*Official* Denon AVR 2309CI/889 Thread - Page 8 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #211 of 3229 Old 09-10-2008, 09:58 AM
OldFilmFan's Avatar
Batpig, sorry to be such a noob. I assigned the input to RCA-3 and I connected the component video to RCA-3 per the manual. I get audio, but I get "No Signal Found" error. I double checked the connections and everything seems OK. Do I need to change anything else? Thanks!
OldFilmFan is offline
post #212 of 3229 Old 09-10-2008, 09:58 AM
jldupont's Avatar
Batpig, thanks for your reply.
I should have added the TV/CBL one as well... I actually didn't realize that you could stack them...
Using BalekFekete's setup as an example, he could connect his PS3 on HDMI4, his wii on the HPD audio input and component 1, assign the HDP input setting to HDMI4 and component 1 so that the PS3 takes precedence over the WII and rename HPD to GAME Clever...
WHich reminds me: Read my next post for a follow up question...
jldupont is offline
post #213 of 3229 Old 09-10-2008, 10:03 AM
jldupont's Avatar
I have tried understanding all these various audio codes and which settings I should use on my 2309.
I also just bought a S350 blue ray disk player and I want to make sure I am optimizing my connections and settings.
I have 5 speakers and the blue ray disk player is connected via HDMI. What settings should I use on either to allow me to get maximum sound quality. Specifically, I am having trouble grasping the bitstream vs PCM vs 5.1/7.1 analog output that people are talking about. I understand that the 2309 should "understand" how that works.
Also, would a PS3 provide comparable quality? SHould I really keep my S350?
jldupont is offline
post #214 of 3229 Old 09-10-2008, 10:06 AM
jldupont's Avatar
OldFilmFan,
Make sure your video source setting for that input is set to component 3 (I forgot the exact name). It is probably trying to find the video on the default video source (yellow connector) not the component.
I am at work right now so I will check later on to see if that helped you.
jldupont is offline
post #215 of 3229 Old 09-10-2008, 10:10 AM
batpig's Avatar
Quoted: 3706 Post(s)
Liked: 3577
jldupont - I am not familiar with that specific blu ray player.
however, the 2309 has EVERYTHING in terms of HDMI audio, so it is flexible enough to handle any HD audio.
I believe the S350 can bitstream the HD audio, so I would set it to bitstream everything and let the 2309 do all the decoding. Check out the blu ray forums (I'm sure there is an S350 thread) to verify that you have all the settings right. Since it can bistream, what you would want to see is the display light up with the correct codec (i.e. if you pop in a blu ray and select "Dolby TrueHD" as the soundtrack, the display should light up "Dolby TrueHD")
The PS3 cannot bitstream HD audio, it must decode it internally first and pass it out as multichannel PCM over HDMI. The sound quality will be identical to bistreaming (the only difference is where the raw audio gets "unzipped", at the player or at the receiver). Your display should light up as "MULTI CH IN" when using a PS3 for HD audio on blu ray.
I highly recommend taking some time to read, and then re-read, the AVR FAQ at the top of this forum. MichaelJHuman did a great job assembling it and it does a nice job explaining all the new codecs and options.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #216 of 3229 Old 09-10-2008, 10:37 AM
OldFilmFan's Avatar
I am such a knucklehead. I forgot that every time I change something on the cable box; HDMI> Component, I have to reboot the cable box
All is right with the world!!(Knock on wood)
post #217 of 3229 Old 09-10-2008, 10:53 AM
batpig's Avatar
Liked: 3577
awesome, glad you got it working. with most "problems" the solution is usually something silly like that.
hopefully that will eliminate the video dropouts entirely. you may also notice faster channel changes...
Setup Guide and FAQ
batpig is offline
post #218 of 3229 Old 09-11-2008, 08:48 PM
mwardncsu's Avatar
I have a question which I've not yet been able to answer reading through the thread.... what flexibility is there in assigning video inputs.
That is, even through there are "lables" on the HDMI, component, composite/S-video inputs for certain things like "DVD", "HDP", "VCR", etc - what level of flexiblity is really provided.
I know (believe?) you can change the name displayed on the received, but what I'm asking is if I use an HDMI port labled "DVD", can I then use a Composite video input labled "DVD" for another input source? I'm trying to understand the actual flexibility here for inputs to determine if the 2309 would work for me, or if I'd be pushed up into the 2809.
My input sources would be
- DirecTV HD DVR (HDMI)
- PS3 (HDMI)
- upscaling DVD player (to later become a dedicated BluRay player) (HDMI)
- Wii (Component)
- future spot for an AppleTV or similar streaming media device (likely HDMI, but could be component)
- want to save a composite or potentially component for a video camera
- if there was an extra S-Video/Composite still avail I might use it for something else, but not critical
thanks
Mike
mwardncsu is offline
post #219 of 3229 Old 09-11-2008, 09:16 PM
batpig's Avatar
Liked: 3577
you didn't try THAT hard, answered only 1 page back the simple answer is "yes"
Originally Posted by batpig View Post
anyway, to your first question, you can hook up more than 4. there are five unique video inputs (HDP, VCR, TV/CBL, DVD, V-AUX) which are all assignable, then two additional audio-only inputs (CD and CDR/TAPE), plus of course the dedicated PHONO input. So that's seven unique inputs, five of them video, plus PHONO and TUNER.
