Official Harman/Kardon AVR x54: Problems and Solutions Thread - Page 96 - AVS Forum
Old 02-12-2014, 10:07 PM
M Code's Avatar
Quoted: 190 Post(s)
Liked: 153
Originally Posted by kaupp240 View Post
Thanks, I'll check on that.
It seems to be working fine in spite of the program crashing.
How about a regular RS232 cable on a COM port instead of USB?
Should be fine...
Just my $0.05... 👍😉
M Code is online now
Old 02-13-2014, 02:20 PM
kaupp240's Avatar
Cool. Now to see if I can find my old serial cable and give it try. If it still doesn't work I'll drag my monster sized desktop out there and try it instead of my laptop.
Cheryl
kaupp240 is offline
Old 03-21-2014, 03:38 PM
Mark Kitchen's Avatar
Just had a good read through here,
I have a avr 255 it's been working fine until you switch the source over I then lose any picture but still have audio?
I have to leave the receiver off for upto 20mins presume this is to let it cool down, anyone else had the same issues and have the factory repairs resolved it?
Thanks in advance
Mark Kitchen is offline
Old 04-10-2014, 10:05 AM
idiotboy's Avatar
intermittent hdmi fault needs repair
a place up in leeds england fixes these avr's and other harmans
i sent my avr 355 with a protection problem and they repaired it updated it and realigned it for under 150 pounds including all spares and courier return delivery this was in august 2012 so not sure if price for repair is still valid it has not gone faulty since i love the sound so trying to keep it going
i heard they do not repair avr 7200 or 8300 too heavy and time consuming and pcbs are normally required for a reliable repair
multicare leeds google it phone or email for more details
idiotboy is offline
Old 05-06-2014, 11:12 AM
jerrolds's Avatar
I cant seem to find the firmware update files needed for this. My AVR-254 is acting wonky when it comes to HDMI.
Can anyone provide a more up to date link?
jerrolds is offline
Old 05-06-2014, 12:17 PM
M Code's Avatar
Quoted: 190 Post(s)
Liked: 153
Try here...
http://www.harmankardon.com/estore/hk/us/support/supportDU.jsp
Just my $0.05... 👍😉
jerrolds likes this.
Old 05-06-2014, 12:50 PM
jerrolds's Avatar
Thanks much - looks like its working. Damn i need a USB -> Serial adapter?
jerrolds is offline
Old 05-06-2014, 03:22 PM
M Code's Avatar
Quoted: 190 Post(s)
Liked: 153
Not all USB > Serial adapters work..
HK tech support has a list of the approved ones..
Just my $0.05... 👍😉
Old 05-09-2014, 02:04 PM
jerrolds's Avatar
Is there a way to get 2-channel stereo to play out all 5 speakers? Say i feed it stereo music, would be nice to get all the speakers going even if its not recorded that way
Right now when i select "Surround Mode" i only have the option of "AVR Selects best" or "2 Channel" - when i select the 2 channel, all the other options are greyed out and disabled.
jerrolds is offline
Old 05-09-2014, 02:42 PM
M Code's Avatar
Quoted: 190 Post(s)
Liked: 153
Select 5 Channel Stereo mode..
Just my $0.05... 👍😉
Old 05-09-2014, 03:08 PM
jerrolds's Avatar
Just my $0.05... 👍😉
I cant though - everythings greyed out other than 2 channel. Maybe HDMI is acting weird? Do i turn off the AVR?
jerrolds is offline
Old 05-09-2014, 08:22 PM
dmb12679's Avatar
Quoted: 24 Post(s)
If you hit the ok center circle button while over the 2 channel, does it give you the option for 5 channel?
Harman Kardon 3700
Klipsch RF-82 II
Klipsch RB-51 II
Klipsch RC-52 II
Klipsch SS-1's
Klipsch R-112SW
dmb12679 is offline
Old 05-12-2014, 09:34 AM
jerrolds's Avatar
Nope, when i hit ok a new sub menu shows up and there is a 2-ch and 5-ch option the problem is the 5ch is unselectable (looks greyed out) and whatever i do i cant select it. I ultimately i just have to back out. Is it because the AVR needs to be updated?
