Dolby EX/Dolby Pro Logic IIx - AVS Forum | Home Theater Discussions And Reviews
post #1 of 20 Old 07-13-2008, 07:24 PM - Thread Starter
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 151
When my RX-V2700 processes a Dolby Digital EX soundtrack, it appears to use the Dolby Pro Logic IIx decoder. It either does this automatically or manually.
Now, if the Dolby Digital EX soundtrack is sent through PCM, I would have to manually enable the Dolby Pro Logic IIx decoder. But there's no way for the receiver to know the soundtrack is Dolby Digital EX.
Does this make a difference? In other words, does the receiver tell the DPLIIx decoder when it's decoding an EX soundtrack? Or does DPLIIx not need to know this?
What I am curious about is whether there is a difference between bitstream DD EX being sent to the receiver vs. the DD EX soundtrack being sent via PCM. In the case of PCM I can turn on the DPLIIx decoder manually, but if it's dependent on knowing whether or not it's decoding DD EX, it won't know that fact when decoding from PCM (as from a PS3)
I guess my confusion results from not understanding how DPLIIx works. I know it can create a 7.1 soundfield from a 2 channel or 5.1 channel soundtrack that lacks any matrixed sound information. But it also seems to encompass the ability to decode a DD EX soundtrack. Is it because the method used to decode the EX soundtrack is identical to it's ability to take a standard 5.1 DD soundtrack and create extra channels for it?
"But this one goes up to 11"
MichaelJHuman is offline
post #2 of 20 Old 07-13-2008, 09:02 PM
M Code's Avatar
Quoted: 806 Post(s)
Liked: 493
In a 7.1 AVR, Dolby EX is the same as Pro Dolby 2X Movie with 6.1 output. Also the AVR will detect the 6.1 EX flag within the DVD. Basic limiting factor of Dolby EX is that there is lack of surround channel spacialness due to the way matrix rear surround encoding is done. Thats the primary reason Dolby recommends 7.1 over 6.1, as Dolby Pro Logic 2X gives the listener a more enhanced soundfield with rear channel separation. Dolby EX was 1st done by THX and then Dolby hired Jim Fosgate to design Pro Logic 2X due to the significant sucess of the HK/Lexicon Logic 7 as they were marketing 7.1 years before the competition.
Just my $0.01..
M Code is online now
post #3 of 20 Old 07-13-2008, 09:32 PM - Thread Starter
Quoted: 266 Post(s)
Liked: 151
If I understand this right, the receiver does not need to know that you are feeding it an EX soundtrack. If you manually set your receiver to process it with DPLIIx Movie, than you are good to go.
post #4 of 20 Old 07-13-2008, 11:49 PM
sdurani's Avatar
Quoted: 5069 Post(s)
Liked: 3546
The basic concept is easy to understand, as long as you treat 'channels' and 'speakers' as separate entities. Think of the surround field as 4 speakers that are wrapped around the listener in a 180 degree arc. Where sounds end up on this arc is determined by where they are mixed in the left and right surround channels.
Sounds that are exclusively in the left or right surround channel will image at the extreme ends of the arc (i.e., the left side or right side speaker). Sounds that mostly in the left or right surround channel will image a little inward on the arc (i.e., between each side and rear speaker). Sounds that are exactly the same in both surround channels will image in the middle of the arc (i.e., in both rear speakers).
In a 5.1-speaker set-up, the dual-mono sounds in an EX soundtrack would have phantom imaged behind you anyway, while stereo content would have imaged towards your left or right side. Using PLIIx on a 7.1 set-up gives you the same imaging, just more stable since your using actual speakers rather than relying on phantom imaging. It's the same reason some people use a centre speaker when listening to 2-channel material: the directionality doesn't change, the imaging just becomes more stable.
PLIIx processing can mimic EX decoding when needed, by sending the same signal to both rear speakers. So if an EX encoded soundtrack has certain content that is mixed to image directly behind you, PLIIx will place it there (see second paragraph). However, if the recording engineer mixed a certain surround effect to image off centre, then PLIIx can send it to either the left or right rear speaker, since it handles each one independently. EX decoding can't do that since it is limited to a mono surround-back channel that is sent to both rear speakers.
So no need for EX auto-detect flags, no need to restrict yourself to EX decoding when listening to EX soundtracks, no need for your receiver to know that it is an EX soundtrack. When the PLIIx circuit sees the exact same sound in both surround channels, it will send it to the speakers behind you, just like the EX decoder would.
