Official Pioneer SC-09TX/SC-LX90 Owner's Thread - Page 180 - AVS Forum | Home Theater Discussions And Reviews
post #5371 of 5393 Old 03-02-2014, 02:51 AM
mkk85lam@hotmail's Avatar
By the way,
When performing the..........
"8.3 How to update the Flash Roms for various Microcomputers".....
Question: Can you purchase one of the "USB to Serial 9-pin null-modem(cross cable) cables", that are widely available on EBay.com, for this update firmware-file/transfer procedure??
Can this be done Hkan?
Just asking, as I do not have an earlier model PC with a "serial-9-pin" connnector on it anymore?
Just wondering IF one of these hybrid "USB-serial-9-pin" cables works as well, for the firmware/software updates on the Pioneer SC-09TX??
mkk85lam@hotmail is offline
post #5372 of 5393 Old 03-02-2014, 05:02 AM - Thread Starter
ss9001's Avatar
Quoted: 306 Post(s)
Liked: 379
I have the Belkin F5U109 USB-to-Serial Adapter. Came with Windows XP drivers. It works like a charm for both FW updates and downloading MCACC data.
I think the Mac version was F5U409.
Still available but a discontinued product:
http://www.ebay.com/itm/BELKIN-USB-to-SERIAL-ADAPTER-Cable-for-PC-F5U109-F5U409-/400071303835
But check Belkin support carefully on compatibility with Windows >> XP & no support for 64 bit Win.
Here's another one that popped up but check WIndows support (32 bit Vista OK but no mention of W7):
http://www.serialgear.com/1-Port-Serial-USB-U232-P9.html
and they have a number of others with Win7 & Win8 support:
http://www.serialgear.com/USB-to-Serial.html
http://www.serialgear.com/usb-to-serial-adapter.html
http://www.serialgear.com/rs232-to-usb-adapter.html
http://www.serialgear.com/usb-to-serial-cable.html
Then you'll need the null modem cable to connect receiver to adapter, like this:
http://www.microcenter.com/product/200404/Serial_Null_Modem_Cable_6_Foot
http://www.newegg.com/Product/Product.aspx?Item=N82E16812196488
As far as a single USB adapter device with a built-in null modem cable, I've never came across one.
btw - glad to see there's still some out there using this excellent receiver smile.gif
Steve
ss9001 is offline
post #5373 of 5393 Old 03-04-2014, 05:53 AM
Thanks very much for the help "ss9001" Susano owner, I'm very appreciative of all your lengthly post/help, in regards to my SC-09TX's Fimware-update queries!!
Will definately be ordering/buying 1 or 2 of these recommended "cross/null cable attachments" you posted about.
# Do you also know whether anybody has posted any official Pioneer Sisano SC-09TX "USB Firmware updates", the one's that the service manual says you can??
....Specifically the bit in the manual where it says.....
8.4 HOW TO UPDATE THE FLASH ROMS FOR USB MODULES........??
Any posts from any SC-09TX bloggers, referring to these particular "USB Flash Roms" firmware-updates??
## Also, just out of query, I also, have a Pioneer SC-07 reciever, and was wondering whether you know of anyone on AVSForum.com who has ever posted "any DSP Flash Roms, Flash roms for various micro-computers, OR USB Module Flash-roms" for the SC-07 reciever, also??
Once Again,
Thanks very much for your help ss9001 user!!!
Very much appreciate all your help, (and anybody else's help, who chimes-in, for that matter).
Best Regards,
Mark
post #5374 of 5393 Old 03-17-2014, 05:53 AM
It seems that "ScreamsDream", "borland", "bguzman", "bumblefeet" (and many other users in this forum!) are absolutely, correct, in their application of sucessfully downloading & applying the "downgrading CFW" and then the "CFW 4.03"(fomr the Russion site, I believe), to SUCCESFULLY make their Pioneer BDP-105 completely "region-free-for-Blu-Ray & DVD" playback!!
Let me just add a few of the "other" problems that I ran into when installing my downloaded CFW for my BDP-105:
1) the "FAT or FAT32" formatting USB format "DID NOT" work for me, so I had to re-doe the formatting in the "NTFS" USB formatting, before the files would work for me!
2) You DON'T seem to need the "extra" 2 x additional files stored on the USB for these CFW's to work.....(i.e.don't seem to need the * "DLDISCIDENTIFIER" file, OR the * "DVD.bin" files, the "one's that appear on the Official PIONEER BDP-150 official Firmware files, now that your installing the CFW files!)
3) Remember to "un-zip" the "BDP-150_S-downgrade" file first (.....& also un-zip the "Pioneer BDP-150 Firmware - v4.03" file as well, when it comes time to use that download)....., as I had to use a program called "Winzip" to unzip mine!......I downloaded this un-zipping program on-line.
