*Official* Denon AVR 2309CI/889 Thread - Page 107 - AVS | Home Theater Discussions And Reviews
post #3181 of 3208 Old 03-28-2014, 04:15 AM
JimWinVA's Avatar
Quoted: 32 Post(s)
Liked: 39
Thanks for the info. Seems like a lot of trouble to go through versus just switching to PCM.
JimWinVA is offline
post #3182 of 3208 Old 03-28-2014, 08:32 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 3706 Post(s)
Liked: 2177
Sure. However, some folks like seeing the bitstream audio display on the front panel vs. just "MULT CH IN". Whichever you prefer. smile.gif
"JD" – jd@avscience.com ; http://shop.avscience.com/ Call only for sales info --> 585-645-1006
Daily - 8am to 8pm EST
AVScience sells Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Oppo, and more
** Think the AVR is defective?  Reset the microprocessor 5 times.
jdsmoothie is online now
post #3183 of 3208 Old 03-29-2014, 01:20 PM
Cinemafreak1's Avatar
So the wife said we need a home theater Receiver in living room for music and TV. So movie Denon 2309 up and replace main HT downstairs Or get a more basic one for living room, 200-300? Would a new 500-600 receiver be that much better than my old Denon?
Cinemafreak1 is offline
post #3184 of 3208 Old 03-29-2014, 02:34 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2177
The newer X2000 would provide networking and a higher version of Audyssey MultEQ XT.
post #3185 of 3208 Old 05-20-2014, 05:05 PM
Folsom's Avatar
I have a MULTI CH IN question, and I wanted to post a question here first before posting in the home computer section..
My PC is connected to my 889 from my video card, and MULTI CH IN lights up. I have found some two channel sources like VLC only output sound on the front speakers, but some sources like google play music and youtube have surround sound.
It could be possible that VLC is outputting five channels (2 music and 3 silence) while the other two are only outputting two channels. Could the 889 be converting the two channels to a surround format? If so, I would like to turn it off. If not, then I have something configured incorrectly on the PC.
I looked at page 69 in the 889 manual, and I see different settings for MULTI CH IN. I would also like to know how to select MULTI CH DIRECT and PURE MULTI CH DIRECT.
Folsom
Folsom is offline
post #3186 of 3208 Old 05-20-2014, 05:19 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2177
If you have a 5.1 setup then a MULTI CH IN signal is already 5CH so there is nothing to change, rather if audio is only heard from the FL/FR speakers than a 2CH audio track is being passed over a 5CH signal. Select DIRECT by pressing the D/ST button on the back of the remote while to select PURE DIRECT, press the PURE button on the back of the remote.
post #3187 of 3208 Old 05-20-2014, 07:01 PM
Folsom's Avatar
When I press the D/ST button, sound only comes from the front speakers, and "STEREO" is displayed. This is the sound I want when listening to 2 channel music from google play. I'd rather not have to switch the 889 mode depending on the source. The sound is much different, it doesn't sound like it's just muting the surround channels. There is a large loss of bass when going away from stereo back to multi ch direct.
Does this mean that the computer is outputting 5 audio channels from the PC when I want only two channels? I want to ensure I have the 889 not doing any processing and the PC is adding extra channels before asking in the home computer section.
Folsom
Folsom is offline
post #3188 of 3208 Old 05-21-2014, 04:20 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2177
Refer to p. 37 in your Owner's manual for more information on DIRECT mode. Unless there is a separate 0.1 (LFE) channel, there would be no audio going to the subwoofer.
post #3189 of 3208 Old 05-22-2014, 05:54 PM
Folsom's Avatar
Thanks for all the help. It's good to know all the direct modes. I figured out that Firefox is upmixing the stereo audio to 5.1 and not the receiver. If I use Chrome then stereo sounds fine.
Regards
Folsom
Folsom is offline
post #3190 of 3208 Old 05-23-2014, 03:21 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2177
Keep in mind that using DIRECT or PURE DIRECT, in addition to disabling any bass management, Audyssey is also disabled.
post #3191 of 3208 Old 07-29-2014, 03:40 PM
Liked: 0
Hey everyone,
New guy here. I have a Denon 2309ci that just today started acting strange while in surround sound. I can't hear any voices. Switching to 5 channel stereo brings the voices back. I tried the reset sequence which flashed all the lights on the display a few times but the surround issue isn't resolved. Anyone hear of this before? Any ideas as to what I can do to fix it?
Edit: I have young kids so it's very possible that one of them played with the control panel.
I appreciate your help!
voltrons_head is offline
post #3192 of 3208 Old 07-29-2014, 03:50 PM
Liked: 0
Silly me. One of the kids had bumped the center channel and knocked the wire loose. All fixed.
post #3193 of 3208 Old 08-14-2014, 08:32 AM
Liked: 0
My Denon is not playing sound from the left or right front speakers. I thought it was the left/right outputs on the receiver so I connected my center cables to both left and right and sound was coming out. Then I thought is was my cables for the left/right speakers so I connected them to the center outputs and sound was coming out.
Anyone having this issue?????
