*Official* Denon AVR 2309CI/889 Thread - Page 54 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #1591 of 3224 Old 02-11-2009, 09:19 AM
BoB/335's Avatar
Quoted: 23 Post(s)
I have skimmed through some of this thread and read the last two pages. I must say that I am pretty overwhelmed! I'm certainly not the brightest guy I know but I would think that these AVR's are too complicated for the average person to understand.
I purchased a 2309 just before Christmas. I have been using a pair of Polk Bookshelves while researching speaker choices. I thought I was understanding some of this set-up stuff but haven't paid a lot of attention because I didn't need to go through all that yet.
My full system consisting of towers, center, surrounds and sub will be here tomorrow or the day after and I figured it might be a good time to get a grip on this. Is it really possible to get a grip on this? Where do I start?
BoB/335 is offline
post #1592 of 3224 Old 02-11-2009, 10:21 AM
jdsmoothie's Avatar
Quoted: 12075 Post(s)
Liked: 5499
Unless you've got more than 2-3 audio/video sources the setup actually doesn't have to be that complicated at all. If you use the default input jacks and settings it's even easier. Although the manual can be somewhat confusing, you can still muddle your way through to get the system setup as many of us have done. If you need more help, trying reading batpig's guide.
jdsmoothie is offline
post #1593 of 3224 Old 02-11-2009, 11:46 AM
BoB/335's Avatar
Quoted: 23 Post(s)
I guess I mis-stated. I have the 2309 hooked up and working. Cable box and blu-ray player into an LCD TV. Everything is working fine. All HDMI cables.
CALIBRATING my speaker system is what I am inquiring about. I'll read through that link.
BoB/335 is offline
post #1594 of 3224 Old 02-11-2009, 12:01 PM
SoundofMind's Avatar
Liked: 166
Bob,
Keep in mind that many, many people run autosetup just following the basic directions in the owners manual and are happy with the results. Those of us on the AVS threads are motivated to get the maximum SQ out of MultEQ. Thus, we (obsessively?) attend to the more detailed instructions which can be found in the Audyssey setup guide referenced here:
http://www.avsforum.com/avs-vb/showt...o_threadsearch
Yes, I still like playing with Dalis.
SoundofMind is offline
post #1595 of 3224 Old 02-11-2009, 01:46 PM
lowmileage's Avatar
If I can figure (most of) it out, anyone can
lowmileage is offline
post #1596 of 3224 Old 02-11-2009, 04:37 PM
jdsmoothie's Avatar
Liked: 5499
As I implied in my previous post and as SoundofMind indicated, once you run AUTO setup, your speaker calibration is done. I would imagine the huge majority of owners, don't bother tweaking beyond that point.
post #1597 of 3224 Old 02-11-2009, 07:21 PM
Cheeze's Avatar
Greetings
I am ordering HDMI cables for my new Denon AVR. Do I need version 1.3a cables going from the PS3 to the Denon - then 1.3a from the Denon to the display?
Or can I stick with regular HDMI cables that are not 1.3a?
Imagination is more important than knowledge
Cheeze is offline
post #1598 of 3224 Old 02-11-2009, 08:27 PM
Liked: 166
Gratings, cheese. Monoprice (see red & white link @ top of page) 1.3a is the way to go per many recommendations on these threads-inexpensive & reliable.
post #1599 of 3224 Old 02-11-2009, 08:45 PM
Cheeze's Avatar
Yup - ordering from Monoprice.
I already have 'regular' HDMI cables, but now that I'm getting a HDMI 1.3a AVR, do i need to change out my existing HDMI cables for the 1.3a versions? I know my PS3 is HDMI 1.3a as well...
Am I making sense
Cheeze is offline
post #1600 of 3224 Old 02-11-2009, 10:44 PM
Liked: 166
Well, cheeze, your IP indicated you were ordering, in which case it would only make sense to order 1.3a. Whether to bother replacing a perfectly good 1.3 is another, and debatable, matter. There is an entire thread on the topic:
http://www.avsforum.com/avs-vb/showt...0#post15476630
post #1601 of 3224 Old 02-11-2009, 11:51 PM
cmanderson's Avatar
Originally Posted by crbaldwin View Post
Is anyone able to test this for me? Thanks.
