Official Pioneer SC-09TX/SC-LX90 Owner's Thread - Page 16 - AVS Forum | Home Theater Discussions And Reviews
post #451 of 5410 Old 08-26-2008, 07:50 AM
Dave Vaughn's Avatar
Quoted: 1047 Post(s)
Liked: 1520
Originally Posted by nippon View Post
My Lx-90 is coming on Thursday. I was almost one month since I order it.
I know it's a bit off topic but whcih HDMI cable short length do you recommand for it.
I have already a SUPRA cable of 10m to my projector but I would like to upgrade the one between my blue ray player and the LX-90. I need only one meter so I can take higher quality (especialy for the audio).
I don't know what's the best cable for audio
I am thinking the FURUTECH xv1.4
Wireworld ultraviolet or AUDIOQUEST HDMI 1.
They are all around 250$.
Dave, which cable did you use to make your review?
For a short length cable, it doesn't really matter...it's 1's and 0's. For longer cable runs, quality does matter. I use a fiberoptic cable for a 15 meter run to my projector, but for my interconnects between my components, I use monoprice. I've tried much more expensive cables for the shorter runs and there was zero difference that I could tell using video test patterns. I would suggest saving some money and try a cheaper solution.
David Vaughn Blu-ray Reviewer / Technical Writer Sound & Vision Magazine (Print & Online)
My Atmos Renovation Part 1 http://www.soundandvision.com/conten...odyssey-part-1
My Atmos Renovation Part 2 http://www.soundandvision.com/conten...odyssey-part-2
Dave Vaughn is offline
post #452 of 5410 Old 08-26-2008, 07:54 AM
Liked: 1520
Originally Posted by corentin View Post
Dave, could you please comment on the SC-09's audio quality compared to denon 5308 and yamaha Z11? Your experience as a professional reviewer would be much appreciated
I've only tested the Z-11, not the 5308 (although I did review the Denon 4308). Frankly, they all sound very good. If price were no object, I would choose the Pioneer due to its overall features, but then again, I haven't used the 5308 so my mind could change.
Also, not being able to switch "on the fly" between each of the AVRs makes a comparison very tough to do after so much time has elapsed between the reviews.
post #453 of 5410 Old 08-26-2008, 08:03 AM
corentin's Avatar
Thanks a lot for your input Dave. I expected the pioneer to be leaps and bounds ahead in terms of sound quality. Interesting!
In your experience, which one is the most laid-back sounding(less bright) amp, the z11, the sc-09 or the denon 4308?
Again, thanks in advance
corentin is offline
post #454 of 5410 Old 08-26-2008, 11:06 AM
catapult's Avatar
There's no need to spend a lot of money on a 1m cable. In a recent Audioholics shootout (using $200K test gear), most of the ones tested far exceeded the required bandwidth at that length. Anything rated for HDMI 1.3 bandwidth should be fine. As the length got longer in the test, differences started showing up but there appears to be no correlation with price. The Monoprice cables ($10 for 2m, $41 for 8m) outperformed cables costing hundreds or even thousands of dollars.
http://www.audioholics.com/education...le-bench-tests
http://www.monoprice.com/products/su...02&cp_id=10240
Dennis H
catapult is offline
post #455 of 5410 Old 08-26-2008, 03:11 PM
Liked: 1520
I wouldn't call any of them bright at all..all have a warm signature to them. Before room correction, the Pioneer was a bit muddy in the midrange, but that has more to do with my room than anything else.
