The Official VSX-1018AH-K Owners, Reviews, and Comments Thread! - Page 197 - AVS Forum
post #5881 of 5908 Old 06-14-2012, 05:47 AM
nivo885's Avatar
Originally Posted by altheus View Post
Having the EXACT same issue:
Things I've tried:
- Setting all speakers to SMALL, SW to ON - All X-Over freq settings.
- All possible combinations on the Sub itself to get volume up.
- Checking the line input on the sub.
- LFE settings are correct, DRC is correct, receiver setting should be correct
- Full reset of the Receiver
- Testing it off say a centre channel to see if there's something wrong with the pre-outs, and nothing :/
On searching and scouring the web - everything points to my own stupidity here, and some glaring issue with the settings, however having never used a sub with the system before, I'm fearing that it could be the sub preout is bust.
Originally Posted by sojourner275 View Post
This is an odd problem that i just remembered that i have. I have had my 1018 for a couple years now and recently got a real sub, Polk PW505. However, when I plug it into the subwoofer port on the back of the 1018, i get no signal sent to it at all. i currently have it plugged into one of the other pre-amp outs and it works fine....but i cant do MCACC with a sub as it cant detect anything from it. any ideas at all?
Have you guys tried setting the SW to PLUS? NO->YES->PLUS in the speaker settings. All my speakers are set to large and have my sub set to PLUS.
Also speaker distance setting for the subwoofer if not correct it will mute the signal.
The channel level of the SW is adjustable.
Also under advanced Eq. set up you have subwoffer trim.
nivo885 is offline
post #5882 of 5908 Old 09-05-2012, 06:56 AM
AnthonyB's Avatar
Trying to figure out if i want this receiver.. My friend is willing to sell it to me for $125 but I've been reading on this thread it had a problem with hdmi hookups to Mitsubishi dlp TVs.. I have a wd65733, will it work or fry something inside?
AnthonyB is offline
post #5883 of 5908 Old 09-05-2012, 07:17 PM
swarm87's Avatar
Liked: 45
as far as i know the problem had to do with the hdmi control function; i had a similar problem with my LG set, just turn it off on both the tv and the receiver and youll be fine. 125 i a great deal the only issue i have with the unit personally is it only has 3 hdmi;in my case 1 for cable, 1 for ps3, and 1 for bluray. have to either cable swap, use a switch or use the up-conversion function. also remember that it only has hdmi 1.3 so if your 3d you need either 2 hdmi ports, analog outs for audio or, if you can find one, a hdmi splitter.
pcm=potato
bitstream=patato
swarm87 is offline
post #5884 of 5908 Old 10-31-2012, 11:53 AM
Hagar's Avatar
Any chance of getting some psychic help?
It seems my HDMI inputs aren't working properly. (I think)
I have my computer with a ASUS Xonar 1.3 slim installed and with a ATI 4650 AGP video card. When I plugged it in to my 1018 via HDMI1, no handshake. Use to but not anymore or sometimes will.eek.gif
Hooking up directly via coaxial from the ASUS card, works great via DVD coaxial input on the receiver. And plugging the video card directly into the monitor works perfectly.
And if I hook up the monitor to the 1018 output, I can get the 1018 menu all day long. So I figure its the inputs.
I'm just not sure its still not the antiquated AGP card or the ASUS Xonar 1.3 HDMI. I've replaced cables but as always, could of been another bad cable.
Geezh, oh well, at least the coaxial is working.
Hagar is offline
post #5885 of 5908 Old 12-02-2012, 02:46 PM
marjen's Avatar
Having an issue all of a sudden with my XBOX 360 and PIO 1018. For some reason I am only getting stereo sound. I have to pick a fake surround mode to get surround sound. other sources seem fine. I checked audio setting on the 360 and it is set to DD out. Any idea what I am missing here?
