Interesting article comparing audio codecs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 07-30-2008, 03:11 PM - Thread Starter
Tom Monahan's Avatar
Location: Butte, Montana Hometown of the late Evel Knievel
Quoted: 60 Post(s)
Liked: 43
I just read an interesting article comparing audio codecs in Home Entertainment magazine. It sounds like about as good of blind listening test as you can get. After reading it, as a by far video first guy, I'm not going to be in any hurry to upgrade my Yamaha RX-V2400 for the RX-V1800. The article can be found on www.hedmag.com. Just click on "other features" and scroll down to the second article titled signal to noise. I apologize if this info has already been posted on this forum.
My equipment: JVC RS55 for 2D, BenQ W7000 for 3D, Carada 40x117 2.925:1 AR BW Criterion screen, Navatar .8 HD conversion lens, Darbee Darblet, region free Oppo BP93, Toshiba HD-A35 HD-DVD, JVC HD-DH5U D-Theater, Mitsubishi HS-HD 20000 DVHS, Pioneer CLD-97 LD player/AC-3 mod, B&K AC3 Demodulator
Tom Monahan is offline
post #2 of 10 Old 07-30-2008, 03:24 PM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 148
It's been posted, but not everyone has probably seen it. I wish Dolby and DTS would publish these WAV files using the exact same source
* Uncompressed music segment with lots of high frequency info especially cymbals
* encoded to 448kbs Dolby Digital, then undecoded to a WAV file
* encoded from 768 kbs DTS, then decoded
* encoed to 1.5 Mbs DTS, then decoded
* encoded to Dolby Digital+ at a typical bitrate, then decoded
* encoded to DTS HD High Resolution audio at a typical bitrate, then decoded
There's no need to have samples of undecoded lossless audio, as it's identical to the uncompressed sample.
With these files, individuals could decide for themselves.
In the meantime, if your player can decode TrueHD as 1.5 Mbs, you are in great shape. The player should be able to send the very high quality 1.5 Mbs DTS-HD Master Audio core even though it can't decode the lextension.
"But this one goes up to 11"
MichaelJHuman is offline
post #3 of 10 Old 07-30-2008, 05:27 PM
quad user's Avatar
Keep in mind that DTS-HD Master Audio is capable of lossless audio with variable data rates up to 24.5 Mbps. If there will be such sources there is likely to be a big improvement over the 1.5 Mbps core. TrueHD has somewhat lower capabilities.
quad user is offline
post #4 of 10 Old 07-30-2008, 05:33 PM
batpig's Avatar
Quoted: 3569 Post(s)
Liked: 3415
I found this somewhat amusing about the DTS labs reference 7.1 setup:
In lieu of a stack of power amplifiers, this system was instead easily powered by a Denon AVR-2808CI audio/video receiver
the blasphemy!! a lowly RECEIVER powering the DTS reference setup!?! and not even a flagship model?!?! don't they know that if they're not using separates they are committing audio heresy!?!??
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #5 of 10 Old 07-30-2008, 09:11 PM
NAD Paradigm's Avatar
They failed to mention that those KRK's are active studio monitors, which means they have built-in poweramps - bi-amped with 160 watts for the LF driver and 120 watts for the HF. The poweramps are designed and optimized specifically for each driver, and the active crossover is before the power amps.
Pro audio studio stuff is a little different than HT...
NAD Paradigm is offline
post #6 of 10 Old 07-30-2008, 09:35 PM
batpig's Avatar
Liked: 3415
I figured they were active monitors.... like I said, just thought it was an amusing little passage in the article.
Setup Guide and FAQ
batpig is offline
post #7 of 10 Old 07-31-2008, 09:56 AM
dsmith901's Avatar
This article confirms what I have suspected - that the considerable extra cost of adding lossless DolbyHD and DTS-HD is hard to justify for all but the well-heeled. The fact that even these well-seasoned audiophiles, in optimum conditions, could detect only the very slightest difference between the original PCM track and plain old DD tells me that my money is better spent on the video rewards of BD than the audio. Thanks to Home Entertainment for this article - it will help me a lot of other people save a lot of money on my HT system.
"The truth is out there!"
dsmith901 is offline
post #8 of 10 Old 08-17-2008, 05:18 PM
CruelInventions's Avatar
Quoted: 460 Post(s)
Liked: 593
Here's a more direct link to the article comparing lossless DolbyHD and DTS-HD to existing codecs, but I'm sure it will fall upon deaf ears for most around here. Resulting pun purely coincidental, but apt, nevertheless.
CruelInventions is online now
post #9 of 10 Old 08-18-2008, 08:28 AM
dsmith901's Avatar
That important article should be linked by the mods in a sticky, both here and in the BD player forum, but I doubt they will bite the hand that feeds them.
post #10 of 10 Old 08-18-2008, 12:41 PM
chatanika's Avatar
Well seasoned audiophiles!!! LOL.
chatanika is offline