You can also (as you mention) "stack" the inputs, so for example you could rename "VCR" as "VIDEO GAME", and then have the PS3 hooked to HDMI, the 360 hooked up via component, and the Wii hooked up via S-video, and it will "prioritize" and just automatically pick the highest-priority one that is turned on.
Setup Guide and FAQ
batpig is offline
post #220 of 3229 Old 09-11-2008, 09:27 PM
mwardncsu's Avatar
thanks batpig.... I did lose steam somewhere before getting to page 7 (i did read all of what was on page 8 at the time )
I think I'm good - 5 in total probably works and the "stacked" input is probably a good trick that I could use - need to give that some thought.... now to decide if the 2809 is that much more valuable than the 2309 since I don't have any other good excuse.... and to convince myself that the Yamaha 1800 is as good an option....
post #221 of 3229 Old 09-12-2008, 07:38 AM
ab2ab's Avatar
Originally Posted by adrian457 View Post
Thanks Batpig.
To me I notice no difference between RGB and Ycbcr with BD or Sat but you get conflicting posts of what should and shouldn't be used. Reading all BDs are done in Ycbcr that would be most logical but then reading if you have problems with black detail use RGB.
I had a Yamaha 1800 which clipped BTB & WTW and some said it didn't matter and some said it did so I was so confused with the whole thing that I sold it. Only lost about $100 on the sale but I had it for a year so I look at it as a 1 yr rental fee. Then reading more about BTB & WTW really upset me because I felt I made a bad decision selling my 1800. Then I purchased the 1909 and was amazed at the sound quality and thumpness of the LFE using Audyssey. I wanted the 4 HDMI so I ordered the 2309 and returned the 1909. I am very happy with it. Now I don't regret selling the Yammy at all as the 1800 never gave me LFE like the Denons do, it sounded rather flat. The 1800 I sold paid for the 2309. Plus the 2309 passes BTB & WTW.
BTW, I find it quite funny that they have a HDMI input labeled VCR. I understand the DVD/VCR combo but still.
So do you get that same "thumpness" of the 1909 with the 2309?
ab2ab is offline
post #222 of 3229 Old 09-12-2008, 08:22 AM
OldFilmFan's Avatar
The bad penny has turned up again. I tried playing a CD for the first time today. The CD starts up, but I get no sound. I am using an Oppo
983H as my player. I have it connected to the HDMI port. DVD's play fine, but no joy with CD's. I think I don't have the proper inputs setup for playing CD's. I have went through the manual so many times, it is almost worn out Thanks!
post #223 of 3229 Old 09-12-2008, 09:40 AM
batpig's Avatar
Liked: 3577
OK, step by step:
Oppo is connected to the Denon via HDMI -- you assigned it correctly (I'm assuming to the "DVD" input) and when you go to the "DVD" input and play a DVD, you get sound.
Then, you take out the DVD, put in a CD, and try to play music, and nothing happens? I don't know what you mean by "I don't have the proper inputs setup for playing CD's", it should work fine there shouldn't be anything special to set up. You are you leaving it on the "DVD" input, right? Does the display show as receiving any signal?
You should be getting 2-channel PCM over HDMI no problem, that's weird.
Setup Guide and FAQ
batpig is offline
post #224 of 3229 Old 09-12-2008, 09:51 AM
OldFilmFan's Avatar
Batpig, I guess I wasn't very clear, imagine that! Cd's will play OK if I have the display turned on. What I would like to do is play CD's without the display being on.
post #225 of 3229 Old 09-12-2008, 10:01 AM
batpig's Avatar
Liked: 3577
ahhh.... hmmm.... that might be an issue with HDMI, I think I've heard of stuff like that before where it won't work when the TV is turned off... hmmm... maybe give Oppo a call and see what they suggest?
Setup Guide and FAQ
batpig is offline
post #226 of 3229 Old 09-12-2008, 10:24 AM
adrian457's Avatar
Yes I do. It's not like a car with 15" subwoofers booming thump but I can actually hear a thump and not a thud which is what I got from the Yamaha 1800.
adrian457 is offline
post #227 of 3229 Old 09-12-2008, 10:31 AM
OldFilmFan's Avatar
Batpig, I will do that and let you know what they say.
post #228 of 3229 Old 09-12-2008, 11:49 AM
mwardncsu's Avatar
I don't have the Denon (yet), but one thing to check on both the TV and I assume the Denon is the HDMI-CEC (I think that's the name) - basically the "control over HDMI" - Samsung calls this "AnyNet" and I think it is BraviaLink in Sony vernaculary. I thought this was vendor specific, but running over HDMI, but I wonder if there is some level of multi-vendor support that could be causing some negotiation between the receiver and the TV (or the lack thereof since the TV is off).