Mark-
marjen is offline
post #5886 of 5908 Old 12-02-2012, 03:56 PM
biglen's Avatar
Sent from my SCH-I535 using Tapatalk 2
With the receiver on, and set to the right input for the 360, try restarting the 360.
biglen is offline
post #5887 of 5908 Old 12-02-2012, 04:31 PM
marjen's Avatar
restarted xbox and it worked again, weird. thanks.
Mark-
marjen is offline
post #5888 of 5908 Old 12-02-2012, 05:13 PM
biglen's Avatar
Are you using an HDMI cable from the 360 to the receiver?
biglen is offline
post #5889 of 5908 Old 12-18-2012, 08:14 PM
swarm87's Avatar
Liked: 45
kind of an odd question; im looking into getting an ottoman but it will block the ir sensor of the receiver, will the monoprice extender cable (pid 8060) work just by pluggin it into the zone 2 ir in plug(as the manual states)? all their support said was something about how many bands the remote was confused.gif figured id ask here
pcm=potato
bitstream=patato
swarm87 is offline
post #5890 of 5908 Old 03-02-2013, 04:58 AM
AnthonyB's Avatar
ever figure this out? Been having the exact same issue
AnthonyB is offline
post #5891 of 5908 Old 03-02-2013, 06:29 PM
swarm87's Avatar
Liked: 45
is whatever pioneer calls hdmi control(havent had to check as ive not had the problem for a few years) set to "off"? a few years back i was having handshake issues and turned off hdmi control on all devices and its been fine ever since
pcm=potato
bitstream=patato
swarm87 is offline
post #5892 of 5908 Old 03-02-2013, 10:22 PM
Hagar's Avatar
Sadly no, I ended up not using HDMI anymore on it and went strictly RCA from my ASUS XSONAR.
Hagar is offline
post #5893 of 5908 Old 03-29-2013, 05:51 AM
marjen's Avatar
Ok I think I know the answer but.......I just ordered a new projector Ben Q W1070. It is 3D. I have a PS 3 bluray player. I have a Pioneer 1018 receiver. Can I watch bluray 3D movies or not?
Mark-
marjen is offline
post #5894 of 5908 Old 03-29-2013, 06:07 PM
swarm87's Avatar
Liked: 45
yes but its a serious PITA, you need to split the hdmi signal from the ps3, one to the projector, the other to the receiver,i think monoprice has something that can do this. you could also get a bluray player with 2 hdmi outs.
pcm=potato
bitstream=patato
swarm87 is offline
post #5895 of 5908 Old 04-30-2013, 11:45 AM
clayhans's Avatar
I have an Oppo BDP-103 Blu-ray player connected to a Samsung UN55F800 TV for video and all things seem right with that. My problem is that the Oppo is connected from HDMI 2 to a Pioneer VSX-1018AH-K A/V receiver on HDMI BD connection. My read out on the Pioneer receiver tells me I am getting a PCM single from the Oppo, but I am not getting any sound out of my Pioneer receiver. I have connected a center speaker to the Pioneer receiver but no sound comes through. Is it the Oppo or the receiver? How do I get things to work?
clayhans is offline
post #5896 of 5908 Old 05-30-2013, 09:05 PM
insanecollector's Avatar
I am having HDMI issues with my receiver, Cable box, blu-ray player, and Roku2 box. All three are connected via HDMI. The cable box, Scientific Atlantic, is connected to HDMI1, Roku Box connected to HDMI 2 and the blu-ray player is connected to BD HDMI input. When I turn on the TV, receiver, and cable box with my Harmony One remote, the receiver goes to the TV/sat input automatically though it is not being used. I need it to go to HDMI 1. The remote is programmed correctly. How can I fix this?
Also, is there a way to have the receiver distinguish HDMI 1 and HDMI 2. Since both connections in the back are technically HDMI 1/2, my harmony remote cant always distinguish which one to go to. Is there a way to fix this?
insanecollector is offline
post #5897 of 5908 Old 05-30-2013, 11:54 PM
Disregard. Think I figured it out.
post #5898 of 5908 Old 01-01-2014, 06:28 AM
kemiza's Avatar
Liked: 89
This receiver sounds like crap! Loaded with useless features and poor sound quality!
