The Official VSX-1018AH-K Owners, Reviews, and Comments Thread! - Page 3 - AVS Forum | Home Theater Discussions And Reviews
Old 06-24-2008, 07:11 PM
Curmudgeonx's Avatar
Two issues perhaps you could check:
Upscaling quality. You touched on the issue that it only upscales 480i/p to 1080p, suggesting that 720p and 1080i/p "pass through". True? Even component in (i.e. SA 8300 cable box) and HDMI?
Ipod interaction. Anyone tried plugging in an Ipod Classic (160G)? Music quality? Movie quality (although it is a terrible use, but still curious) . . .
Curmudgeonx is offline
Old 06-24-2008, 07:21 PM - Thread Starter
bgillyjcu's Avatar
Check my updated first post
Twitter @ Clefoodandbrews
bgillyjcu is offline
Old 06-24-2008, 07:31 PM
Vexeus's Avatar
Anyone have OSD pics?
Vexeus is offline
Old 06-24-2008, 07:57 PM
tvted's Avatar
Quoted: 23 Post(s)
bgillyjcu,
Thanks for the testing.
What was your playback source for BTB & WTW tests? DVE BD or SD or something else?
With respect to LPCM vs TrueHD - some may differ but lossless is lossless - LPCM is the pure digital stream which is passed to the processing or the D/A's, TrueHD is compressed much like a .zip file and has to go through a decoding stage but it is the same losslesss stream once decoded. An argument *might* be made for the quality of the decoder as far as bit perfect decoding goes but this is not particle physics - the algorythms are time tested so I think it is a meaningless argument.
ted
tvted is offline
Old 06-24-2008, 08:38 PM
shinerburke's Avatar
I would like to know that as well.
shinerburke is offline
Old 06-24-2008, 08:47 PM
Alan Gordon's Avatar
Originally Posted by bgillyjcu View Post
I do have one question. TRUE HD vs Uncompressed PCM Isn't the PCM track "better"?
Ted already sorta answered this question, but he left out two bits.
Namely that Dolby TrueHD could actually be superior! Sony, for instance, has released several releases with BOTH PCM and Dolby TrueHD... with a 16-bit PCM mix and a 20 or 24-bit Dolby TrueHD track.
However, Dolby TrueHD (as well as DTS-HD MA) can sometimes use DialNorm which some people would prefer to do without... which makes them favor PCM.
~Alan
All comments are my own. Unless specifically stated, my views do NOT represent the views
of Alan Gordon, Alan Gordon Enterprises, Alan Gordon, Inc., or Alan Gordon Amalgamated.
Alan Gordon is offline
Old 06-24-2008, 08:55 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 402
~Alan
TrueHD tracks almost always come with DialNorm. Those who don't like DialNorm also the ones that don't fully understand what DialNorm does or does not do.
Foxbat121 is online now
Old 06-24-2008, 09:13 PM
drewzus's Avatar
Originally Posted by whoami View Post
I'll try later tonight.. although i doubt this would work well
True. Thanks.
Originally Posted by tvted View Post
Those are likely LINE level so I would be surpirsed if it were possible. Even if the gain were there, it would be unlikely to have an RIAA equalization curve which would be necessary for flat response. I am in the same boat btw. and though I've a PHONO pre amp I wanted to include it with the new setup, so I'll likely be breaking out my old Audio Amateur mags and building.
Good point.
drewzus is offline
Old 06-24-2008, 09:51 PM
Xebec01's Avatar
Bad news on the A.L.C. front:
It appears that A.L.C. requires that you set your sound to Stereo; no surround, no center channel.
The manual states nothing about commercial volume leveling, and I didn't notice any difference. Perhaps I'm doing it wrong?
I will test more when my cables arrive tomorrow and I tinker again...
- Xebec -
Xebec01 is offline
Old 06-24-2008, 10:39 PM
CT_Wiebe's Avatar
tvted & others -- Hi again Ted. I had a similar problem (no Phono Pre-amp input) several years ago. I did a lot of research, and found an excellent (and economical) unit that works (and looks) better than any one I could build. It's the TCC model TC-750 and the link to it is here: http://www.phonopreamps.com/ - see the 3rd item on that page. I have it powered from the Switched AC plug on my AVR. BTW, it's better than any built-in phono pre-amp that I've had.
It is absolutely quiet, and provides an almost (99%) perfect RIAA equalization for moving magnet cartridges (the output response is printed on the top of the unit). It also can connect to a PC audio card as well as the line inputs of AVRs, which makes it perfect for transferring vinyl to lossless PC files (and to CDs & audio DVDs - with the right software, of course). It's also in a nice small box, and is a solid, all steel, shielded, unit of high quality construction.