The Denon is the best value price/performace, but if I had to choose between the three without considering price, I would go Pioneer, then Denon, then Yamaha. My biggest beef with the Yamaha is that it corrupts the HDMI signal (their passthrough isn't a true passthrough), where the Denon and the Pioneer both pass the signal unmolested. SQ wise, I like all three of them, but I would bet that the Pioneer has much greater power, but won't know for sure until it I get the bench report (should post with the review).
post #456 of 5410 Old 08-26-2008, 04:27 PM
corentin's Avatar
Are you referring to 0-255 / 16-235 colour spaces? If so, I thought I read somewhere that Yamaha had the problem solved via a firmware update. Buit maybe there's another issue with this unit and HDMI switching?
corentin is offline
post #457 of 5410 Old 08-26-2008, 04:34 PM
Liked: 1520
The unit I had wasn't upgraded yet with a new firmware, but this was earlier this year. Maybe they have updated it after my review, but at the time, they didn't see what the big deal was! If that's fixed, then the AVR becomes more likable. Although, if you need video processing (or want it), the Denon 5308CI is the best choice. (I personally don't use any of the video processing in my pre/pro...it is set to through).
post #458 of 5410 Old 08-27-2008, 05:06 AM
nippon's Avatar
Thanks for your reply Dave.
What about the power cable? What do you use/recommand?
I will use mainly the LX-90 for audio SACD JAZZ and Classic.
I have a Linn cable but I was thinking wireworld.
nippon is offline
post #459 of 5410 Old 08-27-2008, 08:07 AM
Liked: 1520
Use what you feel comfortable with. I would also test them out and see if they make a big difference in the sound (blind). Put a friend to work changing cables having you pick which one sounds the best (even the stock one). You may be surprised by the outcome once the placebo effect is taken away.
post #460 of 5410 Old 08-27-2008, 11:36 AM
WimdeGier's Avatar
Hello guys,
I'm new at this.
For some time now I'm working on the construction of a new HT room in my old farmhouse in the North of the Netherlands, all wooden walls and sealing, the floor will be made of ceramic tiles (floor heating). Next week I will start ordering the electronics. It will be, apart of the sub's, an all Pioneer set-up including the speakers (2x S-1EX-W in front, 1x S-7EX-W centre and 4x S-3EX-W's as surrounds. The beast that drives it all will be the SC-LX90.
Thanks to you guys I learned a lot about LX90 and it's pro's and con's. However I'm not clear about the quality of the subwoofer set-up/ EQ.
I will be using 2x SVS PB13-ultra's for the low end. This thread and the Manuel doesn't give me sufficient insight..
Will the LX90's MCACC be able to properly EQ these units or do I need additional EQ equipment to get a flat curve (like the velodyne SMS-1).
Since your guy's are way ahead of me in the experience curve, I thought I ask for your opinions.
Thanks in advance, Wim
WimdeGier is offline
post #461 of 5410 Old 08-27-2008, 01:36 PM
AU11's Avatar
I've actually wondered the same thing about subwoofer setup.
BTW, I'm totally envious of your speaker setup... the Pioneer/TAD/EX speakers are quite impressive. They probably don't get the respect they deserve since they are branded as "Pioneer." Check out the owners thread, here, which sure could use more owners posting on it.
AU11 is offline
post #462 of 5410 Old 08-27-2008, 05:17 PM
nippon's Avatar
I bought a SMS-1, I am waiting until I receive it
It should be a good combo with the LX-90
nippon is offline
post #463 of 5410 Old 08-28-2008, 06:02 AM - Thread Starter
ss9001's Avatar
Quoted: 358 Post(s)
Liked: 423
Originally Posted by WimdeGier View Post
..Will the LX90’s MCACC be able to properly EQ these units or do I need additional EQ equipment to get a flat curve (like the velodyne SMS-1).
Since your guy’s are way ahead of me in the experience curve, I thought I ask for your opinions. Thanks in advance, Wim
Welcome!
MCACC will set your subs' levels, delay & distances but not actually EQ them. Also, it sets each sub independently so each one will have its own setting. That is a new feature that the previous 4 yr old flagship did not have. You'll also have the option to turn on/off their standing wave filters & phase control which effects how all the speakers blend.
