Easy way to turn off surround for 2 channel listening? - AVS Forum
post #1 of 4 Old 06-21-2008, 02:08 PM - Thread Starter
myrosen's Avatar
I have a Marantz SR 4002. I originally had 2 Mirage bookshelves and a REL subwoofer hooked up, but I just upgraded to Aperion 6B for mains, 5C for center and 4B for surrounds. The Aperions are great, but I have found that when I listen to music, I don't like the sound of all 5 speakers playing at once. So each time I want to listen to music, I have to go into the AVR setup and turn off my center and surrounds.
Is there an easier way to do this? Can the Marantz not remember that when it's set to CD, it should only run 2 speakers, and when it's set to DVD or TV to output to all 5 speakers?
Is this a dumb question?
myrosen is offline
post #2 of 4 Old 06-21-2008, 02:22 PM
kplex's Avatar
I'm not familiar with your receiver, but look on the remote for a Stereo button.
kplex is offline
post #3 of 4 Old 06-21-2008, 03:02 PM
Brian Hinther's Avatar
I know nothing about the Marantz way of doing things, but on Denon and Yamaha receivers there's a stereo option tucked away in the Surround Decode options. You may also have something similar to Yamaha's "Pure Direct" mode, which switches instantly to stereo and bypasses all processing including the tone controls.
You're better off changing your decoding to stereo, rather than shutting off speakers. If your decoding is set to something other than stereo (like Pro Logic, for example), you could be missing some of the music by simply turning off the center and surrounds.
But no, your input selector is only that--it just selects the inputs. You have to tell the receiver what to do with the signal elsewhere.
Brian Hinther is offline
post #4 of 4 Old 06-23-2008, 10:55 AM - Thread Starter
myrosen's Avatar
D'oh! (Slaps forehead.)
Thanks! That did the trick!
myrosen is offline
User Tag List