PS -- It's got an external power supply (in-line with the power cord).
- Claus {non-Santa model}
CT_Wiebe is offline
Old 06-24-2008, 11:04 PM
Coolpplse's Avatar
I dont see the point of Dialogue Normalization when correctly mastered audio tracks can do the exact same thing Dolby is trying to achieve with this feature for Dolby TrueHD.
Coolpplse is offline
Old 06-24-2008, 11:10 PM
drewzus's Avatar
Thank you for that link. Looks great.
drewzus is offline
Old 06-24-2008, 11:40 PM
fito's Avatar
any good company that has it in stock, that I can order through the web?
fito is offline
Old 06-25-2008, 12:00 AM
CT_Wiebe's Avatar
I don't know, but you can use www.pricegrabber.com or Epinions to see. I believe that I ordered it direct from the PhonoPreamps web site that I linked to, IIRC.
CT_Wiebe is offline
Old 06-25-2008, 05:05 AM
cigga24's Avatar
Can someone take a pic of the On Screen Menus? Are they the same as the Elite 92?
cigga24 is offline
Old 06-25-2008, 05:48 AM - Thread Starter
bgillyjcu's Avatar
Don't have the time before work today for a pic.....but the menus are black with big white lettering. Pretty plain looking, but I find that makes it simple, quick and easy to use.
Old 06-25-2008, 07:00 AM
fito's Avatar
Were are you guys getting the recievers from??? I want one sooo baaaddd!
fito is offline
Old 06-25-2008, 07:05 AM
buzzard767's Avatar
Quoted: 1624 Post(s)
Liked: 2399
From the source.
Buzz
THX Certified Level II Video Calibrator
CalMAN Ultimate license FS
buzzard767 is online now
Old 06-25-2008, 07:22 AM
Taank's Avatar
OSD pic attached.
Taank is offline
Old 06-25-2008, 07:48 AM
mpgxsvcd's Avatar
Quoted: 2518 Post(s)
Liked: 2264
Originally Posted by kulims View Post
Great. Better than the Yamaha 661.
Looks the same as the 663 to me?
mpgxsvcd is online now
Old 06-25-2008, 07:50 AM
EnzymaticRacer's Avatar
Quoted: 12 Post(s)
great news so far. Hopefully by the time the Hk 354 is available there will be some solid reviews of this receiver...
Television: Samsung 55" 4K UHD UN55HU7250F
Receiver: Harman Kardon AVR 354 Receiver driving 5.1 surround
Remote: Logitech Harmony Ultimate Home
EnzymaticRacer is online now
Old 06-25-2008, 07:51 AM
sanhacker's Avatar
Looks the same as my 1981 PC to me.
Plain is an understatement
- John
sanhacker is offline
Old 06-25-2008, 07:52 AM
mpgxsvcd's Avatar
Liked: 2264
- Xebec -
That is not good! Guess that eliminates the 1018 from my list!
Old 06-25-2008, 07:53 AM
mpgxsvcd's Avatar
Liked: 2264
I didn't say either one was "Good". However, they do look the same to me.
Old 06-25-2008, 08:19 AM
Taterman4's Avatar
Hello all:
Couple of quick questions. I am trying to decide on the following receivers Yamaha TX-SR606, the Pioneer VSX-1018AH-K or the Yamaha RX-V663BL. All of these are fine units and I realize that I am asking the Pioneer owners group and my get somewhat biased answers !
Question:
Can you play music from all sources both digital and analog in a remote zone ? The Pioneer manual says that only analog sources can go to Zone 2 and I have some outside speakers and would like to be able to play music from an optically connected CD player or Ipod both on the inside speakers as well as the outside when I am having a party.
Thanks to all
Taterman4 (Ed)
Taterman4 is offline
Old 06-25-2008, 08:53 AM
blackmax2k1's Avatar
I found someone else that has it in stock. An authorized seller.
blackmax2k1 is offline
Old 06-25-2008, 09:15 AM
Aloof's Avatar
B&H Photo seems to be taking orders on their site now, though they don't have it in stock.
Aloof is offline
Old 06-25-2008, 09:19 AM
buzzard767's Avatar
Liked: 2399
July 2nd seems to be the date for Internet sales. Hopefully BB will have them on that date as well.
Buzz
Old 06-25-2008, 09:23 AM
Spartan94's Avatar
ooo -- don't tempt me like that!
how do you know that?
Spartan94 is offline
Old 06-25-2008, 09:30 AM
charlie22's Avatar
what's the msrp for the 1018? didn't see it in the first post.
charlie22 is offline