Perhaps you can disable this option on the receiver, TV and/or player and see if this helps....
post #229 of 3229 Old 09-12-2008, 06:17 PM
bigspur1984's Avatar
Is there any reason to pay the extra money for the 2309?
Does anyone know a place online to buy either one of these for a discount, thanks.
bigspur1984 is offline
post #230 of 3229 Old 09-12-2008, 07:05 PM
pastmaster1993's Avatar
OldFilmFan, Go into "Manual Setup" - "HDMI Setup" - "HDMI Audio Out" setting is set to "TV" change setting to "AMP" You can listen to music with the TV off. The only problem with that is it won't pass anything with your 2309 turned off. SO i guess you need to decide which one is more important. Hope this helps
Dave
pastmaster1993 is offline
post #231 of 3229 Old 09-13-2008, 08:48 AM
batpig's Avatar
Liked: 3577
dave - I think you misunderstood the problem. everything works fine with the TV on, but he's NOT playing it through the TV speakers. his receive is almost certainly set to AMP on the HDMI settings. There is some HDMI communication going on between Denon - Oppo - TV where it wants the TV to be on to play sound from the normal speakers....
Setup Guide and FAQ
batpig is offline
post #232 of 3229 Old 09-13-2008, 09:48 AM
batpig, i just purchased this reciever, i had the same problem, my DVD player is hooked up with HDMI to the TV, i could only play cd's with the TV on with my DVD player. when i changed these settings i now can listen to cd's "without" the TV on.
Dave
post #233 of 3229 Old 09-13-2008, 10:13 AM
batpig, just to clarify, I am talking about sound to my theater speakers not the TV speakers.
Dave
post #234 of 3229 Old 09-13-2008, 02:44 PM
Nants's Avatar
Hi Everyone,
I'm trying to do what the salesperson told me I could do with the 2309ci and that is listen to speakers in another room using the zone 2 feature without a 2nd amp. I've connected all of the speakers - 5.1 in the main zone and stereo in the kitchen, connected to the surround back left & right and set all of the menu setting as recommended in the manual. No sound out of the zone 2. The speakers were used fine as B speakers with my old receiver, so I know those connections are ok. I hope it is merely a setting and was wondering first if this is possible without another amp and second, what are the proper settings? Ideally I'd like to choose an alt source in the kitchen than the main zone (as advertised) but would settle for hearing the same source out of my zone 2 speakers. Anyone?
Nants is offline
post #235 of 3229 Old 09-13-2008, 03:55 PM
batpig's Avatar
Liked: 3577
you cannot output any digital audio to zone 2, you have to also run a set of analog RCA (red/white) cables for any sources you'd like to output to zone 2. see the note in the manual in the multizone operation section. it sounds like you have everything hooked up correctly so I'm assuming this is the problem...
Setup Guide and FAQ
batpig is offline
post #236 of 3229 Old 09-13-2008, 05:56 PM
Nants's Avatar
Bingo! Wasn't aware that I couldn't use just digital, so when I added the analog connection presto! Thank you ever so much - now we'll have tunes for our card parties!
Nants
Nants is offline
post #237 of 3229 Old 09-14-2008, 12:21 PM
Chenthil's Avatar
Hi,
After much contemplation between 2808CI and 2309CI, I decided to go with 2309CI. Hooked up my receiver yesterday and ran the auto setup. Dynamic Volume doesn't work as advertised. I still could hear the volume go up during commercials and main movie sounded low compared to commercials. Red light in the front panel is ON indicating DV is ON. What is the experinece of others? I emailed Denon and waiting for a response. If there is a issue with DV, I might just return and go with 2808CI which is still a nice receiver but no DV.
thanks
Chenthil
Chenthil is offline
post #238 of 3229 Old 09-14-2008, 01:32 PM
egore's Avatar
The red light indicates DV is off and DEQ is on. Green light indicates that both DV and DEQ are on.
egore is offline
post #239 of 3229 Old 09-15-2008, 10:15 AM
OldFilmFan's Avatar
Hey All, I talked to Oppo and we finally fiqured out it was a input conflict
between the DVD player and the receiver. I had to omit assigning the CD input and use DVD only. Now I can play CD's without the display on.
Batpig, I got my handshaking problem between my cable box and receiver fixed. It was the cable box. I swapped the PACE box for a Scientific Atlanta and now I get a picture right away. Thanks all for your advice
post #240 of 3229 Old 09-15-2008, 02:51 PM
Mayhemm's Avatar
I connect my HD DVD player with HDMI for the lossless sound, but for things like a cable box I don't really understand the rush for everyone to go all-HDMI with everything... the marketing guys have done a good job getting consumers on the bandwagon there....
The "one cable does it all" thing was what originally sold HDMI for me. Dealing with a minimum of 4 cables for a single component video connection seemed cumbersome by comparison.
However, I recently had my STB quit on me after over a year of perfect operation because the provider updated their firmware which introduced "handshake" issues.
I mean, HDMI has been out for how long now? Long enough this kind of BS shouldn't happen. That's the problem with a constantly changing "standard".
Mayhemm is offline
Denon Avr 2309ci Receiver