4) After using the initial "downgrade" firmware file, the new Firmware showing on my BDP-150 came up as ....."BDP-150 Activefile "5.09" February 02_2013"" version!!
5) I also had to "download" the program called "Microsoft Visual Studio 2012 x86 Redistributable", a program I found on-line..(using Google...), so that I could in fact use the "MTKPIO.exe" program, otherwise it would not recognise the "MTKPIO.exe" program file on my IBM-compatible pc!
6) After installing the second update file..file "BDP-150_SP.bin", the one you've just un-zipped, form the USB into your Pioneer BDP-150, the software version/Firmware number niow showing should now be ..........."BDP150 V04.03"
7) ....one final tip, remember to press the "GENERATE" icon within the "MTKPIO.exe" program on your PC (after you've entered your BDP-150 player's "unique/individual" "mac address" and "serial numbers", otherwise the "MTKPIO.exe" program will not now show you/Generate your unique "codes" for you to enter on your BDP-150, after entering/pressing 3 7 2 1, in the "twelve step" of "Third step", as ScreamDream avsforum user has indicated!
P.S. the above are just added problems I ran into, in addition to what the others have indicated in their "3-STEP" procedure, to transform your BDP-150 into completely "region FREE for BD-dvd playback!!".
ALL the best converting, as I am completely won-over by how sucessful this CFW's have transformed my player!!
Best Regards,
Mark L.
ScreamsDream
DOWNGRADE TO 1.02 FROM 1.05 TO INSTALL CFW. (uploaded files to different site from the original to make things easier)
First Step:
Downgrade from 1.05 to CFW to DG:
1) Download " http://www.mediafire.com/download/ecfmwbjwo0bbjpv/BDP-150_SP-downgrade.rar " and copy the file "BDP-150_SP " to a Empty USB (formatted in FAT or NTFS NOT EX FAT!!!)
2) Plugin the USB into the BDP 150
3) Boot up BDP 150 (without any discs inserted) and press Home button
4) Go to initial setup
5) Go to options, and select update
6) Update from the USB
7) When installed it will reboot.
Second Step:
1) Download " http://www.mediafire.com/download/1c46szl1ewqe1ld/Pioneer+BDP-150+Firmware+-+v4.03.zip " and copy the file "BDP-150_SP" to a Empty USB (formatted in FAT or NTFS NOT EX FAT!!!)
2) Download " http://www.mediafire.com/download/yy3nyqo8wsjvnpg/Activator.zip " and save to Desktop (or anywhere you want i don't care)
3) Plugin the USB into the BDP 150
4) Boot up BDP 150 (without anything inserted) and press Home button
5) Go to initial setup and options and select update.
7) When installed it will reboot.(IN MY CASE IT GOT STUCK ON WAIT. I HIGHLY SUGGEST WAITING 15-20 MINUTES THEN TAKING THE POWER OUT AND THEN BACK IN)
8) CFW Is now installed.Now to activate
Third Step:
1) Boot up BDP 150 (without anything inserted) and press Home button
2) Go to initial setup
3) Select Network - ip setting and write down the Mac address onto notepad (don't include the - literally just afe456e43 etc)
4) Go to the options and select system information
5) Write down your serial number into notepad (don't include - literally afe4r5e3 etc)
6) Run "MTKPIO.exe" which you downloaded and click on the unlock tap.
7) Select BDP-150 from the drop down box
8) Now copy the mac address you wrote down (5e56te3e etc) and click the From clipboard button
9) Now copy the Serial number you wrote down (98e4t5 etc) and click the From clipboard button
10) Click Generate button.
11) Turn on your BDP and select initial settings.
12) Press 3 7 2 1 on the remote
13) Enter the code from MTKPIO IE 1 2 3 4 5 6 7 8 9 1 2 3 4 5
14) Press Enter
15) DONE.
TO CHANGE REGION CODE PRESS 3344 in initial setup and change DVD TO 0 AND BLU-RAY TO A (1) B (2) AND C (4)
!!!! Huge thanks to borland!!!!
post #5375 of 5393 Old 04-06-2014, 10:56 PM
Hi there Hkan, ss9001 avrforum'ers,
#Anyway you guy's know of where I can obtain the "EVENT", "DSP2" and "item" AND "HMG-usb drivere" firmware update files for the SC-09tx/SC-LX90?
Does anybody know where to gain downloads for the official Pioneer "SC-07_SC-LX81" official fimwares, esp, the "HDMI, DSP1, DSP2, DISP, EVENT, ITEM, Main, DISP-ucom, USB-Home Media Gallery files" from, and from which specific on-line site?