Sanjay
Sanjay
sdurani is offline
post #5 of 20 Old 07-14-2008, 12:25 AM
JBLsound4645's Avatar
Strange I wonder if they re-modified the original Dolby SA10 that was modified from the Dolby CP45 back in (1999) because that had the extra support that was used for “We Were Soldiers” (2002) that uses (matrix anti-phase) this wasn’t used on consumer Dolby EX AVR just centre back and that’s it, unless you use a straight forward Dolby stereo Pro-Logic decoder and use the same re-plugging plus it will have the matrix rear or "sonic whole overhead" as it was dubbed by (Dolby, Todd-AO and Soundelux)
http://www.dolby.com/assets/pdf/pres..._Soundelux.pdf
I guess if I buy cheap AVR at (Richer sounds UK) one that has Dolby pro-logic IIx I could change the existing Dolby pro-logic decoder that I use on the split-surrounds since (1998) and then re-plug it onto the surround RCA pre-outputs, simple.
Also there is what’s called half panning where a portion of the sound will be sent to centre back or within stereo mix half way over and then hard left or right.
The decoder will see that the signal has equal strength of frequency and its in-phase it moves off and away from centre, then its heard on the left rear centre then pans hard so its on the left sidewall and vice versa.
JBLsound4645 is offline
post #6 of 20 Old 07-14-2008, 02:21 AM
SoundChex's Avatar
Quoted: 368 Post(s)
Liked: 311
Originally Posted by JBLsound4645 View Post
Strange I wonder if they re-modified the original Dolby SA10 that was modified from the Dolby CP45 back in (1999) because that had the extra support that was used for We Were Soldiers (2002) that uses (matrix anti-phase) this wasn't used on consumer Dolby EX AVR just centre back and that's it, unless you use a straight forward Dolby stereo Pro-Logic decoder and use the same re-plugging plus it will have the matrix rear or "sonic whole overhead" as it was dubbed by (Dolby, Todd-AO and Soundelux)
Extract from http://www.dolby.com/assets/pdf/pres..._Soundelux.pdf:
"Dubbed Sonic Whole Overhead Sound by We Were Soldiers' producers, this enhancement is the first movie theater audio system to wed a new overhead speaker system with the standard Dolby® Digital Surround EX sound system. It is an innovation of We Were Soldiers' director Randall Wallace, working with the sound experts of Todd-AO/Soundelux and Dolby Laboratories."
Because the original speaker mix soundtrack was specifically designed to reproduce overhead shellfire and helicopter sounds, perhaps we will see a 7.1 Blu-Ray of We Were Soldiers authored in the [DTS-MA named] 7.1 Center Overhead speaker layout [L,R,C,LFE,Ls,Rs,Cs,C-Oh], which adds an overhead speaker to the Standard 6.1 speaker layout, or in its Dolby TrueHD equivalent. [Note: The speaker DTS calls Center-Overhead is called Top Surround in Dolby Labs speaker layouts.]
[Home Office system schematic]
"My AV systems were created by man. They evolved. They rebelled. There are many speakers. And they have . . . A PLAN."
SoundChex is offline
post #7 of 20 Old 07-14-2008, 05:35 AM - Thread Starter
Quoted: 266 Post(s)
Liked: 151
Thanks Sd.
Another question. Is DPL IIx music mode equivalent to the older PL II decoder?
post #8 of 20 Old 07-14-2008, 08:17 AM
sdurani's Avatar
Liked: 3546
For 2-channel sources, PLII and PLIIx use the same surround processing algorithms. Even though PLIIx came years later, it is not an improvement over PLII but instead an eXtension (more channels) to PLII technology.
To answer your question above: PLIIx Music mode is equivalent to PLII Music mode, with the only difference being number of channels (PLII is limited to 5 output channels max while PLIIx can be 6 or 7 output channels).
For discrete multi-channel sources, it is impossible to compare the two modes since PLII can only be applied to 2-channel material.
Sanjay
Sanjay
sdurani is offline
post #9 of 20 Old 07-14-2008, 10:07 AM - Thread Starter
Quoted: 266 Post(s)
Liked: 151
Thanks. I did not realize that PL II had music mode.
post #10 of 20 Old 07-14-2008, 11:22 AM
sdurani's Avatar
Liked: 3546
Yep, both PLII and PLIIx have three modes: Movie, Music and Games.
Sanjay
Sanjay
sdurani is offline
post #11 of 20 Old 07-14-2008, 11:50 AM - Thread Starter
Quoted: 266 Post(s)
Liked: 151
Great.
Do you know if the later Dolby technologies were designed with the intention of being handled by DSPs? Is DPL IIx always done in the digital domain?
post #12 of 20 Old 07-14-2008, 12:00 PM
gbaby's Avatar
Quoted: 654 Post(s)
Liked: 263
Just my $0.01..