Of course, MCACC does EQ all the other speakers in 9 bands from 63hz-16khz
To actually EQ the subs in your room, you'll need a separate equalizer like the Velodyne SMS-1. Some recommend using a Behringer Feedback Destroyer (high learning curve) or a parametric EQ like a Rane, but I'd highly recommend the SMS-1, since its the same as in Velo's DD subs & it's relatively easy to learn & use. Gives excellent results + on screen display of the response curve, filters, settings.
ss9001
Steve
ss9001 is offline
post #464 of 5410 Old 08-28-2008, 08:35 AM
WimdeGier's Avatar
Thanks ss9001,
I thought is would be the answer. So I have to spend some more euro's for a couple of SMS-1's.
Better to do it good than be sorry later. Next week I'm going to order the gear.
post #465 of 5410 Old 08-28-2008, 09:11 AM - Thread Starter
ss9001's Avatar
Quoted: 358 Post(s)
Liked: 423
Thanks ss9001,
Good news for you - you only need 1 SMS-1 One unit will handle up to 3 subs. What the unit will do is EQ the *combined* output of all subs at the same time. Any speakers you set to Large, will also add a bass component so should be measured at the same time as the subs. What gets plugged into the unit is the LFE from the receiver. But if you want any full range speakers that you've set to "large" to be included in the measurements, just make sure they are turned on and play the freq sweep tones along with your subs. Instructions are pretty detailed on what to do, and Velodyne's Curt monitors the Velodyne owners thread on this forum pretty closely, answers questions & you can call him directly for setup help.
Have fun!
ss9001
Steve
ss9001 is offline
post #466 of 5410 Old 08-29-2008, 11:06 AM
CollinViegas's Avatar
Is it possible for me to add an extension to the SC09TX's setup mic without any compromises?
My equipment room is about 40 feet away from my theater so I have no choice either way but just want to make sure before I order a cable.
CollinViegas is offline
post #467 of 5410 Old 08-29-2008, 11:33 AM
Liked: 1520
Collin,
This is just a guess, but I doubt you would have a problem. I bet Radio Shack has what you would need (and they have a GREAT return policy).
post #468 of 5410 Old 08-29-2008, 12:10 PM - Thread Starter
ss9001's Avatar
Quoted: 358 Post(s)
Liked: 423
Hi Dave,
Do you think your review will be up by the holiday weekend or is Ultimate AV going to make us wait another week?
ss9001
Steve
ss9001 is offline
post #469 of 5410 Old 08-29-2008, 12:37 PM
Liked: 1520
SS,
Hopefully it goes up soon...I finished writing it nearly 2 weeks ago, but when the editor goes on vacation, there isn't much I can do. My guess would be we wouldn't see it until early next week, but I could be surprised and have it pop up sooner than that.
Sorry for the delay.
post #470 of 5410 Old 08-29-2008, 01:07 PM
telem's Avatar
Quoted: 59 Post(s)
Liked: 40
I am bit confused, can we play FLAC files with Susano / SC09 / SC-LX90? Sorry if this has been already answered, but I cannot find a clear response. Thank you !!
Trinnov Altitude 32 - Trinnov Amplitude*2 - Sony VW-5000ES - Lumagen Radiance Pro 4446 - Screen Research 175" ClearPix 4K White 1.0 - Wisdom Audio speakers: L8i (LCR) - P6i (SL, SR) -P4i (SBL, SBR - LW, RW(wide for Atmos)) - 6* B&W CCM7.4 (Ceiling Atmos) - Paradigm Subwoofer SUB2 - Kaleidescape Encore & Premiere - Oppo 205 - PS4 Pro - XBOX one S - Roku 4 Ultra - Technics MK2 SL-1200GAE Limited Edition
telem is online now
post #471 of 5410 Old 08-29-2008, 02:13 PM
Liked: 1520
FLAC isn't supported. It's pretty much the only audio file that isn't. When I spoke with their head of Audio marketing, he specifically mentioned this.
post #472 of 5410 Old 08-29-2008, 03:21 PM
catapult's Avatar
I'm confused about FLAC too. The manual says it's supported. Just guessing but I think the catch is it uses Windows Media Player as the server so you need to get WMP playing FLAC before the receiver can play it. Most people using FLAC don't mess with WMP much so they've never installed the codec and had WMP scan the FLAC files into its library.