OK, so I checked and the "Queen Live in Montreal" Blu-ray disc has a 96khz DTS-HD Hi Res audio track, in addition to the default 2 channel LPCM. Sorry, no John Mayer in my collection. At any rate, my Sony BDP-S500 is in PCM output mode, so it is performing the decoding of this 96/24, but lossy, audio track.
My Denon AVR-889 shows Multi Channel PCM @ 96khz and I have 7.1 with "MULTI +Dolby EX" mode on the display. This should hold true for any audio codec @ 96khz, I would think.
cmanderson is offline
post #1602 of 3224 Old 02-12-2009, 02:18 PM
kenyh's Avatar
2309CI
I am using a DVI to HDMI cable and it seems to be ruining the audio output. The vidieo is fine. I have spent hours researching (here mostly) and working on the setup itself. batpig's link has been very helpful.
In an effort to simply get this thing working, I am going to change to composite video & optical audio. The manual says 3-RCA with OPT1 is a default setting so I'll give it a try.
Thoughts or better idea?
Will I lose much quality-wise with this connection?
kenyh is offline
post #1603 of 3224 Old 02-12-2009, 02:22 PM
batpig's Avatar
Quoted: 3568 Post(s)
Liked: 3415
Can you be more specific? DVI doesn't carry audio so if that's all you are using it's no wonder you get no audio output!! It's hard to say what the problem is with no details: is the DVI/HDMI cable coming from the source, or going to the display???
Can you specify exactly:
1. what your source is
2. how it is connected to the receiver
3. how the receiver is then connected to the display
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #1604 of 3224 Old 02-12-2009, 02:34 PM
kenyh's Avatar
Thanks batpig,
1. PS3
2. HDMI
3. DVI/HDMI cable
I am getting some audio, but with a lot of static. This set-up is in my basement for the kids to play Rock Band and watch DirecTv. If it was my main setup, I'd ditch the TV......but it's a 65" Sony (unfortunately with a DVI connector).
kenyh is offline
post #1605 of 3224 Old 02-12-2009, 03:01 PM
batpig's Avatar
Liked: 3415
gotcha. so it's an HDMI/DVI conflict with the display. Then I would suggest going component video from PS3 to receiver, but leaving the HDMI in place for audio, i.e. instead of [component + optical] go with [component + HDMI]. As long as you configure your inputs correctly this should work out and I doubt you will see much loss in video quality. You could also run the component video straight to the display for video, and HDMI to the receiver for audio.
I think it's worth sticking with the HDMI for audio as you get the lossless audio on Blu Rays and some PS3 games.
Setup Guide and FAQ
batpig is offline
post #1606 of 3224 Old 02-12-2009, 03:07 PM
kenyh's Avatar
Thanks again, I will give it [component + hdmi audio] a try.
kenyh is offline
post #1607 of 3224 Old 02-12-2009, 05:52 PM
crbaldwin's Avatar
Quoted: 75 Post(s)
Liked: 24
Thanks very much for trying this. It sounds like DPLIIx overlay should work with 96 kHz Dolby TrueHD too (hopefully ). I can only get this to work with my current receiver by setting my Sony S350 to decode the TrueHD internally which causes it to output 48 kHz multi-channel PCM for some reason.
crbaldwin is online now
post #1608 of 3224 Old 02-12-2009, 06:05 PM
batpig's Avatar
Liked: 3415
as far as I know there are no limitations for post-processing on the Denon AVR's, so you should be fine.
Setup Guide and FAQ
batpig is offline
post #1609 of 3224 Old 02-13-2009, 09:53 AM
kenyh's Avatar
2309CI - connected [component for display + hdmi audio]
Audio still has a bunch of static. It only works without static on "Stereo". Other audio options are static. My next step (before returning this receiver) is connecting audio with optical. Then i'll try the RCA's for audio.
Very discouraged.
Original post:
2309CI - Thanks batpig,
1. PS3
2. HDMI
3. DVI/HDMI cable
kenyh is offline
post #1610 of 3224 Old 02-13-2009, 10:44 AM
batpig's Avatar
Liked: 3415
is it ONLY the PS3 that is giving you audio static? do all other sources work fine in surround sound?
Do you have another HDMI device that you could test to see if it can do audio-over-HDMI without static? It would be nice to isolate the problem to the PS3 specifically.