Luckily i got the 254 for free otherwise i wouldve returned it pretty quickly. It does not pass through video HDMI signals does it? I know it does some weird processing even if i have everything OFF. I used to be able to set the pixel format to my Panasonic ST50 to RGB 4:4:4 Full, but going thru the 254 i get some major black crush going on.
Had to switch to YrCrBr 4:2:2 but i havent had a chance to recalibrate it to make sure its correct.
jerrolds is offline
Old 05-12-2014, 10:29 PM
jerrolds's Avatar
Also - im having trouble bitstreaming from MPC to the receiver, it always says "Multi\-Ch PCM" and cannot make it recognize DTS or DTS-HD. These are playing MKVs with the supported formats so im not sure what im doing wrong. Here are my settings under MPC and my Sound settings http://i.imgur.com/GrBqaSo.png
I'm connecting my PC to the AVR using my Radeon 290X's HDMI connection. Thanks.
EDIT: Fixed it - i installed a slightly newer version 1.7.5, but did not re-add the LAV filters. Maybe it was conflicting before.
jerrolds is offline
Old 05-12-2014, 11:38 PM
M Code's Avatar
Quoted: 190 Post(s)
Liked: 153
In reviewing Intel's website (www.digital-cp.com) we failed to find any HDCP certification for the Radeon 290...
Without this crucial certification, one may likely encounter certain HDCP handshake interoperability issues, with other HDMI components..
Unfortunately many brands attempt to do their own HDCP testing in-house to save $ rather than submitting their products to the HDMI Labs for certification...
Just my $0.05... 👍😉
Old 07-29-2014, 12:27 PM
gimpy's Avatar
Quoted: 21 Post(s)
I haven't visited this site in awhile. My 350 has gone into protect mode after owning it for five years. I have a Denon on the way to replace it. So, I thought just for the heck of it, I would check with you folks here for some things to check to maybe get it to work again.
A little background:
I had the behringer a500 amp hooked into the main speaker pre outs, then to my 4 ohm speakers. A few months back, the speakers started to pop loudly when I would turn on my system with my harmony remote. I had the amp turned on 24/7, all the time. This was so bad that I eventually left the amp turned off all the time, so I was watching tv using only my center, surrounds and sub. If I wanted to listen to music or watch a DVD, I would turn on my system, then turn on the amp (no popping then).
A couple of weeks ago, I changed entertainment centers, unhooking everything and then setting it back up again. A couple of days later, my wife calls and said everything shut down. When I got home, I did a few simple trouble shooting checks, but to no avail.
Things I checked include (this is without the amp. I took it completely out of the system when I reinstalled everything into the new entertainment center before it started going into protect mode): checking the speaker wires (I have since put banana plugs on them), doing a default to factory reset, using the ok button as advised from the manual.
I also tried hooking right speaker to left output, center speaker to left and surrounds. I always get the loud popping, but turned it off before going into protect mode.
May have been one or two other things I tried. Whatever I tried it would start popping and go into protect mode if I did not shut it off first.
Long post, I know, but might try looking at it before trashing it, if given some suggestions. Also the same for the amp. What might cause it to make the speakers pop like that?
Any help, suggestions appreciated.
Thx, Frank
gimpy is offline
Old 09-03-2014, 08:54 AM
FastBunny's Avatar
Liked: 0
Thanks in advance
Same here,
I've checked my AVR255 and it already have the upgraded fuses and the extra wire. The problem i have is almost the same but i lose both video and audio and sometimes only the audio.
To be sure i replaced both the fuses with new 3.15A fuses, but the problem remains. Did you fix your problem? Or could it be that even de 3.15A fuses are to low even when they are replaced??