What about the latest "ufu1.10" unified flash update program utility file from??
Thanks for your help guy's,
Mark
post #5376 of 5393 Old 04-19-2014, 10:31 PM
rhed's Avatar
Quoted: 527 Post(s)
Liked: 363
I notice the L/R channels are rated up to 4 ohms. But not the center channel which is rated up to 6 ohms. Will the center channel handle a 4 ohm speaker?
rhed is online now
post #5377 of 5393 Old 04-20-2014, 05:19 AM - Thread Starter
ss9001's Avatar
Quoted: 306 Post(s)
Liked: 379
yes, all of them will, even though the "official" rating is not. I've been using mine for 5+ yrs with 4 ohm Magnepans. no problems. many used it with 4 ohm speakers & it was bench tested by various reviewers at 4 ohms.
Steve
ss9001 is offline
post #5378 of 5393 Old 04-20-2014, 10:46 AM
rhed's Avatar
Quoted: 527 Post(s)
Liked: 363
Thanks.. Btw, for almost all my questions regarding the sc-09 or MCACC. You've answered them precisely. And I've learned a lot since. Thanks again. And No matter how old this reciever is, I still think it's one of the baddest ones ever made. Had it for over 5 years now. My first reciever ever bought and I don't want to part with it. I'm gonna use it till it gives up on me. But man, it can take some punishment. I think it'll go 5 more years. Lol
rhed is online now
post #5379 of 5393 Old 06-19-2014, 03:42 PM
Liked: 0
Hello! I've just bought SC-LX90 and very happy with. But I have a problem and a few questions.
When I choosing Home media gallery I cannot use remote but can use buttons on the receiver itself
Whats wrong?
lesnik is offline
post #5380 of 5393 Old 06-30-2014, 08:37 AM
JANJWJMC's Avatar
Whats wrong?
At the left of to the volume control at your remote control is a switch for amp-source-tv set it to source to control media center.
JANJWJMC is offline
post #5381 of 5393 Old 06-30-2014, 08:39 AM
JANJWJMC's Avatar
Btw what are the benefits fore upgrading firmware?
Dont have dts bomb I think.
JANJWJMC is offline
post #5382 of 5393 Old 06-30-2014, 09:45 AM
TK-713's Avatar
Quoted: 18 Post(s)
Originally Posted by rhed View Post
<div class="quote-container" data-huddler-embed="/t/1027273/official-pioneer-sc-09tx-sc-lx90-owners-thread/5370#post_24626677" data-huddler-embed-placeholder="false"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>ss9001</strong> <a href="/t/1027273/official-pioneer-sc-09tx-sc-lx90-owners-thread/5370#post_24626677"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif"></a><br><br>
^^<br>
yes, all of them will, even though the "official" rating is not. I've been using mine for 5+ yrs with 4 ohm Magnepans. no problems. many used it with 4 ohm speakers &amp; it was bench tested by various reviewers at 4 ohms.</div>
</div>
<br>
I put the bad boy back in my system after using the SC-79 for almost a year. I am so happy I didnt sell it. The build quality of the SC-09tx is kick ass. I have my THX ULTRA 2 mode back lol.
Anyone out there know what speaker mode would be the best to use? I use the 7.2 bi-amp mode. Speakers are the Atlantic Technology 8200e THX ULTRA. I know its only passive bi-amp but it must do something, wouldnt it.
TK-713 is offline
post #5383 of 5393 Old 08-27-2014, 02:03 PM
Dragnet's Avatar
i.Link mystery
Long time...no post.... been busy and just enjoying the beast.
That was until about two months when lightning struck (literally) with a vengenance. Viped out the upstairs TV, router, switches, the mining computer, sat-boxes and damaged the HDMI board in my Susano (as well as the Sim2 projektor....). Thank goodness for insurance!
Anyway, I recently got the Susano back, still waiting for the projector though, so for now it's music only. I spent last Sunday rewiring and configuring and ended up with a cleaner set-up with less Cables, front-align MCACC etc.
(In this I have to confess a thing about the firmware: although being the first on the thread to upgrade the DSP FW I never got around to upgrade the other subsystems, never found my USB/serial dongle, not urgently needing any of the new "features", not wanting to reconfigure etc ;-) . But I had the service center upgrade the lot as they replaced the HDMI board.)
Now, when trying out my trusty BDP-868AVi (only connected with i.Link and component video as before) I could not get any sound from SACD or DVD-Audio (except my one and only disc from Aix). CD, DTS-CD and burned DVD-Audio discs with HD files from HDtracks worked fine. It seems that I have run into some evil copy protection that I have not encountered before.
Has anyone else seen this behaviour?