Setup Guide and FAQ
batpig is offline
post #1611 of 3224 Old 02-13-2009, 11:57 AM
kenyh's Avatar
BP - I'll try the DirecTv and see what happens. I've tried the Tuner with the new PS3 connection [component + hdmi audio) but the Tuner audio was acting the same way......audio static except when on "Stereo" (only FR, FL & Sub - no SR/SL)
kenyh is offline
post #1612 of 3224 Old 02-13-2009, 08:15 PM
jdsmoothie's Avatar
Liked: 5499
Hmmm .. did you read the last line in my sig?
post #1613 of 3224 Old 02-13-2009, 09:48 PM
ISpoilMyself's Avatar
Hey guys how come the receiver be turning off, well the screen goes dark for like 3-5 seconds when watchin a movie or playing COD on my PS3
ISpoilMyself is offline
post #1614 of 3224 Old 02-13-2009, 10:11 PM
jdsmoothie's Avatar
Liked: 5499
It seems you've had the Denon for a few weeks now. Is this the first time you're experiencing the loss of video? Do you lose audio as well? If you're connected via HDMI from the PS3 to the Denon, it might be a handshaking problem which can be prevented by running a component cable for video.
post #1615 of 3224 Old 02-14-2009, 06:57 AM
I've had it for almost a month now. But this started occurring last week. Yesterday this happened 2-3 times. And yes both loss of video and sound. Both my PS3 and DirecTV are connected thru HDMI but I've only experienced this on the PS3 *knocks on wood*. thanks
post #1616 of 3224 Old 02-14-2009, 12:46 PM
jdsmoothie's Avatar
Liked: 5499
Could just be a loose cable. Try swapping cables around and see what happens.
post #1617 of 3224 Old 02-14-2009, 01:00 PM
tdog4871's Avatar
Guys I need help. I'm stuck between the Denon 2309 and the Marantz 5003. Seems to me most things are the same EXCEPT: 4 vs. 3 HDMI and the availability to add an amp in the future. I feel like I've read every post on them both and still am confuse (or even more than when I started!).
I can't imagine there is that much difference even when I read the Marantz is superior in music sound at this price range. I'm leaning to the 2309 b/c of the 4th HDMI.
Thoughts???
tdog4871 is offline
post #1618 of 3224 Old 02-14-2009, 01:02 PM
jdsmoothie's Avatar
Liked: 5499
Pretty much boils down to a requirements and budget issue.
post #1619 of 3224 Old 02-14-2009, 02:18 PM
Liked: 166
Originally Posted by tdog4871 View Post
Guys I need help. I'm stuck between the Denon 2309 and the Marantz 5003. Seems to me most things are the same EXCEPT: 4 vs. 3 HDMI and the availability to add an amp in the future. I feel like I've read every post on them both and still am confuse (or even more than when I started!).I can't imagine there is that much difference even when I read the Marantz is superior in music sound at this price range. I'm leaning to the 2309 b/c of the 4th HDMI.Thoughts???
dog, you missed a vital difference IMHO. I posted in this thread in response to the identical question just a few days ago:
"I took a quick look at the AVS Marantz thread here http://www.avsforum.com/avs-vb/showt...?t=1060855page and the immediate issue in the first few posts is NO DynEQ. I didn't have to read any further to find any other potential issues. No way I'd buy a new AVR without that huge upgrade in Audyssey which is in the '09 Denons.
As to model of Denon, I'm not sure why you selected 2309(which is a fine choice), but... if you are very discerning on SQ, have (or will have) good speakers and a few more bucks in the budget, also consider the 2809 (the "best sounding amp for my money"). "
http://www.avsforum.com/avs-vb/showt...7#post15741857
The 2809 also has preouts so you can add an amp later, but the vast majority of owners find that unnecessary as it is a pretty beefy amp. I agree with you that it's unlikely you would be giving up SQ with either of those Denons (and with the 2809 in particular).
post #1620 of 3224 Old 02-14-2009, 02:39 PM
crbaldwin's Avatar
Quoted: 75 Post(s)
Liked: 24
Also, apparently Audyssey is disabled when listening to DTS MA signals on the Marantz.
Denon Avr 2309ci Receiver