Sorry, but you gave the wrong infor. DD EX is not the same as DPL 11x. the difference is that in EX the rear center is mono but in IIX the rear center is stereo. Also, EX has nothing to do with THX.
gbaby is offline
post #13 of 20 Old 07-14-2008, 12:37 PM
Hmmm, now that may change my mind in buying the format. The diagram only uses a single overheard the original consists of many placed overhead to give uniform coverage.
post #14 of 20 Old 07-14-2008, 01:09 PM
sdurani's Avatar
Liked: 3546
With analogue processing circuits disappearing, most companies (not just Dolby) were designing their decoding and processing technologies with DSP chips in mind. For example: even though Jim Fosgate created PLII on an analogue circuit board, Dolby always intended the processing to be done in the digital domain.
Yes, always. However, there was one vacuum tube pre-pro that did all its PLII processing in the analogue domain: FAP V1. Alas, there was no such pre-pro for PLIIx.
Sanjay
Sanjay
sdurani is offline
post #15 of 20 Old 07-14-2008, 01:22 PM
SoundChex's Avatar
Quoted: 368 Post(s)
Liked: 311
Originally Posted by gbaby View Post
Sorry, but you gave the wrong info. DD EX is not the same as DPL IIx. The difference is that in EX the rear center is mono but in IIx the rear center is stereo. Also, EX has nothing to do with THX.
In an attempt to aid (or possibly to hinder!) understanding [the differences between/common features of] DD EX and DPLIIx, Dolby conveniently provides the following:
Dolby Pro Logic IIx FAQ
Dolby Digital EX
Dolby Digital Surround EX This material is not completely unambiguous, and it does not even begin to address the variations in implementation [and poor labeling/description] which may exist in a particular manufacturer's product line...
post #16 of 20 Old 07-14-2008, 02:04 PM - Thread Starter
Quoted: 266 Post(s)
Liked: 151
I have read Dolby's own writeups many times and they usually come across as more marketing than substance if you know what I mean.
While much was written about Dolby Surround, Dolby Pro Logic less useful information is out there on Dolby Pro Logic II and Dolby Pro Logic IIx.
Maybe Dolby is a little tight lipped on exactly how the later "matrix based" surround decoders work.
post #17 of 20 Old 07-14-2008, 02:09 PM
kplex's Avatar
Can't find anything on PLIIx, but here's a pretty good description of PLII:
http://www.dolby.com/assets/pdf/tech..._Operation.pdf
kplex is offline
post #18 of 20 Old 07-14-2008, 02:28 PM - Thread Starter
Quoted: 266 Post(s)
Liked: 151
That was great, thanks.
post #19 of 20 Old 07-14-2008, 02:35 PM
SoundChex's Avatar
Quoted: 368 Post(s)
Liked: 311
Just remember that the DTS-MA 7.1 Center Overhead speaker layout [L,R,C,LFE,Ls,Rs,Cs,C-Oh] is really an authoring OR playback CHANNEL mix for use with, e.g., Blu-Ray, which is why there are only 7.1 speakers (i.e., CHANNELS) shown in the schematic. However, nothing therein prevents your replacing the single overhead speaker with a multi speaker array for PLAYBACK, with/without post-processing [perhaps some kind of 3D DPLIIx and/or THX-style decorrelation(?)] [and with the problems/issues associated with multi speaker vs. single speaker reproduction!] to deliver the Center-Overhead channel. [Edit: I'm not sure I'd want one speaker over my head, never mind an entire array!]
A more significant issue is that I know of NO current home theater processor which has a DTS-MA/TrueHD speaker [playback] layout which includes any of the new vertical speakers. And I would expect that a lossless remap from 7.1 Center Overhead to 7.1 Standard would effectively eliminate the focus of the overhead soundstage.
As to the near(?) future:
I can't see any reason why the [amplifier] channel which is left unused when a 7.1 channel receiver is configured in 6.1 Standard [L,R,C,LFE,Ls,Rs,Cs] mode could not be used to allow the receiver to function either in 7.1 Center Overhead mode or 7.1 Center Height [L,R,C,LFE,Ls,Rs,Cs,Ch] mode [intended to emulate the IMAX speaker configuration?]; that should be little more than a firmware change... [Edit: No, I'm not suggesting that existing receivers could be upgraded; rather I'm saying that the incorporation of 7.1 Center Overhead mode and/or 7.1 Center Height mode as speaker layout options should add negligible complexity/cost to future 7.1 channel receiver/processor models.]
post #20 of 20 Old 07-14-2008, 02:56 PM
M Code's Avatar
Quoted: 806 Post(s)
Liked: 493
Read closely..
EX is the same PL2X Movie but in 6.1, which means that when the DSP finds the EX flag both back L/R surround channels have the same mono info. However if the incoming source stream is 5.1 (such as Dolby Digital) and being postprocessed by DPL2x to 7.1, the back L/R surround channels output will be in stereo which provides enhanced channel separation.
Hope that clears up any confusion.
Just my $0.01..
