 Old 08-01-2008, 03:02 PM
rob61's Avatar
Originally Posted by gabrielh1979 View Post
FYI...
Bet they are clearing out their "buzzing" stock. This is one "hummer" of a deal.
rob61 is offline
post #2427 of 9512 Old 08-01-2008, 03:10 PM
kplex's Avatar
Play a soundtrack that has an LFE (.1) channel.
kplex is offline
post #2428 of 9512 Old 08-01-2008, 03:14 PM
NKrader's Avatar
what u mean? "direct"? i have mine plugged into sub line out then monster cable then monster sub splitter then turned lfe off and do it like that
NKrader is offline
post #2429 of 9512 Old 08-01-2008, 03:16 PM
NKrader's Avatar
just go for it
NKrader is offline
post #2430 of 9512 Old 08-01-2008, 03:17 PM
NKrader's Avatar
just connect to the back of the reciver.. plug the sub in and it should all work
NKrader is offline
