Official VSX-01TXH and VSX-03TXH Owners Thread - Page 111 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #3301 of 3303 Old 03-06-2017, 02:46 PM
taxman48's Avatar
Quoted: 317 Post(s)
Liked: 309
I have a Sanus rack with the receiver on the 2nd from the bottom ..I have had no heat problems what so ever..
taxman48 is offline
post #3302 of 3303 Old 03-06-2017, 03:23 PM
gene c353's Avatar
Quoted: 156 Post(s)
Liked: 114
Originally Posted by Fabricator View Post
heat issue.
i have an 01. i changed around my setup. i put the 01 in an open stand, with my BD player on top.
this 01 only runs my 2 small sided (fronts = XPA-3). last night after a movie, i noticed the 01 was pretty hot.
just wondering if anyone has noticed the heat ?
I've had many Pioneer avr's over the years. 1014, 59txi, 94txh, 2 sc-27's, 2 sc-25's an sc-37 a vsx-23, vsx-03, vsx-24, sc-75 and a couple I'm sure I've forgotten about, and none of them ever got more then warm. I did a temperature test with the vsx-23 a while back. Put a thermometer on top of it and hooked up 8 ohm, 6 ohm and 4 ohm speakers for two hours apiece. the 8 ohms ran 95 degrees, the 6 ohms 105 and the 4 ohms 115.
An Integra 8.9 I had ran so hot in Standby I had to un-plug it when not in use.
BTW, the processing section causes at least as much heat as the amp sections, or so I've been told.
gene c353 is offline
post #3303 of 3303 Old 03-06-2017, 07:20 PM
Fabricator's Avatar
Quoted: 71 Post(s)
Liked: 33
well, idk what is going on then. but for just 2 small sides, i would think it shouldn't be hot.
i will get a temp reading this weekend.
chasing rattles ......Pro8100 & Da-Lite HP 2.8 Cult member
Fabricator is offline