FastBunny is offline
Old 09-21-2014, 11:45 AM
willbchap's Avatar
Liked: 0
Distorted audio output, can't find anyone with the same problem...
I have a weird issue that a google/site search hasn't found, and I'm trying to determine if someone has indeed seen this issue and maybe my search techniques suck. I know this thread is older than the computer I am using to reply, but I figure it's worth a shot before boxing the AVR up and wasting money.
I have very distorted, but still intelligible, audio on all 5 main channels, including the pre-amp outs, using digital and analog inputs, but not on the Zone 2 amp or pre-out. I think the Zone 2 "system" bypasses any audio processing, so I think my issue is in the main audio control board somewhere. I took the AVR apart to the bottom board, blew out the dust, and it passed the "eye-test" (couldn't find any blackened/smoked areas). 2008 manf AVR 354, S/N in the HDMI defect range (05719) but never have had any of the issues with the HDMI circuits, and running the latest firmware for a couple of years now.
Anyone seen this issue before?
willbchap is offline
Old 09-21-2014, 12:23 PM
M Code's Avatar
Quoted: 190 Post(s)
Liked: 153
Try a PROCESSOR RESET..
Note that this erases all of station-presets, surround and EQ settings, U will have to enter these..
Just my $0.02...
Old 09-21-2014, 12:42 PM
willbchap's Avatar
Liked: 0
Just my $0.02...
I appreciate that suggestion, though I have already tried resetting the processor. That was the first thing I did because I figure there was some corrupt gain settings. It has been reset twice now, and removed from power for a day. Issues continue in stereo or surround modes after reset and without any adjustments.
Old 09-22-2014, 06:05 PM
willbchap's Avatar
Liked: 0
In case anyone is wondering, Audio Video Labs in VA Beach says they no longer repair HK equipment. The more I read, this thing might be a paperweight now based on parts availability. From what I've read on this site, I think I'll move on to a different manufacturer for my next purchase. Wish this one would have lasted a little longer than it did.
Old 09-24-2014, 10:34 AM
170watt's Avatar
I have some questions, I am trying to figure out something that does not make any sense to me. Here’s the story. HK AVR 354. Symptoms: randomly drop off HDMI sound and image (usually when powered on started well, everything working, but after variable time (2-15 min) the HDMI signal lost). Later on, I also noticed that when HDMI dropped off (image and sound) the front panel buttons (and corresponding remote buttons) were not responding (except for volume and input selection). Also when that happened, the 1.8 V line (on the front side of the HDMI board, CN82 pins 4 and 5) were only at 0.6 V. The fuses F110 and F111 (with higher rating 3.15A/250V and shunt wire (jumper) from HDMI board to Regulator board were already installed, as per service bulletin (HK2008-03 Rev1 December 2008). Although the fuses showed low resistance (were OK? I thought), I replaced them with same specification (3.15A/250V). Here’s comes the mystery. Short time after I changed the fuses nothing changed (and I reset the unit a few times), same symptoms. But later (~minutes), everything worked perfectly fine. How the heck that happened? Could be a contact somewhere that goes on/off? Or the fuses were really the problem? (but then, why nothing changed for the first few times when I reset the unit, turned on/off)? Also the mere fact that the fuses showed low resistance, was indicative that they were working properly? Or maybe the KIA278R00PI voltage regulator from the regulator board is acting up randomly, and the fact that is now working properly is by chance (and strangely kind of coincided with replacing the fuses)? I figure that the same problem will re-surface sooner or later.
170watt is offline
Old 09-24-2014, 12:35 PM
M Code's Avatar
Quoted: 190 Post(s)
Liked: 153
The 254 & 354 uses in-line ribbon cable connectors between the PCBs...
These often work loose making intermittent connections, make certain these are firmly seated..
Just my $0.02...
Old 09-24-2014, 01:20 PM
170watt's Avatar
Just my $0.02...