Of course, if you're using a Squeezebox Duet, the whole issue is moot. No slow onscreen scrolling for me, thanks.
Dennis H
catapult is offline
post #473 of 5410 Old 08-30-2008, 06:04 PM
drkddell's Avatar
Hi everyone,
My Sc-09TX is officially ordered, expected in ~10 days, so I wanted to join in. My theater area is already configured, with a Pioneer PDP-1150HD, PS3, HD-A2, Monster AVS-2000 and HTPS 7000. I have a full 6.1 set of Boston Acoustics VRi in-wall speakers. My big challenge is subwoofer placement, as I have an irregular room with "bass-challenged" main speakers. I have been using a Polk Audio PSW-1000 with good results, but will eventually use that SW in a different room with a full set of Polk LSi's. I will need to add a subwoofer, perhaps two, preferably in-wall, to match the Bostons already installed. Any suggestions?
KDD
drkddell is offline
post #474 of 5410 Old 09-01-2008, 05:24 AM
ssak's Avatar
audio magazine (audio.de) ....
SCLX90 has reached a total of 113 points.... 110 for Z11 , 108 for Denon....
105 points in stereo ,115 in surround 120 in hd-surround
Very positive test even if the price in germany is 7000 euros
Measurements
In stereo mode 260/350 watt (8/4 Ohms)
5 channel mode 250/260 watt ..if i remember correctly
ssak is offline
post #475 of 5410 Old 09-01-2008, 05:45 AM
ssak's Avatar
For me the main reason not to buy Susano is cd playback...
Not having PQLS over HDMI in conjuction with no ilink in their flagship BD player...
Surely this will change but i wonder if it will only need a firmware upgrade...
ssak is offline
post #476 of 5410 Old 09-01-2008, 07:44 AM - Thread Starter
ss9001's Avatar
Quoted: 358 Post(s)
Liked: 423
But, it still does have a jitter-reduction circuit tied into the sampling rate converter for all inputs. And Ilink & HDMI are on the same circuit board, so maybe there's more to it than the marketing blurbs suggest.
Personally, I wouldn't let CD playback be a fundamental reason not to buy the AVR. If anything, the sampling upconversion should help tame CD's.
ss9001
Steve
ss9001 is offline
post #477 of 5410 Old 09-01-2008, 09:50 AM
uw69's Avatar
Anyone using the Pio 09 with Paradigm Signature S8's? Wondering how this combination would sound before I jump in! Thanks
I miss the rosewood sides on the old Pioneer Elite equipment!
Blu-ray - 576
HD DVD - 81
uw69 is offline
post #478 of 5410 Old 09-01-2008, 06:03 PM
lano1106's Avatar
Hi,
Is someone from Pioneer reading this forum?
I am ripping CDs with Winamp and have choosen the m4a file format with LC-AAC encoding.
The winamp AAC encoder is from Coding Technologies which belongs to Dolby Laboratories. I would expect this encoder to be supported but my SC-09TX receiver display a small yellow exclamation mark beside my m4a file.
Have someone here have been able to play m4a AAC file on the SC-09TX?
Which AAC encoders are known to be compatible with the SC-09TX?
Thank you,
lano1106 is offline
post #479 of 5410 Old 09-01-2008, 07:44 PM
FilmMixer's Avatar
Quoted: 1924 Post(s)
Liked: 2389
Originally Posted by lano1106 View Post
Hi,
Thank you,
What bit rate are you at? There is a bit rate cap of 320kbps with AAC...
FilmMixer is offline
post #480 of 5410 Old 09-02-2008, 01:11 AM
JANJWJMC's Avatar
I have the test of audio.de at home it is 8/4 ohm 248/362w stereo and 5 channel 252/267w
105 stereo 120 surround 125 hd
[in the world of of av-vollamps there is no combi of power ,competen ,and sound balandse ,there is no competition fore the sc-lx 90 ] [translate]
Next week i wil get Stereoplay.de and will give a update about this
JANJWJMC is offline