(I'm not in trouble really as I use my excellent Sony SCD-XA5400ES for analog CD, analog 2-channel SACD and digital multichannel SACD and the Denon DVD-3930 handles DVD-Audio nicely.)
Dragnet is offline
post #5384 of 5393 Old 10-07-2014, 08:59 AM
Alicatt's Avatar
Location: Ice cold in Alexandria or Eating in Eksel Belgium
Yep still using it and still enjoying it, but soon will have to start thinking about the 4k minefield
Alicatt is offline
post #5385 of 5393 Old 10-12-2014, 05:58 PM
rhed's Avatar
Quoted: 527 Post(s)
Liked: 363
Yup still using mines too. Only now, I'm using the preouts to a inuke 12000 and 6000 to power my LCR's. While the sc-09 still powers my surrounds. Very minimal noiserunning pro amps. I actually have to put my ear about 8" away to hear a hiss. And no humming too. If I do upgrade, it'll be for Atmos. But I'm not in the hurry. My SC-09 is still going 5 yrs strong. Now, I'm just getting into 2 channel music and love it. Any tips for 2 channel listening with the AVR? As far as settings?
rhed is online now
post #5386 of 5393 Old 10-20-2014, 02:03 AM
Dragnet's Avatar
...... Now, I'm just getting into 2 channel music and love it. Any tips for 2 channel listening with the AVR? As far as settings?
I have a Sony SACD and a Marantz audio streamer and for both I only use analogue in and "Pure Direct " = "Analog Direct". Works like a charm
Dragnet is offline
post #5387 of 5393 Old 03-19-2015, 04:14 PM
Liked: 0
Hi Steve,
Enjoy your helpful posts...been on these boards for a very longtime but first post.
I wanted to ask you how did you setup the Susano as just an amp? I understand you are utilizing the multichannel inputs but wanted to understand the amp section use only without susano jumping in with its own eq? Would be left to use only 4 channels since i wont be using LCR...is there a way to direct the LCR to speakers you want to power?
Any help would be much appreciated.
Z
zchamber is offline
post #5388 of 5393 Old 09-10-2015, 04:10 PM
badass_09's Avatar
Quoted: 16 Post(s)
Liked: 0
Hi guys.. my susano has a problem now.. there's no sound coming from the speakers when i watch movies using hdmi connections and i've checked though the manual and tried everything.. but there's sound when i adjust the speaker levels manually in the setup menu so i guess the amp section is still good.. but can't figure out why there's no sound coming out from any of my speakers and subs.. please help...!!
badass_09 is offline
post #5389 of 5393 Old 10-10-2015, 10:51 AM
Liked: 0
Hi
I have a SC LX90 amplifier - which is great.
However, I have noticed that when playing 7.1 Master Audio sound tracks (e.g. Age of Ultron), from a Pioneer Blu Ray BDP LX52, I get low output volume levels.
My speaker setup is 5.1 It also sounds like the 5.1 output is not capturing all of the soundtrack. I have tried all of the output audio formats. The 5.1 soundtrack on the Blu Ray (in Spanish) sounds great and has normal volume levels.
Any advice?
colin-IOM is offline
post #5390 of 5393 Old 10-11-2015, 05:27 PM
tguzz's Avatar
Originally Posted by colin-IOM View Post
Hi
Any advice?
It's the soundtrack itself. The Storm God is fine. They dropped the ball with the audio conversion, as well as the 3d. Bummer....
tguzz is offline
post #5391 of 5393 Old 10-16-2015, 03:10 AM
Liked: 0
That's a relief - many thanks for posting
post #5392 of 5393 Old 11-24-2015, 09:13 AM
plip71's Avatar
Liked: 0
Hi,
this is the first time i post here. I'm a happy user of the sc-lx90 but I actually have a little problem. The blue light on the power button will remain off. Apparently everything seems to be fine but I'm not sure that this may indicate other problems, light blue part.
Have any of you had the same problem? Someone has solved without service?
I would avoid to bring it to service if it is not really necessary
Thanks for the advice you can give me.
News...
After several weeks now the blue led is again working... I don't know why. Probably it was the holiday time or it need to do a tour in town but now it is again back... Good to know
plip71 is offline
post #5393 of 5393 Old 11-27-2015, 07:43 AM
plip71's Avatar
Liked: 0
Hi,
in the audio setup, at the end of the list, you can swich the hdmi sound: from Susano receiver to pass through the hdmi (to be amplified through the speakers of you TV for ex.). Please, check if you have changed it during your audio setup.
If the led configuration of the speakers are swiched off you probably have exluded the speakers with the dedicated swich button in the front panel of Susano: this can be another reason.
plip71 is offline