Could be…. Or maybe not. I re-seated the HDMI board twice (and also cleaned a vertical connector that had some brownish grease on it – no idea what was that) a day before replacing the fuses but no change. Again, what puzzles me is the fact that the receiver didn’t start working properly immediately after I changed the fuses, but after 10-15 minutes (and during that time I didn’t do anything except restarting, and resetting multiple times.
170watt is offline
Old 09-26-2014, 06:27 PM
170watt's Avatar
Update. Actually the issue reappeared. So basically at random intervals (could be a few minutes but mostly ~20 mins) the HDMI drops out (image & sound), and some functions (when accessed either directly on the receiver or remote) are not responsive: audio effects, video modes, surround modes, AVR menu. If I switch to radio, the sound (including volume control) works perfectly fine but neither HDMI out (to monitor/TV) nor functions mentioned above are present. If I restart the unit everything works fine until the issue above reappears.
I checked a few voltages on the top face of the HDMI board (voltage regulator outputs) that are easily accessible, and connectors; all are fine.
170watt is offline
Old 09-28-2014, 09:02 AM
170watt's Avatar
Just my $0.02...
Update (28-Sep).
What seems to "solve" the issue is actively cooling the receiver. Now figuring that this is a thermal issue, doesn't bring me closer to a definitive solution (active air cooling doesn't seem like a real solution to me).
At this point I really need to hear your/someone’s opinion.
1) Let's assume the culprit is that 1.8 V regulator voltage, on the regulatory board (which incidentally shows the highest temperature on that board, and is also directly under one of the cooling fans). I know that those KIA278R00PI regulators have a thermal protection. My specific question is: if they shut down due to overheating, are they coming on again, once the temperature falls under a certain limit? Because - if they do - it might explain why I got sometime 0.6 V, and other times 1.8 V readings, even when the HDMI was already off. Also, could it overheat internally, due to a malfunction, or because they are overloaded (high current somewhere further away)?
2) If the problem is on the HDMI board itself (most likely, I guess), could it be a BGA chip unsoldered pins issue? Personally I don’t think that, as (from my limited experience) the malfunction is usually permanent, not after heating up. Could also be a bad/cold soldering, somewhere on the board? - which would make this (I think) impossible to detect.
So what’s your take on that?
170watt is offline
Old 10-24-2014, 02:45 PM
Liked: 0
Anyone have the 93.1.1 firmware for the avr 254
I updated due to a problem and finally the problem come from a driver on my linux server
Just after i updated to 98, I got a problem with the hdmi detection , like when i open they recognize the actual hdmi just if i switch they don't scan correctly , i used a hdmi switch and happen the same , tv are normally recognized
So anyone have the 93.1.1 firmware version for i do a downgrade
thesweetiger is offline
Old 12-02-2014, 10:31 AM
mirkyman's Avatar
Well my AVR 254 is now on a shelf
I too finally got fed up with the intermittent HDMI/freezing issues that have become common place. Tackling the issue for the past 3-4 months. Ultimately giving up on any video processing.
Lots of good tricks and tips for fixing, but ultimately, the fixes weren't fixing and the unit just isn't worth saving anymore. My needs have changed since I bought the unit at the beginning of 08.
Audio still works flawlessly, and the fact it has pre-outs makes it worth keeping since pre outs on new lower end receivers are rare. I plan to use it in a in an audio only work environment down the line where I need surround monitoring through my powered studio monitors (film editing speak)
Overall pretty happy that it survived nearly 6 years especially considering it was on probably 5-8 hours a day.
Just picked up a refurb Denon X1000 for 219 bucks as a stop gap for another couple of years. Thoroughly impressed with the sound of the Denon so far, and while I miss the awesome menu and OSD of the HK, I em enjoying at least having something made in the last couple of years.
mirkyman is offline
Harman Kardon Avr 354 7x75w 7 1 Channel Home Theater Receiver , Harman Kardon Avr 254 7x50w 7 1 Channel Home Theater Receiver With Hdmi 1 3a Repeater