HometheaterAddict is offline
post #3194 of 3208 Old 08-14-2014, 09:15 AM
batpig's Avatar
Quoted: 1637 Post(s)
Liked: 1895
Check if you haven't accidentally selected "B" front speakers.
batpig is online now
post #3195 of 3208 Old 08-14-2014, 09:27 AM
Liked: 0
It is all connected under A outlets
post #3196 of 3208 Old 08-14-2014, 09:46 AM
batpig's Avatar
Liked: 1895
Right, but if you accidentally selected "B" speakers the "A" outlets would be muted.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
post #3197 of 3208 Old 08-14-2014, 10:56 AM
Liked: 0
gotcha...how would i un-mute the A speakers or switch back to A speakers?
post #3198 of 3208 Old 03-13-2015, 08:48 AM
HotBBQ's Avatar
Has anyone here attempted the firmware update and had success? I haven't had any luck getting the executable to communicate with the receiver. I'm using a USB to Serial cable (since it's, you know, 2015 and not a single person I know has a laptop or desktop with a serial port) on a Windows 7 desktop. The update tool recognizes the COM port but it just won't connect to the receiver. I also tried setting up Windows XP in a virtual machine, but that didn't help. It's bugging the heck out of me that I can't figure this out.
HotBBQ is offline
post #3199 of 3208 Old 03-13-2015, 09:02 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2177
When I stopped counting a couple of years ago, there were "66" 2309 owners who had updated without issue. Did you read through the instructions in their entirety to include the following caution?
post #3200 of 3208 Old 03-13-2015, 09:23 AM
HotBBQ's Avatar
Yes I tried the various Windows XP compatibility modes and tried all COM ports 1-16. I tried different baud rates, FIFO buffers, flow control settings, etc. I also completely disabled Windows UAC just to be safe. I held the INPUT MODE + SPEAKER buttons when turning it on and the entire display flashes (side note, this was the first time I ever saw the blue bitstreaming light turn on) and everything was at the default settings. I also tried putting it in recovery mode, but nothing seemed to happen. Not sure what else to try at this point.
HotBBQ is offline
post #3201 of 3208 Old 03-13-2015, 09:31 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2177
Did you try the Countermeasure listed in item 2.6? It may also be an issue with the cable you are using if there is a required driver for it to work.
post #3202 of 3208 Old 03-13-2015, 12:09 PM
HotBBQ's Avatar
Yes, I did. I had to get my wife to help because I am red/green colorblind and I couldn't tell if the light was red. Don't think it matters, but here is the cable I used. I have the drivers installed.
HotBBQ is offline
post #3203 of 3208 Old 04-03-2015, 05:20 PM
Liked: 0
I have a couple simple question relating to the 2309ci I bought new back in 2009. It was worked flawlessly over the years but I finally broke down and purchased a Samsung UD 4K television. Wow...after staring at our old Toshiba DLP for so many years, I can't even begin to describe the picture. The Samsung model is a UN55HU6840F
Ideally I would upgrade the 2309 but after doing some research I'm going to wait at least until the next model year in the hope that Denon embraces the HDCP 2.2 protocol.
My questions are in regards to the Denon and the pass through of the video signal. Right now I just plugged the HDMI cable that was attached to the old Toshiba into the new Samsung. Is the video signal being bypassed now?? I didn't make any changes the Denon input settings. If it isn't, would it be best to bypass the Denon all together and have the Samsung manage the video and the Denon take care of just the Audio.
FYI...I read nearly this entire thread. That was a exercise in patience but I did gain a lot of insight.
Bill
Bill_in_PDX is offline
post #3204 of 3208 Old 04-03-2015, 05:23 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2177
As HDCP 2.2 has now been released, the vast majority of the 2015 models from every mfr will be HDCP 2.2. As long as you're not trying to pass a 4k signal, there is no reason not to continue passing the video through the AVR.
post #3205 of 3208 Old 04-03-2015, 06:00 PM
Liked: 0
Wow..that was quick!!
As far as the 4K single goes, the only program that I'm aware of right now that is 4K is House of Cards on Netflix. Please correct me if I'm wrong.
Another question regarding the Samsung Smart Hub. When I start Netflix, the sound is from the satellite box and doesn't switch to the audio feed from Netflix. I have a optical cable attached from the Samsung's digital audio out to the Denon's audio in 1TV/CBL.
Figuring there is something I need to reassign within the Denon's inputs. Help there would be appreciated.
Bill
post #3206 of 3208 Old 04-03-2015, 06:13 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2177
The 2809CI is only HDMI 1.3 and therefore does not support HDMI(ARC) which didn't come until 2 years later with HDMI 1.4. Continue using the optical cable.
post #3207 of 3208 Old 04-03-2015, 06:22 PM
Liked: 0
The 2809CI is only HDMI 1.3 and therefore does not support HDM(ARC) which didn't come until 2 years later with HDMI 1.4. Continue using the optical cable.
Thanks...I figured it wasn't ARC compatible. Any idea what input assignment I need to change in order to get the audio correct for the smart hub?
Thanks again...
Bill
post #3208 of 3208 Old 04-03-2015, 06:24 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2177
Correct? You simply select the optical audio input you have it plugged in to on the AVR.
Denon Avr 2309ci Receiver