Panasonic TC-P50ST60 plasma HD television, Onkyo TX-SR805 and PIONEER ELITE VSX-47TX receivers, Klipsch RB-75(2 pair) and RB-61 bookshelf speakers, Klipsch RSW-10, RSW-12(2), Velodyne HGS-12, HGS-18 subwoofers, PS3 80G, PIONEER DV-525 dvd player, Klipsch RS-42 surrounds, Klipsch RC-52 center channel
kemiza is offline
post #5899 of 5908 Old 01-01-2014, 09:49 AM
Hagar's Avatar
Sell it.
Hagar is offline
post #5900 of 5908 Old 01-01-2014, 09:55 AM
jimkell's Avatar
Please send it to me. I would love to have a second one of these excellent piece of equipment.
jimkell is offline
post #5901 of 5908 Old 01-02-2014, 08:47 AM
kemiza's Avatar
Liked: 89
If you serious PM me.
kemiza is offline
post #5902 of 5908 Old 02-15-2014, 07:06 AM
Leafs17's Avatar
So I have TV/SAT using HDMI 3 in for my satellite signal. I want to also be able to have sound from a goal light come through over the speakers with the normal tv audio. The goal light uses rca(white/red).
I don't see an option for analog audio in the input menu of TV/SAT, just the optical option.
Is there a solution?
Leafs17 is offline
post #5903 of 5908 Old 02-15-2014, 09:06 AM
JChin's Avatar
Quoted: 36 Post(s)
Liked: 122
Hi Leafs17, analog inputs are not assignable so there's no option. Just connect goal light RCA (white & red) cable to TV/SAT analog in then on the remote, press "Receiver" and then "Signal Sel" a few time to select "Analog".
JChin is offline
post #5904 of 5908 Old 03-28-2014, 04:36 AM
mk2rimar's Avatar
Alright peeps....question....i hooked up my sonance 2 channels external amp to my pionner receiver to drive my tsi500 l/r fronts,hooked up rca from pre-outputs in the back of my pioneer 1018 to the amp l/r inputs...now amp lights up i sent it to my friend to check it and all is good bu the right channel is not receiving signal from my pioneer.then i tried to hook it up to my surrounds and same story then to my back surrounds same thing again.looks like the complet right side of pre-outs is not working.can some one shime in if alredy ad this kind of experience... Tx
Sent from my Nexus 4 using Tapatalk
mk2rimar is offline
post #5905 of 5908 Old 07-07-2014, 02:23 PM
teambears's Avatar
Hello all...I just purchased a Sony 60W850B Smart TV and I'm trying to figure out how to get audio (from the TV's smart apps) to my receiver. I know the TV has ARC (Audio Return Channel), but can't seem to find out if the receiver does as well. Basically, I'm trying to figure out if I need a newer HDMI cable or if I have to run an Optical Audio Cable from the TV to the receiver. Can someone please clarify this for me?
teambears is offline
post #5906 of 5908 Old 07-07-2014, 03:03 PM
JChin's Avatar
Quoted: 36 Post(s)
Liked: 122
Hi teambears, the 1018AH-K does not support ARC (Audio Return Channel).
JChin is offline
post #5907 of 5908 Old 07-07-2014, 03:38 PM
teambears's Avatar
Well that sucks...I was hoping to not have to run another cable through my wall. Can someone recommend a good optical audio cable?
post #5908 of 5908 Old 07-18-2014, 07:58 AM
pmiller's Avatar
Help with HDMi issues with new Sony projector
I have a new Sony vpl-hw40es that wont handshake with my Pioneer vsx-1018. Pioneer works fine when hdmi connected to other displays and the projector works perfectly when hdmi connected directly to the source, directv or ps3. Any help would be greatly appreciated.
pmiller is offline
User Tag List
