Sony receiver volume drops? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 05-20-2008, 08:52 AM - Thread Starter
windrockwater's Avatar
I have a sony receiver (str995 maybe?) connected to 7.1 speakers. Most are B&W ceiling speakers (surrounds), the L and R are wall speakers. And there is a klipsch subwoofer.
Sometimes i hear the volume all of a sudden drop off by about 30-50% and then it comes back up to the normal volume when watching TV/movies.
Any ideas on what is causing this?
Epson 6020UB Projector
Dalite Contour HighPower Manual Pull Down
Denon AVR3311CI
Sony PS3
B&W CDM-7NT Speakers
windrockwater is offline
post #2 of 14 Old 05-22-2008, 08:59 AM
Dionyz's Avatar
Quoted: 57 Post(s)
Liked: 48
it is caused by underpowered amplification section off the Sony receiver. Most likely you are trying to drive it past its capability.
Sony receivers are notoriously overstating their rating. They do not deliver anywhere near the 100 w/ch claimed. They only deliver ~35 w/ch in 7 channel mode.
You need to start looking at replacing the Sony toy, with a more capable receiver, like Yaamaha, HK, Dennon, Onkyo ...
Dionyz is offline
post #3 of 14 Old 05-22-2008, 09:04 AM
JOHNnDENVER's Avatar
I'd try to at least try to verify it's not a source issue. Does it do it on all sources including the radio tuner?
JOHNnDENVER is offline
post #4 of 14 Old 05-22-2008, 10:02 AM - Thread Starter
Well i only use it for Cable tv (optical) so it could be the source. But i have surmised for awhile that it is probably simply underpowered. I have noticed it many times while watching TV (or recorded TV).
Denon AVR3311CI
Sony PS3
post #5 of 14 Old 05-22-2008, 10:20 AM
How big is your room? All three dimensions please?
I'm hard on amp sections because I like it loud and dynamic. For most people an AVR like the Sony would probably be OK, but if it's a big room? Probably not.
post #6 of 14 Old 05-22-2008, 11:23 AM - Thread Starter
Room is probably 15' x 25'. I will monkey with some settings, etc.
Denon AVR3311CI
Sony PS3
post #7 of 14 Old 05-22-2008, 11:51 AM
Are the B&W's 4 ohms? That woudl also be a little to much for the Sony in all honesty. 8 ohm speakers would be much gentler so to speak.
post #8 of 14 Old 05-22-2008, 12:45 PM - Thread Starter
They are 8ohm - (4ohm minimum).
Denon AVR3311CI
Sony PS3
post #9 of 14 Old 05-22-2008, 12:55 PM
Goatse's Avatar
Quoted: 68 Post(s)
Liked: 51
hahahaha, stop being a lemming.
Goatse is offline
post #10 of 14 Old 05-22-2008, 01:08 PM
Dionyz's Avatar
Quoted: 57 Post(s)
Liked: 48
Stop being in denial. Check the reviews for proof positive.
However, you seem to be part of the Sony crowd for whom "Ignorance is bliss"
So be happy with your HTIB amplifier repackaged to look like a receiver
Dionyz is offline
post #11 of 14 Old 05-22-2008, 01:40 PM - Thread Starter
I dont understand these last two posts....am i missing something? i actually like Sony and own a huge amount of Sony gear going back to the very first walkman.
Denon AVR3311CI
Sony PS3
post #12 of 14 Old 05-22-2008, 01:43 PM
qirex's Avatar
Fanboys/viral marketers, take your pick. I don't think any forum on this whole site is immune nowadays...
qirex is offline
post #13 of 14 Old 05-22-2008, 02:33 PM
They actually state 8ohm - 4 ohms min. on the speaker specs?
These may be difficult for your Sony. I'd set the cross to the sub higher if at all possible.
post #14 of 14 Old 05-22-2008, 04:03 PM
vipergts2207's Avatar
Quoted: 33 Post(s)
Liked: 33
Most people on here like Sony's products, like their tv's and blu-ray players for instance. Just not their audio because some people say they're underpowered.
vipergts2207 is offline
