how can I use one receiver for 2 zones - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-09-2008, 10:56 AM - Thread Starter
raogundu's Avatar
Hi Everybody,
I am planning to do my home audio system. I did all wiring .
I ahve 5.1 system in one room and 4 ceiling stereo speakers in different rooms with in wall volume control provisions for each speaker. Upto this it is OK. Now when I am trying to set receiver Onkyo 606, I am getting confused. I wnat to use one receiver for both systems. Could someone please answer following questions, if u already has a system in ur house working like what I am planning.
1. Four 100 watts speakers on 2 nd zone will work OK or will burn the receiver
2. If this is not safe what can I do? add amplifier?
raogundu is offline
post #2 of 2 Old 06-09-2008, 11:42 AM
rdclark's Avatar
Quoted: 348 Post(s)
Liked: 651
Much depends on what you want to hear in the remote room.
What most receivers' Zone 2 will do is to send 2-channel analog sources to one pair of speakers. You will not get sound from any of your HDMI, optical, or digital coax sources in Zone 2 unless you also connect an analog cable from the source.
You can achieve the same result by using a stereo tape output from the receiver to feed a separate amplifier (which can be any old used stereo receiver if you're not too picky). Or you can use both approaches, using Zone 2 to drive one pair of speakers and a separate amp to drive another.
You can usually get away with wiring two pairs of speakers in series, which raises the impedance rather than lowering it, at the expense of sound quality and amplifier performance. I wouldn't recommend it.
Wide Awake
on the Edge
of the World
rdclark is offline
